[PULL u-boot] Please pull u-boot-amlogic-20210222
Hi Tom,
These changes adds support for reading the ADC key on the Khadas VIM3 & VIM3L, in the same time it adds plumbing for ADC keys and a test for sandbox.
The CI job is at https://gitlab.denx.de/u-boot/custodians/u-boot-amlogic/pipelines/6461
Thanks, Neil
The following changes since commit 496f49464d90b564da5f1a2f4eecb5553e01edf9:
Merge branch '2021-02-16-assorted-improvements' (2021-02-16 15:14:34 -0500)
https://gitlab.denx.de/u-boot/custodians/u-boot-amlogic.git tags/u-boot-amlogic-20210222
for you to fetch changes up to 2d339efb1ff941705a770e93494427912689ce18:
button: add udevice forward declaration (2021-02-22 11:07:57 +0100)
---------------------------------------------------------------- - adds adc-keys button driver - fix meson-saradc driver to get reference voltage - add adc-keys test for sandbox - enable adc-keys for VIM3 & VIM3L boards - fix button.h build
---------------------------------------------------------------- Marek Szyprowski (5): dt-bindings: input: adc-keys bindings documentation button: add a simple Analog to Digital Converter device based button driver adc: meson-saradc: add support for getting reference voltage value configs: khadas-vim3(l): enable Function button support test: add a simple test for the adc-keys button driver
Neil Armstrong (1): button: add udevice forward declaration
arch/sandbox/dts/test.dts | 28 +++++- configs/khadas-vim3_defconfig | 2 + configs/khadas-vim3l_defconfig | 2 + configs/sandbox_defconfig | 1 + doc/device-tree-bindings/input/adc-keys.txt | 67 +++++++++++++ drivers/adc/meson-saradc.c | 21 ++++ drivers/button/Kconfig | 8 ++ drivers/button/Makefile | 1 + drivers/button/button-adc.c | 146 ++++++++++++++++++++++++++++ include/button.h | 2 + test/dm/button.c | 50 +++++++++- 11 files changed, 325 insertions(+), 3 deletions(-) create mode 100644 doc/device-tree-bindings/input/adc-keys.txt create mode 100644 drivers/button/button-adc.c
On Mon, Feb 22, 2021 at 03:30:36PM +0100, Neil Armstrong wrote:
Hi Tom,
Thanks, Neil
First up, I've applied this to u-boot/master, as there's some small problems, but I don't want to make you recreate the tag. That said, running ./scripts/checkpatch.pl -q --git on this shows that the ADC changes all add "treshold" fields, etc, and not "threshold" fields. A follow-up to fix this, before the misspelling propagates more would be appreciated. Thanks!
Hi Tom,
Thanks, Neil
Thanks for seeing this, I'll fixup ans resubmit !
Neil
Neil Armstrong
