[U-Boot] [RFC PATCH] qemu-x86: Use config_distro_bootcmd
Converts qemu x86 machines to boot using distro_config. The intent is to allow u-boot in qemu to be maximally compatible with many boot methods without having to change the config. Currently, u-boot will only boot in a very limited set of circumstances where there is a /boot/vmlinuz on scsi 0:3 with no ramdisk.
If distro_bootcmd fails, u-boot will fall back to the original method.
Signed-off-by: Joshua Watt JPEWhacker@gmail.com --- include/configs/qemu-x86.h | 30 ++++++++++++++++++++++++++++++ 1 file changed, 30 insertions(+)
diff --git a/include/configs/qemu-x86.h b/include/configs/qemu-x86.h index 64e7a60b8a..d9c96e295d 100644 --- a/include/configs/qemu-x86.h +++ b/include/configs/qemu-x86.h @@ -10,8 +10,38 @@ #ifndef __CONFIG_H #define __CONFIG_H
+#include <linux/sizes.h> + +#define CONFIG_BOOTCOMMAND \ + "run distro_bootcmd; " \ + "ext2load scsi 0:3 01000000 /boot/vmlinuz; " \ + "zboot 01000000" + +#define BOOT_TARGET_DEVICES(func) \ + func(USB, usb, 0) \ + func(SCSI, scsi, 0) \ + func(VIRTIO, virtio, 0) \ + func(IDE, ide, 0) \ + func(DHCP, dhcp, na) + +#include <config_distro_bootcmd.h> #include <configs/x86-common.h>
+#undef CONFIG_ENV_SIZE +#define CONFIG_ENV_SIZE SZ_256K + +#define CONFIG_PREBOOT "pci enum" + +#undef CONFIG_EXTRA_ENV_SETTINGS +#define CONFIG_EXTRA_ENV_SETTINGS \ + CONFIG_STD_DEVICES_SETTINGS \ + "scriptaddr=0x8000000\0" \ + "kernel_addr_r=0x1000000\0" \ + "ramdisk_addr_r=0x4000000\0" \ + "consoledev=ttyS0\0" \ + CONFIG_OTHBOOTARGS \ + BOOTENV + #define CONFIG_SYS_MONITOR_LEN (1 << 20)
#define CONFIG_STD_DEVICES_SETTINGS "stdin=serial,i8042-kbd\0" \
Hi Joshua,
Could you please enable
"zboot 01000000"
This should be in the board defconfig files. I would like to only keep the "run distro_bootcmd" command.
func(USB, usb, 0) \
func(IDE, ide, 0) \
QEMU default memory is 128MiB, so I would put this to somewhere that does not break the default one, like 0x7000000?
BOOTENV
CONFIG_DISTRO_DEFAULTS should also be turned on in the board defconfig files.
Could you please update the README.x86 about testing distro boot on QEMU? Thanks!
Regards, Bin
On Sat, Jun 22, 2019 at 10:51 PM Bin Meng bmeng.cn@gmail.com wrote:
Hi Joshua,
Oops, I wanted to say: enable CONFIG_DISTRO_DEFAULTS in the board defconfig files.
Regards, Bin
Converts qemu x86 machines to boot using distro_config. The intent is to allow u-boot in qemu to be maximally compatible with many boot methods without having to change the config. Previously, u-boot would only boot in a very limited set of circumstances where there was a /boot/vmlinuz on scsi 0:3 with no ramdisk.
Signed-off-by: Joshua Watt JPEWhacker@gmail.com --- configs/qemu-x86_64_defconfig | 1 + configs/qemu-x86_defconfig | 1 + doc/README.x86 | 5 +++++ include/configs/qemu-x86.h | 25 +++++++++++++++++++++++++ 4 files changed, 32 insertions(+)
diff --git a/configs/qemu-x86_64_defconfig b/configs/qemu-x86_64_defconfig index d89cd44144..3e9e83efaf 100644 --- a/configs/qemu-x86_64_defconfig +++ b/configs/qemu-x86_64_defconfig @@ -62,3 +62,4 @@ CONFIG_FRAMEBUFFER_SET_VESA_MODE=y CONFIG_FRAMEBUFFER_VESA_MODE_USER=y CONFIG_FRAMEBUFFER_VESA_MODE=0x144 CONFIG_CONSOLE_SCROLL_LINES=5 +CONFIG_DISTRO_DEFAULTS=y diff --git a/configs/qemu-x86_defconfig b/configs/qemu-x86_defconfig index 898d656ac3..85bb7b1daf 100644 --- a/configs/qemu-x86_defconfig +++ b/configs/qemu-x86_defconfig @@ -50,3 +50,4 @@ CONFIG_FRAMEBUFFER_SET_VESA_MODE=y CONFIG_FRAMEBUFFER_VESA_MODE_USER=y CONFIG_FRAMEBUFFER_VESA_MODE=0x144 CONFIG_CONSOLE_SCROLL_LINES=5 +CONFIG_DISTRO_DEFAULTS=y diff --git a/doc/README.x86 b/doc/README.x86 index 8e0a3f36ed..48557ffa51 100644 --- a/doc/README.x86 +++ b/doc/README.x86 @@ -466,6 +466,11 @@ If you want to check both consoles, use '-serial stdio'. Multicore is also supported by QEMU via '-smp n' where n is the number of cores to instantiate. Note, the maximum supported CPU number in QEMU is 255.
