[U-Boot] [PATCH v1 0/5] apalis/colibri_t30: uart pinmuxing improvements
This series addresses some weaknesses in the current UART pinmuxing mainly observable when trying to use a different UART instance as main U-Boot serial console.
Marcel Ziswiler (5): apalis/colibri_t30: add comment about tristate and input vs. output pinmuxing colibri_t30: fix spi1 and uart2/3 resp. uartb/c pinmuxing apalis/colibri_t30: avoid uart input from floating pins apalis/colibri_t30: add note about colibri vs. nvidia uart mapping colibri_t30: disable rs232 serial transceiver forceoff pins
.../apalis_t30/pinmux-config-apalis_t30.h | 11 +++++-- board/toradex/colibri_t30/colibri_t30.c | 11 +++++++ .../colibri_t30/pinmux-config-colibri_t30.h | 32 +++++++++++-------- include/configs/apalis_t30.h | 9 +++++- include/configs/colibri_t30.h | 8 ++++- 5 files changed, 52 insertions(+), 19 deletions(-)
Add pinmuxing comment stating that TRISTATE means the output driver is tri-stated and INPUT means the input driver is enabled vs. OUTPUT where it is disabled.
Signed-off-by: Marcel Ziswiler marcel.ziswiler@toradex.com
board/toradex/apalis_t30/pinmux-config-apalis_t30.h | 2 ++ board/toradex/colibri_t30/pinmux-config-colibri_t30.h | 2 ++ 2 files changed, 4 insertions(+)
diff --git a/board/toradex/apalis_t30/pinmux-config-apalis_t30.h b/board/toradex/apalis_t30/pinmux-config-apalis_t30.h index 49c2df7ab2..8d6696aaad 100644 --- a/board/toradex/apalis_t30/pinmux-config-apalis_t30.h +++ b/board/toradex/apalis_t30/pinmux-config-apalis_t30.h @@ -11,7 +11,9 @@ .pingrp = PMUX_PINGRP_##_pingrp, \ .func = PMUX_FUNC_##_mux, \ .pull = PMUX_PULL_##_pull, \ +/* TRISTATE here means output driver is tri-stated */ \ .tristate = PMUX_TRI_##_tri, \ +/* INPUT here means input driver is enabled vs. OUTPUT where it is disabled */ \ .io = PMUX_PIN_##_io, \ .lock = PMUX_PIN_LOCK_DEFAULT, \ .od = PMUX_PIN_OD_DEFAULT, \ diff --git a/board/toradex/colibri_t30/pinmux-config-colibri_t30.h b/board/toradex/colibri_t30/pinmux-config-colibri_t30.h index bdbbf5e49a..6181b506a4 100644 --- a/board/toradex/colibri_t30/pinmux-config-colibri_t30.h +++ b/board/toradex/colibri_t30/pinmux-config-colibri_t30.h @@ -11,7 +11,9 @@ .pingrp = PMUX_PINGRP_##_pingrp, \ .func = PMUX_FUNC_##_mux, \ .pull = PMUX_PULL_##_pull, \ +/* TRISTATE here means output driver is tri-stated */ \ .tristate = PMUX_TRI_##_tri, \ +/* INPUT here means input driver is enabled vs. OUTPUT where it is disabled */ \ .io = PMUX_PIN_##_io, \ .lock = PMUX_PIN_LOCK_DEFAULT, \ .od = PMUX_PIN_OD_DEFAULT, \
diff --git a/board/toradex/apalis_t30/pinmux-config-apalis_t30.h b/board/toradex/apalis_t30/pinmux-config-apalis_t30.h index 49c2df7ab2..8d6696aaad 100644 --- a/board/toradex/apalis_t30/pinmux-config-apalis_t30.h +++ b/board/toradex/apalis_t30/pinmux-config-apalis_t30.h @@ -11,7 +11,9 @@ .pingrp = PMUX_PINGRP_##_pingrp, \ .func = PMUX_FUNC_##_mux, \ .pull = PMUX_PULL_##_pull, \ +/* TRISTATE here means output driver is tri-stated */ \ .tristate = PMUX_TRI_##_tri, \ +/* INPUT here means input driver is enabled vs. OUTPUT where it is disabled */ \ .io = PMUX_PIN_##_io, \ .lock = PMUX_PIN_LOCK_DEFAULT, \ .od = PMUX_PIN_OD_DEFAULT, \ diff --git a/board/toradex/colibri_t30/pinmux-config-colibri_t30.h b/board/toradex/colibri_t30/pinmux-config-colibri_t30.h index bdbbf5e49a..6181b506a4 100644 --- a/board/toradex/colibri_t30/pinmux-config-colibri_t30.h +++ b/board/toradex/colibri_t30/pinmux-config-colibri_t30.h @@ -11,7 +11,9 @@ .pingrp = PMUX_PINGRP_##_pingrp, \ .func = PMUX_FUNC_##_mux, \ .pull = PMUX_PULL_##_pull, \ +/* TRISTATE here means output driver is tri-stated */ \ .tristate = PMUX_TRI_##_tri, \ +/* INPUT here means input driver is enabled vs. OUTPUT where it is disabled */ \ .io = PMUX_PIN_##_io, \ .lock = PMUX_PIN_LOCK_DEFAULT, \ .od = PMUX_PIN_OD_DEFAULT, \ -- 2.21.0
Reviewed-by: Igor Opaniuk igor.opaniuk@toradex.com
Fix SPI1 and UART2/3 resp. UARTB/C pinmuxing.
