[U-Boot-Users] [PATCH 1/3] Apollon BSP support
Apollon BSP support
The Apollon based on OMAP2420 is designed for OneNAND development. It's similar with OMAP2420 H4 except some peripherals.
Now this board is maintained at mainline kernel.
Signed-off-by: Kyungmin Park kyungmin.park@samsung.com --- diff --git a/Makefile b/Makefile index 09bbf4f..78910e2 100644 --- a/Makefile +++ b/Makefile @@ -2356,9 +2356,12 @@ zylonite_config : ######################################################################### ## ARM1136 Systems ######################################################################### -omap2420h4_config : unconfig +omap2420h4_config : unconfig @$(MKCONFIG) $(@:_config=) arm arm1136 omap2420h4
+apollon_config : unconfig + @$(MKCONFIG) $(@:_config=) arm arm1136 apollon + #======================================================================== # i386 #======================================================================== diff --git a/board/apollon/Makefile b/board/apollon/Makefile new file mode 100644 index 0000000..91605ca --- /dev/null +++ b/board/apollon/Makefile @@ -0,0 +1,50 @@ +# +# (C) Copyright 2000, 2001, 2002 +# Wolfgang Denk, DENX Software Engineering, wd@denx.de. +# +# See file CREDITS for list of people who contributed to this +# project. +# +# This program is free software; you can redistribute it and/or +# modify it under the terms of the GNU General Public License as +# published by the Free Software Foundation; either version 2 of +# the License, or (at your option) any later version. +# +# This program is distributed in the hope that it will be useful, +# but WITHOUT ANY WARRANTY; without even the implied warranty of +# MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the +# GNU General Public License for more details. +# +# You should have received a copy of the GNU General Public License +# along with this program; if not, write to the Free Software +# Foundation, Inc., 59 Temple Place, Suite 330, Boston, +# MA 02111-1307 USA +# + +include $(TOPDIR)/config.mk + +LIB = $(obj)lib$(BOARD).a + +COBJS := apollon.o mem.o sys_info.o +SOBJS := lowlevel_init.o + +SRCS := $(SOBJS:.o=.S) $(COBJS:.o=.c) +OBJS := $(addprefix $(obj),$(COBJS)) +SOBJS := $(addprefix $(obj),$(SOBJS)) + +$(LIB): $(obj).depend $(OBJS) $(SOBJS) + $(AR) $(ARFLAGS) $@ $(OBJS) $(SOBJS) + +clean: + rm -f $(SOBJS) $(OBJS) + +distclean: clean + rm -f $(LIB) core *.bak .depend + +######################################################################### + +include $(SRCTREE)/rules.mk + +sinclude $(obj).depend + +######################################################################### diff --git a/board/apollon/apollon.c b/board/apollon/apollon.c new file mode 100644 index 0000000..0a48c64 --- /dev/null +++ b/board/apollon/apollon.c @@ -0,0 +1,607 @@ +/* + * (C) Copyright 2005-2007 + * Samsung Electronics. + * Kyungmin Park kyungmin.park@samsung.com + * + * Derived from omap2420 + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + */ +#include <common.h> +#include <asm/arch/omap2420.h> +#include <asm/io.h> +#include <asm/arch/bits.h> +#include <asm/arch/mux.h> +#include <asm/arch/sys_proto.h> +#include <asm/arch/sys_info.h> +#include <asm/arch/mem.h> +#include <i2c.h> +#include <asm/mach-types.h> + +void