+U-Boot uses 'distro_bootcmd' by default when booting on x86 QEMU. This tries to +load a boot script, kernel, and ramdisk from several different interfaces. For +the default boot order, see 'qemu-x86.h'. For more information, see +'README.distro' + The fw_cfg interface in QEMU also provides information about kernel data, initrd, command-line arguments and more. U-Boot supports directly accessing these informtion from fw_cfg interface, which saves the time of loading them diff --git a/include/configs/qemu-x86.h b/include/configs/qemu-x86.h index 64e7a60b8a..097ed414f8 100644 --- a/include/configs/qemu-x86.h +++ b/include/configs/qemu-x86.h @@ -10,8 +10,33 @@ #ifndef __CONFIG_H #define __CONFIG_H
+#include <linux/sizes.h> + +#define BOOT_TARGET_DEVICES(func) \ + func(USB, usb, 0) \ + func(SCSI, scsi, 0) \ + func(VIRTIO, virtio, 0) \ + func(IDE, ide, 0) \ + func(DHCP, dhcp, na) + +#include <config_distro_bootcmd.h> #include <configs/x86-common.h>
+#undef CONFIG_ENV_SIZE +#define CONFIG_ENV_SIZE SZ_256K + +#define CONFIG_PREBOOT "pci enum" + +#undef CONFIG_EXTRA_ENV_SETTINGS +#define CONFIG_EXTRA_ENV_SETTINGS \ + CONFIG_STD_DEVICES_SETTINGS \ + "scriptaddr=0x7000000\0" \ + "kernel_addr_r=0x1000000\0" \ + "ramdisk_addr_r=0x4000000\0" \ + "consoledev=ttyS0\0" \ + CONFIG_OTHBOOTARGS \ + BOOTENV + #define CONFIG_SYS_MONITOR_LEN (1 << 20)
Hi Joshua,
I think this should be inserted to a proper place in the defconfig files. Try "make savedefconfig" and use the generated "defconfig" file.
Thanks for adding some documentation. Do you have any details on for example how to boot Ubuntu or Fedora on QEMU?
Regards, Bin
On 7/2/19 9:24 AM, Bin Meng wrote:
Hi Joshua,
OK, I'll do that.
I don't, but I'll see if I can get an image and give it a try.
- The fw_cfg interface in QEMU also provides information about kernel data, initrd, command-line arguments and more. U-Boot supports directly accessing these informtion from fw_cfg interface, which saves the time of loading them
Regards, Bin
Signed-off-by: Joshua Watt JPEWhacker@gmail.com --- configs/qemu-x86_64_defconfig | 1 + configs/qemu-x86_defconfig | 1 + doc/README.x86 | 17 +++++++++++++++++ include/configs/qemu-x86.h | 25 +++++++++++++++++++++++++ 4 files changed, 44 insertions(+)
diff --git a/configs/qemu-x86_64_defconfig b/configs/qemu-x86_64_defconfig index d89cd44144..89118cc3dc 100644 --- a/configs/qemu-x86_64_defconfig +++ b/configs/qemu-x86_64_defconfig @@ -12,6 +12,7 @@ CONFIG_SMP=y CONFIG_GENERATE_PIRQ_TABLE=y CONFIG_GENERATE_MP_TABLE=y CONFIG_GENERATE_ACPI_TABLE=y +CONFIG_DISTRO_DEFAULTS=y CONFIG_BUILD_ROM=y CONFIG_FIT=y CONFIG_SPL_LOAD_FIT=y diff --git a/configs/qemu-x86_defconfig b/configs/qemu-x86_defconfig index 898d656ac3..a50285beec 100644 --- a/configs/qemu-x86_defconfig +++ b/configs/qemu-x86_defconfig @@ -6,6 +6,7 @@ CONFIG_SMP=y CONFIG_GENERATE_PIRQ_TABLE=y CONFIG_GENERATE_MP_TABLE=y CONFIG_GENERATE_ACPI_TABLE=y +CONFIG_DISTRO_DEFAULTS=y CONFIG_BUILD_ROM=y CONFIG_FIT=y CONFIG_BOOTSTAGE=y diff --git a/doc/README.x86 b/doc/README.x86 index 8e0a3f36ed..a00ae69acc 100644 --- a/doc/README.x86 +++ b/doc/README.x86 @@ -466,6 +466,23 @@ If you want to check both consoles, use '-serial stdio'. Multicore is also supported by QEMU via '-smp n' where n is the number of cores to instantiate. Note, the maximum supported CPU number in QEMU is 255.
