[PATCH v2 0/8] imx8mp: Enable PCIe/NVMe support
pcie_imx doesn't seem to share any useful code for iMX8MP SoC and it is rather tied to quite old port of pcie_designware driver from Linux which suffices only iMX6 specific needs.
But currently we have the common DWC specific bits which alligns pretty well with DW PCIe controller on iMX8MP SoC. So lets reuse those common bits instead as a new driver for iMX8 SoCs. It should be fairly easy to add support for other iMX8 variants to this driver.
iMX8MP SoC also comes up with standalone PCIe PHY support, so hence we can reuse the generic PHY infrastructure to power on PCIe PHY.
Patch #1: Adds PCIe clocks support. Patch #2: Adds i.MX8MP reset controller support. Patch #3: Extend i.MX8MP power domain driver with PCIe support Patch #4: Expose high performance PLL clock required for PCIe PHY on verdin board. Patch #5: Adds standalone PCIe PHY support for i.MX8MP SoC. Patch #6: Adds DW PCIe controller support for iMX8MP SoC. Patch #7: Enable PCIe/NVMe support for verdin board.
Testing with this patch-set included:
Verdin iMX8MP # pci enum PCIE-0: Link up (Gen1-x1, Bus0) Verdin iMX8MP # Verdin iMX8MP # nvme scan Verdin iMX8MP # Verdin iMX8MP # nvme info Device 0: Vendor: 0x126f Rev: T0828A0 Prod: AA000000000000000720 Type: Hard Disk Capacity: 122104.3 MB = 119.2 GB (250069680 x 512) Verdin iMX8MP # Verdin iMX8MP # load nvme 0 $loadaddr <file-name>
Changes in v2: - Renamed PCIe IMX driver pcie_dw_imx8.c -> pcie_dw_imx.c. - Added myself as maintainer for PCIe DWC IMX driver support. - Incorporated various code and commit message improvement suggestions from Marek, thanks. - Patch#3: Gate PCIe and USB clocks behind corresponding power domain IDs. - Patch#4: Expose HSIO PLL clocks as a regular clock driver instead similar to what Linux kernel does. - Patch#7: Picked up tags.
Sumit Garg (8): clk: imx8mp: Add support for PCIe clocks reset: imx: Add support for i.MX8MP reset controller imx8mp: power-domain: Add PCIe support imx8mp: power-domain: Expose high performance PLL clock phy: phy-imx8m-pcie: Add support for i.MX8M{M/P} PCIe PHY pci: Add DW PCIe controller support for iMX8MP SoC verdin-imx8mp_defconfig: Enable PCIe/NVMe support MAINTAINERS: Add entry for PCIe DWC IMX driver
MAINTAINERS | 6 + configs/verdin-imx8mp_defconfig | 6 + drivers/clk/imx/clk-imx8mp.c | 6 + drivers/pci/Kconfig | 8 + drivers/pci/Makefile | 1 + drivers/pci/pcie_dw_imx.c | 314 ++++++++++++++++++++++++++ drivers/phy/Kconfig | 9 + drivers/phy/Makefile | 1 + drivers/phy/phy-imx8m-pcie.c | 269 ++++++++++++++++++++++ drivers/power/domain/imx8mp-hsiomix.c | 179 +++++++++++++-- drivers/reset/reset-imx7.c | 114 ++++++++++ 11 files changed, 890 insertions(+), 23 deletions(-) create mode 100644 drivers/pci/pcie_dw_imx.c create mode 100644 drivers/phy/phy-imx8m-pcie.c
Pre-requisite to enable PCIe support on iMX8MP SoC.
Signed-off-by: Sumit Garg sumit.garg@linaro.org --- drivers/clk/imx/clk-imx8mp.c | 6 ++++++ 1 file changed, 6 insertions(+)
diff --git a/drivers/clk/imx/clk-imx8mp.c b/drivers/clk/imx/clk-imx8mp.c index a21a3ce34bbc..7dfc829df2c4 100644 --- a/drivers/clk/imx/clk-imx8mp.c +++ b/drivers/clk/imx/clk-imx8mp.c @@ -62,6 +62,10 @@ static const char *imx8mp_dram_apb_sels[] = {"clock-osc-24m", "sys_pll2_200m", " "sys_pll1_160m", "sys_pll1_800m", "sys_pll3_out", "sys_pll2_250m", "audio_pll2_out", };
+static const char * const imx8mp_pcie_aux_sels[] = {"clock-osc-24m", "sys_pll2_200m", "sys_pll2_50m", + "sys_pll3_out", "sys_pll2_100m", "sys_pll1_80m", + "sys_pll1_160m", "sys_pll1_200m", }; + static const char *imx8mp_i2c5_sels[] = {"clock-osc-24m", "sys_pll1_160m", "sys_pll2_50m", "sys_pll3_out", "audio_pll1_out", "video_pll1_out", "audio_pll2_out", "sys_pll1_133m", }; @@ -272,6 +276,7 @@ static int imx8mp_clk_probe(struct udevice *dev)
clk_dm(IMX8MP_CLK_DRAM_ALT, imx8m_clk_composite("dram_alt", imx8mp_dram_alt_sels, base + 0xa000)); clk_dm(IMX8MP_CLK_DRAM_APB, imx8m_clk_composite_critical("dram_apb", imx8mp_dram_apb_sels, base + 0xa080)); + clk_dm(IMX8MP_CLK_PCIE_AUX, imx8m_clk_composite("pcie_aux", imx8mp_pcie_aux_sels, base + 0xa400)); clk_dm(IMX8MP_CLK_I2C5, imx8m_clk_composite("i2c5", imx8mp_i2c5_sels, base + 0xa480)); clk_dm(IMX8MP_CLK_I2C6, imx8m_clk_composite("i2c6", imx8mp_i2c6_sels, base + 0xa500)); clk_dm(IMX8MP_CLK_ENET_QOS, imx8m_clk_composite("enet_qos", imx8mp_enet_qos_sels, base + 0xa880)); @@ -322,6 +327,7 @@ static int imx8mp_clk_probe(struct udevice *dev) clk_dm(IMX8MP_CLK_I2C2_ROOT, imx_clk_gate4("i2c2_root_clk", "i2c2", base + 0x4180, 0)); clk_dm(IMX8MP_CLK_I2C3_ROOT, imx_clk_gate4("i2c3_root_clk", "i2c3", base + 0x4190, 0)); clk_dm(IMX8MP_CLK_I2C4_ROOT, imx_clk_gate4("i2c4_root_clk", "i2c4", base + 0x41a0, 0)); + clk_dm(IMX8MP_CLK_PCIE_ROOT, imx_clk_gate4("pcie_root_clk", "pcie_aux", base + 0x4250, 0)); clk_dm(IMX8MP_CLK_PWM1_ROOT, imx_clk_gate4("pwm1_root_clk", "pwm1", base + 0x4280, 0)); clk_dm(IMX8MP_CLK_PWM2_ROOT, imx_clk_gate4("pwm2_root_clk", "pwm2", base + 0x4290, 0)); clk_dm(IMX8MP_CLK_PWM3_ROOT, imx_clk_gate4("pwm3_root_clk", "pwm3", base + 0x42a0, 0));
On Mon, 26 Feb 2024 at 14:24, Marek Vasut marex@denx.de wrote:
Commit message needs fixing.
Ack, I missed this one.
-Sumit
Add support for i.MX8MP reset controller, it has same reset IP inside but with different module layout.
Inspired from counterpart Linux kernel v6.8-rc3 driver: drivers/reset/reset-imx7.c.
Signed-off-by: Sumit Garg sumit.garg@linaro.org --- drivers/reset/reset-imx7.c | 114 +++++++++++++++++++++++++++++++++++++ 1 file changed, 114 insertions(+)
diff --git a/drivers/reset/reset-imx7.c b/drivers/reset/reset-imx7.c index eaef2cc2cdf4..c1de84dea8ba 100644 --- a/drivers/reset/reset-imx7.c +++ b/drivers/reset/reset-imx7.c @@ -10,6 +10,7 @@ #include <dm.h> #include <dt-bindings/reset/imx7-reset.h> #include <dt-bindings/reset/imx8mq-reset.h> +#include <dt-bindings/reset/imx8mp-reset.h> #include <reset-uclass.h> #include <linux/bitops.h> #include <linux/delay.h> @@ -252,6 +253,115 @@ static int imx7_reset_assert_imx8mq(struct reset_ctl *rst) return 0; }
+enum imx8mp_src_registers { + SRC_SUPERMIX_RCR = 0x0018, + SRC_AUDIOMIX_RCR = 0x001c, + SRC_MLMIX_RCR = 0x0028, + SRC_GPU2D_RCR = 0x0038, + SRC_GPU3D_RCR = 0x003c, + SRC_VPU_G1_RCR = 0x0048, + SRC_VPU_G2_RCR = 0x004c, + SRC_VPUVC8KE_RCR = 0x0050, + SRC_NOC_RCR = 0x0054, +}; + +static const struct imx7_src_signal imx8mp_src_signals[IMX8MP_RESET_NUM] = { + [IMX8MP_RESET_A53_CORE_POR_RESET0] = { SRC_A53RCR0, BIT(0) }, + [IMX8MP_RESET_A53_CORE_POR_RESET1] = { SRC_A53RCR0, BIT(1) }, + [IMX8MP_RESET_A53_CORE_POR_RESET2] = { SRC_A53RCR0, BIT(2) }, + [IMX8MP_RESET_A53_CORE_POR_RESET3] = { SRC_A53RCR0, BIT(3) }, + [IMX8MP_RESET_A53_CORE_RESET0] = { SRC_A53RCR0, BIT(4) }, + [IMX8MP_RESET_A53_CORE_RESET1] = { SRC_A53RCR0, BIT(5) }, + [IMX8MP_RESET_A53_CORE_RESET2] = { SRC_A53RCR0, BIT(6) }, + [IMX8MP_RESET_A53_CORE_RESET3] = { SRC_A53RCR0, BIT(7) }, + [IMX8MP_RESET_A53_DBG_RESET0] = { SRC_A53RCR0, BIT(8) }, + [IMX8MP_RESET_A53_DBG_RESET1] = { SRC_A53RCR0, BIT(9) }, + [IMX8MP_RESET_A53_DBG_RESET2] = { SRC_A53RCR0, BIT(10) }, + [IMX8MP_RESET_A53_DBG_RESET3] = { SRC_A53RCR0, BIT(11) }, + [IMX8MP_RESET_A53_ETM_RESET0] = { SRC_A53RCR0, BIT(12) }, + [IMX8MP_RESET_A53_ETM_RESET1] = { SRC_A53RCR0, BIT(13) }, + [IMX8MP_RESET_A53_ETM_RESET2] = { SRC_A53RCR0, BIT(14) }, + [IMX8MP_RESET_A53_ETM_RESET3] = { SRC_A53RCR0, BIT(15) }, + [IMX8MP_RESET_A53_SOC_DBG_RESET] = { SRC_A53RCR0, BIT(20) }, + [IMX8MP_RESET_A53_L2RESET] = { SRC_A53RCR0, BIT(21) }, + [IMX8MP_RESET_SW_NON_SCLR_M7C_RST] = { SRC_M4RCR, BIT(0) }, + [IMX8MP_RESET_OTG1_PHY_RESET] = { SRC_USBOPHY1_RCR, BIT(0) }, + [IMX8MP_RESET_OTG2_PHY_RESET] = { SRC_USBOPHY2_RCR, BIT(0) }, + [IMX8MP_RESET_SUPERMIX_RESET] = { SRC_SUPERMIX_RCR, BIT(0) }, + [IMX8MP_RESET_AUDIOMIX_RESET] = { SRC_AUDIOMIX_RCR, BIT(0) }, + [IMX8MP_RESET_MLMIX_RESET] = { SRC_MLMIX_RCR, BIT(0) }, + [IMX8MP_RESET_PCIEPHY] = { SRC_PCIEPHY_RCR, BIT(2) }, + [IMX8MP_RESET_PCIEPHY_PERST] = { SRC_PCIEPHY_RCR, BIT(3) }, + [IMX8MP_RESET_PCIE_CTRL_APPS_EN] = { SRC_PCIEPHY_RCR, BIT(6) }, + [IMX8MP_RESET_PCIE_CTRL_APPS_TURNOFF] = { SRC_PCIEPHY_RCR, BIT(11) }, + [IMX8MP_RESET_HDMI_PHY_APB_RESET] = { SRC_HDMI_RCR, BIT(0) }, + [IMX8MP_RESET_MEDIA_RESET] = { SRC_DISP_RCR, BIT(0) }, + [IMX8MP_RESET_GPU2D_RESET] = { SRC_GPU2D_RCR, BIT(0) }, + [IMX8MP_RESET_GPU3D_RESET] = { SRC_GPU3D_RCR, BIT(0) }, + [IMX8MP_RESET_GPU_RESET] = { SRC_GPU_RCR, BIT(0) }, + [IMX8MP_RESET_VPU_RESET] = { SRC_VPU_RCR, BIT(0) }, + [IMX8MP_RESET_VPU_G1_RESET] = { SRC_VPU_G1_RCR, BIT(0) }, + [IMX8MP_RESET_VPU_G2_RESET] = { SRC_VPU_G2_RCR, BIT(0) }, + [IMX8MP_RESET_VPUVC8KE_RESET] = { SRC_VPUVC8KE_RCR, BIT(0) }, + [IMX8MP_RESET_NOC_RESET] = { SRC_NOC_RCR, BIT(0) }, +}; + +static int imx7_reset_assert_imx8mp(struct reset_ctl *rst) +{ + struct imx7_reset_priv *priv = dev_get_priv(rst->dev); + const struct imx7_src_signal *sig = imx8mp_src_signals; + u32 val; + + if (rst->id >= IMX8MP_RESET_NUM) + return -EINVAL; + + val = readl(priv->base + sig[rst->id].offset); + switch (rst->id) { + case IMX8MP_RESET_PCIE_CTRL_APPS_EN: + case IMX8MP_RESET_PCIEPHY_PERST: + val &= ~sig[rst->id].bit; + break; + default: + val |= sig[rst->id].bit; + break; + } + writel(val, priv->base + sig[rst->id].offset); + + return 0; +} + +static int imx7_reset_deassert_imx8mp(struct reset_ctl *rst) +{ + struct imx7_reset_priv *priv = dev_get_priv(rst->dev); + const struct imx7_src_signal *sig = imx8mp_src_signals; + u32 val; + + if (rst->id >= IMX8MP_RESET_NUM) + return -EINVAL; + + if (rst->id == IMX8MP_RESET_PCIEPHY) { + /* + * wait for more than 10us to release phy g_rst and + * btnrst + */ + udelay(10); + } + + val = readl(priv->base + sig[rst->id].offset); + switch (rst->id) { + case IMX8MP_RESET_PCIE_CTRL_APPS_EN: + case IMX8MP_RESET_PCIEPHY_PERST: + val |= sig[rst->id].bit; + break; + default: + val &= ~sig[rst->id].bit; + break; + } + writel(val, priv->base + sig[rst->id].offset); + + return 0; +} + static int imx7_reset_assert(struct reset_ctl *rst) { struct imx7_reset_priv *priv = dev_get_priv(rst->dev); @@ -272,6 +382,7 @@ static const struct reset_ops imx7_reset_reset_ops = { static const struct udevice_id imx7_reset_ids[] = { { .compatible = "fsl,imx7d-src" }, { .compatible = "fsl,imx8mq-src" }, + { .compatible = "fsl,imx8mp-src" }, { } };
