[U-Boot] Pull request: u-boot-spi/master
Hi Tom,
Please take this series.
thanks! Jagan.
The following changes since commit e8009beff6d5c55c1bf1ae8184791f167e6378b0:
Merge git://git.denx.de/u-boot-arc (2016-07-04 11:46:21 -0400)
git://git.denx.de/u-boot-spi.git master
for you to fetch changes up to 96907c0fe50a856f66f60ade68864a2d7949bf15:
dm: spi: Read default speed and mode values from DT (2016-07-09 20:16:34 +0530)
---------------------------------------------------------------- Anatolij Gustschin (1): spi: spi-uclass: fix typo in debug output
Vignesh R (18): dm: core: implement dev_map_physmem() spi: davinci_spi: Convert to driver to adapt to DM keystone2: spi: do not define DM_SPI and DM_SPI_FLASH for SPL build ARM: dts: keystone2: add SPI aliases for davinci SPI nodes ARM: dts: k2hk: Enable Davinci SPI controller defconfig: k2hk_evm_defconfig: enable SPI driver model ARM: dts: k2e: Enable Davinci SPI controller defconfig: k2e_evm_defconfig: enable SPI driver model ARM: dts: k2l: Enable Davinci SPI controller defconfig: k2l_evm_defconfig: enable SPI driver model ARM: dts: k2g: add support for Davinci SPI controller defconfig: k2g_evm_defconfig: enable SPI driver model spi: cadence_qspi_apb: Support 32 bit AHB address spi: cadence_quadspi: Enable QUAD mode based on DT data ARM: dts: K2G: Add support for QSPI controller defconfig: k2g_evm_defconfig: Enable Cadence QSPI controller ARM: dts: dra7x: Support QSPI MODE-0 operation at 64MHz dm: spi: Read default speed and mode values from DT
arch/arm/dts/dra7-evm.dts | 6 +- arch/arm/dts/dra72-evm.dts | 6 +- arch/arm/dts/k2e-evm.dts | 3 +- arch/arm/dts/k2g-evm.dts | 69 ++++++++ arch/arm/dts/k2g.dtsi | 61 +++++++ arch/arm/dts/k2hk-evm.dts | 3 +- arch/arm/dts/k2l-evm.dts | 3 +- arch/arm/dts/keystone.dtsi | 3 + cmd/sf.c | 2 + common/env_sf.c | 8 +- configs/k2e_evm_defconfig | 2 + configs/k2g_evm_defconfig | 4 + configs/k2hk_evm_defconfig | 2 + configs/k2l_evm_defconfig | 2 + drivers/core/device.c | 11 ++ drivers/spi/cadence_qspi.c | 3 +- drivers/spi/cadence_qspi.h | 2 +- drivers/spi/cadence_qspi_apb.c | 15 +- drivers/spi/davinci_spi.c | 329 +++++++++++++++++++++++++---------- drivers/spi/spi-uclass.c | 10 +- include/configs/k2g_evm.h | 6 + include/configs/ti_armv7_keystone2.h | 4 + include/dm/device.h | 13 ++ 23 files changed, 450 insertions(+), 117 deletions(-)
On Sat, Jul 09, 2016 at 09:00:16PM +0530, Jagan Teki wrote:
Hi Tom,
We are about 2 days from release. None of these changes are clearly critical for release bug fixes. I will pick this up after the release, thanks.
thanks! Jagan.
Hi Tom,
thanks! Jagan.
Jagan Teki