wait_for_command_complete(unsigned int wd_base); + +/******************************************************* + * Routine: delay + * Description: spinning delay to use before udelay works + ******************************************************/ +static inline void delay(unsigned long loops) +{ + __asm__ volatile ("1:\n" "subs %0, %1, #1\n" + "bne 1b":"=r" (loops):"0"(loops)); +} + +/***************************************** + * Routine: board_init + * Description: Early hardware init. + *****************************************/ +int board_init(void) +{ + DECLARE_GLOBAL_DATA_PTR; + + gpmc_init(); /* in SRAM or SDRM, finish GPMC */ + + gd->bd->bi_arch_number = 919; + /* adress of boot parameters */ + gd->bd->bi_boot_params = (OMAP2420_SDRC_CS0 + 0x100); + + return 0; +} + +/********************************************************** + * Routine: s_init + * Description: Does early system init of muxing and clocks. + * - Called path is with sram stack. + **********************************************************/ +void s_init(void) +{ + + watchdog_init(); + set_muxconf_regs(); + delay(100); + + peripheral_enable(); + icache_enable(); +} + +/******************************************************* + * Routine: misc_init_r + * Description: Init ethernet (done here so udelay works) + ********************************************************/ +int misc_init_r(void) +{ + ether_init(); /* better done here so timers are init'ed */ + return (0); +} + +/**************************************** + * Routine: watchdog_init + * Description: Shut down watch dogs + *****************************************/ +void watchdog_init(void) +{ + /* There are 4 watch dogs. 1 secure, and 3 general purpose. + * The ROM takes care of the secure one. Of the 3 GP ones, + * 1 can reset us directly, the other 2 only generate MPU interrupts. + */ + __raw_writel(WD_UNLOCK1, WD2_BASE + WSPR); + wait_for_command_complete(WD2_BASE); + __raw_writel(WD_UNLOCK2, WD2_BASE + WSPR); + +#define MPU_WD_CLOCKED 1 +#if MPU_WD_CLOCKED /* value 0x10 stick on aptix, BIT4 polarity seems oppsite */ + __raw_writel(WD_UNLOCK1, WD3_BASE + WSPR); + wait_for_command_complete(WD3_BASE); + __raw_writel(WD_UNLOCK2, WD3_BASE + WSPR); + + __raw_writel(WD_UNLOCK1, WD4_BASE + WSPR); + wait_for_command_complete(WD4_BASE); + __raw_writel(WD_UNLOCK2, WD4_BASE + WSPR); +#endif +} + +/****************************************************** + * Routine: wait_for_command_complete + * Description: Wait for posting to finish on watchdog + ******************************************************/ +void wait_for_command_complete(unsigned int wd_base) +{ + int pending = 1; + do { + pending = __raw_readl(wd_base + WWPS); + } while (pending); +} + +/******************************************************************* + * Routine:ether_init + * Description: take the Ethernet controller out of reset and wait + * for the EEPROM load to complete. + ******************************************************************/ +void ether_init(void) +{ +#ifdef CONFIG_DRIVER_LAN91C96 + int cnt = 20; + + __raw_writeb(0x03, OMAP2420_CTRL_BASE + 0x0f2); /*protect->gpio74 */ + + __raw_writew(0x0, LAN_RESET_REGISTER); + do { + __raw_writew(0x1, LAN_RESET_REGISTER); + udelay(100); + if (cnt == 