[PATCH] arm: riscv: Remove additional ifdef from code guarded by CONFIG_IS_ENABLED
CONFIG_OF_LIBFDT is used twice for guarding the same code. It is enough to do it once that's why remove additional ifdefs from arm and risc-v code.
Fixes: 0c303f9a6628 ("image: Drop IMAGE_ENABLE_OF_LIBFDT") Signed-off-by: Michal Simek michal.simek@amd.com ---
arch/arm/lib/bootm.c | 2 -- arch/riscv/lib/bootm.c | 2 -- 2 files changed, 4 deletions(-)
diff --git a/arch/arm/lib/bootm.c b/arch/arm/lib/bootm.c index a59a5e6c0ea0..fc22befeac1f 100644 --- a/arch/arm/lib/bootm.c +++ b/arch/arm/lib/bootm.c @@ -200,12 +200,10 @@ static void boot_prep_linux(bootm_headers_t *images) char *commandline = env_get("bootargs");
if (CONFIG_IS_ENABLED(OF_LIBFDT) && images->ft_len) { -#ifdef CONFIG_OF_LIBFDT debug("using: FDT\n"); if (image_setup_linux(images)) { panic("FDT creation failed!"); } -#endif } else if (BOOTM_ENABLE_TAGS) { debug("using: ATAGS\n"); setup_start_tag(gd->bd); diff --git a/arch/riscv/lib/bootm.c b/arch/riscv/lib/bootm.c index 2e1e286c8ef6..c1ac339283a6 100644 --- a/arch/riscv/lib/bootm.c +++ b/arch/riscv/lib/bootm.c @@ -65,13 +65,11 @@ static void announce_and_cleanup(int fake) static void boot_prep_linux(bootm_headers_t *images) { if (CONFIG_IS_ENABLED(OF_LIBFDT) && images->ft_len) { -#ifdef CONFIG_OF_LIBFDT debug("using: FDT\n"); if (image_setup_linux(images)) { printf("FDT creation failed! hanging..."); hang(); } -#endif } else { printf("Device tree not found or missing FDT support\n"); hang();
Applied. M
Michal Simek
Michal Simek
