[U-Boot] [PATCH] usb: dwc3: Fix warnings on 64-bit builds
Change aritmentics to use 64bit types to be compatible with 64bit builds.
drivers/usb/dwc3/core.c | 7 ++++--- drivers/usb/dwc3/ep0.c | 10 +++++----- drivers/usb/dwc3/gadget.c | 10 +++++----- drivers/usb/dwc3/io.h | 4 ++-- 4 files changed, 16 insertions(+), 15 deletions(-)
diff --git a/drivers/usb/dwc3/core.c b/drivers/usb/dwc3/core.c index ab3c94e51275..0ae3de5c27b9 100644 --- a/drivers/usb/dwc3/core.c +++ b/drivers/usb/dwc3/core.c @@ -281,7 +281,7 @@ static int dwc3_setup_scratch_buffers(struct dwc3 *dwc) return 0;
err1: - dma_unmap_single((void *)dwc->scratch_addr, dwc->nr_scratch * + dma_unmap_single((void *)(uintptr_t)dwc->scratch_addr, dwc->nr_scratch * DWC3_SCRATCHBUF_SIZE, DMA_BIDIRECTIONAL);
err0: @@ -296,7 +296,7 @@ static void dwc3_free_scratch_buffers(struct dwc3 *dwc) if (!dwc->nr_scratch) return;
- dma_unmap_single((void *)dwc->scratch_addr, dwc->nr_scratch * + dma_unmap_single((void *)(uintptr_t)dwc->scratch_addr, dwc->nr_scratch * DWC3_SCRATCHBUF_SIZE, DMA_BIDIRECTIONAL); kfree(dwc->scratchbuf); } @@ -629,7 +629,8 @@ int dwc3_uboot_init(struct dwc3_device *dwc3_dev) dwc = PTR_ALIGN(mem, DWC3_ALIGN_MASK + 1); dwc->mem = mem;
- dwc->regs = (int *)(dwc3_dev->base + DWC3_GLOBALS_REGS_START); + dwc->regs = (void *)(uintptr_t)(dwc3_dev->base + + DWC3_GLOBALS_REGS_START);
/* default to highest possible threshold */ lpm_nyet_threshold = 0xff; diff --git a/drivers/usb/dwc3/ep0.c b/drivers/usb/dwc3/ep0.c index aba614fb4e98..12b133f93e17 100644 --- a/drivers/usb/dwc3/ep0.c +++ b/drivers/usb/dwc3/ep0.c @@ -81,8 +81,8 @@ static int dwc3_ep0_start_trans(struct dwc3 *dwc, u8 epnum, dma_addr_t buf_dma, trb->ctrl |= (DWC3_TRB_CTRL_IOC | DWC3_TRB_CTRL_LST);
- dwc3_flush_cache((int)buf_dma, len); - dwc3_flush_cache((int)trb, sizeof(*trb)); + dwc3_flush_cache((long)buf_dma, len); + dwc3_flush_cache((long)trb, sizeof(*trb));
if (chain) return 0; @@ -790,7 +790,7 @@ static void dwc3_ep0_complete_data(struct dwc3 *dwc, if (!r) return;
- dwc3_flush_cache((int)trb, sizeof(*trb)); + dwc3_flush_cache((long)trb, sizeof(*trb));
status = DWC3_TRB_SIZE_TRBSTS(trb->size); if (status == DWC3_TRBSTS_SETUP_PENDING) { @@ -821,7 +821,7 @@ static void dwc3_ep0_complete_data(struct dwc3 *dwc, ur->actual += transferred;
trb++; - dwc3_flush_cache((int)trb, sizeof(*trb)); + dwc3_flush_cache((long)trb, sizeof(*trb)); length = trb->size & DWC3_TRB_SIZE_MASK;
ep0->free_slot = 0; @@ -831,7 +831,7 @@ static void dwc3_ep0_complete_data(struct dwc3 *dwc, maxp); transferred = min_t(u32, ur->length - transferred, transfer_size - length); - dwc3_flush_cache((int)dwc->ep0_bounce, DWC3_EP0_BOUNCE_SIZE); + dwc3_flush_cache((long)dwc->ep0_bounce, DWC3_EP0_BOUNCE_SIZE); memcpy(buf, dwc->ep0_bounce, transferred); } else { transferred = ur->length - length; diff --git a/drivers/usb/dwc3/gadget.c b/drivers/usb/dwc3/gadget.c index f3d649a5ee2f..8ff949d241f6 100644 --- a/drivers/usb/dwc3/gadget.c +++ b/drivers/usb/dwc3/gadget.c @@ -244,7 +244,7 @@ void dwc3_gadget_giveback(struct dwc3_ep *dep, struct dwc3_request *req,
list_del(&req->list); req->trb = NULL; - dwc3_flush_cache((int)req->request.dma, req->request.length); + dwc3_flush_cache((long)req->request.dma, req->request.length);
if (req->request.status == -EINPROGRESS) req->request.status = status; @@ -771,8 +771,8 @@ static void dwc3_prepare_one_trb(struct dwc3_ep *dep,
