[PATCH v3 1/2] board: rockchip: Add FriendlyElec NanoPi R6C
The NanoPi R6C is a SBC by FriendlyElec based on the Rockchip RK3588s. It comes with 4GB or 8GB of RAM, a microSD card slot, optional 32GB eMMC storage, one M.2 M-Key connector, one RTL8211F 1GbE and one RTL8125 2.5GbE Ethernet port, one USB 2.0 Type-A and one USB 3.0 Type-A port, a HDMI port, a 30-pin GPIO header as well as multiple buttons and LEDs.
Add initial support for this board using the upstream devicetree sources.
Tested in U-Boot proper: - Booting from eMMC works - 1GbE Ethernet works using the eth_eqos driver (tested by ping) - 2.5GbE Ethernet works using the eth_rtl8169 driver (tested by ping), but the status LEDs on this specific port currently aren't working - NVMe SSD in M.2 socket does get recognized (tested with `nvme scan` followed by `nvme details`)
Kernel commit: d5f1d7437451 ("arm64: dts: rockchip: Add support for NanoPi R6C")
Reviewed-by: Quentin Schulz quentin.schulz@cherry.de Reviewed-by: Kever Yang kever.yang@rock-chips.com Signed-off-by: Sebastian Kropatsch seb-dev@mail.de ---
Changes v2 -> v3: - Patch 2/2: Add missing board source to 'rk3588/Kconfig' - Both patches: Collect r-b tag from Kever Yang - Link to v2: https://lore.kernel.org/u-boot/20240607202111.453943-1-seb-dev@mail.de/
Changes v1 -> v2:
- Patch 1/2: Add missing 'S' to 'RK3588S' symbols - Patch 1/2: Collect r-b tag from Quentin Schulz - Add similar board NanoPi R6S (new patch) - Link to v1: https://lore.kernel.org/u-boot/20240605155413.226629-1-seb-dev@mail.de/
Hello!
The Ethernet status LEDs for the RTL8169 ports don't light up when connected (confirmed by Ulli Kehrle [1]). The other port with a RTL8211F has no problems with the LEDs. Have there been occurrences like this in combination with the RTL8125? Could this possibly solved in the devicetree or is this a potential driver bug?
Secondly, the default active network device in U-Boot is the 1GbE one. I believe it would make sense to make the 2.5GbE device the default active one since this one is labeled "LAN", whereas the 1GbE is labeled "WAN". However, since the 2.5GbE device is PCIe-based, it only shows up in U-Boot proper after using the `pci enum` command (shows up as in gets listed in `net list` and `dm tree`). Do you have any tips on the preferred approach to handle this switch of the default active net device? Is this even a sensible thing to include in U-Boot in your opinion?
Thanks for your feedback!
Cheers, Sebastian
Links: [1] https://lore.kernel.org/u-boot/87sex75kub.fsf@kehrle.me/