@@ -289,6 +400,9 @@ static int imx7_reset_probe(struct udevice *dev) } else if (device_is_compatible(dev, "fsl,imx7d-src")) { priv->ops.rst_assert = imx7_reset_assert_imx7; priv->ops.rst_deassert = imx7_reset_deassert_imx7; + } else if (device_is_compatible(dev, "fsl,imx8mp-src")) { + priv->ops.rst_assert = imx7_reset_assert_imx8mp; + priv->ops.rst_deassert = imx7_reset_deassert_imx8mp; }
Same as what ?
Use commit ID of the last change in that driver:
bad8a8afe19f ("reset: Explicitly include correct DT includes")
I guess
Same as what ?
I can expand it.
I guess
Why isn't the Linux kernel tag sufficient here? I don't see the value of cross referencing commits across different git projects.
-Sumit
Same as what ?
I can expand it.
This does not answer the question .
I guess
The commit ID is a unique identifier, tag can be rewritten .
Same as what ?
I can expand it.
The other iMX7 and iMX8 variants.
I guess
Similar arguments can be made for git commit history. But the question is have you come across such instances for Linux kernel where git release/RC tags have been rewritten?
-Sumit
Same as what ?
I can expand it.
Please add that to the commit message.
I guess
If you do rewrite history, then the commit IDs would have changed, right ?
The original commit ID would still describe the exact (old) state, the new rewritten history would have new commit IDs which describe the exact (new) state.
Linux calls those imx8mp_reset_set() can co. which is less confusing than imx7...imx8mp() , use it.
In fact, why not copy the code from Linux outright ?
IMO, it would be more confusing if we choose two different naming patterns for the same driver, see existing function names imx7_reset_{deassert/assert}_imx* pattern.
I suppose the question here is to not convert the driver to use regmap, right? If it is then that should be done as a separate cleanup patch.
However, I can extract common bits as imx8mp_reset_set() for better code reuse as the Linux kernel driver does.
-Sumit
Maybe create a patch which updates the naming scheme ?
Using two SoC names in one function name is confusing I think .
If it isn't too hard, please do the clean up first and then add the MX8MP bits on top.
I can do that as a preparatory patch.
The coding part is easy but it is rather the testing part which I am worried about as I don't have access to all the platforms which rely on this driver.
-Sumit
Don't worry about that part, I'm reasonably sure if something breaks, it will be spotted sooner rather than later.
Add support for GPCv2 power domains and clock handling for PCIe and PCIe PHY.
Signed-off-by: Sumit Garg sumit.garg@linaro.org --- drivers/power/domain/imx8mp-hsiomix.c | 101 ++++++++++++++++++++------ 1 file changed, 78 insertions(+), 23 deletions(-)
diff --git a/drivers/power/domain/imx8mp-hsiomix.c b/drivers/power/domain/imx8mp-hsiomix.c index e2d772c5ec78..58cc3f63bb56 100644 --- a/drivers/power/domain/imx8mp-hsiomix.c +++ b/drivers/power/domain/imx8mp-hsiomix.c @@ -16,48 +16,73 @@ #define GPR_REG0 0x0 #define PCIE_CLOCK_MODULE_EN BIT(0) #define USB_CLOCK_MODULE_EN BIT(1) +#define PCIE_PHY_APB_RST BIT(4) +#define PCIE_PHY_INIT_RST BIT(5)
struct imx8mp_hsiomix_priv { void __iomem *base; struct clk clk_usb; + struct clk clk_pcie; struct power_domain pd_bus; struct power_domain pd_usb; + struct power_domain pd_pcie; struct power_domain pd_usb_phy1; struct power_domain pd_usb_phy2; + struct power_domain pd_pcie_phy; };
static int imx8mp_hsiomix_on(struct power_domain *power_domain) { struct udevice *dev = power_domain->dev; struct imx8mp_hsiomix_priv *priv = dev_get_priv(dev); - struct power_domain *domain; + struct power_domain *domain = NULL; + struct clk *clk = NULL; + u32 gpr_reg0_bits = 0; int ret;
- ret = power_domain_on(&priv->pd_bus); - if (ret) - return ret; - - if (power_domain->id == IMX8MP_HSIOBLK_PD_USB) { + switch (power_domain->id) { + case IMX8MP_HSIOBLK_PD_USB: domain = &priv->pd_usb; - } else if (power_domain->id == IMX8MP_HSIOBLK_PD_USB_PHY1) { + clk = &priv->clk_usb; + gpr_reg0_bits |= USB_CLOCK_MODULE_EN; + break; + case IMX8MP_HSIOBLK_PD_USB_PHY1: domain = &priv->pd_usb_phy1; - } else if (power_domain->id == IMX8MP_HSIOBLK_PD_USB_PHY2) { + break; + case IMX8MP_HSIOBLK_PD_USB_PHY2: domain = &priv->pd_usb_phy2; - } else { - ret = -EINVAL; - goto err_pd; + break; + case IMX8MP_HSIOBLK_PD_PCIE: + domain = &priv->pd_pcie; + clk = &priv->clk_pcie; + gpr_reg0_bits |= PCIE_CLOCK_MODULE_EN; + break; + case IMX8MP_HSIOBLK_PD_PCIE_PHY: + domain = &priv->pd_pcie_phy; + /* Bits to deassert PCIe PHY reset */ + gpr_reg0_bits |= PCIE_PHY_APB_RST | PCIE_PHY_INIT_RST; + break; + default: + dev_err(dev, "unknown power domain id: %ld\n", + power_domain->id); + return -EINVAL; }
+ ret = power_domain_on(&priv->pd_bus); + if (ret) + return ret; + ret = power_domain_on(domain); if (ret) goto err_pd;
- ret = clk_enable(&priv->clk_usb); - if (ret) - goto err_clk; + if (clk) { + ret = clk_enable(clk); + if (ret) + goto err_clk; + }
- if (power_domain->id == IMX8MP_HSIOBLK_PD_USB) - setbits_le32(priv->base + GPR_REG0, USB_CLOCK_MODULE_EN); + setbits_le32(priv->base + GPR_REG0, gpr_reg0_bits);
@@ -73,17 +98,31 @@ static int imx8mp_hsiomix_off(struct power_domain *power_domain) struct udevice *dev = power_domain->dev; struct imx8mp_hsiomix_priv *priv = dev_get_priv(dev);
- if (power_domain->id == IMX8MP_HSIOBLK_PD_USB) + switch (power_domain->id) { + case IMX8MP_HSIOBLK_PD_USB: clrbits_le32(priv->base + GPR_REG0, USB_CLOCK_MODULE_EN); - - clk_disable(&priv->clk_usb); - - if (power_domain->id == IMX8MP_HSIOBLK_PD_USB) + clk_disable(&priv->clk_usb); power_domain_off(&priv->pd_usb); - else if (power_domain->id == IMX8MP_HSIOBLK_PD_USB_PHY1) + break; + case IMX8MP_HSIOBLK_PD_USB_PHY1: power_domain_off(&priv->pd_usb_phy1); - else if (power_domain->id == IMX8MP_HSIOBLK_PD_USB_PHY2) + break; + case IMX8MP_HSIOBLK_PD_USB_PHY2: power_domain_off(&priv->pd_usb_phy2); + break; + case IMX8MP_HSIOBLK_PD_PCIE: + clrbits_le32(priv->base + GPR_REG0, PCIE_CLOCK_MODULE_EN); + clk_disable(&priv->clk_pcie); + power_domain_off(&priv->pd_pcie); + break; + case IMX8MP_HSIOBLK_PD_PCIE_PHY: + clrbits_le32(priv->base + GPR_REG0, PCIE_PHY_APB_RST | + PCIE_PHY_INIT_RST); + power_domain_off(&priv->pd_pcie_phy); + break; + default: + break; + }
power_domain_off(&priv->pd_bus);
@@ -109,6 +148,10 @@ static int imx8mp_hsiomix_probe(struct udevice *dev) if (ret < 0) return ret;
+ ret = clk_get_by_name(dev, "pcie", &priv->clk_pcie); + if (ret < 0) + return ret; + ret = power_domain_get_by_name(dev, &priv->pd_bus, "bus"); if (ret < 0) return ret; @@ -125,8 +168,20 @@ static int imx8mp_hsiomix_probe(struct udevice *dev) if (ret < 0) goto err_pd_usb_phy2;
+ ret = power_domain_get_by_name(dev, &priv->pd_pcie, "pcie"); + if (ret < 0) + goto err_pd_pcie; + + ret = power_domain_get_by_name(dev, &priv->pd_pcie_phy, "pcie-phy"); + if (ret < 0) + goto err_pd_pcie_phy; + return 0;
+err_pd_pcie_phy: + power_domain_free(&priv->pd_pcie); +err_pd_pcie: + power_domain_free(&priv->pd_usb_phy2); err_pd_usb_phy2: power_domain_free(&priv->pd_usb_phy1); err_pd_usb_phy1:
- struct power_domain *domain = NULL;
- struct clk *clk = NULL;
- u32 gpr_reg0_bits = 0; int ret;
- if (ret)
return ret;
- switch (power_domain->id) {
- case IMX8MP_HSIOBLK_PD_USB: domain = &priv->pd_usb;
break;
- case IMX8MP_HSIOBLK_PD_USB_PHY1: domain = &priv->pd_usb_phy1;
break;
- case IMX8MP_HSIOBLK_PD_USB_PHY2: domain = &priv->pd_usb_phy2;
- } else {
ret = -EINVAL;
goto err_pd;
break;
break;
break;
default:
power_domain->id);
return -EINVAL;
if (ret)
return ret;
- if (ret)
goto err_clk;
- if (clk) {
if (ret)
goto err_clk;
- setbits_le32(priv->base + GPR_REG0, gpr_reg0_bits);
Are you sure it is OK to do this unconditionally ?
