[U-Boot] [PATCH 1/3] ARM: dts: uniphier: sync with Linux
This commit imports device tree updates from Linux. It eventually adds pinctrl-related nodes and properties.
Signed-off-by: Masahiro Yamada yamada.masahiro@socionext.com ---
arch/arm/dts/uniphier-ph1-ld4-ref.dts | 22 ++++--- arch/arm/dts/uniphier-ph1-ld4.dtsi | 95 +++++++++++++++++++++++------ arch/arm/dts/uniphier-ph1-pro4-ref.dts | 30 ++++++--- arch/arm/dts/uniphier-ph1-pro4.dtsi | 108 +++++++++++++++++++++++++++------ arch/arm/dts/uniphier-ph1-sld3-ref.dts | 32 +++++++--- arch/arm/dts/uniphier-ph1-sld3.dtsi | 66 ++++++++++++++------ arch/arm/dts/uniphier-ph1-sld8-ref.dts | 26 +++++--- arch/arm/dts/uniphier-ph1-sld8.dtsi | 95 +++++++++++++++++++++++------ arch/arm/dts/uniphier-pinctrl.dtsi | 105 ++++++++++++++++++++++++++++++++ 9 files changed, 472 insertions(+), 107 deletions(-) create mode 100644 arch/arm/dts/uniphier-pinctrl.dtsi
diff --git a/arch/arm/dts/uniphier-ph1-ld4-ref.dts b/arch/arm/dts/uniphier-ph1-ld4-ref.dts index 7c36581..20f2e9a 100644 --- a/arch/arm/dts/uniphier-ph1-ld4-ref.dts +++ b/arch/arm/dts/uniphier-ph1-ld4-ref.dts @@ -20,15 +20,15 @@ };
chosen { - bootargs = "console=ttyPS0,115200 earlyprintk"; - stdout-path = &uart0; + bootargs = "console=ttyS0,115200"; + stdout-path = &serial0; };
aliases { - serial0 = &uart0; - serial1 = &uart1; - serial2 = &uart2; - serial3 = &uart3; + serial0 = &serial0; + serial1 = &serial1; + serial2 = &serial2; + serial3 = &serial3; i2c0 = &i2c0; i2c1 = &i2c1; i2c2 = &i2c2; @@ -36,11 +36,15 @@ }; };
-&uart0 { +&serial0 { status = "okay"; };
-&uart1 { +&serial2 { + status = "okay"; +}; + +&serial3 { status = "okay"; };
@@ -57,6 +61,6 @@ };
/* for U-boot only */ -&uart0 { +&serial0 { u-boot,dm-pre-reloc; }; diff --git a/arch/arm/dts/uniphier-ph1-ld4.dtsi b/arch/arm/dts/uniphier-ph1-ld4.dtsi index 39d7b24..5f12e10 100644 --- a/arch/arm/dts/uniphier-ph1-ld4.dtsi +++ b/arch/arm/dts/uniphier-ph1-ld4.dtsi @@ -28,6 +28,18 @@ compatible = "fixed-clock"; clock-frequency = <50000000>; }; + + uart_clk: uart_clk { + #clock-cells = <0>; + compatible = "fixed-clock"; + clock-frequency = <36864000>; + }; + + iobus_clk: iobus_clk { + #clock-cells = <0>; + compatible = "fixed-clock"; + clock-frequency = <100000000>; + }; };
soc { @@ -43,68 +55,100 @@ #size-cells = <1>; };
- uart0: serial@54006800 { + serial0: serial@54006800 { compatible = "socionext,uniphier-uart"; status = "disabled"; - reg = <0x54006800 0x20>; + reg = <0x54006800 0x40>; + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_uart0>; + interrupts = <0 33 4>; + clocks = <&uart_clk>; clock-frequency = <36864000>; };
- uart1: serial@54006900 { + serial1: serial@54006900 { compatible = "socionext,uniphier-uart"; status = "disabled"; - reg = <0x54006900 0x20>; + reg = <0x54006900 0x40>; + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_uart1>; + interrupts = <0 35 4>; + clocks = <&uart_clk>; clock-frequency = <36864000>; };
- uart2: serial@54006a00 { + serial2: serial@54006a00 { compatible = "socionext,uniphier-uart"; status = "disabled"; - reg = <0x54006a00 0x20>; + reg = <0x54006a00 0x40>; + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_uart2>; + interrupts = <0 37 4>; + clocks = <&uart_clk>; clock-frequency = <36864000>; };
- uart3: serial@54006b00 { + serial3: serial@54006b00 { compatible = "socionext,uniphier-uart"; status = "disabled"; - reg = <0x54006b00 0x20>; + reg = <0x54006b00 0x40>; + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_uart3>; + interrupts = <0 29 4>; + clocks = <&uart_clk>; clock-frequency = <36864000>; };
i2c0: i2c@58400000 { compatible = "socionext,uniphier-i2c"; + status = "disabled"; + reg = <0x58400000 0x40>; #address-cells = <1>; #size-cells = <0>; - reg = <0x58400000 0x40>; + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_i2c0>; + interrupts = <0 41 1>; + clocks = <&iobus_clk>; clock-frequency = <100000>; - status = "disabled"; };
i2c1: i2c@58480000 { compatible = "socionext,uniphier-i2c"; + status = "disabled"; + reg = <0x58480000 0x40>; #address-cells = <1>; #size-cells = <0>; - reg = <0x58480000 0x40>; + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_i2c1>; + interrupts = <0 42 1>; + clocks = <&iobus_clk>; clock-frequency = <100000>; - status = "disabled"; };