Note: The former was illegally muxing multiple SoC balls onto the same internal SoC signal which caused rather strange behaviour regarding the RS232 serial transceiver ForceOFF# pins as available on Iris.
.../colibri_t30/pinmux-config-colibri_t30.h | 23 ++++++++++--------- 1 file changed, 12 insertions(+), 11 deletions(-)
diff --git a/board/toradex/colibri_t30/pinmux-config-colibri_t30.h b/board/toradex/colibri_t30/pinmux-config-colibri_t30.h index 6181b506a4..c583583b3f 100644 --- a/board/toradex/colibri_t30/pinmux-config-colibri_t30.h +++ b/board/toradex/colibri_t30/pinmux-config-colibri_t30.h @@ -181,13 +181,14 @@ static struct pmux_pingrp_config tegra3_pinmux_common[] = { LV_PINMUX(VI_D10_PT2, RSVD1, NORMAL, NORMAL, INPUT, DISABLE, DISABLE), LV_PINMUX(VI_MCLK_PT1, VI, UP, NORMAL, INPUT, DISABLE, DISABLE), DEFAULT_PINMUX(UART2_RXD_PC3, UARTB, NORMAL, NORMAL, INPUT), - DEFAULT_PINMUX(UART2_TXD_PC2, UARTB, NORMAL, NORMAL, OUTPUT), - DEFAULT_PINMUX(UART2_RTS_N_PJ6, UARTB, NORMAL, NORMAL, OUTPUT), - DEFAULT_PINMUX(UART2_CTS_N_PJ5, UARTB, NORMAL, NORMAL, INPUT), - DEFAULT_PINMUX(UART3_TXD_PW6, UARTC, NORMAL, NORMAL, OUTPUT), - DEFAULT_PINMUX(UART3_RXD_PW7, UARTC, NORMAL, NORMAL, INPUT), - DEFAULT_PINMUX(UART3_CTS_N_PA1, UARTC, NORMAL, NORMAL, INPUT), - DEFAULT_PINMUX(UART3_RTS_N_PC0, UARTC, NORMAL, NORMAL, OUTPUT), + DEFAULT_PINMUX(UART2_TXD_PC2, UARTB, NORMAL, NORMAL, INPUT), + DEFAULT_PINMUX(UART2_RTS_N_PJ6, GMI, NORMAL, NORMAL, INPUT), + DEFAULT_PINMUX(UART2_CTS_N_PJ5, GMI, NORMAL, NORMAL, INPUT), + DEFAULT_PINMUX(UART3_TXD_PW6, GMI, NORMAL, NORMAL, INPUT), + DEFAULT_PINMUX(UART3_RXD_PW7, GMI, NORMAL, NORMAL, INPUT), + DEFAULT_PINMUX(UART3_CTS_N_PA1, GMI, NORMAL, NORMAL, INPUT), + DEFAULT_PINMUX(UART3_RTS_N_PC0, GMI, NORMAL, NORMAL, INPUT), + DEFAULT_PINMUX(PU0, RSVD1, NORMAL, NORMAL, INPUT), DEFAULT_PINMUX(PU1, RSVD1, NORMAL, NORMAL, OUTPUT), DEFAULT_PINMUX(PU2, RSVD1, NORMAL, NORMAL, INPUT), @@ -270,10 +271,10 @@ static struct pmux_pingrp_config tegra3_pinmux_common[] = { DEFAULT_PINMUX(DAP2_SCLK_PA3, I2S1, NORMAL, NORMAL, INPUT),
DEFAULT_PINMUX(SPI2_CS1_N_PW2, SPI2, UP, NORMAL, INPUT), - DEFAULT_PINMUX(SPI1_MOSI_PX4, SPI1, NORMAL, NORMAL, INPUT), - DEFAULT_PINMUX(SPI1_SCK_PX5, SPI1, NORMAL, NORMAL, INPUT), - DEFAULT_PINMUX(SPI1_CS0_N_PX6, SPI1, NORMAL, NORMAL, INPUT), - DEFAULT_PINMUX(SPI1_MISO_PX7, SPI1, NORMAL, NORMAL, INPUT), + DEFAULT_PINMUX(SPI1_MOSI_PX4, GMI, NORMAL, NORMAL, INPUT), + DEFAULT_PINMUX(SPI1_SCK_PX5, GMI, NORMAL, NORMAL, INPUT), + DEFAULT_PINMUX(SPI1_CS0_N_PX6, GMI, NORMAL, NORMAL, INPUT), + DEFAULT_PINMUX(SPI1_MISO_PX7, RSVD4, NORMAL, NORMAL, INPUT),
