[U-Boot-Users] FCC2 issue on PQ2FADS
I've got a new PQ2FADS board and am having issues with FCC2. I'm using the 1.1.2 release, we seem to be able to transmit but not receive packets.
Any ideas?
- kumar
Any ideas?
- kumar
* Are you sure your patch cord is OK?
* How do you know it isn't receiving packets?
* How do you know it is transmitting packets? Have you sniffed your ether with ethereal and verified the Tx packets are properly formed (see next bullet)?
* Are you sure your IP address and MAC are OK (WARNING: arbitrarily chosen MACs always seem to be illegal -- must be a corollary to Murphy's law)
* Are you aware that u-boot does not respond to "ping" (you can ping another machine from the command prompt, but u-boot won't respond if you ping _it_ from another machine)?
gvb
On Jan 7, 2005, at 7:38 AM, Jerry Van Baren wrote:
using
packets.
Any ideas?
- kumar
- Are you sure your patch cord is OK?
Yes, tried several
I see ARP requests on the host machine, using tcpdump.
- Are you sure your IP address and MAC are OK (WARNING: arbitrarily
I'm using MAC address assigned for out internal use.
- Are you aware that u-boot does not respond to "ping" (you can ping
I'm pinging from u-boot to host.
- kumar
Kumar Gala writes:
Kumar> I've got a new PQ2FADS board and am having issues with FCC2. Kumar> I'm using the 1.1.2 release, we seem to be able to transmit Kumar> but not receive packets.
Kumar> Any ideas?
Is the board connected to the LAN using hub? If yes, try switch. There can be problems with half-duplex link.
On Jan 7, 2005, at 10:49 AM, Yuli Barcohen wrote:
Kumar Gala writes:
Kumar> Any ideas?
I've tried both a hub & switch. One odd thing was that the hub was reporting half duplex, but the board was report full. I tried modifying the fcc_psmr to match, but that only made things worse.
I need to try using the other ethernet port and see what happens.
- kumar
Jerry Van Baren
Kumar Gala
Yuli Barcohen