+ /* chip-internal connection for DMD */ i2c2: i2c@58500000 { compatible = "socionext,uniphier-i2c"; + reg = <0x58500000 0x40>; #address-cells = <1>; #size-cells = <0>; - reg = <0x58500000 0x40>; - clock-frequency = <100000>; - status = "disabled"; + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_i2c2>; + interrupts = <0 43 1>; + clocks = <&iobus_clk>; + clock-frequency = <400000>; };
i2c3: i2c@58580000 { compatible = "socionext,uniphier-i2c"; + status = "disabled"; + reg = <0x58580000 0x40>; #address-cells = <1>; #size-cells = <0>; - reg = <0x58580000 0x40>; + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_i2c3>; + interrupts = <0 44 1>; + clocks = <&iobus_clk>; clock-frequency = <100000>; - status = "disabled"; };
system-bus-controller-misc@59800000 { @@ -117,18 +161,33 @@ compatible = "socionext,uniphier-ehci", "generic-ehci"; status = "disabled"; reg = <0x5a800100 0x100>; + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_usb0>; + interrupts = <0 80 4>; };
usb1: usb@5a810100 { compatible = "socionext,uniphier-ehci", "generic-ehci"; status = "disabled"; reg = <0x5a810100 0x100>; + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_usb1>; + interrupts = <0 81 4>; };
usb2: usb@5a820100 { compatible = "socionext,uniphier-ehci", "generic-ehci"; status = "disabled"; reg = <0x5a820100 0x100>; + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_usb2>; + interrupts = <0 82 4>; + }; + + pinctrl: pinctrl@5f801000 { + compatible = "socionext,ph1-ld4-pinctrl", + "syscon"; + reg = <0x5f801000 0xe00>; };
timer@60000200 { @@ -160,3 +219,5 @@ }; }; }; + +/include/ "uniphier-pinctrl.dtsi" diff --git a/arch/arm/dts/uniphier-ph1-pro4-ref.dts b/arch/arm/dts/uniphier-ph1-pro4-ref.dts index fd3e8c6..ec1117d 100644 --- a/arch/arm/dts/uniphier-ph1-pro4-ref.dts +++ b/arch/arm/dts/uniphier-ph1-pro4-ref.dts @@ -20,15 +20,15 @@ };
aliases { - serial0 = &uart0; - serial1 = &uart1; - serial2 = &uart2; - serial3 = &uart3; + serial0 = &serial0; + serial1 = &serial1; + serial2 = &serial2; + serial3 = &serial3; i2c0 = &i2c0; i2c1 = &i2c1; i2c2 = &i2c2; @@ -39,11 +39,15 @@ }; };
-&uart1 { +&serial1 { + status = "okay"; +}; + +&serial2 { status = "okay"; };
@@ -55,7 +59,15 @@ status = "okay"; };
+&usb2 { + status = "okay"; +}; + +&usb3 { + status = "okay"; +}; + /* for U-boot only */ -&uart0 { +&serial0 { u-boot,dm-pre-reloc; }; diff --git a/arch/arm/dts/uniphier-ph1-pro4.dtsi b/arch/arm/dts/uniphier-ph1-pro4.dtsi index f06906c..a57f8ae 100644 --- a/arch/arm/dts/uniphier-ph1-pro4.dtsi +++ b/arch/arm/dts/uniphier-ph1-pro4.dtsi @@ -35,6 +35,18 @@ compatible = "fixed-clock"; clock-frequency = <50000000>; }; + + uart_clk: uart_clk { + #clock-cells = <0>; + compatible = "fixed-clock"; + clock-frequency = <73728000>; + }; + + i2c_clk: i2c_clk { + #clock-cells = <0>; + compatible = "fixed-clock"; + clock-frequency = <50000000>; + }; };
soc { @@ -50,88 +62,124 @@ #size-cells = <1>; };
- uart0: serial@54006800 { + serial0: serial@54006800 { compatible = "socionext,uniphier-uart"; status = "disabled"; - reg = <0x54006800 0x20>; + reg = <0x54006800 0x40>; + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_uart0>; + interrupts = <0 33 4>; + clocks = <&uart_clk>; clock-frequency = <73728000>; };
- uart1: serial@54006900 { + serial1: serial@54006900 { compatible = "socionext,uniphier-uart"; status = "disabled"; - reg = <0x54006900 0x20>; + reg = <0x54006900 0x40>; + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_uart1>; + interrupts = <0 35 4>; + clocks = <&uart_clk>; clock-frequency = <73728000>; };
- uart2: serial@54006a00 { + serial2: serial@54006a00 { compatible = "socionext,uniphier-uart"; status = "disabled"; - reg = <0x54006a00 0x20>; + reg = <0x54006a00 0x40>; + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_uart2>; + interrupts = <0 37 4>; + clocks = <&uart_clk>; clock-frequency = <73728000>; };
- uart3: serial@54006b00 { + serial3: serial@54006b00 { compatible = "socionext,uniphier-uart"; status = "disabled"; - reg = <0x54006b00 0x20>; + reg = <0x54006b00 0x40>; + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_uart3>; + interrupts = <0 29 4>; + clocks = <&uart_clk>; clock-frequency = <73728000>; };
