[U-Boot-Users] [PATCH] Add a oftdump (open firmware flattened tree dump) command.
Git repository: http://www.cideas.us/cgi-bin/gitweb.cgi?p=u-boot/u-boot-of-cmd.git;a=summary
Branch: of-cmd http://www.cideas.us/cgi-bin/gitweb.cgi?p=u-boot/u-boot-of-cmd.git;a=shortlog;h=of-cmd
Signed-off-by: Jerry Van Baren vanbaren@cideas.com
From 20328071e132c40c662ffb2a07460144841b9e1a Mon Sep 17 00:00:00 2001
From: Jerry Van Baren vanbaren@cideas.com Date: Mon, 30 Oct 2006 21:47:02 -0500 Subject: [PATCH] Add a oftdump (open firmware flattened tree dump) command. --- common/Makefile | 2 +- common/cmd_bootm.c | 2 -- common/cmd_oftdump.c | 58 +++++++++++++++++++++++++++++++++++++++++++++ common/ft_build.c | 65 ++++++++++++++++++++++++++++++++++++++++++-------- include/ft_build.h | 2 +- 5 files changed, 114 insertions(+), 15 deletions(-)
diff --git a/common/Makefile b/common/Makefile index 07ddc95..477aadb 100644 --- a/common/Makefile +++ b/common/Makefile @@ -37,7 +37,7 @@ COBJS = main.o ACEX1K.o altera.o bedbug. cmd_i2c.o cmd_ide.o cmd_immap.o cmd_itest.o cmd_jffs2.o \ cmd_load.o cmd_log.o \ cmd_mem.o cmd_mii.o cmd_misc.o cmd_mmc.o \ - cmd_nand.o cmd_net.o cmd_nvedit.o \ + cmd_nand.o cmd_net.o cmd_nvedit.o cmd_oftdump.o \ cmd_pci.o cmd_pcmcia.o cmd_portio.o \ cmd_reginfo.o cmd_reiser.o cmd_scsi.o cmd_spi.o cmd_universe.o \ cmd_usb.o cmd_vfd.o \ diff --git a/common/cmd_bootm.c b/common/cmd_bootm.c index 3091a58..1797328 100644 --- a/common/cmd_bootm.c +++ b/common/cmd_bootm.c @@ -950,7 +950,6 @@ #else /* CONFIG_OF_FLAT_TREE */ }
ft_setup(of_flat_tree, kbd, initrd_start, initrd_end); - /* ft_dump_blob(of_flat_tree); */
#if defined(CFG_INIT_RAM_LOCK) && !defined(CONFIG_E500) unlock_ram_in_cache(); @@ -968,7 +967,6 @@ #endif cmd_start, cmd_end); else { ft_setup(of_flat_tree, kbd, initrd_start, initrd_end); - /* ft_dump_blob(of_flat_tree); */ (*kernel) ((bd_t *)of_flat_tree, (ulong)kernel, 0, 0, 0); } #endif /* CONFIG_OF_FLAT_TREE */ diff --git a/common/cmd_oftdump.c b/common/cmd_oftdump.c new file mode 100644 index 0000000..5cc1995 --- /dev/null +++ b/common/cmd_oftdump.c @@ -0,0 +1,58 @@ +/* + * (C) Copyright 2006 + * Gerald Van Baren, Custom IDEAS, vanbaren@cideas.com. + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + */ + +/* + * Misc functions + */ +#include <common.h> +#include <command.h> +#include <ft_build.h> + +#ifdef CONFIG_OF_FLAT_TREE + +int do_oftdump (cmd_tbl_t *cmdtp, int flag, int argc, char *argv[]) +{ + void *p = (void *)simple_strtoul(argv[1], NULL, 16); + + if (argc < 2) { + printf ("Usage:\n%s\n", cmdtp->usage); + return 1; + } else if (argc == 2) { + ft_dump_blob(p, "/"); + } else { + ft_dump_blob(p, argv[2]); + } + + return 0; +} + + +U_BOOT_CMD( + oftdump, 3, 0, do_oftdump, + "oftdump - Open Firmware flattened tree dump\n", + "oftdump <addr> - Dump the whole OF flattened tree\n" + "oftdump <addr> <prop> - Dump the given OF property\n" +); + +#endif /* CONFIG_OF_FLAT_TREE */ + diff --git a/common/ft_build.c b/common/ft_build.c index 980e40f..4fbe34c 100644 --- a/common/ft_build.c +++ b/common/ft_build.c @@ -233,10 +233,19 @@ static void print_data(const void *data, printf(" = <%04x>", be16_to_cpu(*(u16 *) data) & 0xffff); break; case 4: /* word */ - printf(" = <%x>", be32_to_cpu(*(u32 *) data) & 0xffffffffU); + printf(" = <%08x>", be32_to_cpu(*(u32 *) data) & 0xffffffffU); break; case 8: /* double-word */ - printf(" = <%qx>", be64_to_cpu(*(uint64_t *) data)); + /* + * If 64 bit printing is supported, use it. + */ +#ifdef CFG_64BIT_VSPRINTF + printf(" = <%016llx>", be64_to_cpu(*(uint64_t *) data)); +#else + printf(" = <%08x", be32_to_cpu(*(u32 *) data) & 0xffffffffU); + data += sizeof(u32); + printf(" %08x>", be32_to_cpu(*(u32 *) data) & 0xffffffffU); +#endif break; default: /* anything else... hexdump */ printf(" = ["); @@ -248,7 +257,12 @@ static void print_data(const void *data, } }
-void ft_dump_blob(const void *bphp) +/* + * Used by ft_dump_blob() and ft_get_prop() to build up property names + */ +static char path[256], prop[256]; + +void ft_dump_blob(const void *bphp, const char *propname) { const struct boot_param_header *bph = bphp; const uint64_t *p_rsvmap = (const uint64_t *) @@ -260,17 +274,22 @@ void ft_dump_blob(const void *bphp) u32 tag; const u32 *p; const char *s, *t; + char *ss; int depth, sz, shift; + int found; int i; uint64_t addr, size;
if (be32_to_cpu(bph->magic) != OF_DT_HEADER) { /* not valid tree */ + printf("Not a valid tree.\n"); return; }
depth = 0; shift = 4; + found = 0; + strcpy(path, "/");
for (i = 0;; i++) { addr = be64_to_cpu(p_rsvmap[i * 2]); @@ -290,7 +309,17 @@ void ft_dump_blob(const void *bphp) s = (const char *)p; p = (u32 *) _ALIGN((unsigned long)p + strlen(s) + 1, 4);
- printf("%*s%s {\n", depth * shift, "", s); + strcat(path, s); + if (found || (strcmp(path, propname) == 0)) { + found++; + if (depth == 0) + printf("/ {\n"); + else + printf("%*s%s {\n", depth * shift, "", s); + } + /* The root path is already there as "/" */ + if(depth != 0) + strcat(path, "/");
depth++; continue; @@ -299,7 +328,16 @@ void ft_dump_blob(const void *bphp) if (tag == OF_DT_END_NODE) { depth--;
- printf("%*s};\n", depth * shift, ""); + path[strlen(path) - 1] = '\0'; + ss = strrchr(path, '/'); + if (ss != NULL) + ss[1] = '\0'; + + if(found) { + printf("%*s};\n", depth * shift, ""); + if (found-- == 0) + return; /* request done */ + } continue; }
@@ -317,9 +355,15 @@ void ft_dump_blob(const void *bphp) s = (const char *)p_strings + be32_to_cpu(*p++); t = (const char *)p; p = (const u32 *)_ALIGN((unsigned long)p + sz, 4); - printf("%*s%s", depth * shift, "", s); - print_data(t, sz); - printf(";\n"); + + strcpy(prop, path); + strcat(prop, s); + + if(found || (strcmp(prop, propname) == 0)) { + printf("%*s%s", depth * shift, "", s); + print_data(t, sz); + printf(";\n"); + } } }
@@ -349,7 +393,6 @@ void *ft_get_prop(void *bphp, const char char *s, *t; char *ss; int sz; - static char path[256], prop[256];
path[0] = '\0';
@@ -478,7 +521,7 @@ #endif
#ifdef DEBUG printf ("recieved oftree\n"); - ft_dump_blob(blob); + ft_dump_blob(blob, "/"); #endif
ft_init_cxt(&cxt, blob); @@ -585,7 +628,7 @@ #endif
