[U-Boot] [PATCH v3 0/4] add support for atheros ath79 based SOCs
These series of patch add support for atheros ath79 based SOCs in u-boot, at the present moment it's just available for ar933x chip.
Changes in v3: - Convert serial driver to driver model - Convert spi driver to driver model - Add support for device tree - Move SoC specific header files into arch/mips/mach-ath79/include/mach - Optimize assembly code - Same code style convertion
Changes in v2: - Move all SoC specific header files into arch/mips/include/asm/arch-ath79 - Check SOC type and extract common code into arch/mips/mach-ath79 - Add a compatible spi driver - Move serial driver code into drivers/serial - Add a reference board implemention
Wills Wang (4): mips: add base support for atheros ath79 based SOCs mips: ath79: add serial driver for ar933x SOC mips: ath79: add spi driver mips: ath79: add AP121 reference board
arch/mips/Kconfig | 8 + arch/mips/Makefile | 1 + arch/mips/config.mk | 1 + arch/mips/dts/Makefile | 2 +- arch/mips/dts/ap121.dts | 37 + arch/mips/dts/ar933x.dtsi | 64 ++ arch/mips/mach-ath79/Makefile | 9 + arch/mips/mach-ath79/ar933x/Makefile | 6 + arch/mips/mach-ath79/ar933x/ddr_tap.S | 268 ++++++ arch/mips/mach-ath79/ar933x/lowlevel_init.S | 460 +++++++++ arch/mips/mach-ath79/cpu.c | 269 ++++++ arch/mips/mach-ath79/dram.c | 27 + arch/mips/mach-ath79/include/mach/ar71xx_regs.h | 1144 +++++++++++++++++++++++ arch/mips/mach-ath79/include/mach/ar933x_uart.h | 66 ++ arch/mips/mach-ath79/include/mach/ath79.h | 143 +++ arch/mips/mach-ath79/include/mach/ddr.h | 13 + arch/mips/mach-ath79/reset.c | 55 ++ board/ath79/ap121/Kconfig | 15 + board/ath79/ap121/MAINTAINERS | 6 + board/ath79/ap121/Makefile | 8 + board/ath79/ap121/README | 18 + board/ath79/ap121/ap121.c | 18 + board/ath79/ap121/config.mk | 16 + configs/ap121_defconfig | 42 + drivers/serial/Makefile | 1 + drivers/serial/serial_ar933x.c | 274 ++++++ drivers/spi/Kconfig | 6 + drivers/spi/Makefile | 1 + drivers/spi/ath79_spi.c | 211 +++++ include/configs/ap121.h | 79 ++ 30 files changed, 3267 insertions(+), 1 deletion(-) create mode 100644 arch/mips/dts/ap121.dts create mode 100644 arch/mips/dts/ar933x.dtsi create mode 100644 arch/mips/mach-ath79/Makefile create mode 100644 arch/mips/mach-ath79/ar933x/Makefile create mode 100644 arch/mips/mach-ath79/ar933x/ddr_tap.S create mode 100644 arch/mips/mach-ath79/ar933x/lowlevel_init.S create mode 100644 arch/mips/mach-ath79/cpu.c create mode 100644 arch/mips/mach-ath79/dram.c create mode 100644 arch/mips/mach-ath79/include/mach/ar71xx_regs.h create mode 100644 arch/mips/mach-ath79/include/mach/ar933x_uart.h create mode 100644 arch/mips/mach-ath79/include/mach/ath79.h create mode 100644 arch/mips/mach-ath79/include/mach/ddr.h create mode 100644 arch/mips/mach-ath79/reset.c create mode 100644 board/ath79/ap121/Kconfig create mode 100644 board/ath79/ap121/MAINTAINERS create mode 100644 board/ath79/ap121/Makefile create mode 100644 board/ath79/ap121/README create mode 100644 board/ath79/ap121/ap121.c create mode 100644 board/ath79/ap121/config.mk create mode 100644 configs/ap121_defconfig create mode 100644 drivers/serial/serial_ar933x.c create mode 100644 drivers/spi/ath79_spi.c create mode 100644 include/configs/ap121.h
Changes in v3:
Cool, thanks! Just some minor nitpicks, but nothing really heavy. I am looking forward to running this on my AR933x arduino yun, which I bought exactly and only for this purpose :)
Best regards, Marek Vasut
Wills Wang