--- arch/arm/dts/rk3588s-nanopi-r6c-u-boot.dtsi | 3 + arch/arm/mach-rockchip/rk3588/Kconfig | 13 +++ board/friendlyelec/nanopi-r6c-rk3588s/Kconfig | 12 +++ .../nanopi-r6c-rk3588s/MAINTAINERS | 7 ++ configs/nanopi-r6c-rk3588s_defconfig | 83 +++++++++++++++++++ doc/board/rockchip/rockchip.rst | 1 + include/configs/nanopi-r6c-rk3588s.h | 12 +++ 7 files changed, 131 insertions(+) create mode 100644 arch/arm/dts/rk3588s-nanopi-r6c-u-boot.dtsi create mode 100644 board/friendlyelec/nanopi-r6c-rk3588s/Kconfig create mode 100644 board/friendlyelec/nanopi-r6c-rk3588s/MAINTAINERS create mode 100644 configs/nanopi-r6c-rk3588s_defconfig create mode 100644 include/configs/nanopi-r6c-rk3588s.h
diff --git a/arch/arm/dts/rk3588s-nanopi-r6c-u-boot.dtsi b/arch/arm/dts/rk3588s-nanopi-r6c-u-boot.dtsi new file mode 100644 index 0000000000..853ed58cfe --- /dev/null +++ b/arch/arm/dts/rk3588s-nanopi-r6c-u-boot.dtsi @@ -0,0 +1,3 @@ +// SPDX-License-Identifier: (GPL-2.0+ OR MIT) + +#include "rk3588s-u-boot.dtsi" diff --git a/arch/arm/mach-rockchip/rk3588/Kconfig b/arch/arm/mach-rockchip/rk3588/Kconfig index 9a35c7d9cc..26e45f43ff 100644 --- a/arch/arm/mach-rockchip/rk3588/Kconfig +++ b/arch/arm/mach-rockchip/rk3588/Kconfig @@ -78,6 +78,18 @@ config TARGET_NANOPCT6_RK3588 Power: 5.5*2.1mm DC Jack, 12VDC input Dimensions: 110x80x1.6mm (without case) / 86x114.5x30mm (with case)
+config TARGET_NANOPI_R6C_RK3588S + bool "FriendlyElec NanoPi R6C" + select BOARD_LATE_INIT + help + The NanoPi R6C is a SBC by FriendlyElec based on the Rockchip + RK3588s. + It comes with 4GB or 8GB of RAM, a microSD card slot, optional 32GB + eMMC storage, one M.2 M-Key connector, one RTL8211F 1GbE and one + RTL8125 2.5GbE Ethernet port, one USB 2.0 Type-A and one USB 3.0 + Type-A port, a HDMI port, a 30-pin GPIO header as well as some + buttons and LEDs. + config TARGET_NOVA_RK3588 bool "Indiedroid Nova RK3588" select BOARD_LATE_INIT @@ -288,6 +300,7 @@ config TEXT_BASE source "board/armsom/sige7-rk3588/Kconfig" source "board/edgeble/neural-compute-module-6/Kconfig" source "board/friendlyelec/nanopc-t6-rk3588/Kconfig" +source "board/friendlyelec/nanopi-r6c-rk3588s/Kconfig" source "board/indiedroid/nova/Kconfig" source "board/pine64/quartzpro64-rk3588/Kconfig" source "board/turing/turing-rk1-rk3588/Kconfig" diff --git a/board/friendlyelec/nanopi-r6c-rk3588s/Kconfig b/board/friendlyelec/nanopi-r6c-rk3588s/Kconfig new file mode 100644 index 0000000000..2d8acbf62f --- /dev/null +++ b/board/friendlyelec/nanopi-r6c-rk3588s/Kconfig @@ -0,0 +1,12 @@ +if TARGET_NANOPI_R6C_RK3588S + +config SYS_BOARD + default "nanopi-r6c-rk3588s" + +config SYS_VENDOR + default "friendlyelec" + +config SYS_CONFIG_NAME + default "nanopi-r6c-rk3588s" + +endif diff --git a/board/friendlyelec/nanopi-r6c-rk3588s/MAINTAINERS b/board/friendlyelec/nanopi-r6c-rk3588s/MAINTAINERS new file mode 100644 index 0000000000..18d0bd1287 --- /dev/null +++ b/board/friendlyelec/nanopi-r6c-rk3588s/MAINTAINERS @@ -0,0 +1,7 @@ +NANOPI-R6C +M: Sebastian Kropatsch seb-dev@mail.de +S: Maintained +F: