[U-Boot] [PATCH 0/3] socfpga: clean up sfp generation
Move gen5 and arria10 to use CONFIG_SPL_TARGET to specify the required SPL output.
Dalon Westergreen (3): spl: socfpga: remove sfp generation socfpga: Add sfp generation targets socfpga: common: add CONFIG_SPL_TARGET to gen5 and arria10 socfpga header
Makefile | 11 +++++++---- include/configs/socfpga_common.h | 1 + scripts/Makefile.spl | 12 ------------ 3 files changed, 8 insertions(+), 16 deletions(-)
In preparation to move to using CONFIG_SPL_TARGET, remove sfp generation targets.
Signed-off-by: Dalon Westergreen dwesterg@gmail.com --- scripts/Makefile.spl | 12 ------------ 1 file changed, 12 deletions(-)
diff --git a/scripts/Makefile.spl b/scripts/Makefile.spl index 252f13826d..9314365aab 100644 --- a/scripts/Makefile.spl +++ b/scripts/Makefile.spl @@ -187,10 +187,6 @@ ifdef CONFIG_SAMSUNG ALL-y += $(obj)/$(BOARD)-spl.bin endif
-ifdef CONFIG_ARCH_SOCFPGA -ALL-y += $(obj)/$(SPL_BIN).sfp -endif - ifdef CONFIG_ARCH_SUNXI ALL-y += $(obj)/sunxi-spl.bin
@@ -313,14 +309,6 @@ LDFLAGS_$(SPL_BIN) += -Ttext $(CONFIG_SPL_TEXT_BASE) endif endif
-ifdef CONFIG_TARGET_SOCFPGA_ARRIA10 -MKIMAGEFLAGS_$(SPL_BIN).sfp = -T socfpgaimage_v1 -else -MKIMAGEFLAGS_$(SPL_BIN).sfp = -T socfpgaimage -endif -$(obj)/$(SPL_BIN).sfp: $(obj)/$(SPL_BIN).bin FORCE - $(call if_changed,mkimage) - quiet_cmd_mksunxiboot = MKSUNXI $@ cmd_mksunxiboot = $(objtree)/tools/mksunxiboot \ --default-dt $(CONFIG_DEFAULT_DEVICE_TREE) $< $@
Doesn't this break git bisect ?
Some SOCFPGA platforms require a header be added to u-boot-spl and a combined spl / u-boot image. The combined image consists of 4 replicated u-boot-spl images with the afore mentioned header, and a u-boot image cat'ed together.
Signed-off-by: Dalon Westergreen dwesterg@gmail.com --- Makefile | 11 +++++++---- 1 file changed, 7 insertions(+), 4 deletions(-)
diff --git a/Makefile b/Makefile index 133d7ac773..6c93c6c129 100644 --- a/Makefile +++ b/Makefile @@ -1198,14 +1198,12 @@ OBJCOPYFLAGS_u-boot.spr = -I binary -O binary --pad-to=$(CONFIG_SPL_PAD_TO) \ u-boot.spr: spl/u-boot-spl.img u-boot.img FORCE $(call if_changed,pad_cat)
-ifneq ($(CONFIG_ARCH_SOCFPGA),) quiet_cmd_socboot = SOCBOOT $@ cmd_socboot = cat spl/u-boot-spl.sfp spl/u-boot-spl.sfp \ spl/u-boot-spl.sfp spl/u-boot-spl.sfp \ u-boot.img > $@ || rm -f $@ u-boot-with-spl.sfp: spl/u-boot-spl.sfp u-boot.img FORCE $(call if_changed,socboot) -endif
# x86 uses a large ROM. We fill it with 0xff, put the 16-bit stuff (including # reset vector) at the top, Intel ME descriptor at the bottom, and U-Boot in @@ -1518,8 +1516,13 @@ spl/sunxi-spl.bin: spl/u-boot-spl spl/sunxi-spl-with-ecc.bin: spl/sunxi-spl.bin @:
-spl/u-boot-spl.sfp: spl/u-boot-spl - @: +ifdef CONFIG_TARGET_SOCFPGA_ARRIA10 +MKIMAGEFLAGS_$(SPL_BIN).sfp = -T socfpgaimage_v1 +else +MKIMAGEFLAGS_$(SPL_BIN).sfp = -T socfpgaimage +endif +spl/u-boot-spl.sfp: spl/u-boot-spl.bin FORCE + $(call if_changed,mkimage)
spl/boot.bin: spl/u-boot-spl @:
Add CONFIG_SPL_TARGET "u-boot-with-spl.sfp" to common header to generate the required u-boot-spl and u-boot combined image.
Signed-off-by: Dalon Westergreen dwesterg@gmail.com --- include/configs/socfpga_common.h | 1 + 1 file changed, 1 insertion(+)
diff --git a/include/configs/socfpga_common.h b/include/configs/socfpga_common.h index 2330143cf1..4777b4522d 100644 --- a/include/configs/socfpga_common.h +++ b/include/configs/socfpga_common.h @@ -239,6 +239,7 @@ unsigned int cm_get_qspi_controller_clk_hz(void); * 0xFFEz_zzzz ...... Malloc area (grows up to top) * 0xFFE3_FFFF ...... End of SRAM (top) */ +#define CONFIG_SPL_TARGET "u-boot-with-spl.sfp" #define CONFIG_SPL_TEXT_BASE CONFIG_SYS_INIT_RAM_ADDR #define CONFIG_SPL_MAX_SIZE CONFIG_SYS_INIT_RAM_SIZE
Dalon Westergreen
