[U-Boot] [PATCH] arm, at91: fix taurus board
since commit: b529993e0222 "spl: add hierarchical defaults for SPL_LDSCRIPT"
taurus board stopped working. Use the ldscript from arch/arm/cpu/u-boot-spl.lds (as before this patch) fixed it.
Signed-off-by: Heiko Schocher hs@denx.de --- git bisect log: pollux:u-boot-at91_taurus hs [(kein Branch, binäre Suche begonnen bei master)] $ git bisect log git bisect start git bisect bad 883eb53ee54843ebeae967288bb537578296a441 git bisect good eaa90e5df2a4a1cb12fb73571978a9379242d0b5 git bisect good ee14d29db0f49785867f26902540f65d3a1d62eb git bisect good b1a16002f269051bfc82c4b6948e6c069928f704 git bisect good 7b07a20c5e668b67348dc7a3abbeb437ab0afa52 git bisect bad a2a1bfe175038e15bcdc89975b8bc6befa90812d git bisect good c72c161bc0af0dc8fdabdebf3812cfeef3915e4c git bisect bad e8f9ad94bf1e03ee9df6dec112a2009d3a442206 git bisect bad b529993e0222ce8c97d3e8fe41e4a2e7878e281e git bisect good 96b9082c6413c9ec354f9ea5c61014e2b203ff5b pollux:u-boot-at91_taurus hs [(kein Branch, binäre Suche begonnen bei master)] $ git bisect visualize commit b529993e0222ce8c97d3e8fe41e4a2e7878e281e (refs/bisect/bad) Author: Philipp Tomsich philipp.tomsich@theobroma-systems.com Date: Thu Aug 3 23:23:55 2017 +0200
With SPL_LDSCRIPT moved to Kconfig (and this being a 'string' config node), all the lingering definitions in header files will cause warnings/errors due to the redefinition of the configuration item.
As we don't want to pollute the defconfig files (and values should usually be identical for entire architectures), the defaults are moved into Kconfig. Kconfig will always pick the first default that matches, so please keep these values at the end of each file (to allow any board-specific Kconfig, which will be included earlier) to override with an unconditional default setting.
Signed-off-by: Philipp Tomsich philipp.tomsich@theobroma-systems.com Reviewed-by: Simon Glass sjg@chromium.org pollux:u-boot-at91_taurus hs [(kein Branch, binäre Suche begonnen bei master)] $
configs/taurus_defconfig | 1 + 1 file changed, 1 insertion(+)
diff --git a/configs/taurus_defconfig b/configs/taurus_defconfig index 6fecaf89e8..4e5fad7ad4 100644 --- a/configs/taurus_defconfig +++ b/configs/taurus_defconfig @@ -3,6 +3,7 @@ CONFIG_SPL_SYS_THUMB_BUILD=y # CONFIG_SPL_USE_ARCH_MEMCPY is not set # CONFIG_SPL_USE_ARCH_MEMSET is not set CONFIG_ARCH_AT91=y +CONFIG_SPL_LDSCRIPT="arch/$(ARCH)/cpu/u-boot-spl.lds" CONFIG_TARGET_TAURUS=y CONFIG_SPL_GPIO_SUPPORT=y CONFIG_SPL_LIBCOMMON_SUPPORT=y
Reviewed-by: Philipp Tomsich philipp.tomsich@theobroma-systems.com
Note that (in theory; i.e. if the Kconfig framework works as expected) you should be able to put this as a default override into board/siemens/taurus/Kconfig if you prefer
diff --git a/configs/taurus_defconfig b/configs/taurus_defconfig index 6fecaf89e8..4e5fad7ad4 100644 --- a/configs/taurus_defconfig +++ b/configs/taurus_defconfig @@ -3,6 +3,7 @@ CONFIG_SPL_SYS_THUMB_BUILD=y # CONFIG_SPL_USE_ARCH_MEMCPY is not set # CONFIG_SPL_USE_ARCH_MEMSET is not set CONFIG_ARCH_AT91=y +CONFIG_SPL_LDSCRIPT="arch/$(ARCH)/cpu/u-boot-spl.lds" CONFIG_TARGET_TAURUS=y CONFIG_SPL_GPIO_SUPPORT=y CONFIG_SPL_LIBCOMMON_SUPPORT=y -- 2.13.3
Signed-off-by: Heiko Schocher hs@denx.de Reviewed-by: Philipp Tomsich philipp.tomsich@theobroma-systems.com
Dr. Philipp Tomsich
Heiko Schocher