Why not this:
if (gpr_reg0_bits) setbits_le32(priv->base + GPR_REG0, gpr_reg0_bits);
- case IMX8MP_HSIOBLK_PD_USB: clrbits_le32(priv->base + GPR_REG0, USB_CLOCK_MODULE_EN);
power_domain_off(&priv->pd_usb);clk_disable(&priv->clk_usb);
break;
- case IMX8MP_HSIOBLK_PD_USB_PHY1: power_domain_off(&priv->pd_usb_phy1);
break;
- case IMX8MP_HSIOBLK_PD_USB_PHY2: power_domain_off(&priv->pd_usb_phy2);
break;
- case IMX8MP_HSIOBLK_PD_PCIE:
Maybe we need some function ... imx8mp_hsiomix_id_to_pd() to avoid this duplicate switch statement:
pd = imx8mp_hsiomix_id_to_pd(...) ... power_domain_off(fd);
break;
- case IMX8MP_HSIOBLK_PD_PCIE_PHY:
PCIE_PHY_INIT_RST);
Is it OK to turn off the bus PD after this ? Please double-check if power_domain_on/off() is refcounted .
break;
default:
break;
- ret = clk_get_by_name(dev, "pcie", &priv->clk_pcie);
- if (ret < 0)
return ret;
- ret = power_domain_get_by_name(dev, &priv->pd_bus, "bus"); if (ret < 0) return ret;
Some clk_put() seems to be missing for clk_pcie .
if (ret)
return ret;
break;
break;
} else {
ret = -EINVAL;
goto err_pd;
break;
break;
break;
default:
power_domain->id);
return -EINVAL; }
if (ret)
return ret;
if (ret)
goto err_clk;
if (clk) {
if (ret)
goto err_clk;
Although setbits_le32(addr, 0) should be a nop but...
Why not this:
...if we can avoid that then it's better. I will make it conditional.
break;
break;
break;
But still we need another switch case for clocks and GPR_REG0 bits to be configured.
break;
PCIE_PHY_INIT_RST);
I can't see refcounting being implemented in imx8m-power-domain.c. This seems to be an existing issue with USB support too.
break;
default:
break;
} power_domain_off(&priv->pd_bus);
I suppose we should just be fine to drop bus PD off from here.
if (ret < 0)
return ret;
I can't see clk_put() as any generic API. However, there used to be clk_free() which was dropped by this commit [1].
[1] https://source.denx.de/u-boot/u-boot/-/commit/c9309f40a6831b1ac5cd0a7227b5c3...
-Sumit
Expose the high performance PLL as a regular Linux clock, so the PCIe PHY can use it when there is no external refclock provided.
Inspired from counterpart Linux kernel v6.8-rc3 driver: drivers/pmdomain/imx/imx8mp-blk-ctrl.c
Signed-off-by: Sumit Garg sumit.garg@linaro.org --- drivers/power/domain/imx8mp-hsiomix.c | 78 +++++++++++++++++++++++++++ 1 file changed, 78 insertions(+)
diff --git a/drivers/power/domain/imx8mp-hsiomix.c b/drivers/power/domain/imx8mp-hsiomix.c index 58cc3f63bb56..3e514a603578 100644 --- a/drivers/power/domain/imx8mp-hsiomix.c +++ b/drivers/power/domain/imx8mp-hsiomix.c @@ -6,9 +6,15 @@ #include <common.h> #include <asm/io.h> #include <clk.h> +#include <clk-uclass.h> #include <dm.h> #include <dm/device.h> #include <dm/device_compat.h> +#include <dm/device-internal.h> +#include <dm/lists.h> +#include <linux/bitfield.h> +#include <linux/delay.h> +#include <linux/iopoll.h> #include <power-domain-uclass.h>
#include <dt-bindings/power/imx8mp-power.h> @@ -18,6 +24,15 @@ #define USB_CLOCK_MODULE_EN BIT(1) #define PCIE_PHY_APB_RST BIT(4) #define PCIE_PHY_INIT_RST BIT(5) +#define GPR_REG1 0x4 +#define PLL_LOCK BIT(13) +#define GPR_REG2 0x8 +#define P_PLL_MASK GENMASK(5, 0) +#define M_PLL_MASK GENMASK(15, 6) +#define S_PLL_MASK GENMASK(18, 16) +#define GPR_REG3 0xc +#define PLL_CKE BIT(17) +#define PLL_RST BIT(31)
struct imx8mp_hsiomix_priv { void __iomem *base; @@ -137,6 +152,68 @@ static int imx8mp_hsiomix_of_xlate(struct power_domain *power_domain, return 0; }
+static int hsio_pll_clk_enable(struct clk *clk) +{ + void *base = (void *)dev_get_driver_data(clk->dev); + u32 val; + int ret; + + /* Setup HSIO PLL */ + clrsetbits_le32(base + GPR_REG2, + P_PLL_MASK | M_PLL_MASK | S_PLL_MASK, + FIELD_PREP(P_PLL_MASK, 12) | + FIELD_PREP(M_PLL_MASK, 800) | + FIELD_PREP(S_PLL_MASK, 4)); + + /* de-assert PLL reset */ + setbits_le32(base + GPR_REG3, PLL_RST); + + /* enable PLL */ + setbits_le32(base + GPR_REG3, PLL_CKE); + + /* Check if PLL is locked */ + ret = readl_poll_sleep_timeout(base + GPR_REG1, val, + val & PLL_LOCK, 10, 100000); + if (ret) + dev_err(clk->dev, "failed to lock HSIO PLL\n"); + + return ret; +} + +static int hsio_pll_clk_disable(struct clk *clk) +{ + void *base = (void *)dev_get_driver_data(clk->dev); + + clrbits_le32(base + GPR_REG3, PLL_CKE); + clrbits_le32(base + GPR_REG3, PLL_RST); + + return 0; +} + +static const struct clk_ops hsio_pll_clk_ops = { + .enable = hsio_pll_clk_enable, + .disable = hsio_pll_clk_disable, +}; + +U_BOOT_DRIVER(hsio_pll) = { + .name = "hsio-pll", + .id = UCLASS_CLK, + .ops = &hsio_pll_clk_ops, +}; + +int imx8mp_hsiomix_bind(struct udevice *dev) +{ + struct driver *drv; + + drv = lists_driver_lookup_name("hsio-pll"); + if (!drv) + return -ENOENT; + + return device_bind_with_driver_data(dev, drv, "hsio-pll", + (ulong)dev_read_addr_ptr(dev), + dev_ofnode(dev), NULL); +} + static int imx8mp_hsiomix_probe(struct udevice *dev) { struct imx8mp_hsiomix_priv *priv = dev_get_priv(dev); @@ -207,6 +284,7 @@ U_BOOT_DRIVER(imx8mp_hsiomix) = { .id = UCLASS_POWER_DOMAIN, .of_match = imx8mp_hsiomix_ids, .probe = imx8mp_hsiomix_probe, + .bind = imx8mp_hsiomix_bind, .priv_auto = sizeof(struct imx8mp_hsiomix_priv), .ops = &imx8mp_hsiomix_ops, };
Commit ID, please, see previous comments in this series.
- void *base = (void *)dev_get_driver_data(clk->dev);
- u32 val;
- int ret;
- /* Setup HSIO PLL */
- clrsetbits_le32(base + GPR_REG2,
These magic numbers 12, 800, 4 could use explanation (why these numbers?) and a dedicated macro .
- /* de-assert PLL reset */
- setbits_le32(base + GPR_REG3, PLL_RST);
- /* enable PLL */
- setbits_le32(base + GPR_REG3, PLL_CKE);
- /* Check if PLL is locked */
- ret = readl_poll_sleep_timeout(base + GPR_REG1, val,
- if (ret)
- return ret;
- clrbits_le32(base + GPR_REG3, PLL_CKE);
- clrbits_le32(base + GPR_REG3, PLL_RST);
Can you clear both at once, or do they have to be cleared in sequence ?
