[U-Boot] imx6dl_mamoj broken
Hi Raffaele, hi Simone,
your imx6dl_mamoj is broken on u-boot-imx. Reason is that SPL overrruns and it is bigger as the OCRAM on the DL SOC.
arm: + imx6dl_mamoj +spl/u-boot-spl.bin exceeds file size limit: + limit: 53248 bytes + actual: 58597 bytes + excess: 5349 bytes
+make[1]: *** [spl/u-boot-spl.bin] Error 1 +make[1]: *** Deleting file `spl/u-boot-spl.bin' +make: *** [sub-make] Error 2
Can you check it and fix it, please ? You see the error here:
https://travis-ci.org/sbabic/u-boot-imx/jobs/584953098
Best regards, Stefano Babic
Hi Stefano,
arm: + imx6dl_mamoj
- limit: 53248 bytes
- actual: 58597 bytes
- excess: 5349 bytes
Any idea which commit make this blow-out. we didn't do anything with this board recently. I guess some default CLK framework or so?
On 16/09/19 10:06, Jagan Teki wrote:
Hi Stefano,
arm: + imx6dl_mamoj
Yes, I took a look at its include file, there is nothing new or obciously big.
I suppose the same, yes.
Regards, Stefano
Hi Jagan,
On Mon, 16 Sep 2019 13:36:03 +0530 Jagan Teki jagan@amarulasolutions.com wrote: ...
arm: + imx6dl_mamoj
This check fails since the recent changes in SPL size limit check, see commit 25d38f9b34be (imx6: spl: Reduce SPL limit size in case CONFIG_SECURE_BOOT is enabled).
i.MX6DL has 128KiB OCRAM, probably we could increase default SPL_SIZE_LIMIT config in common/spl/Kconfig for i.MX6DL?
-- Anatolij
Hi Anatolji,
On 16/09/19 22:20, Anatolij Gustschin wrote:
Hi Jagan,
arm: + imx6dl_mamoj
Well, the current size was computed for the Solo /DL - Dual / Quad has twice OCRAM. According to chapter "8.4 Internal ROM / RAM map", for Solo /Dl there is 68KB available for user (address 0x907000--0x917FFF). I do not remember the details, but then we have to reserve space for gd, stack, etc. This leads to the actual value.
Regards, Stefano
On 2019-09-16 3:08 p.m., Stefano Babic wrote:
Hi Anatolji,
Hi Jagan,
arm: + imx6dl_mamoj
The patch I posted a while ago ("[PATCH v2] ARM: imx: Support larger SPL size on IMX6DQ") may be helpful for this case. If the platform doesn't need to support the "lite" chip versions with smaller OCRAM size, then the available size for the SPL can be increased.
Hi Robert,
I do think your patch is useful and I hope it can be applied, but I think it does not help in this case as the target name is imx6dl_mamoj.
Thanks
Hi Robert,
Hi Anatolji,
Hi Jagan,
Your patch is "in" - it is applied to u-boot-imx. However, it cannot help because the current limitation is set for Solo / DL. With your patch, SPL on Dual / Quad can be larger.
The SOC is a DL, 128KB
It cannot
Hi Anatolij/Stefano/Jagan,
If you agree I can send a patch doing:
--- a/configs/imx6dl_mamoj_defconfig +++ b/configs/imx6dl_mamoj_defconfig @@ -1,7 +1,6 @@ CONFIG_ARM=y CONFIG_ARCH_MX6=y CONFIG_SYS_TEXT_BASE=0x17800000 -CONFIG_SECURE_BOOT=y CONFIG_TARGET_MX6DL_MAMOJ=y CONFIG_NR_DRAM_BANKS=1 # CONFIG_CMD_BMODE is not set
which allows the target to build again.
It seems that this target does not boot currently, but if we remove CONFIG_SECURE_BOOT then it can build and boot, I suppose.
But this would drop HABv4, which indeed required for this board since all the production boards are secure enabled.
Hi Fabio,
I can't decide for the board maintainer - yes, I have also dropped some feature, and I can build, but I have no idea which feature can be removed (and I could not test at all). The decision should be taken by board maintainer, I hope as soon as possible.
participants (5)
Anatolij Gustschin
Fabio Estevam
Jagan Teki
Robert Hancock
Stefano Babic
