[U-Boot] [PATCH] nios2: remove epled driver
The epled driver was replaced by altera_pio and gpio_led.
Signed-off-by: Thomas Chou thomas@wytron.com.tw --- board/altera/common/epled.c | 46 ----------------------------------- board/altera/nios2-generic/Makefile | 1 - 2 files changed, 0 insertions(+), 47 deletions(-) delete mode 100644 board/altera/common/epled.c
diff --git a/board/altera/common/epled.c b/board/altera/common/epled.c deleted file mode 100644 index 580d590..0000000 --- a/board/altera/common/epled.c +++ /dev/null @@ -1,46 +0,0 @@ -/* - * (C) Copyright 2004, Psyent Corporation <www.psyent.com> - * Scott McNutt smcnutt@psyent.com - * - * SPDX-License-Identifier: GPL-2.0+ - */ - -#include <common.h> -#include <asm/io.h> -#include <nios2-io.h> -#include <status_led.h> - -/* The LED port is configured as output only, so we - * must track the state manually. - */ -static led_id_t val = 0; - -void __led_init (led_id_t mask, int state) -{ - nios_pio_t *pio = (nios_pio_t *)CONFIG_SYS_LEDPIO_ADDR; - - if (state == STATUS_LED_ON) - val &= ~mask; - else - val |= mask; - writel (val, &pio->data); -} - -void __led_set (led_id_t mask, int state) -{ - nios_pio_t *pio = (nios_pio_t *)CONFIG_SYS_LEDPIO_ADDR; - - if (state == STATUS_LED_ON) - val &= ~mask; - else - val |= mask; - writel (val, &pio->data); -} - -void __led_toggle (led_id_t mask) -{ - nios_pio_t *pio = (nios_pio_t *)CONFIG_SYS_LEDPIO_ADDR; - - val ^= mask; - writel (val, &pio->data); -} diff --git a/board/altera/nios2-generic/Makefile b/board/altera/nios2-generic/Makefile index aa362b3..d3c5b43 100644 --- a/board/altera/nios2-generic/Makefile +++ b/board/altera/nios2-generic/Makefile @@ -8,5 +8,4 @@
obj-y := nios2-generic.o obj-$(CONFIG_CMD_IDE) += ../common/cfide.o -obj-$(CONFIG_EPLED) += ../common/epled.o obj-y += text_base.o
Hi Thomas,
Applied.
Thomas Chou
