[U-Boot-Users] Kernel ignores u-boot's bootargs?
It seems like the kernel (2.6.10 for at91rm9200dk) doesn't see the bootargs. I comment CMDLINE in kernel's .config, set and save u-boot's bootargs with parameters (www.denx.de/wiki/view/DULG/LinuxBootArgs). But it stops after the bye-bye u-boot's message "Starting kernel...". The receipt in www.denx.de/wiki/view/DULG/LinuxKernelIgnoresMyBootargs doesn't help.
Hey Andrew,
I am also facing a similar issue. I can get 2.4 kernel to work but not 2.6 with u-boot. With redboot same kenrel image works fine.
My board has console port on ttyS1 and not default ttyS0 and so am suspecting this.
What are your observations. I tried passing the arg's from command line using setenv. And also setting default kernel command line properly.
Both no luck.
Cheers, Alfred
Using Tomcat but need to do more? Need to support web services, security? Get stuff done quickly with pre-integrated technology to make your job easier Download IBM WebSphere Application Server v.1.0.1 based on Apache Geronimo http://sel.as-us.falkag.net/sel?cmd=lnk&kid=120709&bid=263057&da... _______________________________________________ U-Boot-Users mailing list U-Boot-Users@lists.sourceforge.net https://lists.sourceforge.net/lists/listinfo/u-boot-users
alfred hitch
Andrew Zhukov