#ifdef DEBUG printf("final OF-tree\n"); - ft_dump_blob(blob); + ft_dump_blob(blob, "/"); #endif } #endif diff --git a/include/ft_build.h b/include/ft_build.h index 89c689c..5530122 100644 --- a/include/ft_build.h +++ b/include/ft_build.h @@ -58,7 +58,7 @@ void ft_add_rsvmap(struct ft_cxt *cxt, u
void ft_setup(void *blob, bd_t * bd, ulong initrd_start, ulong initrd_end);
-void ft_dump_blob(const void *bphp); +void ft_dump_blob(const void *bphp, const char *propname); void ft_merge_blob(struct ft_cxt *cxt, void *blob); void *ft_get_prop(void *bphp, const char *propname, int *szp);
Not that I have any authority on this, but I'm going to NAK it (for right now). Others may disagree.
The global statics really bother me, and I'll take a look myself if there is a better way. Give me a few days.
Cheers, g.
- (C) Copyright 2006
- Gerald Van Baren, Custom IDEAS, vanbaren@cideas.com.
- project.
- MA 02111-1307 USA
- Misc functions
if (argc < 2) {
return 1;
} else {
+U_BOOT_CMD(
+#else
- Used by ft_dump_blob() and ft_get_prop() to build up property names
int found; int i; uint64_t addr, size; if (be32_to_cpu(bph->magic) != OF_DT_HEADER) { /* not valid tree */
printf("Not a valid tree.\n"); return; } depth = 0; shift = 4;
found = 0;
strcpy(path, "/"); for (i = 0;; i++) { addr = be64_to_cpu(p_rsvmap[i * 2]);
strcat(path, s);
found++;
if (depth == 0)
printf("/ {\n");
else
if(depth != 0)
strcat(path, "/"); depth++; continue;
if (ss != NULL)
ss[1] = '\0';
if(found) {
if (found-- == 0)
} continue; }
print_data(t, sz);
printf(";\n");
strcpy(prop, path);
strcat(prop, s);
print_data(t, sz);
printf(";\n");
static char path[256], prop[256]; path[0] = '\0';
ft_dump_blob(blob);
#endif
ft_dump_blob(blob);
-- 1.4.1.1
Using Tomcat but need to do more? Need to support web services, security? Get stuff done quickly with pre-integrated technology to make your job easier Download IBM WebSphere Application Server v.1.0.1 based on Apache Geronimo http://sel.as-us.falkag.net/sel?cmd=lnk&kid=120709&bid=263057&da...
U-Boot-Users mailing list U-Boot-Users@lists.sourceforge.net https://lists.sourceforge.net/lists/listinfo/u-boot-users
Cheers, g.
Hi Grant,
Global static is a oxymoron, they are "global" only in the ft_build.c file starting at ft_dump_blob() and going to the end of the file. I suspect what you are concerned about is the shared aspect, which isn't a problem in u-boot since it is single threaded.
There are three choices: 1) "Global statics" - easiest and least memory use, but makes Good Engineers[tm] queasy. 2) "Duplicate" the arrays (currently 2x256, becomes 4x256) as statics inside the two functions - uses 2x the memory with no benefit (still makes Good Engineers[tm] queasy, just a different queasy). 3) More clever matching on the parameter string vs. the OF blob where the string is built up - I bailed out on this, but it is the best solution.
I know your type, you are just challenging me to actually do #3. ;-)
Best regards, gvb
- "Global statics" - easiest and least memory use, but makes Good
I see your ;-) and raise you a :-P
g.
Grant Likely
Jerry Van Baren