0) { + printf("1. eth reset err\n"); + goto eth_reset_err_out; + } + --cnt; + } while (__raw_readw(LAN_RESET_REGISTER) != 0x1); + + cnt = 20; + + do { + __raw_writew(0x0, LAN_RESET_REGISTER); + udelay(100); + if (cnt == 0) { + printf("2. eth reset err\n"); + goto eth_reset_err_out; + } + --cnt; + } while (__raw_readw(LAN_RESET_REGISTER) != 0x0000); + udelay(1000); + + *((volatile unsigned char *)ETH_CONTROL_REG) &= ~0x01; + udelay(1000); + +eth_reset_err_out: + return; +#endif +} + +/********************************************** + * Routine: dram_init + * Description: sets uboots idea of sdram size + **********************************************/ +int dram_init(void) +{ + DECLARE_GLOBAL_DATA_PTR; + unsigned int size0 = 0, size1 = 0; + u32 mtype, btype, rev = 0, cpu = 0; +#define NOT_EARLY 0 + + btype = get_board_type(); + mtype = get_mem_type(); + rev = get_cpu_rev(); + cpu = get_cpu_type(); + + display_board_info(btype); + + if ((mtype == DDR_COMBO) || (mtype == DDR_STACKED)) { + printf("ddr combo\n"); + do_sdrc_init(SDRC_CS1_OSET, NOT_EARLY); /* init other chip select */ + } + + size0 = get_sdr_cs_size(SDRC_CS0_OSET); + size1 = get_sdr_cs_size(SDRC_CS1_OSET); + + gd->bd->bi_dram[0].start = PHYS_SDRAM_1; + gd->bd->bi_dram[0].size = size0; +#if CONFIG_NR_DRAM_BANKS > 1 + gd->bd->bi_dram[1].start = PHYS_SDRAM_1 + size0; + gd->bd->bi_dram[1].size = size1; +#endif + + return 0; +} + +/********************************************************** + * Routine: set_muxconf_regs + * Description: Setting up the configuration Mux registers + * specific to the hardware + *********************************************************/ +void set_muxconf_regs(void) +{ + muxSetupSDRC(); + muxSetupGPMC(); + muxSetupUsb0(); /* USB Device */ + muxSetupUsbHost(); /* USB Host */ + muxSetupUART1(); + muxSetupLCD(); + muxSetupMMCSD(); + muxSetupTouchScreen(); +} + +/***************************************************************** + * Routine: peripheral_enable + * Description: Enable the clks & power for perifs (GPT2, UART1,...) + ******************************************************************/ +void peripheral_enable(void) +{ + unsigned int v, if_clks = 0, func_clks = 0; + + /* Enable GP2 timer. */ + if_clks |= BIT4 | BIT3; + func_clks |= BIT4 | BIT3; + v = __raw_readl(CM_CLKSEL2_CORE) | 0x4 | 0x2; /* Sys_clk input OMAP2420_GPT2 */ + __raw_writel(v, CM_CLKSEL2_CORE); + __raw_writel(0x1, CM_CLKSEL_WKUP); + +#ifdef CFG_NS16550 + /* Enable UART1 clock */ + func_clks |= BIT21; + if_clks |= BIT21; +#endif + v = __raw_readl(CM_ICLKEN1_CORE) | if_clks; /* Interface clocks on */ + __raw_writel(v, CM_ICLKEN1_CORE); + v = __raw_readl(CM_FCLKEN1_CORE) | func_clks; /* Functional Clocks on */ + __raw_writel(v, CM_FCLKEN1_CORE); + delay(1000); + +#ifndef KERNEL_UPDATED + { +#define V1 0xffffffff +#define V2 0x00000007 + + __raw_writel(V1, CM_FCLKEN1_CORE); + __raw_writel(V2, CM_FCLKEN2_CORE); + __raw_writel(V1, CM_ICLKEN1_CORE); + __raw_writel(V1, CM_ICLKEN2_CORE); + } +#endif +} + +/**************************************** + * Routine: muxSetupUsb0 (ostboot) + * Description: Setup usb muxing + *****************************************/ +void muxSetupUsb0(void) +{ + volatile uint8 *MuxConfigReg; + + MuxConfigReg = (volatile uint8 *)CONTROL_PADCONF_USB0_PUEN; + *MuxConfigReg &= (uint8) (~0x1F); + + MuxConfigReg = (volatile uint8 *)CONTROL_PADCONF_USB0_VP; + *MuxConfigReg &= (uint8) (~0x1F); + + MuxConfigReg = (volatile uint8 *)CONTROL_PADCONF_USB0_VM; + *MuxConfigReg &= (uint8) (~0x1F); + + MuxConfigReg = (volatile uint8 *)CONTROL_PADCONF_USB0_RCV; + *MuxConfigReg &= (uint8) (~0x1F); + + MuxConfigReg = (volatile uint8 *)CONTROL_PADCONF_USB0_TXEN; + *MuxConfigReg &= (uint8) (~0x1F); + + MuxConfigReg = (volatile uint8 *)CONTROL_PADCONF_USB0_SE0; + *MuxConfigReg &= (uint8) (~0x1F); + + MuxConfigReg = (volatile uint8 *)CONTROL_PADCONF_USB0_DAT; + *MuxConfigReg &= (uint8) (~0x1F); +} + +#define CONTROL_PADCONF_USB1_RCV ((volatile uint8 *)0x480000EB) +#define CONTROL_PADCONF_USB1_TXEN ((volatile uint8 *)0x480000EC) +#define CONTROL_PADCONF_GPIO69 ((volatile uint8 *)0x480000ED) +#define CONTROL_PADCONF_GPIO70 ((volatile uint8 *)0x480000EE) + +#define CONTROL_PADCONF_GPIO102 ((volatile uint8 *)0x48000116) +#define CONTROL_PADCONF_GPIO103 ((volatile uint8 *)0x48000117) +#define CONTROL_PADCONF_GPIO104 ((volatile uint8 *)0x48000118) +#define CONTROL_PADCONF_GPIO105 ((volatile uint8 *)0x48000119) +/**************************************** + * Routine: muxSetupUSBHost (ostboot) + * Description: Setup USB Host muxing + *****************************************/ +void muxSetupUsbHost(void) +{ + volatile uint8 *MuxConfigReg; + + /* V19 */ + MuxConfigReg = (volatile uint8 *)CONTROL_PADCONF_USB1_RCV; + *MuxConfigReg = 1; + /* W20 */ + MuxConfigReg = (volatile uint8 *)CONTROL_PADCONF_USB1_TXEN; + *MuxConfigReg = 1; + /* N14 */ + MuxConfigReg = (volatile uint8 *)CONTROL_PADCONF_GPIO69; + *MuxConfigReg = 3; + /* P15 */ + MuxConfigReg = (volatile uint8 *)CONTROL_PADCONF_GPIO70; + *MuxConfigReg = 3; + + /* L18 */ + MuxConfigReg = (volatile uint8 *)CONTROL_PADCONF_GPIO102; + *MuxConfigReg = 3; + /* L19 */ + MuxConfigReg = (volatile uint8 *)CONTROL_PADCONF_GPIO103; + *MuxConfigReg = 3; + /* K15 */ + MuxConfigReg = (volatile uint8 *)CONTROL_PADCONF_GPIO104; + *MuxConfigReg = 3; + /* K14 */ + MuxConfigReg = (volatile uint8 *)CONTROL_PADCONF_GPIO105; + *MuxConfigReg = 3; +} + +/**************************************** + * Routine: muxSetupUART1 (ostboot) + * Description: Set up uart1 muxing + *****************************************/ +void muxSetupUART1(void) +{ + volatile unsigned char *MuxConfigReg; + + /* UART1_CTS pin configuration, PIN = D21 */ + MuxConfigReg = (volatile unsigned char *)CONTROL_PADCONF_UART1_CTS; + *MuxConfigReg = 0x00; /* Mode = 0, PUPD=Disabled */ + + /* UART1_RTS pin configuration, PIN = H21 */ + MuxConfigReg = (volatile unsigned char *)CONTROL_PADCONF_UART1_RTS; + *MuxConfigReg = 0x00; /* Mode = 0, PUPD=Disabled */ + + /* UART1_TX pin configuration, PIN = L20 */ + MuxConfigReg = (volatile unsigned char *)CONTROL_PADCONF_UART1_TX; + *MuxConfigReg = 0x00; /* Mode = 0, PUPD=Disabled */ + + /* UART1_RX pin configuration, PIN = T21 */ + MuxConfigReg = (volatile unsigned char *)CONTROL_PADCONF_UART1_RX; + *MuxConfigReg = 0x00; /* Mode = 0, PUPD=Disabled */ +} + +/**************************************** + * Routine: muxSetupLCD (ostboot) + * Description: Setup lcd muxing + *****************************************/ +void