i2c0: i2c@58780000 { compatible = "socionext,uniphier-fi2c"; + status = "disabled"; + reg = <0x58780000 0x80>; #address-cells = <1>; #size-cells = <0>; - reg = <0x58780000 0x80>; + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_i2c0>; + interrupts = <0 41 4>; + clocks = <&i2c_clk>; clock-frequency = <100000>; - status = "disabled"; };
i2c1: i2c@58781000 { compatible = "socionext,uniphier-fi2c"; + status = "disabled"; + reg = <0x58781000 0x80>; #address-cells = <1>; #size-cells = <0>; - reg = <0x58781000 0x80>; + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_i2c1>; + interrupts = <0 42 4>; + clocks = <&i2c_clk>; clock-frequency = <100000>; - status = "disabled"; };
i2c2: i2c@58782000 { compatible = "socionext,uniphier-fi2c"; + status = "disabled"; + reg = <0x58782000 0x80>; #address-cells = <1>; #size-cells = <0>; - reg = <0x58782000 0x80>; + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_i2c2>; + interrupts = <0 43 4>; + clocks = <&i2c_clk>; clock-frequency = <100000>; - status = "disabled"; };
i2c3: i2c@58783000 { compatible = "socionext,uniphier-fi2c"; + status = "disabled"; + reg = <0x58783000 0x80>; #address-cells = <1>; #size-cells = <0>; - reg = <0x58783000 0x80>; + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_i2c3>; + interrupts = <0 44 4>; + clocks = <&i2c_clk>; clock-frequency = <100000>; - status = "disabled"; };
/* i2c4 does not exist */
+ /* chip-internal connection for DMD */ i2c5: i2c@58785000 { compatible = "socionext,uniphier-fi2c"; + reg = <0x58785000 0x80>; #address-cells = <1>; #size-cells = <0>; - reg = <0x58785000 0x80>; + interrupts = <0 25 4>; + clocks = <&i2c_clk>; clock-frequency = <400000>; - status = "ok"; };
+ /* chip-internal connection for HDMI */ i2c6: i2c@58786000 { compatible = "socionext,uniphier-fi2c"; + reg = <0x58786000 0x80>; #address-cells = <1>; #size-cells = <0>; - reg = <0x58786000 0x80>; + interrupts = <0 26 4>; + clocks = <&i2c_clk>; clock-frequency = <400000>; - status = "ok"; };
system-bus-controller-misc@59800000 { @@ -144,24 +192,42 @@ compatible = "socionext,uniphier-ehci", "generic-ehci"; status = "disabled"; reg = <0x5a800100 0x100>; + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_usb2>; + interrupts = <0 80 4>; };
usb3: usb@5a810100 { compatible = "socionext,uniphier-ehci", "generic-ehci"; status = "disabled"; reg = <0x5a810100 0x100>; + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_usb3>; + interrupts = <0 81 4>; };
usb0: usb@65a00000 { compatible = "socionext,uniphier-xhci", "generic-xhci"; status = "disabled"; reg = <0x65a00000 0x100>; + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_usb0>; + interrupts = <0 134 4>; };
usb1: usb@65c00000 { compatible = "socionext,uniphier-xhci", "generic-xhci"; status = "disabled"; reg = <0x65c00000 0x100>; + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_usb1>; + interrupts = <0 135 4>; + }; + + pinctrl: pinctrl@5f801000 { + compatible = "socionext,ph1-pro4-pinctrl", + "syscon"; + reg = <0x5f801000 0xe00>; };
timer@60000200 { @@ -193,3 +259,5 @@ }; }; }; + +/include/ "uniphier-pinctrl.dtsi" diff --git a/arch/arm/dts/uniphier-ph1-sld3-ref.dts b/arch/arm/dts/uniphier-ph1-sld3-ref.dts index 2406bfc..c760b6d 100644 --- a/arch/arm/dts/uniphier-ph1-sld3-ref.dts +++ b/arch/arm/dts/uniphier-ph1-sld3-ref.dts @@ -16,30 +16,36 @@
memory { device_type = "memory"; - reg = <0x80000000 0x40000000>; + reg = <0x80000000 0x20000000 + 0xc0000000 0x20000000>; };
aliases { - serial0 = &uart0; - serial1 = &uart1; - serial2 = &uart2; + serial0 = &serial0; + serial1 = &serial1; + serial2 = &serial2; i2c0 = &i2c0; i2c1 = &i2c1; i2c2 = &i2c2; i2c3 = &i2c3; + i2c4 = &i2c4; }; };
@@ -55,7 +61,15 @@ status = "okay"; };
+&usb2 { + status = "okay"; +}; + +&usb3 { + status = "okay"; +}; + /* for U-boot only */ -&uart0 { +&serial0 { u-boot,dm-pre-reloc; }; diff --git a/arch/arm/dts/uniphier-ph1-sld3.dtsi b/arch/arm/dts/uniphier-ph1-sld3.dtsi index 5e29436..f481521 100644 --- a/arch/arm/dts/uniphier-ph1-sld3.dtsi +++ b/arch/arm/dts/uniphier-ph1-sld3.dtsi @@ -35,6 +35,18 @@ compatible = "fixed-clock"; clock-frequency = <50000000>; }; + + uart_clk: uart_clk { + #clock-cells = <0>; + compatible = "fixed-clock"; + clock-frequency = <36864000>; + }; + + iobus_clk: iobus_clk { + #clock-cells = <0>; + compatible = "fixed-clock"; + clock-frequency = <100000000>; + }; };
