[PATCH 0/2] PWM backlight patches from 'Add DM support for omap PWM backlight' series
As suggested by Grygorii Strashko I have removed these patches from the 'Add DM support for omap PWM backlight' series and grouped them into this one. One of the two patches has already been reviewed by Simon Glass.
Dario Binacchi (2): video: backlight: fix pwm data structure description video: backlight: fix pwm's duty cycle calculation
drivers/video/pwm_backlight.c | 4 ++-- test/dm/panel.c | 12 ++++++------ 2 files changed, 8 insertions(+), 8 deletions(-)
The description of the 'max_level' field was incorrectly assigned to the 'min_level' field.
Signed-off-by: Dario Binacchi dariobin@libero.it ---
drivers/video/pwm_backlight.c | 2 +- 1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/drivers/video/pwm_backlight.c b/drivers/video/pwm_backlight.c index 468a5703bd..acfde7ba3d 100644 --- a/drivers/video/pwm_backlight.c +++ b/drivers/video/pwm_backlight.c @@ -33,7 +33,7 @@ * @cur_level: Current level for the backlight (index or value) * @default_level: Default level for the backlight (index or value) * @min_level: Minimum level of the backlight (full off) - * @min_level: Maximum level of the backlight (full on) + * @max_level: Maximum level of the backlight (full on) * @enabled: true if backlight is enabled */ struct pwm_backlight_priv {
For levels equal to the maximum value, the duty cycle must be equal to the period.
Signed-off-by: Dario Binacchi dariobin@libero.it Reviewed-by: Simon Glass sjg@chromium.org
drivers/video/pwm_backlight.c | 2 +- test/dm/panel.c | 12 ++++++------ 2 files changed, 7 insertions(+), 7 deletions(-)
diff --git a/drivers/video/pwm_backlight.c b/drivers/video/pwm_backlight.c index acfde7ba3d..9519180ceb 100644 --- a/drivers/video/pwm_backlight.c +++ b/drivers/video/pwm_backlight.c @@ -63,7 +63,7 @@ static int set_pwm(struct pwm_backlight_priv *priv) int ret;
duty_cycle = priv->period_ns * (priv->cur_level - priv->min_level) / - (priv->max_level - priv->min_level + 1); + (priv->max_level - priv->min_level); ret = pwm_set_config(priv->pwm, priv->channel, priv->period_ns, duty_cycle); if (ret) diff --git a/test/dm/panel.c b/test/dm/panel.c index a840fb4951..49f5ac7169 100644 --- a/test/dm/panel.c +++ b/test/dm/panel.c @@ -40,7 +40,7 @@ static int dm_test_panel(struct unit_test_state *uts) ut_assertok(sandbox_pwm_get_config(pwm, 0, &period_ns, &duty_ns, &enable, &polarity)); ut_asserteq(1000, period_ns); - ut_asserteq(170 * 1000 / 256, duty_ns); + ut_asserteq(170 * 1000 / 255, duty_ns); ut_asserteq(true, enable); ut_asserteq(false, polarity); ut_asserteq(1, sandbox_gpio_get_value(gpio, 1)); @@ -49,29 +49,29 @@ static int dm_test_panel(struct unit_test_state *uts) ut_assertok(panel_set_backlight(dev, 40)); ut_assertok(sandbox_pwm_get_config(pwm, 0, &period_ns, &duty_ns, &enable, &polarity)); - ut_asserteq(64 * 1000 / 256, duty_ns); + ut_asserteq(64 * 1000 / 255, duty_ns);
ut_assertok(panel_set_backlight(dev, BACKLIGHT_MAX)); ut_assertok(sandbox_pwm_get_config(pwm, 0, &period_ns, &duty_ns, &enable, &polarity)); - ut_asserteq(255 * 1000 / 256, duty_ns); + ut_asserteq(255 * 1000 / 255, duty_ns);
ut_assertok(panel_set_backlight(dev, BACKLIGHT_MIN)); ut_assertok(sandbox_pwm_get_config(pwm, 0, &period_ns, &duty_ns, &enable, &polarity)); - ut_asserteq(0 * 1000 / 256, duty_ns); + ut_asserteq(0 * 1000 / 255, duty_ns); ut_asserteq(1, sandbox_gpio_get_value(gpio, 1));
ut_assertok(panel_set_backlight(dev, BACKLIGHT_DEFAULT)); ut_assertok(sandbox_pwm_get_config(pwm, 0, &period_ns, &duty_ns, &enable, &polarity)); ut_asserteq(true, enable); - ut_asserteq(170 * 1000 / 256, duty_ns); + ut_asserteq(170 * 1000 / 255, duty_ns);
ut_assertok(panel_set_backlight(dev, BACKLIGHT_OFF)); ut_assertok(sandbox_pwm_get_config(pwm, 0, &period_ns, &duty_ns, &enable, &polarity)); - ut_asserteq(0 * 1000 / 256, duty_ns); + ut_asserteq(0 * 1000 / 255, duty_ns); ut_asserteq(0, sandbox_gpio_get_value(gpio, 1)); ut_asserteq(false, regulator_get_enable(reg));
Anatolij Gustschin
Dario Binacchi
