[U-Boot] [PATCH v2 01/21] patman: Update cros_subprocess to use bytes
At present this function uses lists and strings. This does not work so well with Python 3, and testing against '' does not work for a bytearray. Update the code to fix these issues.
Changes in v2: - Update to use bytes instead of bytearray
tools/patman/cros_subprocess.py | 47 +++++++++++++++++++-------------- tools/patman/gitutil.py | 2 ++ 2 files changed, 29 insertions(+), 20 deletions(-)
diff --git a/tools/patman/cros_subprocess.py b/tools/patman/cros_subprocess.py index ebd4300dfd5..0f0d60dfb7a 100644 --- a/tools/patman/cros_subprocess.py +++ b/tools/patman/cros_subprocess.py @@ -100,6 +100,19 @@ class Popen(subprocess.Popen): if kwargs: raise ValueError("Unit tests do not test extra args - please add tests")
+ def ConvertData(self, data): + """Convert stdout/stderr data to the correct format for output + + Args: + data: Data to convert, or None for '' + + Returns: + Converted data, as bytes + """ + if data is None: + return b'' + return data + def CommunicateFilter(self, output): """Interact with process: Read data from stdout and stderr.
@@ -156,11 +169,11 @@ class Popen(subprocess.Popen): self.stdin.close() if self.stdout: read_set.append(self.stdout) - stdout = [] + stdout = b'' if self.stderr and self.stderr != self.stdout: read_set.append(self.stderr) - stderr = [] - combined = [] + stderr = b'' + combined = b''
input_offset = 0 while read_set or write_set: @@ -186,46 +199,40 @@ class Popen(subprocess.Popen): write_set.remove(self.stdin)
if self.stdout in rlist: - data = "" + data = b'' # We will get an error on read if the pty is closed try: data = os.read(self.stdout.fileno(), 1024) except OSError: pass - if data == "": + if not len(data): self.stdout.close() read_set.remove(self.stdout) else: - stdout.append(data) - combined.append(data) + stdout += data + combined += data if output: output(sys.stdout, data) if self.stderr in rlist: - data = "" + data = b'' # We will get an error on read if the pty is closed try: data = os.read(self.stderr.fileno(), 1024) except OSError: pass - if data == "": + if not len(data): self.stderr.close() read_set.remove(self.stderr) else: - stderr.append(data) - combined.append(data) + stderr += data + combined += data if output: output(sys.stderr, data)
# All data exchanged. Translate lists into strings. - if stdout is not None: - stdout = ''.join(stdout) - else: - stdout = '' - if stderr is not None: - stderr = ''.join(stderr) - else: - stderr = '' - combined = ''.join(combined) + stdout = self.ConvertData(stdout) + stderr = self.ConvertData(stderr) + combined = self.ConvertData(combined)
# Translate newlines, if requested. We cannot let the file # object do the translation: It is based on stdio, which is diff --git a/tools/patman/gitutil.py b/tools/patman/gitutil.py index 9905bb0bbd8..7650b51bd5b 100644 --- a/tools/patman/gitutil.py +++ b/tools/patman/gitutil.py @@ -326,6 +326,8 @@ def BuildEmailList(in_list, tag=None, alias=None, raise_on_error=True): result = [] for item in raw: if not item in result: + if type(item) == unicode: + item = item.encode('utf-8') result.append(item) if tag: return ['%s %s%s%s' % (tag, quote, email, quote) for email in result]
Changes in v2:
Applied to u-boot-dm.