/* LAN_RESET */ DEFAULT_PINMUX(PEX_L0_PRSNT_N_PDD0, RSVD2, NORMAL, NORMAL, OUTPUT),
DEFAULT_PINMUX(SPI1_MISO_PX7, RSVD4, NORMAL, NORMAL, INPUT), /* LAN_RESET */ DEFAULT_PINMUX(PEX_L0_PRSNT_N_PDD0, RSVD2, NORMAL, NORMAL, OUTPUT),
-- 2.21.0
Avoid UART input from floating RX pins on UARTB and UARTC (Colibri T30) and UARTB, UARTC and UARTD (Apalis T30).
Note: Floating pins may cause spurious break conditions potentially interrupting U-Boot's autoboot.
board/toradex/apalis_t30/pinmux-config-apalis_t30.h | 9 ++++++--- board/toradex/colibri_t30/pinmux-config-colibri_t30.h | 7 ++++--- 2 files changed, 10 insertions(+), 6 deletions(-)
diff --git a/board/toradex/apalis_t30/pinmux-config-apalis_t30.h b/board/toradex/apalis_t30/pinmux-config-apalis_t30.h index 8d6696aaad..3a2cf4606e 100644 --- a/board/toradex/apalis_t30/pinmux-config-apalis_t30.h +++ b/board/toradex/apalis_t30/pinmux-config-apalis_t30.h @@ -120,7 +120,8 @@ static struct pmux_pingrp_config tegra3_pinmux_common[] = { DEFAULT_PINMUX(ULPI_DATA6_PO7, UARTA, NORMAL, NORMAL, INPUT), DEFAULT_PINMUX(ULPI_DATA7_PO0, UARTA, NORMAL, NORMAL, OUTPUT), DEFAULT_PINMUX(ULPI_CLK_PY0, UARTD, NORMAL, NORMAL, OUTPUT), - DEFAULT_PINMUX(ULPI_DIR_PY1, UARTD, NORMAL, NORMAL, INPUT), + /* UARTD RX, make sure we don't get input form a floating Pin */ + DEFAULT_PINMUX(ULPI_DIR_PY1, UARTD, UP, NORMAL, INPUT), DEFAULT_PINMUX(ULPI_NXT_PY2, UARTD, NORMAL, NORMAL, INPUT), DEFAULT_PINMUX(ULPI_STP_PY3, UARTD, NORMAL, NORMAL, OUTPUT), DEFAULT_PINMUX(DAP3_FS_PP0, I2S2, NORMAL, NORMAL, INPUT), @@ -189,12 +190,14 @@ static struct pmux_pingrp_config tegra3_pinmux_common[] = { LV_PINMUX(VI_MCLK_PT1, VI, NORMAL, NORMAL, OUTPUT, DISABLE, DISABLE), LV_PINMUX(VI_PCLK_PT0, VI, NORMAL, NORMAL, INPUT, DISABLE, DISABLE), LV_PINMUX(VI_VSYNC_PD6, VI, NORMAL, NORMAL, INPUT, DISABLE, DISABLE), - DEFAULT_PINMUX(UART2_RXD_PC3, UARTB, NORMAL, NORMAL, INPUT), + /* UARTB RX, make sure we don't get input form a floating Pin */ + DEFAULT_PINMUX(UART2_RXD_PC3, UARTB, UP, NORMAL, INPUT), DEFAULT_PINMUX(UART2_TXD_PC2, UARTB, NORMAL, NORMAL, OUTPUT), DEFAULT_PINMUX(UART2_RTS_N_PJ6, UARTB, DOWN, TRISTATE, OUTPUT), /* NC */ DEFAULT_PINMUX(UART2_CTS_N_PJ5, UARTB, DOWN, TRISTATE, OUTPUT), /* NC */ DEFAULT_PINMUX(UART3_TXD_PW6, UARTC, NORMAL, NORMAL, OUTPUT), - DEFAULT_PINMUX(UART3_RXD_PW7, UARTC, NORMAL, NORMAL, INPUT), + /* UARTC