arch/arm/dts/rk3588s-nanopi-r6c-u-boot.dtsi +F: board/friendlyelec/nanopi-r6c-rk3588s +F: configs/nanopi-r6c-rk3588s_defconfig +F: include/configs/nanopi-r6c-rk3588s.h diff --git a/configs/nanopi-r6c-rk3588s_defconfig b/configs/nanopi-r6c-rk3588s_defconfig new file mode 100644 index 0000000000..f8d2d67bd3 --- /dev/null +++ b/configs/nanopi-r6c-rk3588s_defconfig @@ -0,0 +1,83 @@ +CONFIG_ARM=y +CONFIG_SKIP_LOWLEVEL_INIT=y +CONFIG_SYS_HAS_NONCACHED_MEMORY=y +CONFIG_COUNTER_FREQUENCY=24000000 +CONFIG_ARCH_ROCKCHIP=y +CONFIG_DEFAULT_DEVICE_TREE="rockchip/rk3588s-nanopi-r6c" +CONFIG_ROCKCHIP_RK3588=y +CONFIG_SPL_SERIAL=y +CONFIG_TARGET_NANOPI_R6C_RK3588S=y +CONFIG_DEBUG_UART_BASE=0xFEB50000 +CONFIG_DEBUG_UART_CLOCK=24000000 +CONFIG_SYS_LOAD_ADDR=0xc00800 +CONFIG_PCI=y +CONFIG_DEBUG_UART=y +CONFIG_FIT=y +CONFIG_FIT_VERBOSE=y +CONFIG_SPL_FIT_SIGNATURE=y +CONFIG_SPL_LOAD_FIT=y +CONFIG_LEGACY_IMAGE_FORMAT=y +CONFIG_DEFAULT_FDT_FILE="rockchip/rk3588s-nanopi-r6c.dtb" +# CONFIG_DISPLAY_CPUINFO is not set +CONFIG_DISPLAY_BOARDINFO_LATE=y +CONFIG_SPL_MAX_SIZE=0x40000 +CONFIG_SPL_PAD_TO=0x7f8000 +# CONFIG_SPL_RAW_IMAGE_SUPPORT is not set +CONFIG_SPL_ATF=y +CONFIG_CMD_GPIO=y +CONFIG_CMD_PWM=y +CONFIG_CMD_GPT=y +CONFIG_CMD_I2C=y +CONFIG_CMD_MMC=y +CONFIG_CMD_PCI=y +CONFIG_CMD_USB=y +CONFIG_CMD_ROCKUSB=y +# CONFIG_CMD_SETEXPR is not set +CONFIG_CMD_REGULATOR=y +# CONFIG_SPL_DOS_PARTITION is not set +CONFIG_SPL_OF_CONTROL=y +CONFIG_OF_LIVE=y +CONFIG_OF_SPL_REMOVE_PROPS="clock-names interrupt-parent assigned-clocks assigned-clock-rates assigned-clock-parents" +CONFIG_SPL_DM_SEQ_ALIAS=y +CONFIG_SPL_REGMAP=y +CONFIG_SPL_SYSCON=y +CONFIG_SPL_CLK=y +# CONFIG_USB_FUNCTION_FASTBOOT is not set +CONFIG_ROCKCHIP_GPIO=y +CONFIG_SYS_I2C_ROCKCHIP=y +CONFIG_MISC=y +CONFIG_SUPPORT_EMMC_RPMB=y +CONFIG_MMC_DW=y +CONFIG_MMC_DW_ROCKCHIP=y +CONFIG_MMC_SDHCI=y +CONFIG_MMC_SDHCI_SDMA=y +CONFIG_MMC_SDHCI_ROCKCHIP=y +# CONFIG_SPI_FLASH is not set +CONFIG_PHY_REALTEK=y +CONFIG_DWC_ETH_QOS=y +CONFIG_DWC_ETH_QOS_ROCKCHIP=y +CONFIG_RTL8169=y +CONFIG_NVME_PCI=y +CONFIG_PCIE_DW_ROCKCHIP=y +CONFIG_PHY_ROCKCHIP_INNO_USB2=y +CONFIG_PHY_ROCKCHIP_NANENG_COMBOPHY=y +CONFIG_PHY_ROCKCHIP_USBDP=y +CONFIG_SPL_PINCTRL=y +CONFIG_PWM_ROCKCHIP=y +CONFIG_SPL_RAM=y +CONFIG_BAUDRATE=1500000 +CONFIG_DEBUG_UART_SHIFT=2 +CONFIG_SYS_NS16550_MEM32=y +CONFIG_SYSRESET=y +CONFIG_USB=y +CONFIG_USB_XHCI_HCD=y +CONFIG_USB_EHCI_HCD=y +CONFIG_USB_EHCI_GENERIC=y +CONFIG_USB_OHCI_HCD=y +CONFIG_USB_OHCI_GENERIC=y +CONFIG_USB_DWC3=y +CONFIG_USB_DWC3_GENERIC=y +CONFIG_USB_GADGET=y +CONFIG_USB_GADGET_DOWNLOAD=y +CONFIG_USB_FUNCTION_ROCKUSB=y +CONFIG_ERRNO_STR=y diff --git a/doc/board/rockchip/rockchip.rst b/doc/board/rockchip/rockchip.rst index eaf71673b7..d04fc6d3c6 100644 --- a/doc/board/rockchip/rockchip.rst +++ b/doc/board/rockchip/rockchip.rst @@ -124,6 +124,7 @@ List of mainline supported Rockchip boards: - Edgeble Neural Compute Module 6A SoM - Neu6a (neu6a-io-rk3588) - Edgeble Neural Compute Module 6B SoM - Neu6b (neu6b-io-rk3588) - FriendlyElec NanoPC-T6 (nanopc-t6-rk3588) + - FriendlyElec NanoPi R6C (nanopi-r6c-rk3588s) - Generic RK3588S/RK3588 (generic-rk3588) - Indiedroid Nova (nova-rk3588s) - Pine64 QuartzPro64 (quartzpro64-rk3588) diff --git a/include/configs/nanopi-r6c-rk3588s.h b/include/configs/nanopi-r6c-rk3588s.h new file mode 100644 index 0000000000..2b57d60eb5 --- /dev/null +++ b/include/configs/nanopi-r6c-rk3588s.h @@ -0,0 +1,12 @@ +/* SPDX-License-Identifier: GPL-2.0+ */ + +#ifndef __NANOPI_R6C_RK3588S_H +#define __NANOPI_R6C_RK3588S_H + +#define ROCKCHIP_DEVICE_SETTINGS \ + "stdout=serial,vidconsole\0" \ + "stderr=serial,vidconsole\0" + +#include <configs/rk3588_common.h> + +#endif /* __NANOPI_R6C_RK3588S_H */
The NanoPi R6S is a SBC by FriendlyElec based on the Rockchip RK3588s. It comes with 4GB or 8GB of RAM, a microSD card slot, 32GB eMMC storage, one RTL8211F 1GbE and two RTL8125 2.5GbE Ethernet ports, one USB 2.0 Type-A and one USB 3.0 Type-A port, a HDMI port, a 12-pin GPIO FPC connector, a fan connector, IR receiver as well as some buttons and LEDs.
Kernel commit: f1b11f43b3e9 ("arm64: dts: rockchip: Add support for NanoPi R6S")
Reviewed-by: Kever Yang kever.yang@rock-chips.com Signed-off-by: Sebastian Kropatsch seb-dev@mail.de --- arch/arm/dts/rk3588s-nanopi-r6s-u-boot.dtsi | 3 + arch/arm/mach-rockchip/rk3588/Kconfig | 13 +++ board/friendlyelec/nanopi-r6s-rk3588s/Kconfig | 12 +++ .../nanopi-r6s-rk3588s/MAINTAINERS | 7 ++ configs/nanopi-r6s-rk3588s_defconfig | 82 +++++++++++++++++++ doc/board/rockchip/rockchip.rst | 1 + include/configs/nanopi-r6s-rk3588s.h | 12 +++ 7 files changed, 130 insertions(+) create mode 100644 arch/arm/dts/rk3588s-nanopi-r6s-u-boot.dtsi create mode 100644 board/friendlyelec/nanopi-r6s-rk3588s/Kconfig create mode 100644 board/friendlyelec/nanopi-r6s-rk3588s/MAINTAINERS create mode 100644 configs/nanopi-r6s-rk3588s_defconfig create mode 100644 include/configs/nanopi-r6s-rk3588s.h
diff --git a/arch/arm/dts/rk3588s-nanopi-r6s-u-boot.dtsi b/arch/arm/dts/rk3588s-nanopi-r6s-u-boot.dtsi new file mode 100644 index 0000000000..853ed58cfe --- /dev/null +++ b/arch/arm/dts/rk3588s-nanopi-r6s-u-boot.dtsi @@ -0,0 +1,3 @@ +// SPDX-License-Identifier: (GPL-2.0+ OR MIT) + +#include "rk3588s-u-boot.dtsi" diff --git a/arch/arm/mach-rockchip/rk3588/Kconfig b/arch/arm/mach-rockchip/rk3588/Kconfig index 26e45f43ff..e751d64e1a 100644 --- a/arch/arm/mach-rockchip/rk3588/Kconfig +++ b/arch/arm/mach-rockchip/rk3588/Kconfig @@ -90,6 +90,18 @@ config TARGET_NANOPI_R6C_RK3588S Type-A port, a HDMI port, a 30-pin GPIO header as well as some buttons and LEDs.
