[U-Boot] [PATCH 1/1] efi_loader: default EFI_LOADER=n on ARM11
Some of the ARM11 boards have tight limits on the size of U-Boots. Hence use EFI_LOADER=n as default on ARM11.
Set EFI_LOADER=y for the Raspberry Pi and Raspberry Pi Zero as these boards have sufficient storage on the SD card.
Suggested-by: Tom Rini trini@konsulko.com Signed-off-by: Heinrich Schuchardt xypron.glpk@gmx.de --- configs/rpi_0_w_defconfig | 1 + configs/rpi_defconfig | 1 + lib/efi_loader/Kconfig | 2 +- 3 files changed, 3 insertions(+), 1 deletion(-)
diff --git a/configs/rpi_0_w_defconfig b/configs/rpi_0_w_defconfig index fe5a7763a6..6614adfc9b 100644 --- a/configs/rpi_0_w_defconfig +++ b/configs/rpi_0_w_defconfig @@ -41,3 +41,4 @@ CONFIG_SYS_WHITE_ON_BLACK=y CONFIG_CONSOLE_SCROLL_LINES=10 CONFIG_PHYS_TO_BUS=y CONFIG_OF_LIBFDT_OVERLAY=y +CONFIG_EFI_LOADER=y diff --git a/configs/rpi_defconfig b/configs/rpi_defconfig index 2c04b3334e..fa4d9c0b04 100644 --- a/configs/rpi_defconfig +++ b/configs/rpi_defconfig @@ -41,3 +41,4 @@ CONFIG_SYS_WHITE_ON_BLACK=y CONFIG_CONSOLE_SCROLL_LINES=10 CONFIG_PHYS_TO_BUS=y CONFIG_OF_LIBFDT_OVERLAY=y +CONFIG_EFI_LOADER=y diff --git a/lib/efi_loader/Kconfig b/lib/efi_loader/Kconfig index 7984d6f42d..91411ad124 100644 --- a/lib/efi_loader/Kconfig +++ b/lib/efi_loader/Kconfig @@ -10,7 +10,7 @@ config EFI_LOADER depends on !EFI_STUB || !X86_64 || EFI_STUB_64BIT # We need EFI_STUB_32BIT to be set on x86_32 with EFI_STUB depends on !EFI_STUB || !X86 || X86_64 || EFI_STUB_32BIT - default y + default y if !ARM || SYS_CPU = armv7 || SYS_CPU = armv8 select LIB_UUID select HAVE_BLOCK_DEVICE select REGEX -- 2.24.0
On Wed, Nov 20, 2019 at 7:04 PM Heinrich Schuchardt xypron.glpk@gmx.de wrote:
Reviewed-by: Linus Walleij linus.walleij@linaro.org
Yours, Linus Walleij
For RPi configs:
Acked-by: Matthias Brugger mbrugger@suse.com
- default y
- default y if !ARM || SYS_CPU = armv7 || SYS_CPU = armv8 select LIB_UUID select HAVE_BLOCK_DEVICE select REGEX
-- 2.24.0
Linus Walleij
Matthias Brugger