muxSetupLCD(void) +{ + volatile unsigned char *MuxConfigReg; + + /* LCD_D0 pin configuration, PIN = Y7 */ + MuxConfigReg = (volatile unsigned char *)CONTROL_PADCONF_DSS_D0; + *MuxConfigReg = 0x00; /* Mode = 0, PUPD=Disabled */ + + /* LCD_D1 pin configuration, PIN = P10 */ + MuxConfigReg = (volatile unsigned char *)CONTROL_PADCONF_DSS_D1; + *MuxConfigReg = 0x00; /* Mode = 0, PUPD=Disabled */ + + /* LCD_D2 pin configuration, PIN = V8 */ + MuxConfigReg = (volatile unsigned char *)CONTROL_PADCONF_DSS_D2; + *MuxConfigReg = 0x00; /* Mode = 0, PUPD=Disabled */ + + /* LCD_D3 pin configuration, PIN = Y8 */ + MuxConfigReg = (volatile unsigned char *)CONTROL_PADCONF_DSS_D3; + *MuxConfigReg = 0x00; /* Mode = 0, PUPD=Disabled */ + + /* LCD_D4 pin configuration, PIN = W8 */ + MuxConfigReg = (volatile unsigned char *)CONTROL_PADCONF_DSS_D4; + *MuxConfigReg = 0x00; /* Mode = 0, PUPD=Disabled */ + + /* LCD_D5 pin configuration, PIN = R10 */ + MuxConfigReg = (volatile unsigned char *)CONTROL_PADCONF_DSS_D5; + *MuxConfigReg = 0x00; /* Mode = 0, PUPD=Disabled */ + + /* LCD_D6 pin configuration, PIN = Y9 */ + MuxConfigReg = (volatile unsigned char *)CONTROL_PADCONF_DSS_D6; + *MuxConfigReg = 0x00; /* Mode = 0, PUPD=Disabled */ + + /* LCD_D7 pin configuration, PIN = V9 */ + MuxConfigReg = (volatile unsigned char *)CONTROL_PADCONF_DSS_D7; + *MuxConfigReg = 0x00; /* Mode = 0, PUPD=Disabled */ + + /* LCD_D8 pin configuration, PIN = W9 */ + MuxConfigReg = (volatile unsigned char *)CONTROL_PADCONF_DSS_D8; + *MuxConfigReg = 0x00; /* Mode = 0, PUPD=Disabled */ + + /* LCD_D9 pin configuration, PIN = P11 */ + MuxConfigReg = (volatile unsigned char *)CONTROL_PADCONF_DSS_D9; + *MuxConfigReg = 0x00; /* Mode = 0, PUPD=Disabled */ + + /* LCD_D10 pin configuration, PIN = V10 */ + MuxConfigReg = (volatile unsigned char *)CONTROL_PADCONF_DSS_D10; + *MuxConfigReg = 0x00; /* Mode = 0, PUPD=Disabled */ + + /* LCD_D11 pin configuration, PIN = Y10 */ + MuxConfigReg = (volatile unsigned char *)CONTROL_PADCONF_DSS_D11; + *MuxConfigReg = 0x00; /* Mode = 0, PUPD=Disabled */ + + /* LCD_D12 pin configuration, PIN = W10 */ + MuxConfigReg = (volatile unsigned char *)CONTROL_PADCONF_DSS_D12; + *MuxConfigReg = 0x00; /* Mode = 0, PUPD=Disabled */ + + /* LCD_D13 pin configuration, PIN = R11 */ + MuxConfigReg = (volatile unsigned char *)CONTROL_PADCONF_DSS_D13; + *MuxConfigReg = 0x00; /* Mode = 0, PUPD=Disabled */ + + /* LCD_D14 pin configuration, PIN = V11 */ + MuxConfigReg = (volatile unsigned char *)CONTROL_PADCONF_DSS_D14; + *MuxConfigReg = 0x00; /* Mode = 0, PUPD=Disabled */ + + /* LCD_D15 pin configuration, PIN = W11 */ + MuxConfigReg = (volatile unsigned char *)CONTROL_PADCONF_DSS_D15; + *MuxConfigReg = 0x00; /* Mode = 0, PUPD=Disabled */ + + /* LCD_D16 pin configuration, PIN = P12 */ + MuxConfigReg = (volatile unsigned char *)CONTROL_PADCONF_DSS_D16; + *MuxConfigReg = 0x00; /* Mode = 0, PUPD=Disabled */ + + /* LCD_D17 pin configuration, PIN = R12 */ + MuxConfigReg = (volatile unsigned char *)CONTROL_PADCONF_DSS_D17; + *MuxConfigReg = 0x00; /* Mode = 0, PUPD=Disabled */ + + /* LCD_PCLK pin configuration, PIN = W6 */ + MuxConfigReg = (volatile unsigned char *)CONTROL_PADCONF_DSS_PCLK; + *MuxConfigReg = 0x00; /* Mode = 0, PUPD=Disabled */ + + /* LCD_VSYNC pin configuration, PIN = V7 */ + MuxConfigReg = (volatile unsigned char *)CONTROL_PADCONF_DSS_VSYNC; + *MuxConfigReg = 0x00; /* Mode = 0, PUPD=Disabled */ + + /* LCD_HSYNC pin configuration, PIN = Y6 */ + MuxConfigReg = (volatile unsigned char *)CONTROL_PADCONF_DSS_HSYNC; + *MuxConfigReg = 0x00; /* Mode = 0, PUPD=Disabled */ + + /* LCD_ACBIAS pin configuration, PIN = W7 */ + MuxConfigReg = (volatile unsigned char *)CONTROL_PADCONF_DSS_ACBIAS; + *MuxConfigReg = 0x00; /* Mode = 0, PUPD=Disabled */ +} + +/**************************************** + * Routine: muxSetupMMCSD (ostboot) + * Description: set up MMC muxing + *****************************************/ +void muxSetupMMCSD(void) +{ + volatile unsigned char *MuxConfigReg; + + /* SDMMC_CLKI pin configuration, PIN = H15 */ + MuxConfigReg = (volatile unsigned char *)CONTROL_PADCONF_MMC_CLKI; + *MuxConfigReg = 0x00; /* Mode = 0, PUPD=Disabled */ + + /* SDMMC_CLKO pin configuration, PIN = G19 */ + MuxConfigReg = (volatile unsigned char *)CONTROL_PADCONF_MMC_CLKO; + *MuxConfigReg = 0x00; /* Mode = 0, PUPD=Disabled */ + + /* SDMMC_CMD pin configuration, PIN = H18 */ + MuxConfigReg = (volatile unsigned char *)CONTROL_PADCONF_MMC_CMD; + *MuxConfigReg = 0x00; /* Mode = 0, PUPD=Disabled */ + /* External pull-ups are present. */ + /* *MuxConfigReg |= 0x18 ; #/ PullUDEnable=Enabled, PullTypeSel=PU */ + + /* SDMMC_DAT0 pin configuration, PIN = F20 */ + MuxConfigReg = (volatile unsigned char *)CONTROL_PADCONF_MMC_DAT0; + *MuxConfigReg = 0x00; /* Mode = 0, PUPD=Disabled */ + /* External pull-ups are present. */ + /* *MuxConfigReg |= 0x18 ; #/ PullUDEnable=Enabled, PullTypeSel=PU */ + + /* SDMMC_DAT1 pin configuration, PIN = H14 */ + MuxConfigReg = (volatile unsigned char *)CONTROL_PADCONF_MMC_DAT1; + *MuxConfigReg = 0x00; /* Mode = 0, PUPD=Disabled */ + /* External pull-ups are present. */ + /* *MuxConfigReg |= 0x18 ; #/ PullUDEnable=Enabled, PullTypeSel=PU */ + + /* SDMMC_DAT2 pin configuration, PIN = E19 */ + MuxConfigReg = (volatile unsigned char *)CONTROL_PADCONF_MMC_DAT2; + *MuxConfigReg = 0x00; /* Mode = 0, PUPD=Disabled */ + /* External pull-ups are present. */ + /* *MuxConfigReg |= 0x18 ; #/ PullUDEnable=Enabled, PullTypeSel=PU */ + + /* SDMMC_DAT3 pin configuration, PIN = D19 */ + MuxConfigReg = (volatile unsigned char *)CONTROL_PADCONF_MMC_DAT3; + *MuxConfigReg = 0x00; /* Mode = 0, PUPD=Disabled */ + /* External pull-ups are present. */ + /* *MuxConfigReg |= 0x18 ; #/ PullUDEnable=Enabled, PullTypeSel=PU */ + + /* SDMMC_DDIR0 pin configuration, PIN = F19 */ + MuxConfigReg = (volatile unsigned char *)CONTROL_PADCONF_MMC_DAT_DIR0; + *MuxConfigReg = 0x00; /* Mode = 0, PUPD=Disabled */ + + /* SDMMC_DDIR1 pin configuration, PIN = E20 */ + MuxConfigReg = (volatile unsigned char *)CONTROL_PADCONF_MMC_DAT_DIR1; + *MuxConfigReg = 0x00; /* Mode = 0, PUPD=Disabled */ + + /* SDMMC_DDIR2 pin configuration, PIN = F18 */ + MuxConfigReg = (volatile unsigned char *)CONTROL_PADCONF_MMC_DAT_DIR2; + *MuxConfigReg = 0x00; /* Mode = 0, PUPD=Disabled */ + + /* SDMMC_DDIR3 pin configuration, PIN = E18 */ + MuxConfigReg = (volatile unsigned char *)CONTROL_PADCONF_MMC_DAT_DIR3; + *MuxConfigReg = 0x00; /* Mode = 0, PUPD=Disabled */ + + /* SDMMC_CDIR pin