+config TARGET_NANOPI_R6S_RK3588S + bool "FriendlyElec NanoPi R6S" + select BOARD_LATE_INIT + help + The NanoPi R6S is a SBC by FriendlyElec based on the Rockchip + RK3588s. + It comes with 4GB or 8GB of RAM, a microSD card slot, 32GB eMMC + storage, one RTL8211F 1GbE and two RTL8125 2.5GbE Ethernet ports, + one USB 2.0 Type-A and one USB 3.0 Type-A port, a HDMI port, a + 12-pin GPIO FPC connector, a fan connector, IR receiver as well + as some buttons and LEDs. + config TARGET_NOVA_RK3588 bool "Indiedroid Nova RK3588" select BOARD_LATE_INIT @@ -301,6 +313,7 @@ source "board/armsom/sige7-rk3588/Kconfig" source "board/edgeble/neural-compute-module-6/Kconfig" source "board/friendlyelec/nanopc-t6-rk3588/Kconfig" source "board/friendlyelec/nanopi-r6c-rk3588s/Kconfig" +source "board/friendlyelec/nanopi-r6s-rk3588s/Kconfig" source "board/indiedroid/nova/Kconfig" source "board/pine64/quartzpro64-rk3588/Kconfig" source "board/turing/turing-rk1-rk3588/Kconfig" diff --git a/board/friendlyelec/nanopi-r6s-rk3588s/Kconfig b/board/friendlyelec/nanopi-r6s-rk3588s/Kconfig new file mode 100644 index 0000000000..4d579816b1 --- /dev/null +++ b/board/friendlyelec/nanopi-r6s-rk3588s/Kconfig @@ -0,0 +1,12 @@ +if TARGET_NANOPI_R6S_RK3588S + +config SYS_BOARD + default "nanopi-r6s-rk3588s" + +config SYS_VENDOR + default "friendlyelec" + +config SYS_CONFIG_NAME + default "nanopi-r6s-rk3588s" + +endif diff --git a/board/friendlyelec/nanopi-r6s-rk3588s/MAINTAINERS b/board/friendlyelec/nanopi-r6s-rk3588s/MAINTAINERS new file mode 100644 index 0000000000..76288b4320 --- /dev/null +++ b/board/friendlyelec/nanopi-r6s-rk3588s/MAINTAINERS @@ -0,0 +1,7 @@ +NANOPI-R6S +M: Sebastian Kropatsch seb-dev@mail.de +S: Maintained +F: arch/arm/dts/rk3588s-nanopi-r6s-u-boot.dtsi +F: board/friendlyelec/nanopi-r6s-rk3588s +F: configs/nanopi-r6s-rk3588s_defconfig +F: include/configs/nanopi-r6s-rk3588s.h diff --git a/configs/nanopi-r6s-rk3588s_defconfig b/configs/nanopi-r6s-rk3588s_defconfig new file mode 100644 index 0000000000..f7b364655f --- /dev/null +++ b/configs/nanopi-r6s-rk3588s_defconfig @@ -0,0 +1,82 @@ +CONFIG_ARM=y +CONFIG_SKIP_LOWLEVEL_INIT=y +CONFIG_SYS_HAS_NONCACHED_MEMORY=y +CONFIG_COUNTER_FREQUENCY=24000000 +CONFIG_ARCH_ROCKCHIP=y +CONFIG_DEFAULT_DEVICE_TREE="rockchip/rk3588s-nanopi-r6s" +CONFIG_ROCKCHIP_RK3588=y +CONFIG_SPL_SERIAL=y +CONFIG_TARGET_NANOPI_R6S_RK3588S=y +CONFIG_DEBUG_UART_BASE=0xFEB50000 +CONFIG_DEBUG_UART_CLOCK=24000000 +CONFIG_SYS_LOAD_ADDR=0xc00800 +CONFIG_PCI=y +CONFIG_DEBUG_UART=y +CONFIG_FIT=y +CONFIG_FIT_VERBOSE=y +CONFIG_SPL_FIT_SIGNATURE=y +CONFIG_SPL_LOAD_FIT=y +CONFIG_LEGACY_IMAGE_FORMAT=y +CONFIG_DEFAULT_FDT_FILE="rockchip/rk3588s-nanopi-r6s.dtb" +# CONFIG_DISPLAY_CPUINFO