RX, make sure we don't get input form a floating Pin */ + DEFAULT_PINMUX(UART3_RXD_PW7, UARTC, UP, NORMAL, INPUT), DEFAULT_PINMUX(UART3_CTS_N_PA1, UARTC, NORMAL, NORMAL, INPUT), DEFAULT_PINMUX(UART3_RTS_N_PC0, PWM0, NORMAL, NORMAL, OUTPUT), DEFAULT_PINMUX(PU0, RSVD1, DOWN, TRISTATE, OUTPUT), diff --git a/board/toradex/colibri_t30/pinmux-config-colibri_t30.h b/board/toradex/colibri_t30/pinmux-config-colibri_t30.h index c583583b3f..5ac1a6da97 100644 --- a/board/toradex/colibri_t30/pinmux-config-colibri_t30.h +++ b/board/toradex/colibri_t30/pinmux-config-colibri_t30.h @@ -180,7 +180,8 @@ static struct pmux_pingrp_config tegra3_pinmux_common[] = { LV_PINMUX(VI_D7_PL5, SDMMC2, NORMAL, NORMAL, INPUT, DISABLE, DISABLE), LV_PINMUX(VI_D10_PT2, RSVD1, NORMAL, NORMAL, INPUT, DISABLE, DISABLE), LV_PINMUX(VI_MCLK_PT1, VI, UP, NORMAL, INPUT, DISABLE, DISABLE), - DEFAULT_PINMUX(UART2_RXD_PC3, UARTB, NORMAL, NORMAL, INPUT), + /* UARTC RX, make sure we don't get input form a floating Pin */ + DEFAULT_PINMUX(UART2_RXD_PC3, UARTB, UP, NORMAL, INPUT), DEFAULT_PINMUX(UART2_TXD_PC2, UARTB, NORMAL, NORMAL, INPUT), DEFAULT_PINMUX(UART2_RTS_N_PJ6, GMI, NORMAL, NORMAL, INPUT), DEFAULT_PINMUX(UART2_CTS_N_PJ5, GMI, NORMAL, NORMAL, INPUT), @@ -207,11 +208,11 @@ static struct pmux_pingrp_config tegra3_pinmux_common[] = { DEFAULT_PINMUX(GMI_AD8_PH0, PWM0, NORMAL, NORMAL, OUTPUT), /* LCD1_BL_PWM */ DEFAULT_PINMUX(GMI_AD10_PH2, NAND, NORMAL, NORMAL, OUTPUT), /* LCD1_BL_EN */ DEFAULT_PINMUX(GMI_A16_PJ7, UARTD, NORMAL, NORMAL, INPUT), - DEFAULT_PINMUX(GMI_A17_PB0, UARTD, NORMAL, NORMAL, INPUT), + /* UARTB RX, make sure we don't get input form a floating Pin */ + DEFAULT_PINMUX(GMI_A17_PB0, UARTD, UP, NORMAL, INPUT), DEFAULT_PINMUX(GMI_A18_PB1, UARTD, NORMAL, NORMAL, INPUT), DEFAULT_PINMUX(GMI_A19_PK7, UARTD, NORMAL, NORMAL, INPUT),
- /* Multiplexed with KB_ROW10/KB_ROW11/KB_ROW12/KB_ROW15 */ DEFAULT_PINMUX(CAM_MCLK_PCC0, VI_ALT2, UP, TRISTATE, INPUT), DEFAULT_PINMUX(PCC1, RSVD1, NORMAL, TRISTATE, INPUT),
-- 2.21.0
The following mapping is applicable for Apalis T30:
Apalis UART1: NVIDIA UARTA Apalis UART2: NVIDIA UARTD Apalis UART3: NVIDIA UARTB Apalis UART4: NVIDIA UARTC
The following mapping is applicable for Colibri T30:
Colibri UART-A: NVIDIA UARTA Colibri UART-B: NVIDIA UARTD Colibri UART-C: NVIDIA UARTB
include/configs/apalis_t30.h | 9 ++++++++- include/configs/colibri_t30.h | 8 +++++++- 2 files changed, 15 insertions(+), 2 deletions(-)