soc { @@ -72,70 +84,86 @@ <0x20000100 0x100>; };
- uart0: serial@54006800 { + serial0: serial@54006800 { compatible = "socionext,uniphier-uart"; status = "disabled"; - reg = <0x54006800 0x20>; + reg = <0x54006800 0x40>; + interrupts = <0 33 4>; + clocks = <&uart_clk>; clock-frequency = <36864000>; };
- uart1: serial@54006900 { + serial1: serial@54006900 { compatible = "socionext,uniphier-uart"; status = "disabled"; - reg = <0x54006900 0x20>; + reg = <0x54006900 0x40>; + interrupts = <0 35 4>; + clocks = <&uart_clk>; clock-frequency = <36864000>; };
- uart2: serial@54006a00 { + serial2: serial@54006a00 { compatible = "socionext,uniphier-uart"; status = "disabled"; - reg = <0x54006a00 0x20>; + reg = <0x54006a00 0x40>; + interrupts = <0 37 4>; + clocks = <&uart_clk>; clock-frequency = <36864000>; };
i2c0: i2c@58400000 { compatible = "socionext,uniphier-i2c"; + status = "disabled"; + reg = <0x58400000 0x40>; #address-cells = <1>; #size-cells = <0>; - reg = <0x58400000 0x40>; + interrupts = <0 41 1>; + clocks = <&iobus_clk>; clock-frequency = <100000>; - status = "disabled"; };
i2c1: i2c@58480000 { compatible = "socionext,uniphier-i2c"; + status = "disabled"; + reg = <0x58480000 0x40>; #address-cells = <1>; #size-cells = <0>; - reg = <0x58480000 0x40>; + interrupts = <0 42 1>; + clocks = <&iobus_clk>; clock-frequency = <100000>; - status = "disabled"; };
i2c2: i2c@58500000 { compatible = "socionext,uniphier-i2c"; + status = "disabled"; + reg = <0x58500000 0x40>; #address-cells = <1>; #size-cells = <0>; - reg = <0x58500000 0x40>; + interrupts = <0 43 1>; + clocks = <&iobus_clk>; clock-frequency = <100000>; - status = "disabled"; };
i2c3: i2c@58580000 { compatible = "socionext,uniphier-i2c"; + status = "disabled"; + reg = <0x58580000 0x40>; #address-cells = <1>; #size-cells = <0>; - reg = <0x58580000 0x40>; + interrupts = <0 44 1>; + clocks = <&iobus_clk>; clock-frequency = <100000>; - status = "disabled"; };
+ /* chip-internal connection for DMD */ i2c4: i2c@58600000 { - compatible = "panasonic,uniphier-i2c"; + compatible = "socionext,uniphier-i2c"; + reg = <0x58600000 0x40>; #address-cells = <1>; #size-cells = <0>; - reg = <0x58600000 0x40>; + interrupts = <0 45 1>; + clocks = <&iobus_clk>; clock-frequency = <400000>; - status = "okay"; };
system-bus-controller-misc@59800000 { @@ -148,24 +176,28 @@ compatible = "socionext,uniphier-ehci", "generic-ehci"; status = "disabled"; reg = <0x5a800100 0x100>; + interrupts = <0 80 4>; };
usb1: usb@5a810100 { compatible = "socionext,uniphier-ehci", "generic-ehci"; status = "disabled"; reg = <0x5a810100 0x100>; + interrupts = <0 81 4>; };
usb2: usb@5a820100 { compatible = "socionext,uniphier-ehci", "generic-ehci"; status = "disabled"; reg = <0x5a820100 0x100>; + interrupts = <0 82 4>; };
usb3: usb@5a830100 { compatible = "socionext,uniphier-ehci", "generic-ehci"; status = "disabled"; reg = <0x5a830100 0x100>; + interrupts = <0 83 4>; };
nand: nand@f8000000 { diff --git a/arch/arm/dts/uniphier-ph1-sld8-ref.dts b/arch/arm/dts/uniphier-ph1-sld8-ref.dts index b7ed275..6269f9a 100644 --- a/arch/arm/dts/uniphier-ph1-sld8-ref.dts +++ b/arch/arm/dts/uniphier-ph1-sld8-ref.dts @@ -20,15 +20,15 @@ };
@@ -56,7 +60,11 @@ status = "okay"; };
+&usb2 { + status = "okay"; +}; + /* for U-boot only */ -&uart0 { +&serial0 { u-boot,dm-pre-reloc; }; diff --git a/arch/arm/dts/uniphier-ph1-sld8.dtsi b/arch/arm/dts/uniphier-ph1-sld8.dtsi index 15df50f..7d06f7e 100644 --- a/arch/arm/dts/uniphier-ph1-sld8.dtsi +++ b/arch/arm/dts/uniphier-ph1-sld8.dtsi @@ -28,6 +28,18 @@ compatible = "fixed-clock"; clock-frequency = <50000000>; }; + + uart_clk: uart_clk { + #clock-cells = <0>; + compatible = "fixed-clock"; + clock-frequency = <80000000>; + }; + + iobus_clk: iobus_clk { + #clock-cells = <0>; + compatible = "fixed-clock"; + clock-frequency = <100000000>; + }; };
- uart0: serial@54006800 { + serial0: serial@54006800 { compatible = "socionext,uniphier-uart"; status = "disabled"; - reg = <0x54006800 0x20>; + reg = <0x54006800 0x40>; + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_uart0>; + interrupts = <0 33 4>; + clocks = <&uart_clk>; clock-frequency = <80000000>; };