is not set +CONFIG_DISPLAY_BOARDINFO_LATE=y +CONFIG_SPL_MAX_SIZE=0x40000 +CONFIG_SPL_PAD_TO=0x7f8000 +# CONFIG_SPL_RAW_IMAGE_SUPPORT is not set +CONFIG_SPL_ATF=y +CONFIG_CMD_GPIO=y +CONFIG_CMD_PWM=y +CONFIG_CMD_GPT=y +CONFIG_CMD_I2C=y +CONFIG_CMD_MMC=y +CONFIG_CMD_PCI=y +CONFIG_CMD_USB=y +CONFIG_CMD_ROCKUSB=y +# CONFIG_CMD_SETEXPR is not set +CONFIG_CMD_REGULATOR=y +# CONFIG_SPL_DOS_PARTITION is not set +CONFIG_SPL_OF_CONTROL=y +CONFIG_OF_LIVE=y +CONFIG_OF_SPL_REMOVE_PROPS="clock-names interrupt-parent assigned-clocks assigned-clock-rates assigned-clock-parents" +CONFIG_SPL_DM_SEQ_ALIAS=y +CONFIG_SPL_REGMAP=y +CONFIG_SPL_SYSCON=y +CONFIG_SPL_CLK=y +# CONFIG_USB_FUNCTION_FASTBOOT is not set +CONFIG_ROCKCHIP_GPIO=y +CONFIG_SYS_I2C_ROCKCHIP=y +CONFIG_MISC=y +CONFIG_SUPPORT_EMMC_RPMB=y +CONFIG_MMC_DW=y +CONFIG_MMC_DW_ROCKCHIP=y +CONFIG_MMC_SDHCI=y +CONFIG_MMC_SDHCI_SDMA=y +CONFIG_MMC_SDHCI_ROCKCHIP=y +# CONFIG_SPI_FLASH is not set +CONFIG_PHY_REALTEK=y +CONFIG_DWC_ETH_QOS=y +CONFIG_DWC_ETH_QOS_ROCKCHIP=y +CONFIG_RTL8169=y +CONFIG_PCIE_DW_ROCKCHIP=y +CONFIG_PHY_ROCKCHIP_INNO_USB2=y +CONFIG_PHY_ROCKCHIP_NANENG_COMBOPHY=y +CONFIG_PHY_ROCKCHIP_USBDP=y +CONFIG_SPL_PINCTRL=y +CONFIG_PWM_ROCKCHIP=y +CONFIG_SPL_RAM=y +CONFIG_BAUDRATE=1500000 +CONFIG_DEBUG_UART_SHIFT=2 +CONFIG_SYS_NS16550_MEM32=y +CONFIG_SYSRESET=y +CONFIG_USB=y +CONFIG_USB_XHCI_HCD=y +CONFIG_USB_EHCI_HCD=y +CONFIG_USB_EHCI_GENERIC=y +CONFIG_USB_OHCI_HCD=y +CONFIG_USB_OHCI_GENERIC=y +CONFIG_USB_DWC3=y +CONFIG_USB_DWC3_GENERIC=y +CONFIG_USB_GADGET=y +CONFIG_USB_GADGET_DOWNLOAD=y +CONFIG_USB_FUNCTION_ROCKUSB=y +CONFIG_ERRNO_STR=y diff --git a/doc/board/rockchip/rockchip.rst b/doc/board/rockchip/rockchip.rst index d04fc6d3c6..6b951cda52 100644 --- a/doc/board/rockchip/rockchip.rst +++ b/doc/board/rockchip/rockchip.rst @@ -125,6 +125,7 @@ List of mainline supported Rockchip boards: - Edgeble Neural Compute Module 6B SoM - Neu6b (neu6b-io-rk3588) - FriendlyElec NanoPC-T6 (nanopc-t6-rk3588) - FriendlyElec NanoPi R6C (nanopi-r6c-rk3588s) + - FriendlyElec NanoPi R6S (nanopi-r6s-rk3588s) - Generic RK3588S/RK3588 (generic-rk3588) - Indiedroid Nova (nova-rk3588s) - Pine64 QuartzPro64 (quartzpro64-rk3588) diff --git a/include/configs/nanopi-r6s-rk3588s.h b/include/configs/nanopi-r6s-rk3588s.h new file mode 100644 index 0000000000..a1b19783c5 --- /dev/null +++ b/include/configs/nanopi-r6s-rk3588s.h @@ -0,0 +1,12 @@ +/* SPDX-License-Identifier: GPL-2.0+ */ + +#ifndef __NANOPI_R6S_RK3588S_H +#define __NANOPI_R6S_RK3588S_H + +#define ROCKCHIP_DEVICE_SETTINGS \ + "stdout=serial,vidconsole\0" \ + "stderr=serial,vidconsole\0" + +#include <configs/rk3588_common.h> + +#endif /* __NANOPI_R6S_RK3588S_H */
Sebastian Kropatsch
