[U-Boot] [PATCH] delete Kbuild "select" of long-dead SPL_DISABLE_OF_CONTROL
From way back in 2015:
commit dffb86e468c8e02ba77283989aefef214d904dc5 Author: Masahiro Yamada yamada.masahiro@socionext.com Date: Wed Aug 12 07:31:54 2015 +0900
of: flip CONFIG_SPL_DISABLE_OF_CONTROL into CONFIG_SPL_OF_CONTROL
As we discussed a couple of times, negative CONFIG options make our life difficult; CONFIG_SYS_NO_FLASH, CONFIG_SYS_DCACHE_OFF, ... and here is another one.
Now, there are three boards enabling OF_CONTROL on SPL: - socfpga_arria5_defconfig - socfpga_cyclone5_defconfig - socfpga_socrates_defconfig
This commit adds CONFIG_SPL_OF_CONTROL for them and deletes CONFIG_SPL_DISABLE_OF_CONTROL from the other boards to invert the logic.
Signed-off-by: Masahiro Yamada yamada.masahiro@socionext.com Reviewed-by: Tom Rini trini@konsulko.com Reviewed-by: Simon Glass sjg@chromium.org
AFAICT, simple deletion should be sufficient but i'm willing to be convinced otherwise.
diff --git a/arch/arm/mach-exynos/Kconfig b/arch/arm/mach-exynos/Kconfig index 3807770362..14347e7c7d 100644 --- a/arch/arm/mach-exynos/Kconfig +++ b/arch/arm/mach-exynos/Kconfig @@ -116,7 +116,6 @@ config TARGET_SNOW config TARGET_SPRING bool "Spring board" select OF_CONTROL - select SPL_DISABLE_OF_CONTROL select SUPPORT_SPL
config TARGET_SMDK5420 @@ -150,7 +149,6 @@ config TARGET_ESPRESSO7420 select OF_CONTROL select PINCTRL select PINCTRL_EXYNOS7420 - select SPL_DISABLE_OF_CONTROL select SUPPORT_SPL
endchoice
On Sun, Apr 14, 2019 at 7:21 PM Robert P. J. Day rpjday@crashcourse.ca wrote:
of: flip CONFIG_SPL_DISABLE_OF_CONTROL into CONFIG_SPL_OF_CONTROL As we discussed a couple of times, negative CONFIG options make our life difficult; CONFIG_SYS_NO_FLASH, CONFIG_SYS_DCACHE_OFF, ... and here is another one. Now, there are three boards enabling OF_CONTROL on SPL: - socfpga_arria5_defconfig - socfpga_cyclone5_defconfig - socfpga_socrates_defconfig This commit adds CONFIG_SPL_OF_CONTROL for them and deletes CONFIG_SPL_DISABLE_OF_CONTROL from the other boards to invert the logic. Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com> Reviewed-by: Tom Rini <trini@konsulko.com> Reviewed-by: Simon Glass <sjg@chromium.org>
Thanks for catching this.
Reviewed-by: Masahiro Yamada yamada.masahiro@socionext.com
endchoice
======================================================================== Robert P. J. Day Ottawa, Ontario, CANADA http://crashcourse.ca
Twitter: http://twitter.com/rpjday LinkedIn: http://ca.linkedin.com/in/rpjday ======================================================================== _______________________________________________ U-Boot mailing list U-Boot@lists.denx.de https://lists.denx.de/listinfo/u-boot
Masahiro Yamada
Robert P. J. Day
