[U-Boot] [PATCH] config.mk: unify duplicated flag setting
Multiple rules are using the expanded AFLAGS/CFLAGS settings and some are getting so long that the rules need to be line wrapped. So unify them in one variable, use that variable in the rule, and then unwrap things. This makes the actual `make` output nicer as it doesn't have line continuations in it anymore.
Signed-off-by: Mike Frysinger vapier@gentoo.org --- config.mk | 17 +++++++---------- 1 files changed, 7 insertions(+), 10 deletions(-)
diff --git a/config.mk b/config.mk index eb95093..d6ca9b9 100644 --- a/config.mk +++ b/config.mk @@ -242,20 +242,17 @@ export TEXT_BASE PLATFORM_CPPFLAGS PLATFORM_RELFLAGS CPPFLAGS CFLAGS AFLAGS
# Allow boards to use custom optimize flags on a per dir/file basis BCURDIR = $(subst $(SRCTREE)/,,$(CURDIR:$(obj)%=%)) +ALL_AFLAGS = $(AFLAGS) $(AFLAGS_$(BCURDIR)/$(@F)) $(AFLAGS_$(BCURDIR)) +ALL_CFLAGS = $(CFLAGS) $(CFLAGS_$(BCURDIR)/$(@F)) $(CFLAGS_$(BCURDIR)) $(obj)%.s: %.S - $(CPP) $(AFLAGS) $(AFLAGS_$(BCURDIR)/$(@F)) $(AFLAGS_$(BCURDIR)) \ - -o $@ $< + $(CPP) $(ALL_AFLAGS) -o $@ $< $(obj)%.o: %.S - $(CC) $(AFLAGS) $(AFLAGS_$(BCURDIR)/$(@F)) $(AFLAGS_$(BCURDIR)) \ - -o $@ $< -c + $(CC) $(ALL_AFLAGS) -o $@ $< -c $(obj)%.o: %.c - $(CC) $(CFLAGS) $(CFLAGS_$(BCURDIR)/$(@F)) $(CFLAGS_$(BCURDIR)) \ - -o $@ $< -c + $(CC) $(ALL_CFLAGS) -o $@ $< -c $(obj)%.i: %.c - $(CPP) $(CFLAGS) $(CFLAGS_$(BCURDIR)/$(@F)) $(CFLAGS_$(BCURDIR)) \ - -o $@ $< -c + $(CPP) $(ALL_CFLAGS) -o $@ $< -c $(obj)%.s: %.c - $(CC) $(CFLAGS) $(CFLAGS_$(BCURDIR)/$(@F)) $(CFLAGS_$(BCURDIR)) \ - -o $@ $< -c -S + $(CC) $(ALL_CFLAGS) -o $@ $< -c -S
Dear Mike Frysinger,
Applied to "next", thanks.
Mike Frysinger