The series is starting to look much better compared to V1 btw , these ^ are only nitpicks .
u32 val;
int ret;
I can't find any information in TRM as to how HSIO PLL computation is done. However, I can extend the comment above to say that this configuration leads to a 100 MHz PHY clock as per clk_hsio_pll_recalc_rate() in Linux kernel driver.
/* enable PLL */
if (ret)
return ret;
I generally follow the reverse sequence of how the configuration is done during hsio_pll_clk_enable(). These bits have seperate functions related to clock and reset. So I would prefer to keep them as they are.
Thanks for your detailed review, I appreciate it.
-Sumit
u32 val;
int ret;
Try the CCM section 5.1.5.4.4 SSCG and Fractional PLLs I think, this is likely PLL14xxx from Samsung, so
f_out = f_in * M / P * 2^S
I think f_in is something like 24 MHz, so 24 * 800 / 12 * 16 = 100 MHz
P - predivider S - subdivider (output divider) M - multiplier
/* enable PLL */
if (ret)
return ret;
Linux does this in drivers/pmdomain/imx/imx8mp-blk-ctrl.c :
120 static void clk_hsio_pll_unprepare(struct clk_hw *hw) 121 { 122 struct clk_hsio_pll *clk = to_clk_hsio_pll(hw); 123 124 regmap_update_bits(clk->regmap, GPR_REG3, PLL_RST | PLL_CKE, 0); 125 }
u32 val;
int ret;
That section also does mention following:
"The ARM PLL, GPU PLL, VPU PLL, DRAM PLL, Audio PLL1/2, and Video PLL1 are fractional PLLs. The frequency on these can be tuned to be very accurate to meet audio and video interface requirements."
without any mention of HSIO PLL.
IMO, we shouldn't document something based on our analysis but rather it should be based on facts.
/* enable PLL */
if (ret)
return ret;
And just above it:
static int clk_hsio_pll_prepare(struct clk_hw *hw) { ... /* de-assert PLL reset */ regmap_update_bits(clk->regmap, GPR_REG3, PLL_RST, PLL_RST);
/* enable PLL */ regmap_update_bits(clk->regmap, GPR_REG3, PLL_CKE, PLL_CKE); ... }
That's an anti-pattern in the Linux kernel driver which we shouldn't copy, right?
-Sumit
u32 val;
int ret;
See ^
Frankly, all the PLLs in the MX8M are very much similar, so either wait for someone from NXP to confirm this, or try and find some statement in the MX8MPRM .
And just above it:
This is the enable part which is done in sequence, the part I quoted is the disable part.
Add initial support for i.MX8M{M/P} PCIe PHY. On i.MX8M{M/P} SoCs PCIe PHY initialization moved to this standalone PHY driver.
Inspired from counterpart Linux kernel v6.8-rc3 driver: drivers/phy/freescale/phy-fsl-imx8m-pcie.c.
Signed-off-by: Sumit Garg sumit.garg@linaro.org --- drivers/phy/Kconfig | 9 ++ drivers/phy/Makefile | 1 + drivers/phy/phy-imx8m-pcie.c | 269 +++++++++++++++++++++++++++++++++++ 3 files changed, 279 insertions(+) create mode 100644 drivers/phy/phy-imx8m-pcie.c
diff --git a/drivers/phy/Kconfig b/drivers/phy/Kconfig index 60138beca498..110ec8f5008d 100644 --- a/drivers/phy/Kconfig +++ b/drivers/phy/Kconfig @@ -284,6 +284,15 @@ config PHY_IMX8MQ_USB help Support the USB3.0 PHY in NXP i.MX8MQ or i.MX8MP SoC
+config PHY_IMX8M_PCIE + bool "NXP i.MX8MM/i.MX8MP PCIe PHY Driver" + depends on PHY + depends on IMX8MM || IMX8MP + help + Support the PCIe PHY in NXP i.MX8MM or i.MX8MP SoC + + This PHY is found on i.MX8M devices supporting PCIe. + config PHY_XILINX_ZYNQMP tristate "Xilinx ZynqMP PHY driver" depends on PHY && ARCH_ZYNQMP diff --git a/drivers/phy/Makefile b/drivers/phy/Makefile index 2e8723186c05..7a2b764492be 100644 --- a/drivers/phy/Makefile +++ b/drivers/phy/Makefile @@ -38,6 +38,7 @@ obj-$(CONFIG_PHY_DA8XX_USB) += phy-da8xx-usb.o obj-$(CONFIG_PHY_MTK_TPHY) += phy-mtk-tphy.o obj-$(CONFIG_PHY_NPCM_USB) += phy-npcm-usb.o obj-$(CONFIG_PHY_IMX8MQ_USB) += phy-imx8mq-usb.o +obj-$(CONFIG_PHY_IMX8M_PCIE) += phy-imx8m-pcie.o obj-$(CONFIG_PHY_XILINX_ZYNQMP) += phy-zynqmp.o obj-y += cadence/ obj-y += ti/ diff --git a/drivers/phy/phy-imx8m-pcie.c b/drivers/phy/phy-imx8m-pcie.c new file mode 100644 index 000000000000..e09a7ac97235 --- /dev/null +++ b/drivers/phy/phy-imx8m-pcie.c @@ -0,0 +1,269 @@ +// SPDX-License-Identifier: GPL-2.0+ +/* + * Copyright 2024 Linaro Ltd. + * + * Derived from Linux counterpart driver + */ + +#include <asm/io.h> +#include <clk.h> +#include <dm.h> +#include <dm/device_compat.h> +#include <generic-phy.h> +#include <linux/bitfield.h> +#include <linux/clk-provider.h> +#include <linux/iopoll.h> +#include <syscon.h> +#include <regmap.h> +#include <reset.h> + +#include <dt-bindings/phy/phy-imx8-pcie.h> + +#define IMX8MM_PCIE_PHY_CMN_REG061 0x184 +#define ANA_PLL_CLK_OUT_TO_EXT_IO_EN BIT(0) +#define IMX8MM_PCIE_PHY_CMN_REG062 0x188 +#define ANA_PLL_CLK_OUT_TO_EXT_IO_SEL BIT(3) +#define IMX8MM_PCIE_PHY_CMN_REG063 0x18C +#define AUX_PLL_REFCLK_SEL_SYS_PLL GENMASK(7, 6) +#define IMX8MM_PCIE_PHY_CMN_REG064 0x190 +#define ANA_AUX_RX_TX_SEL_TX BIT(7) +#define ANA_AUX_RX_TERM_GND_EN BIT(3) +#define ANA_AUX_TX_TERM BIT(2) +#define IMX8MM_PCIE_PHY_CMN_REG065 0x194 +#define ANA_AUX_RX_TERM (BIT(7) | BIT(4)) +#define ANA_AUX_TX_LVL GENMASK(3, 0) +#define IMX8MM_PCIE_PHY_CMN_REG075 0x1D4 +#define ANA_PLL_DONE 0x3 +#define PCIE_PHY_TRSV_REG5 0x414 +#define PCIE_PHY_TRSV_REG6 0x418 + +#define IMX8MM_GPR_PCIE_REF_CLK_SEL GENMASK(25, 24) +#define IMX8MM_GPR_PCIE_REF_CLK_PLL FIELD_PREP(IMX8MM_GPR_PCIE_REF_CLK_SEL, 0x3) +#define IMX8MM_GPR_PCIE_REF_CLK_EXT FIELD_PREP(IMX8MM_GPR_PCIE_REF_CLK_SEL, 0x2) +#define IMX8MM_GPR_PCIE_AUX_EN BIT(19) +#define IMX8MM_GPR_PCIE_CMN_RST BIT(18) +#define IMX8MM_GPR_PCIE_POWER_OFF BIT(17) +#define IMX8MM_GPR_PCIE_SSC_EN BIT(16) +#define IMX8MM_GPR_PCIE_AUX_EN_OVERRIDE BIT(9) + +#define IOMUXC_GPR14_OFFSET 0x38 + +enum imx8_pcie_phy_type { + IMX8MM, + IMX8MP, +}; + +struct imx8_pcie_phy_drvdata { + const char *gpr; + enum imx8_pcie_phy_type variant; +}; + +struct imx8_pcie_phy { + ulong base; + struct clk hsio_clk; + struct regmap *iomuxc_gpr; + struct reset_ctl perst; + struct reset_ctl reset; + u32 refclk_pad_mode; + u32 tx_deemph_gen1; + u32 tx_deemph_gen2; + bool clkreq_unused; + const struct imx8_pcie_phy_drvdata *drvdata; +}; + +static int imx8_pcie_phy_power_on(struct phy *phy) +{ + int ret; + u32 val, pad_mode; + struct imx8_pcie_phy *imx8_phy = dev_get_priv(phy->dev); + + pad_mode = imx8_phy->refclk_pad_mode; + switch (imx8_phy->drvdata->variant) { + case IMX8MM: + reset_assert(&imx8_phy->reset); + + /* Tune PHY de-emphasis setting to pass PCIe compliance. */ + if (imx8_phy->tx_deemph_gen1) + writel(imx8_phy->tx_deemph_gen1, + imx8_phy->base + PCIE_PHY_TRSV_REG5); + if (imx8_phy->tx_deemph_gen2) + writel(imx8_phy->tx_deemph_gen2, + imx8_phy->base + PCIE_PHY_TRSV_REG6); + break; + case IMX8MP: /* Do nothing. */ + break; + } + + if (pad_mode == IMX8_PCIE_REFCLK_PAD_INPUT || + pad_mode == IMX8_PCIE_REFCLK_PAD_UNUSED) { + /* Configure the pad as input */ + val = readl(imx8_phy->base + IMX8MM_PCIE_PHY_CMN_REG061); + writel(val & ~ANA_PLL_CLK_OUT_TO_EXT_IO_EN, + imx8_phy->base + IMX8MM_PCIE_PHY_CMN_REG061); + } else { + /* Configure the PHY to output the refclock via pad */ + writel(ANA_PLL_CLK_OUT_TO_EXT_IO_EN, + imx8_phy->base + IMX8MM_PCIE_PHY_CMN_REG061); + } + + if (pad_mode == IMX8_PCIE_REFCLK_PAD_OUTPUT || + pad_mode == IMX8_PCIE_REFCLK_PAD_UNUSED) { + /* Source clock from SoC internal PLL */ + writel(ANA_PLL_CLK_OUT_TO_EXT_IO_SEL, + imx8_phy->base + IMX8MM_PCIE_PHY_CMN_REG062); + writel(AUX_PLL_REFCLK_SEL_SYS_PLL, + imx8_phy->base + IMX8MM_PCIE_PHY_CMN_REG063); + val = ANA_AUX_RX_TX_SEL_TX | ANA_AUX_TX_TERM; + writel(val | ANA_AUX_RX_TERM_GND_EN, + imx8_phy->base + IMX8MM_PCIE_PHY_CMN_REG064); + writel(ANA_AUX_RX_TERM | ANA_AUX_TX_LVL, + imx8_phy->base + IMX8MM_PCIE_PHY_CMN_REG065); + } + + /* Set AUX_EN_OVERRIDE 1'b0, when the CLKREQ# isn't hooked */ + regmap_update_bits(imx8_phy->iomuxc_gpr, IOMUXC_GPR14_OFFSET, + IMX8MM_GPR_PCIE_AUX_EN_OVERRIDE, + imx8_phy->clkreq_unused ? + 0 : IMX8MM_GPR_PCIE_AUX_EN_OVERRIDE); + regmap_update_bits(imx8_phy->iomuxc_gpr, IOMUXC_GPR14_OFFSET, + IMX8MM_GPR_PCIE_AUX_EN, + IMX8MM_GPR_PCIE_AUX_EN); + regmap_update_bits(imx8_phy->iomuxc_gpr, IOMUXC_GPR14_OFFSET, + IMX8MM_GPR_PCIE_POWER_OFF, 