configuration, PIN = G18 */ + MuxConfigReg = (volatile unsigned char *)CONTROL_PADCONF_MMC_CMD_DIR; + *MuxConfigReg = 0x00; /* Mode = 0, PUPD=Disabled */ +} + +/****************************************** + * Routine: muxSetupTouchScreen (ostboot) + * Description: Set up touch screen muxing + *******************************************/ +void muxSetupTouchScreen(void) +{ + volatile unsigned char *MuxConfigReg; + + /* SPI1_CLK pin configuration, PIN = U18 */ + MuxConfigReg = (volatile unsigned char *)CONTROL_PADCONF_SPI1_CLK; + *MuxConfigReg = 0x00; /* Mode = 0, PUPD=Disabled */ + + /* SPI1_MOSI pin configuration, PIN = V20 */ + MuxConfigReg = (volatile unsigned char *)CONTROL_PADCONF_SPI1_SIMO; + *MuxConfigReg = 0x00; /* Mode = 0, PUPD=Disabled */ + + /* SPI1_MISO pin configuration, PIN = T18 */ + MuxConfigReg = (volatile unsigned char *)CONTROL_PADCONF_SPI1_SOMI; + *MuxConfigReg = 0x00; /* Mode = 0, PUPD=Disabled */ + + /* SPI1_nCS0 pin configuration, PIN = U19 */ + MuxConfigReg = (volatile unsigned char *)CONTROL_PADCONF_SPI1_NCS0; + *MuxConfigReg = 0x00; /* Mode = 0, PUPD=Disabled */ + +#define CONTROL_PADCONF_GPIO85 CONTROL_PADCONF_SPI1_NCS1 + + /* PEN_IRQ pin configuration, PIN = N15 */ + MuxConfigReg = (volatile unsigned char *)CONTROL_PADCONF_GPIO85; + *MuxConfigReg = 0x03; /* Mode = 3, PUPD=Disabled */ +} + +/*************************************************************** + * Routine: muxSetupGPMC (ostboot) + * Description: Configures balls which cam up in protected mode + ***************************************************************/ +void muxSetupGPMC(void) +{ + volatile uint8 *MuxConfigReg; + volatile unsigned int *MCR = (volatile unsigned int *)0x4800008C; + + /* gpmc_io_dir */ + *MCR = 0x19000000; + + /* NOR FLASH CS0 */ + /* signal - Gpmc_clk; pin - J4; offset - 0x0088; mode - 0; Byte-3 Pull/up - N/A */ + MuxConfigReg = (volatile uint8 *)CONTROL_PADCONF_GPMC_D2_BYTE3; + *MuxConfigReg = 0x00; + + /* MPDB(Multi Port Debug Port) CS1 */ + /* signal - gpmc_ncs1; pin - N8; offset - 0x008C; mode - 0; Byte-1 Pull/up - N/A */ + MuxConfigReg = (volatile uint8 *)CONTROL_PADCONF_GPMC_NCS0_BYTE1; + *MuxConfigReg = 0x00; + + /* signal - Gpmc_ncs2; pin - E2; offset - 0x008C; mode - 0; Byte-2 Pull/up - N/A */ + MuxConfigReg = (volatile uint8 *)CONTROL_PADCONF_GPMC_NCS0_BYTE2; + *MuxConfigReg = 0x00; + + /* signal - Gpmc_ncs3; pin - N2; offset - 0x008C; mode - 0; Byte-3 Pull/up - N/A */ + MuxConfigReg = (volatile uint8 *)CONTROL_PADCONF_GPMC_NCS0_BYTE3; + *MuxConfigReg = 0x00; + + MuxConfigReg = (volatile uint8 *)((volatile unsigned char *)0x48000090); + *MuxConfigReg = 0x00; + MuxConfigReg = (volatile uint8 *)((volatile unsigned char *)0x48000091); + *MuxConfigReg = 0x00; + MuxConfigReg = (volatile uint8 *)((volatile unsigned char *)0x48000092); + *MuxConfigReg = 0x00; + MuxConfigReg = (volatile uint8 *)((volatile unsigned char *)0x48000093); + *MuxConfigReg = 0x00; +} + +/**************************************************************** + * Routine: muxSetupSDRC (ostboot) + * Description: Configures balls which come up in protected mode + ****************************************************************/ +void muxSetupSDRC(void) +{ + /* It's set by IPL */ +} diff --git a/board/apollon/config.mk