[PATCH] Revert "imx: imx8: apalis: switch to binman"
This reverts commit b8072ae848b73e89a73ba5b535324e4dc2793f37.
Signed-off-by: Stefano Babic sbabic@denx.de Reported-by: Marcel Ziswiler marcel.ziswiler@toradex.com --- arch/arm/dts/fsl-imx8qm-apalis-u-boot.dtsi | 2 -- arch/arm/mach-imx/imx8/Kconfig | 1 - configs/apalis-imx8_defconfig | 1 - 3 files changed, 4 deletions(-)
diff --git a/arch/arm/dts/fsl-imx8qm-apalis-u-boot.dtsi b/arch/arm/dts/fsl-imx8qm-apalis-u-boot.dtsi index 8fd0e33d2b..956d724979 100644 --- a/arch/arm/dts/fsl-imx8qm-apalis-u-boot.dtsi +++ b/arch/arm/dts/fsl-imx8qm-apalis-u-boot.dtsi @@ -3,8 +3,6 @@ * Copyright 2019 Toradex AG */
-#include "imx8qm-u-boot.dtsi" - &mu { u-boot,dm-pre-proper; }; diff --git a/arch/arm/mach-imx/imx8/Kconfig b/arch/arm/mach-imx/imx8/Kconfig index 91bd888308..37d12d1895 100644 --- a/arch/arm/mach-imx/imx8/Kconfig +++ b/arch/arm/mach-imx/imx8/Kconfig @@ -46,7 +46,6 @@ choice
config TARGET_APALIS_IMX8 bool "Support Apalis iMX8 module" - select BINMAN select BOARD_LATE_INIT select IMX8QM
diff --git a/configs/apalis-imx8_defconfig b/configs/apalis-imx8_defconfig index d0e24785ae..6226d50c8a 100644 --- a/configs/apalis-imx8_defconfig +++ b/configs/apalis-imx8_defconfig @@ -17,7 +17,6 @@ CONFIG_HAS_CUSTOM_SYS_INIT_SP_ADDR=y CONFIG_CUSTOM_SYS_INIT_SP_ADDR=0x80200000 CONFIG_REMAKE_ELF=y CONFIG_FIT=y -CONFIG_FIT_EXTERNAL_OFFSET=0x3000 CONFIG_FIT_VERBOSE=y CONFIG_OF_SYSTEM_SETUP=y CONFIG_LOG=y
Thanks Stefano. This way at least no completely defunct flash.bin gets generated.
As I do have further doubts about the whole topic I will continue on the discussion where the discussion is/was happening...
Acked-by: Marcel Ziswiler marcel.ziswiler@toradex.com
diff --git a/arch/arm/dts/fsl-imx8qm-apalis-u-boot.dtsi b/arch/arm/dts/fsl-imx8qm-apalis-u-boot.dtsi index 8fd0e33d2b..956d724979 100644 --- a/arch/arm/dts/fsl-imx8qm-apalis-u-boot.dtsi +++ b/arch/arm/dts/fsl-imx8qm-apalis-u-boot.dtsi @@ -3,8 +3,6 @@ * Copyright 2019 Toradex AG */ -#include "imx8qm-u-boot.dtsi" -Marcel Ziswiler marcel.ziswiler@toradex.com &mu { u-boot,dm-pre-proper; }; diff --git a/arch/arm/mach-imx/imx8/Kconfig b/arch/arm/mach-imx/imx8/Kconfig index 91bd888308..37d12d1895 100644 --- a/arch/arm/mach-imx/imx8/Kconfig +++ b/arch/arm/mach-imx/imx8/Kconfig @@ -46,7 +46,6 @@ choice config TARGET_APALIS_IMX8 bool "Support Apalis iMX8 module" - select BINMAN select BOARD_LATE_INIT select IMX8QM diff --git a/configs/apalis-imx8_defconfig b/configs/apalis-imx8_defconfig index d0e24785ae..6226d50c8a 100644 --- a/configs/apalis-imx8_defconfig +++ b/configs/apalis-imx8_defconfig @@ -17,7 +17,6 @@ CONFIG_HAS_CUSTOM_SYS_INIT_SP_ADDR=y CONFIG_CUSTOM_SYS_INIT_SP_ADDR=0x80200000 CONFIG_REMAKE_ELF=y CONFIG_FIT=y -CONFIG_FIT_EXTERNAL_OFFSET=0x3000 CONFIG_FIT_VERBOSE=y CONFIG_OF_SYSTEM_SETUP=y CONFIG_LOG=y
Sorry for that - patch slip in, I was aware it should not be merged. I merge at least in u-boot-imx, maybe it takes a while before sending PR to Tom.
Regards, Stefano
Signed-off-by: Stefano Babic sbabic@denx.de Reported-by: Marcel Ziswiler marcel.ziswiler@toradex.com Acked-by: Marcel Ziswiler marcel.ziswiler@toradex.com
I saw you had mentioned putting this in to the -imx tree, but given that I'm doing a -rc today I didn't want this to be missed, so I'm picking up up directly now. Applied to u-boot/master, thanks!
Marcel Ziswiler
Stefano Babic