0); + regmap_update_bits(imx8_phy->iomuxc_gpr, IOMUXC_GPR14_OFFSET, + IMX8MM_GPR_PCIE_SSC_EN, 0); + + regmap_update_bits(imx8_phy->iomuxc_gpr, IOMUXC_GPR14_OFFSET, + IMX8MM_GPR_PCIE_REF_CLK_SEL, + pad_mode == IMX8_PCIE_REFCLK_PAD_INPUT ? + IMX8MM_GPR_PCIE_REF_CLK_EXT : + IMX8MM_GPR_PCIE_REF_CLK_PLL); + udelay(200); + + /* Do the PHY common block reset */ + regmap_update_bits(imx8_phy->iomuxc_gpr, IOMUXC_GPR14_OFFSET, + IMX8MM_GPR_PCIE_CMN_RST, + IMX8MM_GPR_PCIE_CMN_RST); + + switch (imx8_phy->drvdata->variant) { + case IMX8MP: + reset_deassert(&imx8_phy->perst); + fallthrough; + case IMX8MM: + reset_deassert(&imx8_phy->reset); + udelay(500); + break; + } + + /* Polling to check the phy is ready or not. */ + ret = readl_poll_timeout(imx8_phy->base + IMX8MM_PCIE_PHY_CMN_REG075, + val, val == ANA_PLL_DONE, 20000); + return ret; +} + +static int imx8_pcie_phy_init(struct phy *phy) +{ + struct imx8_pcie_phy *imx8_phy = dev_get_priv(phy->dev); + + return clk_enable(&imx8_phy->hsio_clk); +} + +static int imx8_pcie_phy_exit(struct phy *phy) +{ + struct imx8_pcie_phy *imx8_phy = dev_get_priv(phy->dev); + + return clk_disable(&imx8_phy->hsio_clk); +} + +static const struct phy_ops imx8_pcie_phy_ops = { + .init = imx8_pcie_phy_init, + .exit = imx8_pcie_phy_exit, + .power_on = imx8_pcie_phy_power_on, +}; + +static const struct imx8_pcie_phy_drvdata imx8mm_drvdata = { + .gpr = "fsl,imx8mm-iomuxc-gpr", + .variant = IMX8MM, +}; + +static const struct imx8_pcie_phy_drvdata imx8mp_drvdata = { + .gpr = "fsl,imx8mp-iomuxc-gpr", + .variant = IMX8MP, +}; + +static const struct udevice_id imx8_pcie_phy_of_match[] = { + {.compatible = "fsl,imx8mm-pcie-phy", .data = (ulong)&imx8mm_drvdata, }, + {.compatible = "fsl,imx8mp-pcie-phy", .data = (ulong)&imx8mp_drvdata, }, + { }, +}; + +static int imx8_pcie_phy_probe(struct udevice *dev) +{ + struct imx8_pcie_phy *imx8_phy = dev_get_priv(dev); + ofnode gpr; + int ret = 0; + + imx8_phy->drvdata = (void *)dev_get_driver_data(dev); + imx8_phy->base = dev_read_addr(dev); + if (!imx8_phy->base) + return -EINVAL; + + /* get PHY refclk pad mode */ + dev_read_u32(dev, "fsl,refclk-pad-mode", &imx8_phy->refclk_pad_mode); + + if (dev_read_u32(dev, "fsl,tx-deemph-gen1", &imx8_phy->tx_deemph_gen1)) + imx8_phy->tx_deemph_gen1 = 0; + + if (dev_read_u32(dev, "fsl,tx-deemph-gen2", &imx8_phy->tx_deemph_gen2)) + imx8_phy->tx_deemph_gen2 = 0; + + if (dev_read_bool(dev, "fsl,clkreq-unsupported")) + imx8_phy->clkreq_unused = true; + else + imx8_phy->clkreq_unused = false; + + /* Grab GPR config register range */ + gpr = ofnode_by_compatible(ofnode_null(), imx8_phy->drvdata->gpr); + if (ofnode_equal(gpr, ofnode_null())) { + dev_err(dev, "unable to find GPR node\n"); + return -ENODEV; + } + + imx8_phy->iomuxc_gpr = syscon_node_to_regmap(gpr); + if (IS_ERR(imx8_phy->iomuxc_gpr)) { + dev_err(dev, "unable to find iomuxc registers\n"); + return PTR_ERR(imx8_phy->iomuxc_gpr); + } + + ret = clk_get_by_name(dev, "ref", &imx8_phy->hsio_clk); + if (ret) { + dev_err(dev, "Failed to get PCIEPHY ref clock\n"); + return ret; + } + + ret = reset_get_by_name(dev, "pciephy", &imx8_phy->reset); + if (ret) { + dev_err(dev, "Failed to get PCIEPHY reset control\n"); + return ret; + } + + if (imx8_phy->drvdata->variant == IMX8MP) { + ret = reset_get_by_name(dev, "perst", &imx8_phy->perst); + if (ret) { + dev_err(dev, + "Failed to get PCIEPHY PHY PERST control\n"); + return ret; + } + } + + return 0; +} + +U_BOOT_DRIVER(nxp_imx8_pcie_phy) = { + .name = "nxp_imx8_pcie_phy", + .id = UCLASS_PHY, + .of_match = imx8_pcie_phy_of_match, + .probe = imx8_pcie_phy_probe, + .ops = &imx8_pcie_phy_ops, + .priv_auto = sizeof(struct imx8_pcie_phy), +};
Commit ID , see previous comments.
- struct imx8_pcie_phy *imx8_phy = dev_get_priv(dev);
- ofnode gpr;
- int ret = 0;
- imx8_phy->drvdata = (void *)dev_get_driver_data(dev);
- imx8_phy->base = dev_read_addr(dev);
- if (!imx8_phy->base)
return -EINVAL;
- /* get PHY refclk pad mode */
- dev_read_u32(dev, "fsl,refclk-pad-mode", &imx8_phy->refclk_pad_mode);
- if (dev_read_u32(dev, "fsl,tx-deemph-gen1", &imx8_phy->tx_deemph_gen1))
Use dev_read_u32_default() and you won't need the if (...)
- if (dev_read_u32(dev, "fsl,tx-deemph-gen2", &imx8_phy->tx_deemph_gen2))
- if (dev_read_bool(dev, "fsl,clkreq-unsupported"))
- else
- /* Grab GPR config register range */
- gpr = ofnode_by_compatible(ofnode_null(), imx8_phy->drvdata->gpr);
- if (ofnode_equal(gpr, ofnode_null())) {
return -ENODEV;
- imx8_phy->iomuxc_gpr = syscon_node_to_regmap(gpr);
- if (IS_ERR(imx8_phy->iomuxc_gpr)) {
- ret = clk_get_by_name(dev, "ref", &imx8_phy->hsio_clk);
- if (ret) {
return ret;
- ret = reset_get_by_name(dev, "pciephy", &imx8_phy->reset);
- if (ret) {
return ret;
Some clk_put() and co. fail path is missing here. Also .remove is missing .
ofnode gpr;
int ret = 0;
return -EINVAL;
Ack.
else
return -ENODEV;
if (ret) {
return ret;
if (ret) {
return ret;
Ditto for clk_put() not being available. However, I can add the fail path for the other reset.
Sure, I will add that to release resets.
-Sumit
if (ret) {
return ret;
Oh, maybe reset_free() and clk_release*() then ?
if (ret) {
return ret;
AFAICS, clk_release*() APIs are internally only a wrapper around clk_disable(). So actually those APIs don't seem to do anything useful in the fail path here.
However, I will let clock tree maintainers chime in here if they plan to remove clk_release*() APIs on similar lines as with clk_free().
-Sumit
if (ret) {
return ret;
Maybe they should be in place so in case in the future clock should be torn down, it wouldn't be necessary to fix so many drivers ?
if (ret) {
return ret;
See the following comparison:
$ git grep -nr clk_get_by_name | wc -l 229
$ git grep -nr clk_release | wc -l 59
There are already many driver instances which don't use clk_release*() APIs.
-Sumit
> + ret = reset_get_by_name(dev, "pciephy", &imx8_phy->reset); > + if (ret) { > + dev_err(dev, "Failed to get PCIEPHY reset control\n"); > + return ret; > + }
And that's a good argument to make the situation worse ?
I have a PCIe device that works just fine in Linux. I have applied your series an enabled the same config options as you did along with some others to resolve some build issues.
Any ideas how to address:
nxp_imx8_pcie_phy pcie-phy@32f00000: PHY: Failed to power on pcie-phy@32f00000: -110.
My PHY node looks like this
&pcie_phy { fsl,refclk-pad-mode = <IMX8_PCIE_REFCLK_PAD_INPUT>; clocks = <&pcie0_refclk>; clock-names = "ref"; status = "okay"; };
The pcie_refcllk is defined as a 100MHz fixed clock in U-Boot. clk dump shows it to be:
100000000 0 |-- clock-pcie
depends on PHY
This should also depend on SYSCON and REGMAP to prevent build errors.
help
- Copyright 2024 Linaro Ltd.
- Derived from Linux counterpart driver
IMX8MM,
IMX8MP,
const char *gpr;
ulong base;
u32 tx_deemph_gen1;
u32 tx_deemph_gen2;
bool clkreq_unused;
int ret;
u32 val, pad_mode;
case IMX8MM:
break;
break;
} else {
udelay(200);
case IMX8MP:
fallthrough;
case IMX8MM:
udelay(500);
break;
return ret;
.variant = IMX8MM,
.variant = IMX8MP,
ofnode gpr;
int ret = 0;
return -EINVAL;
else
return -ENODEV;
if (ret) {
return ret;
if (ret) {
return ret;
if (ret) {
dev_err(dev,
return ret;
.id = UCLASS_PHY,
2.34.1
Hi Adam,
I suppose that's an EVK board, try enabling MPCIE_3V3 regulator required for EVK board via following patch:
diff --git a/drivers/pci/pcie_dw_imx.c b/drivers/pci/pcie_dw_imx.c index 7856823c9188..32fd2cb05d4b 100644 --- a/drivers/pci/pcie_dw_imx.c +++ b/drivers/pci/pcie_dw_imx.c @@ -17,6 +17,7 @@ #include <linux/iopoll.h> #include <log.h> #include <pci.h> +#include <power/regulator.h> #include <regmap.h> #include <reset.h> #include <syscon.h> @@ -158,6 +159,8 @@ static int pcie_dw_imx_probe(struct udevice *dev) struct pci_controller *hose = dev_get_uclass_priv(ctlr); int ret;
+ regulator_autoset_by_name("MPCIE_3V3", NULL); + ret = imx_pcie_assert_core_reset(priv); if (ret) { dev_err(dev, "failed to assert core reset\n");
depends on PHY
Ack, I will add those.