trb->ctrl |= DWC3_TRB_CTRL_HWO;
- dwc3_flush_cache((int)dma, length); - dwc3_flush_cache((int)trb, sizeof(*trb)); + dwc3_flush_cache((long)dma, length); + dwc3_flush_cache((long)trb, sizeof(*trb)); }
/* @@ -1769,7 +1769,7 @@ static int dwc3_cleanup_done_reqs(struct dwc3 *dwc, struct dwc3_ep *dep, slot %= DWC3_TRB_NUM; trb = &dep->trb_pool[slot];
- dwc3_flush_cache((int)trb, sizeof(*trb)); + dwc3_flush_cache((long)trb, sizeof(*trb)); __dwc3_cleanup_done_trbs(dwc, dep, req, trb, event, status); dwc3_gadget_giveback(dep, req, status);
@@ -2670,7 +2670,7 @@ void dwc3_gadget_uboot_handle_interrupt(struct dwc3 *dwc)
for (i = 0; i < dwc->num_event_buffers; i++) { evt = dwc->ev_buffs[i]; - dwc3_flush_cache((int)evt->buf, evt->length); + dwc3_flush_cache((long)evt->buf, evt->length); }
dwc3_thread_interrupt(0, dwc); diff --git a/drivers/usb/dwc3/io.h b/drivers/usb/dwc3/io.h index 5042a2419369..0d9fa220e922 100644 --- a/drivers/usb/dwc3/io.h +++ b/drivers/usb/dwc3/io.h @@ -23,7 +23,7 @@ #define CACHELINE_SIZE CONFIG_SYS_CACHELINE_SIZE static inline u32 dwc3_readl(void __iomem *base, u32 offset) { - u32 offs = offset - DWC3_GLOBALS_REGS_START; + unsigned long offs = offset - DWC3_GLOBALS_REGS_START; u32 value;
/* @@ -38,7 +38,7 @@ static inline u32 dwc3_readl(void __iomem *base, u32 offset)
static inline void dwc3_writel(void __iomem *base, u32 offset, u32 value) { - u32 offs = offset - DWC3_GLOBALS_REGS_START; + unsigned long offs = offset - DWC3_GLOBALS_REGS_START;
/* * We requested the mem region starting from the Globals address
err1:
- dma_unmap_single((void *)(uintptr_t)dwc->scratch_addr, dwc->nr_scratch *
Is this double type-cast necessary ?
err0:
Best regards, Marek Vasut
err1:
Do you know better way how to do it?
Thanks, Michal
err1:
I guess I don't, sorry.
err1:
ok. Then can you please apply it?
Thanks, Michal
err1:
dwc->nr_scratch *
Applied all three.
Hi Michal,
err1:
trb++;
dwc3_flush_cache((long)trb, sizeof(*trb)); length = trb->size & DWC3_TRB_SIZE_MASK; ep0->free_slot = 0;
DWC3_EP0_BOUNCE_SIZE); memcpy(buf, dwc->ep0_bounce, transferred); } else { transferred = ur->length - length; diff --git a/drivers/usb/dwc3/gadget.c b/drivers/usb/dwc3/gadget.c index f3d649a5ee2f..8ff949d241f6 100644 --- a/drivers/usb/dwc3/gadget.c +++ b/drivers/usb/dwc3/gadget.c @@ -244,7 +244,7 @@ void dwc3_gadget_giveback(struct dwc3_ep *dep, struct dwc3_request *req, list_del(&req->list); req->trb = NULL;
- dwc3_flush_cache((long)req->request.dma,
req->request.length); if (req->request.status == -EINPROGRESS) req->request.status = status; @@ -771,8 +771,8 @@ static void dwc3_prepare_one_trb(struct dwc3_ep *dep, trb->ctrl |= DWC3_TRB_CTRL_HWO;
- dwc3_flush_cache((long)dma, length);
- dwc3_flush_cache((long)trb, sizeof(*trb));
- dwc3_flush_cache((long)trb, sizeof(*trb)); __dwc3_cleanup_done_trbs(dwc, dep, req, trb, event, status); dwc3_gadget_giveback(dep, req, status);
@@ -2670,7 +2670,7 @@ void dwc3_gadget_uboot_handle_interrupt(struct dwc3 *dwc) for (i = 0; i < dwc->num_event_buffers; i++) { evt = dwc->ev_buffs[i];
evt->length); }
@@ -38,7 +38,7 @@ static inline u32 dwc3_readl(void __iomem *base, u32 offset) static inline void dwc3_writel(void __iomem *base, u32 offset, u32 value) {
- We requested the mem region starting from the Globals
address
Acked-by: Lukasz Majewski l.majewski@samsung.com
Lukasz Majewski
Michal Simek
