Re: [PATCH v2] usb: dwc3-meson-g12a: add power-on/off of the PHYs
On 21/04/2020 10:17, Neil Armstrong via groups.io wrote:
Power on/off the PHYs to enable power to the USB ports, fixing USB support on Khadas VIM3/VIM3L boards.
The G12A USB complex has at least 2 USB2 PHYs, but one is muxed between the DWC2 and DWC3 controller and the other one directly connected to the DWC3 controller. The USB3+PCIe combo PHY is muxed between the DWC3 controller and a DW-PCIE controller. All PHYs are optional, but it's type (usb2/usb3) and position are important to determine it's capabilities, thus they are stored in a fixed size array and the phy-name determines it's position, it's position determining it's type and functionnalities. This is why we need to loop over the array to power on all the DT provided PHYs.
Signed-off-by: Neil Armstrong narmstrong@baylibre.com
Changes since v1:
- removed extra space before semicolon
- added clarification in commit message
drivers/usb/dwc3/dwc3-meson-g12a.c | 16 ++++++++++++++++ 1 file changed, 16 insertions(+)
diff --git a/drivers/usb/dwc3/dwc3-meson-g12a.c b/drivers/usb/dwc3/dwc3-meson-g12a.c index d4453f8784..de964d6c10 100644 --- a/drivers/usb/dwc3/dwc3-meson-g12a.c +++ b/drivers/usb/dwc3/dwc3-meson-g12a.c @@ -408,6 +408,15 @@ static int dwc3_meson_g12a_probe(struct udevice *dev) goto err_phy_init; }
- for (i = 0; i < PHY_COUNT; ++i) {
if (!priv->phys[i].dev)
continue;
ret = generic_phy_power_on(&priv->phys[i]);
if (ret)
goto err_phy_init;
err_phy_init: @@ -430,6 +439,13 @@ static int dwc3_meson_g12a_remove(struct udevice *dev)
clk_release_all(&priv->clk, 1);
continue;
generic_phy_power_off(&priv->phys[i]);
- for (i = 0 ; i < PHY_COUNT ; ++i) { if (!priv->phys[i].dev) continue;
Applied to u-boot-amlogic
Changes since v1:
continue;
if (ret)
goto err_phy_init;
continue;
Did you apply V1 or V2 ?
Changes since v1:
continue;
if (ret)
goto err_phy_init;
continue;
v2
Neil
Neil Armstrong