- uart1: serial@54006900 { + serial1: serial@54006900 { compatible = "socionext,uniphier-uart"; status = "disabled"; - reg = <0x54006900 0x20>; + reg = <0x54006900 0x40>; + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_uart1>; + interrupts = <0 35 4>; + clocks = <&uart_clk>; clock-frequency = <80000000>; };
- uart2: serial@54006a00 { + serial2: serial@54006a00 { compatible = "socionext,uniphier-uart"; status = "disabled"; - reg = <0x54006a00 0x20>; + reg = <0x54006a00 0x40>; + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_uart2>; + interrupts = <0 37 4>; + clocks = <&uart_clk>; clock-frequency = <80000000>; };
- uart3: serial@54006b00 { + serial3: serial@54006b00 { compatible = "socionext,uniphier-uart"; status = "disabled"; - reg = <0x54006b00 0x20>; + reg = <0x54006b00 0x40>; + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_uart3>; + interrupts = <0 29 4>; + clocks = <&uart_clk>; clock-frequency = <80000000>; };
usb2: usb@5a820100 { compatible = "socionext,uniphier-ehci", "generic-ehci"; status = "disabled"; reg = <0x5a820100 0x100>; + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_usb2>; + interrupts = <0 82 4>; + }; + + pinctrl: pinctrl@5f801000 { + compatible = "socionext,ph1-sld8-pinctrl", + "syscon"; + reg = <0x5f801000 0xe00>; };
timer@60000200 { @@ -160,3 +219,5 @@ }; }; }; + +/include/ "uniphier-pinctrl.dtsi" diff --git a/arch/arm/dts/uniphier-pinctrl.dtsi b/arch/arm/dts/uniphier-pinctrl.dtsi new file mode 100644 index 0000000..f67445f --- /dev/null +++ b/arch/arm/dts/uniphier-pinctrl.dtsi @@ -0,0 +1,105 @@ +/* + * Device Tree Source for UniPhier SoCs default pinctrl settings + * + * Copyright (C) 2015 Masahiro Yamada yamada.masahiro@socionext.com + * + * This file is dual-licensed: you can use it either under the terms + * of the GPL or the X11 license, at your option. Note that this dual + * licensing only applies to this file, and not this project as a + * whole. + * + * a) This file is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of the + * License, or (at your option) any later version. + * + * This file is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * Or, alternatively, + * + * b) Permission is hereby granted, free of charge, to any person + * obtaining a copy of this software and associated documentation + * files (the "Software"), to deal in the Software without + * restriction, including without limitation the rights to use, + * copy, modify, merge, publish, distribute, sublicense, and/or + * sell copies of the Software, and to permit persons to whom the + * Software is furnished to do so, subject to the following + * conditions: + * + * The above copyright notice and this permission notice shall be + * included in all copies or substantial portions of the Software. + * + * THE SOFTWARE IS PROVIDED "AS IS", WITHOUT WARRANTY OF ANY KIND, + * EXPRESS OR IMPLIED, INCLUDING BUT NOT LIMITED TO THE WARRANTIES + * OF MERCHANTABILITY, FITNESS FOR A PARTICULAR PURPOSE AND + * NONINFRINGEMENT. IN NO EVENT SHALL THE AUTHORS OR COPYRIGHT + * HOLDERS BE LIABLE FOR ANY CLAIM, DAMAGES OR OTHER LIABILITY, + * WHETHER IN AN ACTION OF CONTRACT, TORT OR OTHERWISE, ARISING + * FROM, OUT OF OR IN CONNECTION WITH THE SOFTWARE OR THE USE OR + * OTHER DEALINGS IN THE SOFTWARE. + */ + +&pinctrl { + pinctrl_i2c0: i2c0_grp { + groups = "i2c0"; + function = "i2c0"; + }; + + pinctrl_i2c1: i2c1_grp { + groups = "i2c1"; + function = "i2c1"; + }; + + pinctrl_i2c2: i2c2_grp { + groups = "i2c2"; + function = "i2c2"; + }; + + pinctrl_i2c3: i2c3_grp { + groups = "i2c3"; + function = "i2c3"; + }; + + pinctrl_uart0: uart0_grp { + groups = "uart0"; + function = "uart0"; + }; + + pinctrl_uart1: uart1_grp { + groups = "uart1"; + function = "uart1"; + }; + + pinctrl_uart2: uart2_grp { + groups = "uart2"; + function = "uart2"; + }; + + pinctrl_uart3: uart3_grp { + groups = "uart3"; + function = "uart3"; + }; + + pinctrl_usb0: usb0_grp { + groups = "usb0"; + function = "usb0"; + }; + + pinctrl_usb1: usb1_grp { + groups = "usb1"; + function = "usb1"; + }; + + pinctrl_usb2: usb2_grp { + groups = "usb2"; + function = "usb2"; + }; + + pinctrl_usb3: usb3_grp { + groups = "usb3"; + function = "usb3"; + }; +};
Initial version of UniPhier PH1-Pro5 device tree.
