[U-Boot] [PATCH] arm: jadecpu: Readd MACH_TYPE_JADECPU
MACH_TYPE_JADECPU was removed from mach-types.h. Add it to board config file.
Signed-off-by: Matthias Weisser weisserm@arcor.de --- board/syteco/jadecpu/jadecpu.c | 1 - include/configs/jadecpu.h | 6 ++++++ 2 files changed, 6 insertions(+), 1 deletions(-)
diff --git a/board/syteco/jadecpu/jadecpu.c b/board/syteco/jadecpu/jadecpu.c index 63a0d33..72288fe 100644 --- a/board/syteco/jadecpu/jadecpu.c +++ b/board/syteco/jadecpu/jadecpu.c @@ -40,7 +40,6 @@ int board_init(void) writel(0x00000010, &ccnt->cmux_md);
gd->flags = 0; - gd->bd->bi_arch_number = MACH_TYPE_JADECPU; gd->bd->bi_boot_params = PHYS_SDRAM + PHYS_SDRAM_SIZE - 0x10000;
icache_enable(); diff --git a/include/configs/jadecpu.h b/include/configs/jadecpu.h index a239efc..42cb858 100644 --- a/include/configs/jadecpu.h +++ b/include/configs/jadecpu.h @@ -37,6 +37,12 @@ #define CONFIG_USE_ARCH_MEMCPY #define CONFIG_USE_ARCH_MEMSET
+#ifndef MACH_TYPE_JADECPU +#define MACH_TYPE_JADECPU 2636 +#endif + +#define CONFIG_MACH_TYPE MACH_TYPE_JADECPU + /* * Environment settings */
Acked-by: Igor Grinberg grinberg@compulab.co.il
gd->flags = 0;
icache_enable();
- Environment settings
Hi Matthias,
Signed-off-by: Matthias Weisserweisserm@arcor.de
diff --git a/board/syteco/jadecpu/jadecpu.c b/board/syteco/jadecpu/jadecpu.c index 63a0d33..72288fe 100644 --- a/board/syteco/jadecpu/jadecpu.c +++ b/board/syteco/jadecpu/jadecpu.c @@ -40,7 +40,6 @@ int board_init(void) writel(0x00000010,&ccnt->cmux_md);
gd->flags = 0;
icache_enable();
NAK -- remove ifndef/endif around definition. This way, if/when mach type reappears in official mach-type.h, we will get a warning about your mach-type being defined twice.
Amicalement,
Dear Albert ARIBAUD,
Note that you will only get a warning if a _different_ value get's defined (``warning: "VAR" redefined''). If both values are the same, no warning will be raised.
Hmm, correct. In order to catch the mach-type creeping back in mach-types.h, we'd need to define something like
#define MACH_TYPE_JADECPU (2636)
I'll post an ARM-global patch for this, but as it will obviously not be a bugfix, it'll wait until next merge window.
Amicalement,
Please save the effort. Waht would it be good for? As long as the values are the same, it's OK anyway. And if they should be different, we get a bunch of warnings.
Just wanted to make sure we know when the temporary MACH_TYPE addition in the config header becomes obsolete. But then, I can also run a grep on include/configs/*.h whenever mach-types.h is updated.
Amicalement,
Signed-off-by: Matthias Weisser weisserm@arcor.de --- Changes in V2: Removed ifdef around MACH_TYPE
icache_enable(); diff --git a/include/configs/jadecpu.h b/include/configs/jadecpu.h index a239efc..42cb858 100644 --- a/include/configs/jadecpu.h +++ b/include/configs/jadecpu.h @@ -37,6 +37,10 @@ #define CONFIG_USE_ARCH_MEMCPY #define CONFIG_USE_ARCH_MEMSET
+#define MACH_TYPE_JADECPU 2636 + +#define CONFIG_MACH_TYPE MACH_TYPE_JADECPU + /* * Environment settings */
Hi Matthias,
gd->flags = 0;
icache_enable();
Applied to u-boot-arm/master, thanks!
Amicalement,
Albert ARIBAUD
Igor Grinberg
Matthias Weisser
