[U-Boot] [PATCH] arm: sama5d3: fix smc cs related registers offset
the smc cs related registers start at 0x600 and loop with 5 registers so the reserved register should be in at91_smc structure while no in at91_cs structure. So fix it
Signed-off-by: Bo Shen voice.shen@atmel.com
--- arch/arm/include/asm/arch-at91/sama5d3_smc.h | 2 +- 1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/arch/arm/include/asm/arch-at91/sama5d3_smc.h b/arch/arm/include/asm/arch-at91/sama5d3_smc.h index c060894..6caa9b6 100644 --- a/arch/arm/include/asm/arch-at91/sama5d3_smc.h +++ b/arch/arm/include/asm/arch-at91/sama5d3_smc.h @@ -17,7 +17,6 @@ #define AT91_ASM_SMC_MODE0 (ATMEL_BASE_SMC + 0x60C) #else struct at91_cs { - u32 reserved[96]; u32 setup; /* 0x600 SMC Setup Register */ u32 pulse; /* 0x604 SMC Pulse Register */ u32 cycle; /* 0x608 SMC Cycle Register */ @@ -26,6 +25,7 @@ struct at91_cs { };
struct at91_smc { + u32 reserved[384]; struct at91_cs cs[4]; }; #endif /* __ASSEMBLY__ */
Dear Bo Shen,
Bo Shen voice.shen@atmel.com writes:
applied to u-boot-atmel/master, thanks!
Best regards, Andreas Bießmann
Andreas Bießmann
Bo Shen