(Imported from Linux with adjustment for SPDX License Identifier)
arch/arm/dts/uniphier-ph1-pro5.dtsi | 216 ++++++++++++++++++++++++++++++++++++ 1 file changed, 216 insertions(+) create mode 100644 arch/arm/dts/uniphier-ph1-pro5.dtsi
diff --git a/arch/arm/dts/uniphier-ph1-pro5.dtsi b/arch/arm/dts/uniphier-ph1-pro5.dtsi new file mode 100644 index 0000000..a15c7b2 --- /dev/null +++ b/arch/arm/dts/uniphier-ph1-pro5.dtsi @@ -0,0 +1,216 @@ +/* + * Device Tree Source for UniPhier PH1-Pro5 SoC + * + * Copyright (C) 2015 Masahiro Yamada yamada.masahiro@socionext.com + * + * SPDX-License-Identifier: GPL-2.0+ X11 + */ + +/include/ "skeleton.dtsi" + +/ { + compatible = "socionext,ph1-pro5"; + + cpus { + #address-cells = <1>; + #size-cells = <0>; + enable-method = "socionext,uniphier-smp"; + + cpu@0 { + device_type = "cpu"; + compatible = "arm,cortex-a9"; + reg = <0>; + }; + + cpu@1 { + device_type = "cpu"; + compatible = "arm,cortex-a9"; + reg = <1>; + }; + }; + + clocks { + arm_timer_clk: arm_timer_clk { + #clock-cells = <0>; + compatible = "fixed-clock"; + clock-frequency = <50000000>; + }; + + uart_clk: uart_clk { + #clock-cells = <0>; + compatible = "fixed-clock"; + clock-frequency = <73728000>; + }; + + i2c_clk: i2c_clk { + #clock-cells = <0>; + compatible = "fixed-clock"; + clock-frequency = <50000000>; + }; + }; + + soc { + compatible = "simple-bus"; + #address-cells = <1>; + #size-cells = <1>; + ranges; + interrupt-parent = <&intc>; + + extbus: extbus { + compatible = "simple-bus"; + #address-cells = <2>; + #size-cells = <1>; + }; + + serial0: serial@54006800 { + compatible = "socionext,uniphier-uart"; + status = "disabled"; + reg = <0x54006800 0x40>; + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_uart0>; + interrupts = <0 33 4>; + clocks = <&uart_clk>; + }; + + serial1: serial@54006900 { + compatible = "socionext,uniphier-uart"; + status = "disabled"; + reg = <0x54006900 0x40>; + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_uart1>; + interrupts = <0 35 4>; + clocks = <&uart_clk>; + }; + + serial2: serial@54006a00 { + compatible = "socionext,uniphier-uart"; + status = "disabled"; + reg = <0x54006a00 0x40>; + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_uart2>; + interrupts = <0 37 4>; + clocks = <&uart_clk>; + }; + + serial3: serial@54006b00 { + compatible = "socionext,uniphier-uart"; + status = "disabled"; + reg = <0x54006b00 0x40>; + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_uart3>; + interrupts = <0 177 4>; + clocks = <&uart_clk>; + }; + + i2c0: i2c@58780000 { + compatible = "socionext,uniphier-fi2c"; + status = "disabled"; + reg = <0x58780000 0x80>; + #address-cells = <1>; + #size-cells = <0>; + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_i2c0>; + interrupts = <0 41 4>; + clocks = <&i2c_clk>; + clock-frequency = <100000>; + }; + + i2c1: i2c@58781000 { + compatible = "socionext,uniphier-fi2c"; + status = "disabled"; + reg = <0x58781000 0x80>; + #address-cells = <1>; + #size-cells = <0>; + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_i2c1>; + interrupts = <0 42 4>; + clocks = <&i2c_clk>; + clock-frequency = <100000>; + }; + + i2c2: i2c@58782000 { + compatible = "socionext,uniphier-fi2c"; + status = "disabled"; + reg = <0x58782000 0x80>; + #address-cells = <1>; + #size-cells = <0>; + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_i2c2>; + interrupts = <0 43 4>; + clocks = <&i2c_clk>; + clock-frequency = <100000>; + }; + + i2c3: i2c@58783000 { + compatible = "socionext,uniphier-fi2c"; + status = "disabled"; + reg = <0x58783000 0x80>; + #address-cells = <1>; + #size-cells = <0>; + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_i2c3>; + interrupts = <0 44 4>; + clocks = <&i2c_clk>; + clock-frequency = <100000>; + }; + + /* i2c4 does not exist */ + + /* chip-internal connection for DMD */ + i2c5: i2c@58785000 { + compatible = "socionext,uniphier-fi2c"; + reg = <0x58785000 0x80>; + #address-cells = <1>; + #size-cells = <0>; + interrupts = <0 25 4>; + clocks = <&i2c_clk>; + clock-frequency = <400000>; + }; + + /* chip-internal connection for HDMI */ + i2c6: i2c@58786000 { + compatible = "socionext,uniphier-fi2c"; + reg = <0x58786000 0x80>; + #address-cells = <1>; + #size-cells = <0>; + interrupts = <0 26 4>; + clocks = <&i2c_clk>; + clock-frequency = <400000>; + }; + + system-bus-controller-misc@59800000 { + compatible = "socionext,uniphier-system-bus-controller-misc", + "syscon"; + reg = <0x59800000 0x2000>; + }; + + pinctrl: pinctrl@5f801000 { + compatible = "socionext,ph1-pro5-pinctrl", "syscon"; + reg = <0x5f801000 0xe00>; + }; + + timer@60000200 { + compatible = "arm,cortex-a9-global-timer"; + reg = <0x60000200 0x20>; + interrupts = <1 11 0x304>; + clocks = <&arm_timer_clk>; + }; + + timer@60000600 { + compatible = "arm,cortex-a9-twd-timer"; + reg = <0x60000600 0x20>; + interrupts = <1 13 0x304>; + clocks = <&arm_timer_clk>; + }; + + intc: interrupt-controller@60001000 { + compatible = "arm,cortex-a9-gic"; + #interrupt-cells = <3>; + interrupt-controller; + reg = <0x60001000 0x1000>, + <0x60000100 0x100>; + }; + }; +}; + +/include/ "uniphier-pinctrl.dtsi"
2015-08-28 22:33 GMT+09:00 Masahiro Yamada yamada.masahiro@socionext.com:
Applied to u-boot-uniphier/master.
Initial version of DTSI for ProXstream2 and PH1-LD6b and DTS for PH1-LD6b reference board.