diff --git a/include/configs/apalis_t30.h b/include/configs/apalis_t30.h index f6adfeb96a..b6711c57b8 100644 --- a/include/configs/apalis_t30.h +++ b/include/configs/apalis_t30.h @@ -12,7 +12,14 @@
#include "tegra30-common.h"
-/* Board-specific serial config */ +/* + * Board-specific serial config + * + * Apalis UART1: NVIDIA UARTA + * Apalis UART2: NVIDIA UARTD + * Apalis UART3: NVIDIA UARTB + * Apalis UART4: NVIDIA UARTC + */ #define CONFIG_TEGRA_ENABLE_UARTA #define CONFIG_SYS_NS16550_COM1 NV_PA_APB_UARTA_BASE
diff --git a/include/configs/colibri_t30.h b/include/configs/colibri_t30.h index 8ff6433f45..6053776019 100644 --- a/include/configs/colibri_t30.h +++ b/include/configs/colibri_t30.h @@ -14,7 +14,13 @@
/* High-level configuration options */
-/* Board-specific serial config */ +/* + * Board-specific serial config + * + * Colibri UART-A: NVIDIA UARTA + * Colibri UART-B: NVIDIA UARTD + * Colibri UART-C: NVIDIA UARTB + */ #define CONFIG_TEGRA_ENABLE_UARTA #define CONFIG_SYS_NS16550_COM1 NV_PA_APB_UARTA_BASE
- Board-specific serial config
- Apalis UART1: NVIDIA UARTA
- Apalis UART2: NVIDIA UARTD
- Apalis UART3: NVIDIA UARTB
- Apalis UART4: NVIDIA UARTC
- Colibri UART-A: NVIDIA UARTA
- Colibri UART-B: NVIDIA UARTD
- Colibri UART-C: NVIDIA UARTB
-- 2.21.0
Use gpio_early_init_uart() function to disable RS232 serial transceiver ForceOFF# pins on Iris.
board/toradex/colibri_t30/colibri_t30.c | 11 +++++++++++ 1 file changed, 11 insertions(+)
diff --git a/board/toradex/colibri_t30/colibri_t30.c b/board/toradex/colibri_t30/colibri_t30.c index b6b00e3860..eb53fa6126 100644 --- a/board/toradex/colibri_t30/colibri_t30.c +++ b/board/toradex/colibri_t30/colibri_t30.c @@ -55,6 +55,17 @@ void pinmux_init(void) ARRAY_SIZE(colibri_t30_padctrl)); }
+/* + * Disable RS232 serial transceiver ForceOFF# pins on Iris + */ +void gpio_early_init_uart(void) +{ + gpio_request(TEGRA_GPIO(X, 6), "Force OFF# X13"); + gpio_direction_output(TEGRA_GPIO(X, 6), 1); + gpio_request(TEGRA_GPIO(X, 7), "Force OFF# X14"); + gpio_direction_output(TEGRA_GPIO(X, 7), 1); +} + /* * Enable AX88772B USB to LAN controller */
Hi Marcel,
- Disable RS232 serial transceiver ForceOFF# pins on Iris
- Enable AX88772B USB to LAN controller
2.21.0
What not to handle this in the dts instead?
-- Best regards - Freundliche Grüsse - Meilleures salutations
Igor Opaniuk
mailto: igor.opaniuk@gmail.com skype: igor.opanyuk +380 (93) 836 40 67 http://ua.linkedin.com/in/iopaniuk
Igor Opaniuk
Marcel Ziswiler
