Re: [U-Boot] USB storage performance EHCI question
On 1/14/2011 1:19 AM, Wolfgang Denk wrote:
Dear Aaron Williams,
please always keep the ML on cc:
In message4D2FA7F0.7020900@caviumnetworks.com you wrote:
It is based off of 2010.09 but I have applied all of the latest USB updates from GIT with the exception of the multiple LUN support (this breaks the SanDisk Cruzer because the Cruzer reports max lun=1). All caches are enabled and this is on a 1.2GHz MIPS which is cache-coherent (no need to flush/invalidate).
Maybe there are other issues with your code. It's hard to comment on onknown out-of-tree ports.
I don't think so. The only changes I made were to the register access macros to use a couple assembly functions since our EHCI registers require 64-bit addressing and a very quick virtual to physical conversion for the descriptors which is quite fast. Other than that, the code is stock from GIT. Note that we do not use interrupts either but polling.
Unless I'm reading it wrong it also looks like in EHCI it only uses one descriptor and I wonder if this might have something to do with it?
I can provide a diff when I return to the office next week.
-Aaron
Aaron Williams