b/board/apollon/config.mk new file mode 100644 index 0000000..45529c8 --- /dev/null +++ b/board/apollon/config.mk @@ -0,0 +1,28 @@ +# +# (C) Copyright 2005-2007 +# Samsung Electronics +# +# Samsung December board with OMAP2420 (ARM1136) cpu +# see http://www.ti.com/ for more information on Texas Instruments +# +# December has 1 bank of 128MB mDDR-SDRAM on CS0 +# December has 1 bank of 00MB mDDR-SDRAM on CS1 +# Physical Address: +# 8000'0000 (bank0) +# A000/0000 (bank1) ES2 will be configurable +# Linux-Kernel is expected to be at 8000'8000, entry 8000'8000 +# (mem base + reserved) + +# For use with external or internal boots. +TEXT_BASE = 0x80e80000 + +# Used with full SRAM boot. +# This is either with a GP system or a signed boot image. +# easiest, and safest way to go if you can. +#TEXT_BASE = 0x40270000 + + +# Handy to get symbols to debug ROM version. +#TEXT_BASE = 0x0 +#TEXT_BASE = 0x08000000 +#TEXT_BASE = 0x04000000
In message 20070914005131.GA14660@party you wrote:
Apollon BSP support
- MuxConfigReg = (volatile uint8 *)CONTROL_PADCONF_USB0_PUEN;
- *MuxConfigReg &= (uint8) (~0x1F);
- MuxConfigReg = (volatile uint8 *)CONTROL_PADCONF_USB0_VP;
- MuxConfigReg = (volatile uint8 *)CONTROL_PADCONF_USB0_VM;
- MuxConfigReg = (volatile uint8 *)CONTROL_PADCONF_USB0_RCV;
- MuxConfigReg = (volatile uint8 *)CONTROL_PADCONF_USB0_TXEN;
- MuxConfigReg = (volatile uint8 *)CONTROL_PADCONF_USB0_SE0;
- MuxConfigReg = (volatile uint8 *)CONTROL_PADCONF_USB0_DAT;
You use this sequence extensively. In the current form, it's extremly lengthy, difficult to read and difficult to maintain.
Please define an (inline?) fintion which performs the actions and allows you to change (for example)
- /* V19 */
- MuxConfigReg = (volatile uint8 *)CONTROL_PADCONF_USB1_RCV;
- *MuxConfigReg = 1;
- /* W20 */
- MuxConfigReg = (volatile uint8 *)CONTROL_PADCONF_USB1_TXEN;
- /* N14 */
- MuxConfigReg = (volatile uint8 *)CONTROL_PADCONF_GPIO69;
- *MuxConfigReg = 3;
- /* P15 */
- MuxConfigReg = (volatile uint8 *)CONTROL_PADCONF_GPIO70;
into
write_config_reg (CONTROL_PADCONF_USB1_RCV, 1); /* V19 */ write_config_reg (CONTROL_PADCONF_USB1_TXEN, 1); /* W20 */ write_config_reg (CONTROL_PADCONF_GPIO69, 3); /* N14 */ write_config_reg (CONTROL_PADCONF_GPIO70, 3); /* P15 */
This is IMO *much* easier to read and understand.
Please also note that identifiers like "MuxConfigReg" are in violation with the Coding Style:
C is a Spartan language, and so should your naming be. Unlike Modula-2 and Pascal programmers, C programmers do not use cute names like ThisVariableIsATemporaryCounter. A C programmer would call that variable "tmp", which is much easier to write, and not the least more difficult to understand.
Resend it I clicked the reply button instead of reply-all
Apollon BSP support
/* V19 */
*MuxConfigReg = 1;
/* W20 */
*MuxConfigReg = 1;
/* N14 */
*MuxConfigReg = 3;
/* P15 */
*MuxConfigReg = 3;
into
Oh, it's better. Actually I borrowed it from omap2420 and modified for apollon board. I will modify it as you suggested
Thank you, Kyungmin Park
In message 9c9fda240709141908h6ef1731bve5d5c39ac6713cc2@mail.gmail.com you wrote:
Thanks a lot. If you have some spare cycles it would be great if your patch could clean up the omap2420 code, too :-)
Kyungmin Park