Import from Linux with some adjustments: - Use SPDX-License-Identifier - Add clock-frequency to serial nodes - Drop unusable nodes from -ref.dts
While I am here, sort Makefile entries alphabetically.
arch/arm/dts/Makefile | 5 +- arch/arm/dts/uniphier-ph1-ld6b-ref.dts | 59 ++++++++ arch/arm/dts/uniphier-ph1-ld6b.dtsi | 31 +++++ arch/arm/dts/uniphier-proxstream2.dtsi | 241 +++++++++++++++++++++++++++++++++ 4 files changed, 334 insertions(+), 2 deletions(-) create mode 100644 arch/arm/dts/uniphier-ph1-ld6b-ref.dts create mode 100644 arch/arm/dts/uniphier-ph1-ld6b.dtsi create mode 100644 arch/arm/dts/uniphier-proxstream2.dtsi
diff --git a/arch/arm/dts/Makefile b/arch/arm/dts/Makefile index d9a2f5f..c4c4344 100644 --- a/arch/arm/dts/Makefile +++ b/arch/arm/dts/Makefile @@ -38,9 +38,10 @@ dtb-$(CONFIG_TEGRA) += tegra20-harmony.dtb \ tegra210-p2371-0000.dtb \ tegra210-p2571.dtb dtb-$(CONFIG_ARCH_UNIPHIER) += \ - uniphier-ph1-sld3-ref.dtb \ - uniphier-ph1-pro4-ref.dtb \ uniphier-ph1-ld4-ref.dtb \ + uniphier-ph1-ld6b-ref.dtb \ + uniphier-ph1-pro4-ref.dtb \ + uniphier-ph1-sld3-ref.dtb \ uniphier-ph1-sld8-ref.dtb dtb-$(CONFIG_ARCH_ZYNQ) += zynq-zc702.dtb \ zynq-zc706.dtb \ diff --git a/arch/arm/dts/uniphier-ph1-ld6b-ref.dts b/arch/arm/dts/uniphier-ph1-ld6b-ref.dts new file mode 100644 index 0000000..58dc20e --- /dev/null +++ b/arch/arm/dts/uniphier-ph1-ld6b-ref.dts @@ -0,0 +1,59 @@ +/* + * Device Tree Source for UniPhier PH1-LD6b Reference Board + * + * Copyright (C) 2015 Masahiro Yamada yamada.masahiro@socionext.com + * + */ + +/dts-v1/; +/include/ "uniphier-ph1-ld6b.dtsi" +/include/ "uniphier-ref-daughter.dtsi" + +/ { + model = "UniPhier PH1-LD6b Reference Board"; + compatible = "socionext,ph1-ld6b-ref", "socionext,ph1-ld6b"; + + memory { + device_type = "memory"; + reg = <0x80000000 0x80000000>; + }; + + chosen { + bootargs = "console=ttyS0,115200"; + stdout-path = &serial0; + }; + + aliases { + serial0 = &serial0; + serial1 = &serial1; + serial2 = &serial2; + i2c0 = &i2c0; + i2c1 = &i2c1; + i2c2 = &i2c2; + i2c3 = &i2c3; + i2c4 = &i2c4; + i2c5 = &i2c5; + i2c6 = &i2c6; + }; +}; + +&serial0 { + status = "okay"; +}; + +&serial1 { + status = "okay"; +}; + +&serial2 { + status = "okay"; +}; + +&i2c0 { + status = "okay"; +}; + +/* for U-boot only */ +&serial0 { + u-boot,dm-pre-reloc; +}; diff --git a/arch/arm/dts/uniphier-ph1-ld6b.dtsi b/arch/arm/dts/uniphier-ph1-ld6b.dtsi new file mode 100644 index 0000000..cf02e62 --- /dev/null +++ b/arch/arm/dts/uniphier-ph1-ld6b.dtsi @@ -0,0 +1,31 @@ +/* + * Device Tree Source for UniPhier PH1-LD6b SoC + * + * Copyright (C) 2015 Masahiro Yamada yamada.masahiro@socionext.com + * + * SPDX-License-Identifier: GPL-2.0+ X11 + */ + +/* + * PH1-LD6b consists of two silicon dies: D-chip and A-chip. + * The D-chip (digital chip) is the same as the ProXstream2 die. + * Reuse the ProXstream2 device tree with some properties overridden. + */ +/include/ "uniphier-proxstream2.dtsi" + +/ { + compatible = "socionext,ph1-ld6b"; +}; + +/* UART3 unavilable: the pads are not wired to the package balls */ +&serial3 { + status = "disabled"; +}; + +/* + * PH1-LD6b and ProXstream2 have completely different packages, + * which makes the pinctrl driver unshareable. + */ +&pinctrl { + compatible = "socionext,ph1-ld6b-pinctrl", "syscon"; +}; diff --git a/arch/arm/dts/uniphier-proxstream2.dtsi b/arch/arm/dts/uniphier-proxstream2.dtsi new file mode 100644 index 0000000..8b496a7 --- /dev/null +++ b/arch/arm/dts/uniphier-proxstream2.dtsi @@ -0,0 +1,241 @@ +/* + * Device Tree Source for UniPhier ProXstream2 SoC + * + * Copyright (C) 2015 Masahiro Yamada yamada.masahiro@socionext.com + * + * SPDX-License-Identifier: GPL-2.0+ X11 + */ + +/include/ "skeleton.dtsi" + +/ { + compatible = "socionext,proxstream2"; + + cpus { + #address-cells = <1>; + #size-cells = <0>; + enable-method = "socionext,uniphier-smp"; + + cpu@0 { + device_type = "cpu"; + compatible = "arm,cortex-a9"; + reg = <0>; + }; + + cpu@1 { + device_type = "cpu"; + compatible = "arm,cortex-a9"; + reg = <1>; + }; + + cpu@2 { + device_type = "cpu"; + compatible = "arm,cortex-a9"; + reg = <2>; + }; + + cpu@3 { + device_type = "cpu"; + compatible = "arm,cortex-a9"; + reg = <3>; + }; + }; + + clocks { + arm_timer_clk: arm_timer_clk { + #clock-cells = <0>; + compatible = "fixed-clock"; + clock-frequency = <50000000>; + }; + + uart_clk: uart_clk { + #clock-cells = <0>; + compatible = "fixed-clock"; + clock-frequency = <88900000>; + }; + + i2c_clk: i2c_clk { + #clock-cells = <0>; + compatible = "fixed-clock"; + clock-frequency = <50000000>; + }; + }; + + soc { + compatible = "simple-bus"; + #address-cells = <1>; + #size-cells = <1>; + ranges; + interrupt-parent = <&intc>; + + extbus: extbus { + compatible = "simple-bus"; + #address-cells = <2>; + #size-cells = <1>; + }; + + serial0: serial@54006800 { + compatible = "socionext,uniphier-uart"; + status = "disabled"; + reg = <0x54006800 0x40>; + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_uart0>; + interrupts = <0 33 4>; + clocks = <&uart_clk>; + clock-frequency = <88900000>; + }; + + serial1: serial@54006900 { + compatible = "socionext,uniphier-uart"; + status = "disabled"; + reg = <0x54006900 0x40>; + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_uart1>; + interrupts = <0 35 4>; + clocks = <&uart_clk>; + clock-frequency = <88900000>; + }; + + serial2: serial@54006a00 { + compatible = "socionext,uniphier-uart"; + status = "disabled"; + reg = <0x54006a00 0x40>; + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_uart2>; + interrupts = <0 37 4>; + clocks = <&uart_clk>; + clock-frequency = <88900000>; + }; + + serial3: serial@54006b00 { + compatible = "socionext,uniphier-uart"; + status = "disabled"; + reg = <0x54006b00 0x40>; + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_uart3>; + interrupts = <0 177 4>; + clocks = <&uart_clk>; + clock-frequency = <88900000>; + }; + + i2c0: i2c@58780000 { + compatible = "socionext,uniphier-fi2c"; + status = "disabled"; + reg = <0x58780000 0x80>; + #address-cells = <1>; + #size-cells = <0>; + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_i2c0>; + interrupts = <0 41 4>; + clocks = <&i2c_clk>; + clock-frequency = <100000>; + }; + + i2c1: i2c@58781000 { + compatible = "socionext,uniphier-fi2c"; + status = "disabled"; + reg = <0x58781000 0x80>; + #address-cells = <1>; + #size-cells = <0>; + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_i2c1>; + interrupts = <0 42 4>; + clocks = <&i2c_clk>; + clock-frequency = <100000>; + }; + + i2c2: i2c@58782000 { + compatible = "socionext,uniphier-fi2c"; + status = "disabled"; + reg = <0x58782000 0x80>; + #address-cells = <1>; + #size-cells = <0>; + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_i2c2>; + interrupts = <0 43 4>; + clocks = <&i2c_clk>; + clock-frequency = <100000>; + }; + + i2c3: i2c@58783000 { + compatible = "socionext,uniphier-fi2c"; + status = "disabled"; + reg = <0x58783000 0x80>; + #address-cells = <1>; + #size-cells = <0>; + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_i2c3>; + interrupts = <0 44 4>; + clocks = <&i2c_clk>; + clock-frequency = <100000>; + }; + + /* chip-internal connection for DMD */ + i2c4: i2c@58784000 { + compatible = "socionext,uniphier-fi2c"; + reg = <0x58784000 0x80>; + #address-cells = <1>; + #size-cells = <0>; + interrupts = <0 45 4>; + clocks = <&i2c_clk>; + clock-frequency = <400000>; + }; + + /* chip-internal connection for STM */ + i2c5: i2c@58785000 { + compatible = "socionext,uniphier-fi2c"; + reg = <0x58785000 0x80>; + #address-cells = <1>; + #size-cells = <0>; + interrupts = <0 25 4>; + clocks = <&i2c_clk>; + clock-frequency = <400000>; + }; + + /* chip-internal connection for HDMI */ + i2c6: i2c@58786000 { + compatible = "socionext,uniphier-fi2c"; + reg = <0x58786000 0x80>; + #address-cells = <1>; + #size-cells = <0>; + interrupts = <0 26 4>; + clocks = <&i2c_clk>; + clock-frequency = <400000>; + }; + + system-bus-controller-misc@59800000 { + compatible = "socionext,uniphier-system-bus-controller-misc", + "syscon"; + reg = <0x59800000 0x2000>; + }; + + pinctrl: pinctrl@5f801000 { + compatible = "socionext,proxstream2-pinctrl", "syscon"; + reg = <0x5f801000 0xe00>; + }; + + timer@60000200 { + compatible = "arm,cortex-a9-global-timer"; + reg = <0x60000200 0x20>; + interrupts = <1 11 0xf04>; + clocks = <&arm_timer_clk>; + }; + + timer@60000600 { + compatible = "arm,cortex-a9-twd-timer"; + reg = <0x60000600 0x20>; + interrupts = <1 13 0xf04>; + clocks = <&arm_timer_clk>; + }; + + intc: interrupt-controller@60001000 { + compatible = "arm,cortex-a9-gic"; + #interrupt-cells = <3>; + interrupt-controller; + reg = <0x60001000 0x1000>, + <0x60000100 0x100>; + }; + }; +}; + +/include/ "uniphier-pinctrl.dtsi"
Masahiro Yamada