-Sumit
help
IMX8MM,
IMX8MP,
const char *gpr;
ulong base;
u32 tx_deemph_gen1;
u32 tx_deemph_gen2;
bool clkreq_unused;
int ret;
u32 val, pad_mode;
case IMX8MM:
break;
break;
} else {
udelay(200);
case IMX8MP:
fallthrough;
case IMX8MM:
udelay(500);
break;
return ret;
.variant = IMX8MM,
.variant = IMX8MP,
ofnode gpr;
int ret = 0;
return -EINVAL;
else
return -ENODEV;
if (ret) {
return ret;
if (ret) {
return ret;
if (ret) {
dev_err(dev,
return ret;
.id = UCLASS_PHY,
2.34.1
Hi Adam,
On Wed, 28 Feb 2024 at 12:29, Sumit Garg sumit.garg@linaro.org wrote:
Hi Adam,
Were you able to give a retry with the above diff?
-Sumit
On Tue, Mar 5, 2024 at 7:48 AM Sumit Garg sumit.garg@linaro.org wrote:
Hi Adam,
Hi Adam,
Not yet, but I'll try to do it tonight.
adam
-Sumit
Hi Adam,
Hi Adam,
I think you should search the device tree for "vpcie-supply" and enable the corresponding regulator, because is more flexible than hard-coding regulator names. This is also more of a standard practice.
That didn't work for me. I am using a Beacon Embedded kit which does not use a regulator, so this had no impact, but I think having the vpcie-supply regulator is a good idea.
I'll investigate a bit more and let you know if I make any progress.
adam
adam
-Sumit
Hi Adam,
Hi Adam,
Yeah I agree, this was sort of a minimal diff to test with.
Sure, I can add that.
-Sumit
adam
adam
-Sumit
Hi Adam,
Hi Adam,
Adam and Sumit,
In case it helps this series works for PCI bus scanning for the imx8mp-venice-* boards with the following patch: diff --git a/configs/imx8mp_venice_defconfig b/configs/imx8mp_venice_defconfig index 11b356b77856..ff7ea9811ed6 100644 --- a/configs/imx8mp_venice_defconfig +++ b/configs/imx8mp_venice_defconfig @@ -12,6 +12,7 @@ CONFIG_DEFAULT_DEVICE_TREE="imx8mp-venice" CONFIG_SPL_TEXT_BASE=0x920000 CONFIG_TARGET_IMX8MP_VENICE=y CONFIG_OF_LIBFDT_OVERLAY=y +CONFIG_DM_RESET=y CONFIG_SYS_MONITOR_LEN=524288 CONFIG_SPL_MMC=y CONFIG_SPL_SERIAL=y @@ -21,6 +22,7 @@ CONFIG_SPL=y CONFIG_ENV_OFFSET_REDUND=0x3f8000 CONFIG_SPL_IMX_ROMAPI_LOADADDR=0x48000000 CONFIG_SYS_LOAD_ADDR=0x40480000 +CONFIG_PCI=y CONFIG_SYS_MEMTEST_START=0x40000000 CONFIG_SYS_MEMTEST_END=0x80000000 CONFIG_LTO=y @@ -65,6 +67,7 @@ CONFIG_CMD_FUSE=y CONFIG_CMD_GPIO=y CONFIG_CMD_I2C=y CONFIG_CMD_MMC=y +CONFIG_CMD_PCI=y CONFIG_CMD_USB=y CONFIG_SYS_DISABLE_AUTOLOAD=y CONFIG_CMD_CACHE=y @@ -86,6 +89,8 @@ CONFIG_NET_RANDOM_ETHADDR=y CONFIG_IP_DEFRAG=y CONFIG_TFTP_BLOCKSIZE=4096 CONFIG_SPL_DM=y +CONFIG_REGMAP=y +CONFIG_SYSCON=y CONFIG_CLK_COMPOSITE_CCF=y CONFIG_CLK_IMX8MP=y CONFIG_GPIO_HOG=y @@ -114,7 +119,10 @@ CONFIG_FEC_MXC=y CONFIG_KSZ9477=y CONFIG_RGMII=y CONFIG_MII=y +CONFIG_NVME_PCI=y +CONFIG_PCIE_DW_IMX=y CONFIG_PHY_IMX8MQ_USB=y +CONFIG_PHY_IMX8M_PCIE=y CONFIG_PINCTRL=y CONFIG_SPL_PINCTRL=y CONFIG_PINCTRL_IMX8M=y
on an imx8mp-venice-gw71xx-2x (imx8mp with miniPCIe socket using a miniPCIe to NVMe adapter) u-boot=> pci enum PCIE-0: Link up (Gen1-x1, Bus0) u-boot=> pci BusDevFun VendorId DeviceId Device Class Sub-Class _____________________________________________________________ 00.00.00 0x16c3 0xabcd Bridge device 0x04 01.00.00 0x10ec 0x5765 Mass storage controller 0x08 u-boot=> nvme scan u-boot=> nvme info Device 0: Vendor: 0x10ec Rev: 0426-D00 Prod: 60272-0005 Type: Hard Disk Capacity: 57241.8 MB = 55.9 GB (117231408 x 512)
I also verified this works imx8mp-venice-gw74xx (imx8mp with PCIe switch to multiple miniPCIe sockets using a miniPCIe to NVMe adapter) u-boot=> pci enum PCIE-0: Link up (Gen1-x1, Bus0) u-boot=> pci BusDevFun VendorId DeviceId Device Class Sub-Class _____________________________________________________________ 00.00.00 0x16c3 0xabcd Bridge device 0x04 01.00.00 0x12d8 0x2608 Bridge device 0x04 02.01.00 0x12d8 0x2608 Bridge device 0x04 02.02.00 0x12d8 0x2608 Bridge device 0x04 02.03.00 0x12d8 0x2608 Bridge device 0x04 02.04.00 0x12d8 0x2608 Bridge device 0x04 05.00.00 0x10ec 0x5765 Mass storage controller 0x08 u-boot=> nvme scan u-boot=> nvme info Device 0: Vendor: 0x10ec Rev: 0426-D00 Prod: 60272-0005 Type: Hard Disk Capacity: 57241.8 MB = 55.9 GB (117231408 x 512)
It looks like the imx8mp-beacon-kit has almost the same setup as the imx8mp-venice-gw74xx with the exception of you having a PCIe_nDIS gpio defined in pinctrl (used nowhere) and the gw74xx does not support CLKREQ so has 'fsl,clkreq-unsupported'.
tested-by: Tim Harvey tharvey@gateworks.com : imx8mp-venice*
Tim
Hi Adam,
Hi Adam,
On Mon, Feb 26, 2024 at 2:05 AM Sumit Garg sumit.garg@linaro.org wrote: > > Add initial support for i.MX8M{M/P} PCIe PHY. On i.MX8M{M/P} SoCs PCIe > PHY initialization moved to this standalone PHY driver. > > Inspired from counterpart Linux kernel v6.8-rc3 driver: > drivers/phy/freescale/phy-fsl-imx8m-pcie.c.
Adam and Sumit,
Thanks Tim for taking time to test this series. I hope you are fine with me taking your below patch with you being the author.
Ah, I see. So it turns out that it's Adam Linux kernel DTS patch [1] which is missing for U-Boot DTS. This is one of the reasons why we should switch to OF_UPSTREAM to start regular sync with Linux kernel DTS.
Adam,
Can you make corresponding changes to U-Boot DTS for imx8mp-beacon-kit? Or better just switch to OF_UPSTREAM instead?
[1] https://git.kernel.org/pub/scm/linux/kernel/git/torvalds/linux.git/commit/ar...
Thanks again.
-Sumit
Tim
Hi Adam,
Hi Adam,
On Wed, 28 Feb 2024 at 04:42, Adam Ford aford173@gmail.com wrote: > > On Mon, Feb 26, 2024 at 2:05 AM Sumit Garg sumit.garg@linaro.org wrote: > > > > Add initial support for i.MX8M{M/P} PCIe PHY. On i.MX8M{M/P} SoCs PCIe > > PHY initialization moved to this standalone PHY driver. > > > > Inspired from counterpart Linux kernel v6.8-rc3 driver: > > drivers/phy/freescale/phy-fsl-imx8m-pcie.c. > > I have a PCIe device that works just fine in Linux. I have applied > your series an enabled the same config options as you did along with > some others to resolve some build issues. > > Any ideas how to address: > > nxp_imx8_pcie_phy pcie-phy@32f00000: PHY: Failed to power on > pcie-phy@32f00000: -110. > > My PHY node looks like this > > &pcie_phy { > fsl,refclk-pad-mode = <IMX8_PCIE_REFCLK_PAD_INPUT>; > clocks = <&pcie0_refclk>; > clock-names = "ref"; > status = "okay"; > }; > > The pcie_refcllk is defined as a 100MHz fixed clock in U-Boot. clk > dump shows it to be: > > 100000000 0 |-- clock-pcie >
Adam and Sumit,
Adam,
I have it working now.
This is one of the first things I did when I tried the patch, but the renesas clock driver isn't available in U-Boot. With and without that above patch, the Linux driver enumerates, but the real issue appears to be something related to ATF (or lack thereof). I had experimented with a series of patches which bypassed ATF, and pushed them upstream a while ago. Unfortunately, it appears to have caused more issues. When I revert those it all works just fine. Sorry for the noise.
u-boot=> pci enum PCIE-0: Link up (Gen1-x1, Bus0) u-boot=> nvme scan u-boot=> nvme info Device 0: Vendor: 0x15b7 Rev: 20120022 Prod: 184960441105 Type: Hard Disk Capacity: 122104.3 MB = 119.2 GB (250069680 x 512) u-boot=>
WIth my suggested regulator and build-dependency fixes added you can add
Tested-by: Adam Ford aford173@gmail.com #imx8mp-beacon-kit
adam
Thanks again.