+U-Boot uses 'distro_bootcmd' by default when booting on x86 QEMU. This tries to +load a boot script, kernel, and ramdisk from several different interfaces. For +the default boot order, see 'qemu-x86.h'. For more information, see +'README.distro'. Most Linux distros can be booted by writing a uboot script. +For example, Debian (stretch) can be booted by creating a script file named +'boot.txt' with the contents: + + setenv bootargs root=/dev/sda1 ro + load ${devtype} ${devnum}:${distro_bootpart} ${kernel_addr_r} /vmlinuz + load ${devtype} ${devnum}:${distro_bootpart} ${ramdisk_addr_r} /initrd.img + zboot ${kernel_addr_r} - ${ramdisk_addr_r} ${filesize} + +Then compile and install it with: + + $ apt install u-boot-tools && \ + mkimage -T script -C none -n "Boot script" -d boot.txt /boot/boot.scr + The fw_cfg interface in QEMU also provides information about kernel data, initrd, command-line arguments and more. U-Boot supports directly accessing these informtion from fw_cfg interface, which saves the time of loading them diff --git a/include/configs/qemu-x86.h b/include/configs/qemu-x86.h index 64e7a60b8a..097ed414f8 100644 --- a/include/configs/qemu-x86.h +++ b/include/configs/qemu-x86.h @@ -10,8 +10,33 @@ #ifndef __CONFIG_H #define __CONFIG_H
ping?
- setenv bootargs root=/dev/sda1 ro
- load ${devtype} ${devnum}:${distro_bootpart} ${kernel_addr_r} /vmlinuz
- load ${devtype} ${devnum}:${distro_bootpart} ${ramdisk_addr_r} /initrd.img
- zboot ${kernel_addr_r} - ${ramdisk_addr_r} ${filesize}
- $ apt install u-boot-tools && \
- func(USB, usb, 0) \
- func(SCSI, scsi, 0) \
- func(VIRTIO, virtio, 0) \
- func(IDE, ide, 0) \
- func(DHCP, dhcp, na)
BOOTENV
applied to u-boot-x86, thanks!
applied to u-boot-x86, thanks! _______________________________________________ U-Boot mailing list U-Boot@lists.denx.de https://lists.denx.de/listinfo/u-boot
This patch leads to a build error when building with CONFIG_DISTRO_DEFAULTS=n.
In file included from include/configs/qemu-x86.h:23, from include/config.h:5, from include/common.h:23, from lib/asm-offsets.c:14: include/configs/x86-common.h:109: error: "BOOTENV" redefined [-Werror] #define BOOTENV
In file included from include/configs/qemu-x86.h:22, from include/config.h:5, from include/common.h:23, from lib/asm-offsets.c:14: include/config_distro_bootcmd.h:407: note: this is the location of the previous definition #define BOOTENV \
I am glad that qemu-x86 now can use distro defaults. But I would not expect a build error due to a legal configuration choice.
If you do not want to retain backwards compatibility you could 'select DISTRO_DEFAULTS' in board/emulation/Kconfig. This way distro defaults would no longer be deselectable for qemu-x86.
Best regards
Heinrich
Hi Heinrich,
On Wed, Aug 14, 2019 at 12:15 PM Heinrich Schuchardt xypron.debian@gmx.de wrote:
Thanks for reporting it. I will prepare a patch to fix it.
Regards, Bin
Bin Meng
Joshua Watt
