[U-Boot] [PATCH] ci_udc: fix 64-bit compile warnings
This is the same as f72d8320b605 "usb: ci_udc: fix warnings on 64-bit builds", but more.
Signed-off-by: Stephen Warren swarren@nvidia.com --- drivers/usb/gadget/ci_udc.c | 19 ++++++++++--------- 1 file changed, 10 insertions(+), 9 deletions(-)
diff --git a/drivers/usb/gadget/ci_udc.c b/drivers/usb/gadget/ci_udc.c index aadff42a9cdc..993be315a8cf 100644 --- a/drivers/usb/gadget/ci_udc.c +++ b/drivers/usb/gadget/ci_udc.c @@ -221,8 +221,8 @@ static void ci_flush_qtd(int ep_num) */ static void ci_flush_td(struct ept_queue_item *td) { - const uint32_t start = (uint32_t)td; - const uint32_t end = (uint32_t) td + ILIST_ENT_SZ; + const unsigned long start = (unsigned long)td; + const unsigned long end = (unsigned long)td + ILIST_ENT_SZ; flush_dcache_range(start, end); }
@@ -249,8 +249,8 @@ static void ci_invalidate_qtd(int ep_num) */ static void ci_invalidate_td(struct ept_queue_item *td) { - const uint32_t start = (uint32_t)td; - const uint32_t end = start + ILIST_ENT_SZ; + const unsigned long start = (unsigned long)td; + const unsigned long end = start + ILIST_ENT_SZ; invalidate_dcache_range(start, end); }
@@ -459,7 +459,7 @@ static void ci_ep_submit_next_request(struct ci_ep *ci_ep) if (len) { qtd = (struct ept_queue_item *) memalign(ILIST_ALIGN, ILIST_ENT_SZ); - dtd->next = (uint32_t)qtd; + dtd->next = (unsigned long)qtd; dtd = qtd; memset(dtd, 0, ILIST_ENT_SZ); } @@ -503,10 +503,10 @@ static void ci_ep_submit_next_request(struct ci_ep *ci_ep)
ci_flush_qtd(num);
- item = (struct ept_queue_item *)head->next; + item = (struct ept_queue_item *)(unsigned long)head->next; while (item->next != TERMINATE) { - ci_flush_td((struct ept_queue_item *)item->next); - item = (struct ept_queue_item *)item->next; + ci_flush_td((struct ept_queue_item *)(unsigned long)item->next); + item = (struct ept_queue_item *)(unsigned long)item->next; }
DBG("ept%d %s queue len %x, req %p, buffer %p\n", @@ -594,7 +594,8 @@ static void handle_ep_complete(struct ci_ep *ci_ep) printf("EP%d/%s FAIL info=%x pg0=%x\n", num, in ? "in" : "out", item->info, item->page0); if (j != ci_req->dtd_count - 1) - next_td = (struct ept_queue_item *)item->next; + next_td = (struct ept_queue_item *)(unsigned long) + item->next; if (j != 0) free(item); }
Applied, thanks!
Best regards, Marek Vasut
Hi Marek,
- const unsigned long start = (unsigned long)td;
- const unsigned long end = (unsigned long)td + ILIST_ENT_SZ; flush_dcache_range(start, end);
- const unsigned long end = start + ILIST_ENT_SZ; invalidate_dcache_range(start, end);
}dtd->next = (unsigned long)qtd; dtd = qtd; memset(dtd, 0, ILIST_ENT_SZ);
@@ -503,10 +503,10 @@ static void ci_ep_submit_next_request(struct ci_ep *ci_ep) ci_flush_qtd(num);
- item = (struct ept_queue_item *)(unsigned long)head->next; while (item->next != TERMINATE) {
long)item->next);
long)item->next; }
*)item->next;
long)
if (j != 0) free(item); }item->next;
Should I take the patch to -dfu tree?
On Thursday, July 23, 2015 at 09:00:53 AM, Lukasz Majewski wrote:
Hi Marek,
ci_flush_qtd(num);
long)item->next);
long)item->next; }
*)item->next;
long)
item->next;
if (j != 0)
free(item);
I picked it for -usb . I will wait until the weekend, then build and send a PR to Tom.
Hi Marek,
Never mind :-). It is already in your tree. Sorry for the noise.
long)item->next);
long)item->next; }
*)item->next;
long)
On Thursday, July 23, 2015 at 09:09:44 AM, Lukasz Majewski wrote:
Hi Marek,
No worries :)
Lukasz Majewski
Stephen Warren