-Sumit
Tim
Hi Adam,
On Wed, 28 Feb 2024 at 12:29, Sumit Garg sumit.garg@linaro.org wrote: > > Hi Adam, > > On Wed, 28 Feb 2024 at 04:42, Adam Ford aford173@gmail.com wrote: > > > > On Mon, Feb 26, 2024 at 2:05 AM Sumit Garg sumit.garg@linaro.org wrote: > > > > > > Add initial support for i.MX8M{M/P} PCIe PHY. On i.MX8M{M/P} SoCs PCIe > > > PHY initialization moved to this standalone PHY driver. > > > > > > Inspired from counterpart Linux kernel v6.8-rc3 driver: > > > drivers/phy/freescale/phy-fsl-imx8m-pcie.c. > > > > I have a PCIe device that works just fine in Linux. I have applied > > your series an enabled the same config options as you did along with > > some others to resolve some build issues. > > > > Any ideas how to address: > > > > nxp_imx8_pcie_phy pcie-phy@32f00000: PHY: Failed to power on > > pcie-phy@32f00000: -110. > > > > My PHY node looks like this > > > > &pcie_phy { > > fsl,refclk-pad-mode = <IMX8_PCIE_REFCLK_PAD_INPUT>; > > clocks = <&pcie0_refclk>; > > clock-names = "ref"; > > status = "okay"; > > }; > > > > The pcie_refcllk is defined as a 100MHz fixed clock in U-Boot. clk > > dump shows it to be: > > > > 100000000 0 |-- clock-pcie > > > > I suppose that's an EVK board, try enabling MPCIE_3V3 regulator > required for EVK board via following patch: > > diff --git a/drivers/pci/pcie_dw_imx.c b/drivers/pci/pcie_dw_imx.c > index 7856823c9188..32fd2cb05d4b 100644 > --- a/drivers/pci/pcie_dw_imx.c > +++ b/drivers/pci/pcie_dw_imx.c > @@ -17,6 +17,7 @@ > #include <linux/iopoll.h> > #include <log.h> > #include <pci.h> > +#include <power/regulator.h> > #include <regmap.h> > #include <reset.h> > #include <syscon.h> > @@ -158,6 +159,8 @@ static int pcie_dw_imx_probe(struct udevice *dev) > struct pci_controller *hose = dev_get_uclass_priv(ctlr); > int ret; > > + regulator_autoset_by_name("MPCIE_3V3", NULL);
> + > ret = imx_pcie_assert_core_reset(priv); > if (ret) { > dev_err(dev, "failed to assert core reset\n"); >
Adam and Sumit,
Adam,
No worries.
Thanks for taking time to test this series.
-Sumit
adam
Thanks again.
-Sumit
Tim
Hi Adam,
Hi Adam,
Adam and Sumit,
Sumit,
Yes you can take that patch if you want to add it to your series - thanks!
Tim
Adam,
Thanks again.
-Sumit
Tim
pcie_imx doesn't seem to share any useful code for iMX8 SoC and it is tied to quite old port of pcie_designware driver from Linux which suffices only iMX6 specific needs.
Signed-off-by: Sumit Garg sumit.garg@linaro.org --- drivers/pci/Kconfig | 8 + drivers/pci/Makefile | 1 + drivers/pci/pcie_dw_imx.c | 314 ++++++++++++++++++++++++++++++++++++++ 3 files changed, 323 insertions(+) create mode 100644 drivers/pci/pcie_dw_imx.c
diff --git a/drivers/pci/Kconfig b/drivers/pci/Kconfig index 463ec47eb92d..7edbf35004a9 100644 --- a/drivers/pci/Kconfig +++ b/drivers/pci/Kconfig @@ -413,4 +413,12 @@ config PCIE_STARFIVE_JH7110 Say Y here if you want to enable PLDA XpressRich PCIe controller support on StarFive JH7110 SoC.
+config PCIE_DW_IMX + bool "i.MX DW PCIe controller support" + depends on ARCH_IMX8M + select PCIE_DW_COMMON + help + Say Y here if you want to enable DW PCIe controller support on + iMX SoCs. + endif diff --git a/drivers/pci/Makefile b/drivers/pci/Makefile index 72ef8b4bc772..2927c519129b 100644 --- a/drivers/pci/Makefile +++ b/drivers/pci/Makefile @@ -53,3 +53,4 @@ obj-$(CONFIG_PCIE_UNIPHIER) += pcie_uniphier.o obj-$(CONFIG_PCIE_XILINX_NWL) += pcie-xilinx-nwl.o obj-$(CONFIG_PCIE_PLDA_COMMON) += pcie_plda_common.o obj-$(CONFIG_PCIE_STARFIVE_JH7110) += pcie_starfive_jh7110.o +obj-$(CONFIG_PCIE_DW_IMX) += pcie_dw_imx.o diff --git a/drivers/pci/pcie_dw_imx.c b/drivers/pci/pcie_dw_imx.c new file mode 100644 index 000000000000..7856823c9188 --- /dev/null +++ b/drivers/pci/pcie_dw_imx.c @@ -0,0 +1,314 @@ +// SPDX-License-Identifier: GPL-2.0+ +/* + * Copyright (C) 2024 Linaro Ltd. + * + * Author: Sumit Garg sumit.garg@linaro.org + */ + +#include <asm/io.h> +#include <asm-generic/gpio.h> +#include <clk.h> +#include <dm.h> +#include <dm/device_compat.h> +#include <generic-phy.h> +#include <linux/bitops.h> +#include <linux/delay.h> +#include <linux/err.h> +#include <linux/iopoll.h> +#include <log.h> +#include <pci.h> +#include <regmap.h> +#include <reset.h> +#include <syscon.h> +#include <time.h> + +#include "pcie_dw_common.h" + +#define PCIE_LINK_CAPABILITY 0x7c +#define TARGET_LINK_SPEED_MASK 0xf +#define LINK_SPEED_GEN_1 0x1 +#define LINK_SPEED_GEN_2 0x2 +#define LINK_SPEED_GEN_3 0x3 + +#define PCIE_MISC_CONTROL_1_OFF 0x8bc +#define PCIE_DBI_RO_WR_EN BIT(0) + +#define PCIE_PORT_DEBUG0 0x728 +#define PCIE_PORT_DEBUG1 0x72c +#define PCIE_PORT_DEBUG1_LINK_UP BIT(4) +#define PCIE_PORT_DEBUG1_LINK_IN_TRAINING BIT(29) + +#define PCIE_LINK_UP_TIMEOUT_MS 100 + +#define IOMUXC_GPR14_OFFSET 0x38 +#define IMX8M_GPR_PCIE_CLK_REQ_OVERRIDE_EN BIT(10) +#define IMX8M_GPR_PCIE_CLK_REQ_OVERRIDE BIT(11) + +struct pcie_dw_imx { + /* Must be first member of the struct */ + struct pcie_dw dw; + struct regmap *iomuxc_gpr; + struct clk_bulk clks; + struct gpio_desc reset_gpio; + struct reset_ctl apps_reset; + struct phy phy; +}; + +static void pcie_dw_configure(struct pcie_dw_imx *priv, u32 cap_speed) +{ + dw_pcie_dbi_write_enable(&priv->dw, true); + + clrsetbits_le32(priv->dw.dbi_base + PCIE_LINK_CAPABILITY, + TARGET_LINK_SPEED_MASK, cap_speed); + + dw_pcie_dbi_write_enable(&priv->dw, false); +} + +static void imx_pcie_ltssm_enable(struct pcie_dw_imx *priv) +{ + reset_deassert(&priv->apps_reset); +} + +static void imx_pcie_ltssm_disable(struct pcie_dw_imx *priv) +{ + reset_assert(&priv->apps_reset); +} + +static bool is_link_up(u32 val) +{ + return ((val & PCIE_PORT_DEBUG1_LINK_UP) && + (!(val & PCIE_PORT_DEBUG1_LINK_IN_TRAINING))); +} + +static int wait_link_up(struct pcie_dw_imx *priv) +{ + u32 val; + + return readl_poll_sleep_timeout(priv->dw.dbi_base + PCIE_PORT_DEBUG1, + val, is_link_up(val), 10000, 100000); +} + +static int pcie_link_up(struct pcie_dw_imx *priv, u32 cap_speed) +{ + int ret; + + /* DW pre link configurations */ + pcie_dw_configure(priv, cap_speed); + + /* Initiate link training */ + imx_pcie_ltssm_enable(priv); + + /* Check that link was established */ + ret = wait_link_up(priv); + if (ret) + imx_pcie_ltssm_disable(priv); + + return ret; +} + +static int imx_pcie_assert_core_reset(struct pcie_dw_imx *priv) +{ + if (dm_gpio_is_valid(&priv->reset_gpio)) { + dm_gpio_set_value(&priv->reset_gpio, 1); + mdelay(20); + } + + return reset_assert(&priv->apps_reset); +} + +static int imx_pcie_clk_enable(struct pcie_dw_imx *priv) +{ + int ret; + + ret = clk_enable_bulk(&priv->clks); + if (ret) + return ret; + + /* + * Set the over ride low and enabled make sure that + * REF_CLK is turned on. + */ + regmap_update_bits(priv->iomuxc_gpr, IOMUXC_GPR14_OFFSET, + IMX8M_GPR_PCIE_CLK_REQ_OVERRIDE, 0); + regmap_update_bits(priv->iomuxc_gpr, IOMUXC_GPR14_OFFSET, + IMX8M_GPR_PCIE_CLK_REQ_OVERRIDE_EN, + IMX8M_GPR_PCIE_CLK_REQ_OVERRIDE_EN); + + /* allow the clocks to stabilize */ + udelay(500); + + return 0; +} + +static void imx_pcie_deassert_core_reset(struct pcie_dw_imx *priv) +{ + if (!dm_gpio_is_valid(&priv->reset_gpio)) + return; + + mdelay(100); + dm_gpio_set_value(&priv->reset_gpio, 0); + /* Wait for 100ms after PERST# deassertion (PCIe r5.0, 6.6.1) */ + mdelay(100); +} + +static int pcie_dw_imx_probe(struct udevice *dev) +{ + struct pcie_dw_imx *priv = dev_get_priv(dev); + struct udevice *ctlr = pci_get_controller(dev); + struct pci_controller *hose = dev_get_uclass_priv(ctlr); + int ret; + + ret = imx_pcie_assert_core_reset(priv); + if (ret) { + dev_err(dev, "failed to assert core reset\n"); + return ret; + } + + ret = imx_pcie_clk_enable(priv); + if (ret) { + dev_err(dev, "failed to enable clocks\n"); + goto err_clk; + } + + ret = generic_phy_init(&priv->phy); + if (ret) { + dev_err(dev, "failed to initialize PHY\n"); + goto err_phy_init; + } + + ret = generic_phy_power_on(&priv->phy); + if (ret) { + dev_err(dev, "failed to power on PHY\n"); + goto err_phy_power; + } + + imx_pcie_deassert_core_reset(priv); + + priv->dw.first_busno = dev_seq(dev); + priv->dw.dev = dev; + pcie_dw_setup_host(&priv->dw); + + if (pcie_link_up(priv, LINK_SPEED_GEN_1)) { + printf("PCIE-%d: Link down\n", dev_seq(dev)); + ret = -ENODEV; + goto err_link; + } + + printf("PCIE-%d: Link up (Gen%d-x%d, Bus%d)\n", dev_seq(dev), + pcie_dw_get_link_speed(&priv->dw), + pcie_dw_get_link_width(&priv->dw), + hose->first_busno); + + pcie_dw_prog_outbound_atu_unroll(&priv->dw, PCIE_ATU_REGION_INDEX0, + PCIE_ATU_TYPE_MEM, + priv->dw.mem.phys_start, + priv->dw.mem.bus_start, priv->dw.mem.size); + + return 0; + +err_link: + generic_shutdown_phy(&priv->phy); +err_phy_power: + generic_phy_exit(&priv->phy); +err_phy_init: + clk_disable_bulk(&priv->clks); +err_clk: + imx_pcie_deassert_core_reset(priv); + + return ret; +} + +static int pcie_dw_imx_remove(struct udevice *dev) +{ + struct pcie_dw_imx *priv = dev_get_priv(dev); + + generic_shutdown_phy(&priv->phy); + dm_gpio_free(dev, &priv->reset_gpio); + reset_release_all(&priv->apps_reset, 1); + clk_release_bulk(&priv->clks); + + return 0; +} + +static int pcie_dw_imx_of_to_plat(struct udevice *dev) +{ + struct pcie_dw_imx *priv = dev_get_priv(dev); + ofnode gpr; + int ret; + + /* Get the controller base address */ + priv->dw.dbi_base = (void *)dev_read_addr_name(dev, "dbi"); + if ((fdt_addr_t)priv->dw.dbi_base == FDT_ADDR_T_NONE) { + dev_err(dev, "failed to get dbi_base address\n"); + return -EINVAL; + } + + /* Get the config space base address and size */ + priv->dw.cfg_base = (void *)dev_read_addr_size_name(dev, "config", + &priv->dw.cfg_size); + if ((fdt_addr_t)priv->dw.cfg_base == FDT_ADDR_T_NONE) { + dev_err(dev, "failed to get cfg_base address\n"); + return -EINVAL; + } + + ret = clk_get_bulk(dev, &priv->clks); + if (ret) { + dev_err(dev, "failed to get PCIe clks\n"); + return ret; + } + + ret = reset_get_by_name(dev, "apps", &priv->apps_reset); + if (ret) { + dev_err(dev, + "Failed to get PCIe apps reset control\n"); + return ret; + } + + ret = gpio_request_by_name(dev, "reset-gpio", 0, &priv->reset_gpio, + (GPIOD_IS_OUT | GPIOD_IS_OUT_ACTIVE)); + if (ret) { + dev_err(dev, "unable to get reset-gpio\n"); + return ret; + } + + ret = generic_phy_get_by_name(dev, "pcie-phy", &priv->phy); + if (ret) { + dev_err(dev, "failed to get pcie phy\n"); + return ret; + } + + gpr = ofnode_by_compatible(ofnode_null(), "fsl,imx8mp-iomuxc-gpr"); + if (ofnode_equal(gpr, ofnode_null())) { + dev_err(dev, "unable to find GPR node\n"); + return -ENODEV; + } + + priv->iomuxc_gpr = syscon_node_to_regmap(gpr); + if (IS_ERR(priv->iomuxc_gpr)) { + dev_err(dev, "unable to find iomuxc registers\n"); + return PTR_ERR(priv->iomuxc_gpr); + } + + return 0; +} + +static const struct dm_pci_ops pcie_dw_imx_ops = { + .read_config = pcie_dw_read_config, + .write_config = pcie_dw_write_config, +}; + +static const struct udevice_id pcie_dw_imx_ids[] = { + { .compatible = "fsl,imx8mp-pcie" }, + { } +}; + +U_BOOT_DRIVER(pcie_dw_imx) = { + .name = "pcie_dw_imx", + .id = UCLASS_PCI, + .of_match = pcie_dw_imx_ids, + .ops = &pcie_dw_imx_ops, + .of_to_plat = pcie_dw_imx_of_to_plat, + .probe = pcie_dw_imx_probe, + .remove = pcie_dw_imx_remove, + .priv_auto = sizeof(struct pcie_dw_imx), +};
It is probably hand-rolled, but it does suck, that's true.
- struct pcie_dw_imx *priv = dev_get_priv(dev);
- ofnode gpr;
- int ret;
- /* Get the controller base address */
- priv->dw.dbi_base = (void *)dev_read_addr_name(dev, "dbi");
- if ((fdt_addr_t)priv->dw.dbi_base == FDT_ADDR_T_NONE) {
return -EINVAL;
- /* Get the config space base address and size */
- priv->dw.cfg_base = (void *)dev_read_addr_size_name(dev, "config",
- if ((fdt_addr_t)priv->dw.cfg_base == FDT_ADDR_T_NONE) {
return -EINVAL;
- ret = clk_get_bulk(dev, &priv->clks);
- if (ret) {
return ret;
- ret = reset_get_by_name(dev, "apps", &priv->apps_reset);
- if (ret) {
dev_err(dev,
return ret;
- ret = gpio_request_by_name(dev, "reset-gpio", 0, &priv->reset_gpio,
- if (ret) {
return ret;
- ret = generic_phy_get_by_name(dev, "pcie-phy", &priv->phy);
- if (ret) {
return ret;
- gpr = ofnode_by_compatible(ofnode_null(), "fsl,imx8mp-iomuxc-gpr");
return -ENODEV;
You likely need a fail path here too, to undo allocation and co.
But currently we have the common DWC specific bits which alligns pretty well with DW PCIe controller on iMX8MP SoC. So lets reuse those common bits instead as a new driver for iMX8 SoCs. It should be fairly easy to add support for other iMX8 variants to this driver.
iMX8MP SoC also comes up with standalone PCIe PHY support, so hence we can reuse the generic PHY infrastructure to power on PCIe PHY.
ofnode gpr;
int ret;
return -EINVAL;
return -EINVAL;
if (ret) {
return ret;
if (ret) {
dev_err(dev,
return ret;
if (ret) {
return ret;
if (ret) {
return ret;
return -ENODEV;
Ack.
-Sumit
+config PCIE_DW_IMX
I think this also needs to depend on REGMAP to prevent build errors.
adam
help
iMX SoCs.
- Copyright (C) 2024 Linaro Ltd.
- Author: Sumit Garg sumit.garg@linaro.org
struct pcie_dw dw;
struct phy phy;
u32 val;
int ret;
if (ret)
return ret;
mdelay(20);
int ret;
if (ret)
return ret;
udelay(500);
return;
mdelay(100);
mdelay(100);
int ret;
if (ret) {
return ret;
if (ret) {
goto err_clk;
if (ret) {
goto err_phy_init;
if (ret) {
goto err_phy_power;
priv->dw.dev = dev;
ret = -ENODEV;
goto err_link;
hose->first_busno);
PCIE_ATU_TYPE_MEM,
+err_link:
+err_phy_power:
+err_phy_init:
+err_clk:
return ret;
ofnode gpr;
int ret;
return -EINVAL;
return -EINVAL;
if (ret) {
return ret;
if (ret) {
dev_err(dev,
return ret;
if (ret) {
return ret;
if (ret) {
return ret;
return -ENODEV;
.id = UCLASS_PCI,
2.34.1
+config PCIE_DW_IMX
Ack, I will add that.
-Sumit
adam
help
iMX SoCs.
struct pcie_dw dw;
struct phy phy;
u32 val;
int ret;
if (ret)
return ret;
mdelay(20);
int ret;
if (ret)
return ret;
udelay(500);
return;
mdelay(100);
mdelay(100);
int ret;
if (ret) {
return ret;
if (ret) {
goto err_clk;
if (ret) {
goto err_phy_init;
if (ret) {
goto err_phy_power;
priv->dw.dev = dev;
ret = -ENODEV;
goto err_link;
hose->first_busno);
PCIE_ATU_TYPE_MEM,
+err_link:
+err_phy_power:
+err_phy_init:
+err_clk:
return ret;
ofnode gpr;
int ret;
return -EINVAL;
return -EINVAL;
if (ret) {
return ret;
if (ret) {
dev_err(dev,
return ret;
if (ret) {
return ret;
if (ret) {
return ret;
return -ENODEV;
.id = UCLASS_PCI,
2.34.1
+config PCIE_DW_IMX
Sumit,
both REGMAP and SYSCON are needed to build.
Best Regards,
Tim
+config PCIE_DW_IMX
Sumit,
Ack.
-Sumit
Enable PCIe/NVMe support. Also, enable the reset driver which is a prerequisite for PCIe support.
Acked-by: Francesco Dolcini francesco.dolcini@toradex.com Tested-by: Marcel Ziswiler marcel.ziswiler@toradex.com Signed-off-by: Sumit Garg sumit.garg@linaro.org --- configs/verdin-imx8mp_defconfig | 6 ++++++ 1 file changed, 6 insertions(+)
diff --git a/configs/verdin-imx8mp_defconfig b/configs/verdin-imx8mp_defconfig index 22b8a334dfaf..fefadb344f8b 100644 --- a/configs/verdin-imx8mp_defconfig +++ b/configs/verdin-imx8mp_defconfig @@ -16,6 +16,7 @@ CONFIG_DEFAULT_DEVICE_TREE="imx8mp-verdin-wifi-dev" CONFIG_SPL_TEXT_BASE=0x920000 CONFIG_TARGET_VERDIN_IMX8MP=y CONFIG_OF_LIBFDT_OVERLAY=y +CONFIG_DM_RESET=y CONFIG_SYS_MONITOR_LEN=524288 CONFIG_SPL_MMC=y CONFIG_SPL_SERIAL=y @@ -26,6 +27,7 @@ CONFIG_SPL=y CONFIG_IMX_BOOTAUX=y CONFIG_SPL_IMX_ROMAPI_LOADADDR=0x48000000 CONFIG_SYS_LOAD_ADDR=0x48200000 +CONFIG_PCI=y CONFIG_SYS_MEMTEST_START=0x40000000 CONFIG_SYS_MEMTEST_END=0x80000000 CONFIG_REMAKE_ELF=y @@ -77,6 +79,7 @@ CONFIG_CMD_FUSE=y CONFIG_CMD_GPIO=y CONFIG_CMD_I2C=y CONFIG_CMD_MMC=y +CONFIG_CMD_PCI=y CONFIG_CMD_READ=y CONFIG_CMD_USB=y CONFIG_CMD_USB_MASS_STORAGE=y @@ -145,8 +148,11 @@ CONFIG_DWC_ETH_QOS_IMX=y CONFIG_FEC_MXC=y CONFIG_RGMII=y CONFIG_MII=y +CONFIG_NVME_PCI=y +CONFIG_PCIE_DW_IMX=y CONFIG_PHY=y CONFIG_PHY_IMX8MQ_USB=y +CONFIG_PHY_IMX8M_PCIE=y CONFIG_PINCTRL=y CONFIG_SPL_PINCTRL=y CONFIG_PINCTRL_IMX8M=y
Add myself as maintainer for PCIe DWC IMX driver support.
Signed-off-by: Sumit Garg sumit.garg@linaro.org --- MAINTAINERS | 6 ++++++ 1 file changed, 6 insertions(+)
diff --git a/MAINTAINERS b/MAINTAINERS index 0b08ca192397..af23b0c6c862 100644 --- a/MAINTAINERS +++ b/MAINTAINERS @@ -1369,6 +1369,12 @@ M: Simon Glass sjg@chromium.org S: Maintained F: tools/patman/
+PCIe DWC IMX +M: Sumit Garg sumit.garg@linaro.org +S: Maintained +F: drivers/pci/pcie_dw_imx.c +F: drivers/phy/phy-imx8m-pcie.c + PCI Endpoint M: Ramon Fried rfried.dev@gmail.com S: Maintained
Acked-by: Marek Vasut marex@denx.de
Thanks !
Adam Ford
Sumit Garg
Tim Harvey
