[U-Boot] [PATCH v2 0/4] amlogic: Add Khadas VIM3 support
Hi Neil,
This mini-series adds initial support for Amlogic A311D based Khadas VIM3.
v2 fixes an oversight and adds some cleanups.
Regards, Andreas
v1 -> v2: * Fixed branch name in README * Mention linux-next tag for DT/header import (Neil) * Avoid "Unknown" SoC output for A311D, fixing a typo while at it
Cc: Neil Armstrong narmstrong@baylibre.com
Andreas Färber (4): arm: dts: Import and update DT for Khadas VIM3 configs: Add Khadas VIM3 defconfig arm: meson: Tidy SoC information output arm: meson: Recognize A311D SoC
arch/arm/dts/Makefile | 3 +- arch/arm/dts/meson-g12-common.dtsi | 2435 ++++++++++++++++++++ arch/arm/dts/meson-g12b-a311d-khadas-vim3.dts | 15 + arch/arm/dts/meson-g12b-a311d.dtsi | 149 ++ arch/arm/dts/meson-g12b-khadas-vim3.dtsi | 544 +++++ arch/arm/dts/meson-g12b.dtsi | 39 +- arch/arm/mach-meson/board-info.c | 3 +- board/amlogic/w400/MAINTAINERS | 1 + board/amlogic/w400/README.khadas-vim3 | 132 ++ configs/khadas-vim3_defconfig | 54 + include/dt-bindings/clock/g12a-clkc.h | 6 + include/dt-bindings/power/meson-g12a-power.h | 13 + .../reset/amlogic,meson-g12a-audio-reset.h | 38 + 13 files changed, 3427 insertions(+), 5 deletions(-) create mode 100644 arch/arm/dts/meson-g12-common.dtsi create mode 100644 arch/arm/dts/meson-g12b-a311d-khadas-vim3.dts create mode 100644 arch/arm/dts/meson-g12b-a311d.dtsi create mode 100644 arch/arm/dts/meson-g12b-khadas-vim3.dtsi create mode 100644 board/amlogic/w400/README.khadas-vim3 create mode 100644 configs/khadas-vim3_defconfig create mode 100644 include/dt-bindings/power/meson-g12a-power.h create mode 100644 include/dt-bindings/reset/amlogic,meson-g12a-audio-reset.h
In Linux meson-g12-common.dtsi was introduced as well as new g12b nodes and headers, as dependencies of new meson-g12b-a311d-khadas-vim3.dts.
Copied from next-20190830.
Signed-off-by: Andreas Färber afaerber@suse.de --- v1 -> v2: * Mention linux-next tag for DT/header import (Neil)
arch/arm/dts/Makefile | 3 +- arch/arm/dts/meson-g12-common.dtsi | 2435 ++++++++++++++++++++ arch/arm/dts/meson-g12b-a311d-khadas-vim3.dts | 15 + arch/arm/dts/meson-g12b-a311d.dtsi | 149 ++ arch/arm/dts/meson-g12b-khadas-vim3.dtsi | 544 +++++ arch/arm/dts/meson-g12b.dtsi | 39 +- include/dt-bindings/clock/g12a-clkc.h | 6 + include/dt-bindings/power/meson-g12a-power.h | 13 + .../reset/amlogic,meson-g12a-audio-reset.h | 38 + 9 files changed, 3238 insertions(+), 4 deletions(-) create mode 100644 arch/arm/dts/meson-g12-common.dtsi create mode 100644 arch/arm/dts/meson-g12b-a311d-khadas-vim3.dts create mode 100644 arch/arm/dts/meson-g12b-a311d.dtsi create mode 100644 arch/arm/dts/meson-g12b-khadas-vim3.dtsi create mode 100644 include/dt-bindings/power/meson-g12a-power.h create mode 100644 include/dt-bindings/reset/amlogic,meson-g12a-audio-reset.h
diff --git a/arch/arm/dts/Makefile b/arch/arm/dts/Makefile index aac1b83d49..6de5e4c62a 100644 --- a/arch/arm/dts/Makefile +++ b/arch/arm/dts/Makefile @@ -141,7 +141,8 @@ dtb-$(CONFIG_ARCH_MESON) += \ meson-axg-s400.dtb \ meson-g12a-u200.dtb \ meson-g12a-sei510.dtb \ - meson-g12b-odroid-n2.dtb + meson-g12b-odroid-n2.dtb \ + meson-g12b-a311d-khadas-vim3.dtb dtb-$(CONFIG_TEGRA) += tegra20-harmony.dtb \ tegra20-medcom-wide.dtb \ tegra20-paz00.dtb \ diff --git a/arch/arm/dts/meson-g12-common.dtsi b/arch/arm/dts/meson-g12-common.dtsi new file mode 100644 index 0000000000..3f39e020f7 --- /dev/null +++ b/arch/arm/dts/meson-g12-common.dtsi @@ -0,0 +1,2435 @@ +// SPDX-License-Identifier: (GPL-2.0+ OR MIT) +/* + * Copyright (c) 2018 Amlogic, Inc. All rights reserved. + */ + +#include <dt-bindings/phy/phy.h> +#include <dt-bindings/gpio/gpio.h> +#include <dt-bindings/clock/axg-audio-clkc.h> +#include <dt-bindings/clock/g12a-clkc.h> +#include <dt-bindings/clock/g12a-aoclkc.h> +#include <dt-bindings/interrupt-controller/irq.h> +#include <dt-bindings/interrupt-controller/arm-gic.h> +#include <dt-bindings/reset/amlogic,meson-axg-audio-arb.h> +#include <dt-bindings/reset/amlogic,meson-g12a-audio-reset.h> +#include <dt-bindings/reset/amlogic,meson-g12a-reset.h> + +/ { + interrupt-parent = <&gic>; + #address-cells = <2>; + #size-cells = <2>; + + tdmif_a: audio-controller-0 { + compatible = "amlogic,axg-tdm-iface"; + #sound-dai-cells = <0>; + sound-name-prefix = "TDM_A"; + clocks = <&clkc_audio AUD_CLKID_MST_A_MCLK>, + <&clkc_audio AUD_CLKID_MST_A_SCLK>, + <&clkc_audio AUD_CLKID_MST_A_LRCLK>; + clock-names = "mclk", "sclk", "lrclk"; + status = "disabled"; + }; + + tdmif_b: audio-controller-1 { + compatible = "amlogic,axg-tdm-iface"; + #sound-dai-cells = <0>; + sound-name-prefix = "TDM_B"; + clocks = <&clkc_audio AUD_CLKID_MST_B_MCLK>, + <&clkc_audio AUD_CLKID_MST_B_SCLK>, + <&clkc_audio AUD_CLKID_MST_B_LRCLK>; + clock-names = "mclk", "sclk", "lrclk"; + status = "disabled"; + }; + + tdmif_c: audio-controller-2 { + compatible = "amlogic,axg-tdm-iface"; + #sound-dai-cells = <0>; + sound-name-prefix = "TDM_C"; + clocks = <&clkc_audio AUD_CLKID_MST_C_MCLK>, + <&clkc_audio AUD_CLKID_MST_C_SCLK>, + <&clkc_audio AUD_CLKID_MST_C_LRCLK>; + clock-names = "mclk", "sclk", "lrclk"; + status = "disabled"; + }; + + efuse: efuse { + compatible = "amlogic,meson-gxbb-efuse"; + clocks = <&clkc CLKID_EFUSE>; + #address-cells = <1>; + #size-cells = <1>; + read-only; + }; + + psci { + compatible = "arm,psci-1.0"; + method = "smc"; + }; + + reserved-memory { + #address-cells = <2>; + #size-cells = <2>; + ranges; + + /* 3 MiB reserved for ARM Trusted Firmware (BL31) */ + secmon_reserved: secmon@5000000 { + reg = <0x0 0x05000000 0x0 0x300000>; + no-map; + }; + + linux,cma { + compatible = "shared-dma-pool"; + reusable; + size = <0x0 0x10000000>; + alignment = <0x0 0x400000>; + linux,cma-default; + }; + }; + + sm: secure-monitor { + compatible = "amlogic,meson-gxbb-sm"; + }; + + soc { + compatible = "simple-bus"; + #address-cells = <2>; + #size-cells = <2>; + ranges; + + ethmac: ethernet@ff3f0000 { + compatible = "amlogic,meson-axg-dwmac", + "snps,dwmac-3.70a", + "snps,dwmac"; + reg = <0x0 0xff3f0000 0x0 0x10000>, + <0x0 0xff634540 0x0 0x8>; + interrupts = <GIC_SPI 8 IRQ_TYPE_LEVEL_HIGH>; + interrupt-names = "macirq"; + clocks = <&clkc CLKID_ETH>, + <&clkc CLKID_FCLK_DIV2>, + <&clkc CLKID_MPLL2>; + clock-names = "stmmaceth", "clkin0", "clkin1"; + rx-fifo-depth = <4096>; + tx-fifo-depth = <2048>; + status = "disabled"; + + mdio0: mdio { + #address-cells = <1>; + #size-cells = <0>; + compatible = "snps,dwmac-mdio"; + }; + }; + + apb: bus@ff600000 { + compatible = "simple-bus"; + reg = <0x0 0xff600000 0x0 0x200000>; + #address-cells = <2>; + #size-cells = <2>; + ranges = <0x0 0x0 0x0 0xff600000 0x0 0x200000>; + + hdmi_tx: hdmi-tx@0 { + compatible = "amlogic,meson-g12a-dw-hdmi"; + reg = <0x0 0x0 0x0 0x10000>; + interrupts = <GIC_SPI 57 IRQ_TYPE_EDGE_RISING>; + resets = <&reset RESET_HDMITX_CAPB3>, + <&reset RESET_HDMITX_PHY>, + <&reset RESET_HDMITX>; + reset-names = "hdmitx_apb", "hdmitx", "hdmitx_phy"; + clocks = <&clkc CLKID_HDMI>, + <&clkc CLKID_HTX_PCLK>, + <&clkc CLKID_VPU_INTR>; + clock-names = "isfr", "iahb", "venci"; + #address-cells = <1>; + #size-cells = <0>; + #sound-dai-cells = <0>; + status = "disabled"; + + /* VPU VENC Input */ + hdmi_tx_venc_port: port@0 { + reg = <0>; + + hdmi_tx_in: endpoint { + remote-endpoint = <&hdmi_tx_out>; + }; + }; + + /* TMDS Output */ + hdmi_tx_tmds_port: port@1 { + reg = <1>; + }; + }; + + apb_efuse: bus@30000 { + compatible = "simple-bus"; + reg = <0x0 0x30000 0x0 0x2000>; + #address-cells = <2>; + #size-cells = <2>; + ranges = <0x0 0x0 0x0 0x30000 0x0 0x2000>; + + hwrng: rng@218 { + compatible = "amlogic,meson-rng"; + reg = <0x0 0x218 0x0 0x4>; + }; + }; + + periphs: bus@34400 { + compatible = "simple-bus"; + reg = <0x0 0x34400 0x0 0x400>; + #address-cells = <2>; + #size-cells = <2>; + ranges = <0x0 0x0 0x0 0x34400 0x0 0x400>; + + periphs_pinctrl: pinctrl@40 { + compatible = "amlogic,meson-g12a-periphs-pinctrl"; + #address-cells = <2>; + #size-cells = <2>; + ranges; + + gpio: bank@40 { + reg = <0x0 0x40 0x0 0x4c>, + <0x0 0xe8 0x0 0x18>, + <0x0 0x120 0x0 0x18>, + <0x0 0x2c0 0x0 0x40>, + <0x0 0x340 0x0 0x1c>; + reg-names = "gpio", + "pull", + "pull-enable", + "mux", + "ds"; + gpio-controller; + #gpio-cells = <2>; + gpio-ranges = <&periphs_pinctrl 0 0 86>; + }; + + cec_ao_a_h_pins: cec_ao_a_h { + mux { + groups = "cec_ao_a_h"; + function = "cec_ao_a_h"; + bias-disable; + }; + }; + + cec_ao_b_h_pins: cec_ao_b_h { + mux { + groups = "cec_ao_b_h"; + function = "cec_ao_b_h"; + bias-disable; + }; + }; + + emmc_pins: emmc { + mux-0 { + groups = "emmc_nand_d0", + "emmc_nand_d1", + "emmc_nand_d2", + "emmc_nand_d3", + "emmc_nand_d4", + "emmc_nand_d5", + "emmc_nand_d6", + "emmc_nand_d7", + "emmc_cmd"; + function = "emmc"; + bias-pull-up; + drive-strength-microamp = <4000>; + }; + + mux-1 { + groups = "emmc_clk"; + function = "emmc"; + bias-disable; + drive-strength-microamp = <4000>; + }; + }; + + emmc_ds_pins: emmc-ds { + mux { + groups = "emmc_nand_ds"; + function = "emmc"; + bias-pull-down; + drive-strength-microamp = <4000>; + }; + }; + + emmc_clk_gate_pins: emmc_clk_gate { + mux { + groups = "BOOT_8"; + function = "gpio_periphs"; + bias-pull-down; + drive-strength-microamp = <4000>; + }; + }; + + hdmitx_ddc_pins: hdmitx_ddc { + mux { + groups = "hdmitx_sda", + "hdmitx_sck"; + function = "hdmitx"; + bias-disable; + drive-strength-microamp = <4000>; + }; + }; + + hdmitx_hpd_pins: hdmitx_hpd { + mux { + groups = "hdmitx_hpd_in"; + function = "hdmitx"; + bias-disable; + }; + }; + + + i2c0_sda_c_pins: i2c0-sda-c { + mux { + groups = "i2c0_sda_c"; + function = "i2c0"; + bias-disable; + drive-strength-microamp = <3000>; + + }; + }; + + i2c0_sck_c_pins: i2c0-sck-c { + mux { + groups = "i2c0_sck_c"; + function = "i2c0"; + bias-disable; + drive-strength-microamp = <3000>; + }; + }; + + i2c0_sda_z0_pins: i2c0-sda-z0 { + mux { + groups = "i2c0_sda_z0"; + function = "i2c0"; + bias-disable; + drive-strength-microamp = <3000>; + }; + }; + + i2c0_sck_z1_pins: i2c0-sck-z1 { + mux { + groups = "i2c0_sck_z1"; + function = "i2c0"; + bias-disable; + drive-strength-microamp = <3000>; + }; + }; + + i2c0_sda_z7_pins: i2c0-sda-z7 { + mux { + groups = "i2c0_sda_z7"; + function = "i2c0"; + bias-disable; + drive-strength-microamp = <3000>; + }; + }; + + i2c0_sda_z8_pins: i2c0-sda-z8 { + mux { + groups = "i2c0_sda_z8"; + function = "i2c0"; + bias-disable; + drive-strength-microamp = <3000>; + }; + }; + + i2c1_sda_x_pins: i2c1-sda-x { + mux { + groups = "i2c1_sda_x"; + function = "i2c1"; + bias-disable; + drive-strength-microamp = <3000>; + }; + }; + + i2c1_sck_x_pins: i2c1-sck-x { + mux { + groups = "i2c1_sck_x"; + function = "i2c1"; + bias-disable; + drive-strength-microamp = <3000>; + }; + }; + + i2c1_sda_h2_pins: i2c1-sda-h2 { + mux { + groups = "i2c1_sda_h2"; + function = "i2c1"; + bias-disable; + drive-strength-microamp = <3000>; + }; + }; + + i2c1_sck_h3_pins: i2c1-sck-h3 { + mux { + groups = "i2c1_sck_h3"; + function = "i2c1"; + bias-disable; + drive-strength-microamp = <3000>; + }; + }; + + i2c1_sda_h6_pins: i2c1-sda-h6 { + mux { + groups = "i2c1_sda_h6"; + function = "i2c1"; + bias-disable; + drive-strength-microamp = <3000>; + }; + }; + + i2c1_sck_h7_pins: i2c1-sck-h7 { + mux { + groups = "i2c1_sck_h7"; + function = "i2c1"; + bias-disable; + drive-strength-microamp = <3000>; + }; + }; + + i2c2_sda_x_pins: i2c2-sda-x { + mux { + groups = "i2c2_sda_x"; + function = "i2c2"; + bias-disable; + drive-strength-microamp = <3000>; + }; + }; + + i2c2_sck_x_pins: i2c2-sck-x { + mux { + groups = "i2c2_sck_x"; + function = "i2c2"; + bias-disable; + drive-strength-microamp = <3000>; + }; + }; + + i2c2_sda_z_pins: i2c2-sda-z { + mux { + groups = "i2c2_sda_z"; + function = "i2c2"; + bias-disable; + drive-strength-microamp = <3000>; + }; + }; + + i2c2_sck_z_pins: i2c2-sck-z { + mux { + groups = "i2c2_sck_z"; + function = "i2c2"; + bias-disable; + drive-strength-microamp = <3000>; + }; + }; + + i2c3_sda_h_pins: i2c3-sda-h { + mux { + groups = "i2c3_sda_h"; + function = "i2c3"; + bias-disable; + drive-strength-microamp = <3000>; + }; + }; + + i2c3_sck_h_pins: i2c3-sck-h { + mux { + groups = "i2c3_sck_h"; + function = "i2c3"; + bias-disable; + drive-strength-microamp = <3000>; + }; + }; + + i2c3_sda_a_pins: i2c3-sda-a { + mux { + groups = "i2c3_sda_a"; + function = "i2c3"; + bias-disable; + drive-strength-microamp = <3000>; + }; + }; + + i2c3_sck_a_pins: i2c3-sck-a { + mux { + groups = "i2c3_sck_a"; + function = "i2c3"; + bias-disable; + drive-strength-microamp = <3000>; + }; + }; + + mclk0_a_pins: mclk0-a { + mux { + groups = "mclk0_a"; + function = "mclk0"; + bias-disable; + drive-strength-microamp = <3000>; + }; + }; + + mclk1_a_pins: mclk1-a { + mux { + groups = "mclk1_a"; + function = "mclk1"; + bias-disable; + drive-strength-microamp = <3000>; + }; + }; + + mclk1_x_pins: mclk1-x { + mux { + groups = "mclk1_x"; + function = "mclk1"; + bias-disable; + drive-strength-microamp = <3000>; + }; + }; + + mclk1_z_pins: mclk1-z { + mux { + groups = "mclk1_z"; + function = "mclk1"; + bias-disable; + drive-strength-microamp = <3000>; + }; + }; + + pdm_din0_a_pins: pdm-din0-a { + mux { + groups = "pdm_din0_a"; + function = "pdm"; + bias-disable; + }; + }; + + pdm_din0_c_pins: pdm-din0-c { + mux { + groups = "pdm_din0_c"; + function = "pdm"; + bias-disable; + }; + }; + + pdm_din0_x_pins: pdm-din0-x { + mux { + groups = "pdm_din0_x"; + function = "pdm"; + bias-disable; + }; + }; + + pdm_din0_z_pins: pdm-din0-z { + mux { + groups = "pdm_din0_z"; + function = "pdm"; + bias-disable; + }; + }; + + pdm_din1_a_pins: pdm-din1-a { + mux { + groups = "pdm_din1_a"; + function = "pdm"; + bias-disable; + }; + }; + + pdm_din1_c_pins: pdm-din1-c { + mux { + groups = "pdm_din1_c"; + function = "pdm"; + bias-disable; + }; + }; + + pdm_din1_x_pins: pdm-din1-x { + mux { + groups = "pdm_din1_x"; + function = "pdm"; + bias-disable; + }; + }; + + pdm_din1_z_pins: pdm-din1-z { + mux { + groups = "pdm_din1_z"; + function = "pdm"; + bias-disable; + }; + }; + + pdm_din2_a_pins: pdm-din2-a { + mux { + groups = "pdm_din2_a"; + function = "pdm"; + bias-disable; + }; + }; + + pdm_din2_c_pins: pdm-din2-c { + mux { + groups = "pdm_din2_c"; + function = "pdm"; + bias-disable; + }; + }; + + pdm_din2_x_pins: pdm-din2-x { + mux { + groups = "pdm_din2_x"; + function = "pdm"; + bias-disable; + }; + }; + + pdm_din2_z_pins: pdm-din2-z { + mux { + groups = "pdm_din2_z"; + function = "pdm"; + bias-disable; + }; + }; + + pdm_din3_a_pins: pdm-din3-a { + mux { + groups = "pdm_din3_a"; + function = "pdm"; + bias-disable; + }; + }; + + pdm_din3_c_pins: pdm-din3-c { + mux { + groups = "pdm_din3_c"; + function = "pdm"; + bias-disable; + }; + }; + + pdm_din3_x_pins: pdm-din3-x { + mux { + groups = "pdm_din3_x"; + function = "pdm"; + bias-disable; + }; + }; + + pdm_din3_z_pins: pdm-din3-z { + mux { + groups = "pdm_din3_z"; + function = "pdm"; + bias-disable; + }; + }; + + pdm_dclk_a_pins: pdm-dclk-a { + mux { + groups = "pdm_dclk_a"; + function = "pdm"; + bias-disable; + drive-strength-microamp = <500>; + }; + }; + + pdm_dclk_c_pins: pdm-dclk-c { + mux { + groups = "pdm_dclk_c"; + function = "pdm"; + bias-disable; + drive-strength-microamp = <500>; + }; + }; + + pdm_dclk_x_pins: pdm-dclk-x { + mux { + groups = "pdm_dclk_x"; + function = "pdm"; + bias-disable; + drive-strength-microamp = <500>; + }; + }; + + pdm_dclk_z_pins: pdm-dclk-z { + mux { + groups = "pdm_dclk_z"; + function = "pdm"; + bias-disable; + drive-strength-microamp = <500>; + }; + }; + + pwm_a_pins: pwm-a { + mux { + groups = "pwm_a"; + function = "pwm_a"; + bias-disable; + }; + }; + + pwm_b_x7_pins: pwm-b-x7 { + mux { + groups = "pwm_b_x7"; + function = "pwm_b"; + bias-disable; + }; + }; + + pwm_b_x19_pins: pwm-b-x19 { + mux { + groups = "pwm_b_x19"; + function = "pwm_b"; + bias-disable; + }; + }; + + pwm_c_c_pins: pwm-c-c { + mux { + groups = "pwm_c_c"; + function = "pwm_c"; + bias-disable; + }; + }; + + pwm_c_x5_pins: pwm-c-x5 { + mux { + groups = "pwm_c_x5"; + function = "pwm_c"; + bias-disable; + }; + }; + + pwm_c_x8_pins: pwm-c-x8 { + mux { + groups = "pwm_c_x8"; + function = "pwm_c"; + bias-disable; + }; + }; + + pwm_d_x3_pins: pwm-d-x3 { + mux { + groups = "pwm_d_x3"; + function = "pwm_d"; + bias-disable; + }; + }; + + pwm_d_x6_pins: pwm-d-x6 { + mux { + groups = "pwm_d_x6"; + function = "pwm_d"; + bias-disable; + }; + }; + + pwm_e_pins: pwm-e { + mux { + groups = "pwm_e"; + function = "pwm_e"; + bias-disable; + }; + }; + + pwm_f_x_pins: pwm-f-x { + mux { + groups = "pwm_f_x"; + function = "pwm_f"; + bias-disable; + }; + }; + + pwm_f_h_pins: pwm-f-h { + mux { + groups = "pwm_f_h"; + function = "pwm_f"; + bias-disable; + }; + }; + + sdcard_c_pins: sdcard_c { + mux-0 { + groups = "sdcard_d0_c", + "sdcard_d1_c", + "sdcard_d2_c", + "sdcard_d3_c", + "sdcard_cmd_c"; + function = "sdcard"; + bias-pull-up; + drive-strength-microamp = <4000>; + }; + + mux-1 { + groups = "sdcard_clk_c"; + function = "sdcard"; + bias-disable; + drive-strength-microamp = <4000>; + }; + }; + + sdcard_clk_gate_c_pins: sdcard_clk_gate_c { + mux { + groups = "GPIOC_4"; + function = "gpio_periphs"; + bias-pull-down; + drive-strength-microamp = <4000>; + }; + }; + + sdcard_z_pins: sdcard_z { + mux-0 { + groups = "sdcard_d0_z", + "sdcard_d1_z", + "sdcard_d2_z", + "sdcard_d3_z", + "sdcard_cmd_z"; + function = "sdcard"; + bias-pull-up; + drive-strength-microamp = <4000>; + }; + + mux-1 { + groups = "sdcard_clk_z"; + function = "sdcard"; + bias-disable; + drive-strength-microamp = <4000>; + }; + }; + + sdcard_clk_gate_z_pins: sdcard_clk_gate_z { + mux { + groups = "GPIOZ_6"; + function = "gpio_periphs"; + bias-pull-down; + drive-strength-microamp = <4000>; + }; + }; + + sdio_pins: sdio { + mux { + groups = "sdio_d0", + "sdio_d1", + "sdio_d2", + "sdio_d3", + "sdio_clk", + "sdio_cmd"; + function = "sdio"; + bias-disable; + drive-strength-microamp = <4000>; + }; + }; + + sdio_clk_gate_pins: sdio_clk_gate { + mux { + groups = "GPIOX_4"; + function = "gpio_periphs"; + bias-pull-down; + drive-strength-microamp = <4000>; + }; + }; + + spdif_in_a10_pins: spdif-in-a10 { + mux { + groups = "spdif_in_a10"; + function = "spdif_in"; + bias-disable; + }; + }; + + spdif_in_a12_pins: spdif-in-a12 { + mux { + groups = "spdif_in_a12"; + function = "spdif_in"; + bias-disable; + }; + }; + + spdif_in_h_pins: spdif-in-h { + mux { + groups = "spdif_in_h"; + function = "spdif_in"; + bias-disable; + }; + }; + + spdif_out_h_pins: spdif-out-h { + mux { + groups = "spdif_out_h"; + function = "spdif_out"; + drive-strength-microamp = <500>; + bias-disable; + }; + }; + + spdif_out_a11_pins: spdif-out-a11 { + mux { + groups = "spdif_out_a11"; + function = "spdif_out"; + drive-strength-microamp = <500>; + bias-disable; + }; + }; + + spdif_out_a13_pins: spdif-out-a13 { + mux { + groups = "spdif_out_a13"; + function = "spdif_out"; + drive-strength-microamp = <500>; + bias-disable; + }; + }; + + tdm_a_din0_pins: tdm-a-din0 { + mux { + groups = "tdm_a_din0"; + function = "tdm_a"; + bias-disable; + }; + }; + + + tdm_a_din1_pins: tdm-a-din1 { + mux { + groups = "tdm_a_din1"; + function = "tdm_a"; + bias-disable; + }; + }; + + tdm_a_dout0_pins: tdm-a-dout0 { + mux { + groups = "tdm_a_dout0"; + function = "tdm_a"; + bias-disable; + drive-strength-microamp = <3000>; + }; + }; + + tdm_a_dout1_pins: tdm-a-dout1 { + mux { + groups = "tdm_a_dout1"; + function = "tdm_a"; + bias-disable; + drive-strength-microamp = <3000>; + }; + }; + + tdm_a_fs_pins: tdm-a-fs { + mux { + groups = "tdm_a_fs"; + function = "tdm_a"; + bias-disable; + drive-strength-microamp = <3000>; + }; + }; + + tdm_a_sclk_pins: tdm-a-sclk { + mux { + groups = "tdm_a_sclk"; + function = "tdm_a"; + bias-disable; + drive-strength-microamp = <3000>; + }; + }; + + tdm_a_slv_fs_pins: tdm-a-slv-fs { + mux { + groups = "tdm_a_slv_fs"; + function = "tdm_a"; + bias-disable; + }; + }; + + + tdm_a_slv_sclk_pins: tdm-a-slv-sclk { + mux { + groups = "tdm_a_slv_sclk"; + function = "tdm_a"; + bias-disable; + }; + }; + + tdm_b_din0_pins: tdm-b-din0 { + mux { + groups = "tdm_b_din0"; + function = "tdm_b"; + bias-disable; + }; + }; + + tdm_b_din1_pins: tdm-b-din1 { + mux { + groups = "tdm_b_din1"; + function = "tdm_b"; + bias-disable; + }; + }; + + tdm_b_din2_pins: tdm-b-din2 { + mux { + groups = "tdm_b_din2"; + function = "tdm_b"; + bias-disable; + }; + }; + + tdm_b_din3_a_pins: tdm-b-din3-a { + mux { + groups = "tdm_b_din3_a"; + function = "tdm_b"; + bias-disable; + }; + }; + + tdm_b_din3_h_pins: tdm-b-din3-h { + mux { + groups = "tdm_b_din3_h"; + function = "tdm_b"; + bias-disable; + }; + }; + + tdm_b_dout0_pins: tdm-b-dout0 { + mux { + groups = "tdm_b_dout0"; + function = "tdm_b"; + bias-disable; + drive-strength-microamp = <3000>; + }; + }; + + tdm_b_dout1_pins: tdm-b-dout1 { + mux { + groups = "tdm_b_dout1"; + function = "tdm_b"; + bias-disable; + drive-strength-microamp = <3000>; + }; + }; + + tdm_b_dout2_pins: tdm-b-dout2 { + mux { + groups = "tdm_b_dout2"; + function = "tdm_b"; + bias-disable; + drive-strength-microamp = <3000>; + }; + }; + + tdm_b_dout3_a_pins: tdm-b-dout3-a { + mux { + groups = "tdm_b_dout3_a"; + function = "tdm_b"; + bias-disable; + drive-strength-microamp = <3000>; + }; + }; + + tdm_b_dout3_h_pins: tdm-b-dout3-h { + mux { + groups = "tdm_b_dout3_h"; + function = "tdm_b"; + bias-disable; + drive-strength-microamp = <3000>; + }; + }; + + tdm_b_fs_pins: tdm-b-fs { + mux { + groups = "tdm_b_fs"; + function = "tdm_b"; + bias-disable; + drive-strength-microamp = <3000>; + }; + }; + + tdm_b_sclk_pins: tdm-b-sclk { + mux { + groups = "tdm_b_sclk"; + function = "tdm_b"; + bias-disable; + drive-strength-microamp = <3000>; + }; + }; + + tdm_b_slv_fs_pins: tdm-b-slv-fs { + mux { + groups = "tdm_b_slv_fs"; + function = "tdm_b"; + bias-disable; + }; + }; + + tdm_b_slv_sclk_pins: tdm-b-slv-sclk { + mux { + groups = "tdm_b_slv_sclk"; + function = "tdm_b"; + bias-disable; + }; + }; + + tdm_c_din0_a_pins: tdm-c-din0-a { + mux { + groups = "tdm_c_din0_a"; + function = "tdm_c"; + bias-disable; + }; + }; + + tdm_c_din0_z_pins: tdm-c-din0-z { + mux { + groups = "tdm_c_din0_z"; + function = "tdm_c"; + bias-disable; + }; + }; + + tdm_c_din1_a_pins: tdm-c-din1-a { + mux { + groups = "tdm_c_din1_a"; + function = "tdm_c"; + bias-disable; + }; + }; + + tdm_c_din1_z_pins: tdm-c-din1-z { + mux { + groups = "tdm_c_din1_z"; + function = "tdm_c"; + bias-disable; + }; + }; + + tdm_c_din2_a_pins: tdm-c-din2-a { + mux { + groups = "tdm_c_din2_a"; + function = "tdm_c"; + bias-disable; + }; + }; + + eth_leds_pins: eth-leds { + mux { + groups = "eth_link_led", + "eth_act_led"; + function = "eth"; + bias-disable; + }; + }; + + eth_pins: eth { + mux { + groups = "eth_mdio", + "eth_mdc", + "eth_rgmii_rx_clk", + "eth_rx_dv", + "eth_rxd0", + "eth_rxd1", + "eth_txen", + "eth_txd0", + "eth_txd1"; + function = "eth"; + drive-strength-microamp = <4000>; + bias-disable; + }; + }; + + eth_rgmii_pins: eth-rgmii { + mux { + groups = "eth_rxd2_rgmii", + "eth_rxd3_rgmii", + "eth_rgmii_tx_clk", + "eth_txd2_rgmii", + "eth_txd3_rgmii"; + function = "eth"; + drive-strength-microamp = <4000>; + bias-disable; + }; + }; + + tdm_c_din2_z_pins: tdm-c-din2-z { + mux { + groups = "tdm_c_din2_z"; + function = "tdm_c"; + bias-disable; + }; + }; + + tdm_c_din3_a_pins: tdm-c-din3-a { + mux { + groups = "tdm_c_din3_a"; + function = "tdm_c"; + bias-disable; + }; + }; + + tdm_c_din3_z_pins: tdm-c-din3-z { + mux { + groups = "tdm_c_din3_z"; + function = "tdm_c"; + bias-disable; + }; + }; + + tdm_c_dout0_a_pins: tdm-c-dout0-a { + mux { + groups = "tdm_c_dout0_a"; + function = "tdm_c"; + bias-disable; + drive-strength-microamp = <3000>; + }; + }; + + tdm_c_dout0_z_pins: tdm-c-dout0-z { + mux { + groups = "tdm_c_dout0_z"; + function = "tdm_c"; + bias-disable; + drive-strength-microamp = <3000>; + }; + }; + + tdm_c_dout1_a_pins: tdm-c-dout1-a { + mux { + groups = "tdm_c_dout1_a"; + function = "tdm_c"; + bias-disable; + drive-strength-microamp = <3000>; + }; + }; + + tdm_c_dout1_z_pins: tdm-c-dout1-z { + mux { + groups = "tdm_c_dout1_z"; + function = "tdm_c"; + bias-disable; + drive-strength-microamp = <3000>; + }; + }; + + tdm_c_dout2_a_pins: tdm-c-dout2-a { + mux { + groups = "tdm_c_dout2_a"; + function = "tdm_c"; + bias-disable; + drive-strength-microamp = <3000>; + }; + }; + + tdm_c_dout2_z_pins: tdm-c-dout2-z { + mux { + groups = "tdm_c_dout2_z"; + function = "tdm_c"; + bias-disable; + drive-strength-microamp = <3000>; + }; + }; + + tdm_c_dout3_a_pins: tdm-c-dout3-a { + mux { + groups = "tdm_c_dout3_a"; + function = "tdm_c"; + bias-disable; + drive-strength-microamp = <3000>; + }; + }; + + tdm_c_dout3_z_pins: tdm-c-dout3-z { + mux { + groups = "tdm_c_dout3_z"; + function = "tdm_c"; + bias-disable; + drive-strength-microamp = <3000>; + }; + }; + + tdm_c_fs_a_pins: tdm-c-fs-a { + mux { + groups = "tdm_c_fs_a"; + function = "tdm_c"; + bias-disable; + drive-strength-microamp = <3000>; + }; + }; + + tdm_c_fs_z_pins: tdm-c-fs-z { + mux { + groups = "tdm_c_fs_z"; + function = "tdm_c"; + bias-disable; + drive-strength-microamp = <3000>; + }; + }; + + tdm_c_sclk_a_pins: tdm-c-sclk-a { + mux { + groups = "tdm_c_sclk_a"; + function = "tdm_c"; + bias-disable; + drive-strength-microamp = <3000>; + }; + }; + + tdm_c_sclk_z_pins: tdm-c-sclk-z { + mux { + groups = "tdm_c_sclk_z"; + function = "tdm_c"; + bias-disable; + drive-strength-microamp = <3000>; + }; + }; + + tdm_c_slv_fs_a_pins: tdm-c-slv-fs-a { + mux { + groups = "tdm_c_slv_fs_a"; + function = "tdm_c"; + bias-disable; + }; + }; + + tdm_c_slv_fs_z_pins: tdm-c-slv-fs-z { + mux { + groups = "tdm_c_slv_fs_z"; + function = "tdm_c"; + bias-disable; + }; + }; + + tdm_c_slv_sclk_a_pins: tdm-c-slv-sclk-a { + mux { + groups = "tdm_c_slv_sclk_a"; + function = "tdm_c"; + bias-disable; + }; + }; + + tdm_c_slv_sclk_z_pins: tdm-c-slv-sclk-z { + mux { + groups = "tdm_c_slv_sclk_z"; + function = "tdm_c"; + bias-disable; + }; + }; + + uart_a_pins: uart-a { + mux { + groups = "uart_a_tx", + "uart_a_rx"; + function = "uart_a"; + bias-disable; + }; + }; + + uart_a_cts_rts_pins: uart-a-cts-rts { + mux { + groups = "uart_a_cts", + "uart_a_rts"; + function = "uart_a"; + bias-disable; + }; + }; + + uart_b_pins: uart-b { + mux { + groups = "uart_b_tx", + "uart_b_rx"; + function = "uart_b"; + bias-disable; + }; + }; + + uart_c_pins: uart-c { + mux { + groups = "uart_c_tx", + "uart_c_rx"; + function = "uart_c"; + bias-disable; + }; + }; + + uart_c_cts_rts_pins: uart-c-cts-rts { + mux { + groups = "uart_c_cts", + "uart_c_rts"; + function = "uart_c"; + bias-disable; + }; + }; + }; + }; + + usb2_phy0: phy@36000 { + compatible = "amlogic,g12a-usb2-phy"; + reg = <0x0 0x36000 0x0 0x2000>; + clocks = <&xtal>; + clock-names = "xtal"; + resets = <&reset RESET_USB_PHY20>; + reset-names = "phy"; + #phy-cells = <0>; + }; + + dmc: bus@38000 { + compatible = "simple-bus"; + reg = <0x0 0x38000 0x0 0x400>; + #address-cells = <2>; + #size-cells = <2>; + ranges = <0x0 0x0 0x0 0x38000 0x0 0x400>; + + canvas: video-lut@48 { + compatible = "amlogic,canvas"; + reg = <0x0 0x48 0x0 0x14>; + }; + }; + + usb2_phy1: phy@3a000 { + compatible = "amlogic,g12a-usb2-phy"; + reg = <0x0 0x3a000 0x0 0x2000>; + clocks = <&xtal>; + clock-names = "xtal"; + resets = <&reset RESET_USB_PHY21>; + reset-names = "phy"; + #phy-cells = <0>; + }; + + hiu: bus@3c000 { + compatible = "simple-bus"; + reg = <0x0 0x3c000 0x0 0x1400>; + #address-cells = <2>; + #size-cells = <2>; + ranges = <0x0 0x0 0x0 0x3c000 0x0 0x1400>; + + hhi: system-controller@0 { + compatible = "amlogic,meson-gx-hhi-sysctrl", + "simple-mfd", "syscon"; + reg = <0 0 0 0x400>; + + clkc: clock-controller { + compatible = "amlogic,g12a-clkc"; + #clock-cells = <1>; + clocks = <&xtal>; + clock-names = "xtal"; + }; + + pwrc: power-controller { + compatible = "amlogic,meson-g12a-pwrc"; + #power-domain-cells = <1>; + amlogic,ao-sysctrl = <&rti>; + resets = <&reset RESET_VIU>, + <&reset RESET_VENC>, + <&reset RESET_VCBUS>, + <&reset RESET_BT656>, + <&reset RESET_RDMA>, + <&reset RESET_VENCI>, + <&reset RESET_VENCP>, + <&reset RESET_VDAC>, + <&reset RESET_VDI6>, + <&reset RESET_VENCL>, + <&reset RESET_VID_LOCK>; + reset-names = "viu", "venc", "vcbus", "bt656", + "rdma", "venci", "vencp", "vdac", + "vdi6", "vencl", "vid_lock"; + clocks = <&clkc CLKID_VPU>, + <&clkc CLKID_VAPB>; + clock-names = "vpu", "vapb"; + /* + * VPU clocking is provided by two identical clock paths + * VPU_0 and VPU_1 muxed to a single clock by a glitch + * free mux to safely change frequency while running. + * Same for VAPB but with a final gate after the glitch free mux. + */ + assigned-clocks = <&clkc CLKID_VPU_0_SEL>, + <&clkc CLKID_VPU_0>, + <&clkc CLKID_VPU>, /* Glitch free mux */ + <&clkc CLKID_VAPB_0_SEL>, + <&clkc CLKID_VAPB_0>, + <&clkc CLKID_VAPB_SEL>; /* Glitch free mux */ + assigned-clock-parents = <&clkc CLKID_FCLK_DIV3>, + <0>, /* Do Nothing */ + <&clkc CLKID_VPU_0>, + <&clkc CLKID_FCLK_DIV4>, + <0>, /* Do Nothing */ + <&clkc CLKID_VAPB_0>; + assigned-clock-rates = <0>, /* Do Nothing */ + <666666666>, + <0>, /* Do Nothing */ + <0>, /* Do Nothing */ + <250000000>, + <0>; /* Do Nothing */ + }; + }; + }; + + pdm: audio-controller@40000 { + compatible = "amlogic,g12a-pdm", + "amlogic,axg-pdm"; + reg = <0x0 0x40000 0x0 0x34>; + #sound-dai-cells = <0>; + sound-name-prefix = "PDM"; + clocks = <&clkc_audio AUD_CLKID_PDM>, + <&clkc_audio AUD_CLKID_PDM_DCLK>, + <&clkc_audio AUD_CLKID_PDM_SYSCLK>; + clock-names = "pclk", "dclk", "sysclk"; + status = "disabled"; + }; + + audio: bus@42000 { + compatible = "simple-bus"; + reg = <0x0 0x42000 0x0 0x2000>; + #address-cells = <2>; + #size-cells = <2>; + ranges = <0x0 0x0 0x0 0x42000 0x0 0x2000>; + + clkc_audio: clock-controller@0 { + status = "disabled"; + compatible = "amlogic,g12a-audio-clkc"; + reg = <0x0 0x0 0x0 0xb4>; + #clock-cells = <1>; + #reset-cells = <1>; + + clocks = <&clkc CLKID_AUDIO>, + <&clkc CLKID_MPLL0>, + <&clkc CLKID_MPLL1>, + <&clkc CLKID_MPLL2>, + <&clkc CLKID_MPLL3>, + <&clkc CLKID_HIFI_PLL>, + <&clkc CLKID_FCLK_DIV3>, + <&clkc CLKID_FCLK_DIV4>, + <&clkc CLKID_GP0_PLL>; + clock-names = "pclk", + "mst_in0", + "mst_in1", + "mst_in2", + "mst_in3", + "mst_in4", + "mst_in5", + "mst_in6", + "mst_in7"; + + resets = <&reset RESET_AUDIO>; + }; + + toddr_a: audio-controller@100 { + compatible = "amlogic,g12a-toddr", + "amlogic,axg-toddr"; + reg = <0x0 0x100 0x0 0x1c>; + #sound-dai-cells = <0>; + sound-name-prefix = "TODDR_A"; + interrupts = <GIC_SPI 148 IRQ_TYPE_EDGE_RISING>; + clocks = <&clkc_audio AUD_CLKID_TODDR_A>; + resets = <&arb AXG_ARB_TODDR_A>; + status = "disabled"; + }; + + toddr_b: audio-controller@140 { + compatible = "amlogic,g12a-toddr", + "amlogic,axg-toddr"; + reg = <0x0 0x140 0x0 0x1c>; + #sound-dai-cells = <0>; + sound-name-prefix = "TODDR_B"; + interrupts = <GIC_SPI 149 IRQ_TYPE_EDGE_RISING>; + clocks = <&clkc_audio AUD_CLKID_TODDR_B>; + resets = <&arb AXG_ARB_TODDR_B>; + status = "disabled"; + }; + + toddr_c: audio-controller@180 { + compatible = "amlogic,g12a-toddr", + "amlogic,axg-toddr"; + reg = <0x0 0x180 0x0 0x1c>; + #sound-dai-cells = <0>; + sound-name-prefix = "TODDR_C"; + interrupts = <GIC_SPI 150 IRQ_TYPE_EDGE_RISING>; + clocks = <&clkc_audio AUD_CLKID_TODDR_C>; + resets = <&arb AXG_ARB_TODDR_C>; + status = "disabled"; + }; + + frddr_a: audio-controller@1c0 { + compatible = "amlogic,g12a-frddr", + "amlogic,axg-frddr"; + reg = <0x0 0x1c0 0x0 0x1c>; + #sound-dai-cells = <0>; + sound-name-prefix = "FRDDR_A"; + interrupts = <GIC_SPI 152 IRQ_TYPE_EDGE_RISING>; + clocks = <&clkc_audio AUD_CLKID_FRDDR_A>; + resets = <&arb AXG_ARB_FRDDR_A>; + status = "disabled"; + }; + + frddr_b: audio-controller@200 { + compatible = "amlogic,g12a-frddr", + "amlogic,axg-frddr"; + reg = <0x0 0x200 0x0 0x1c>; + #sound-dai-cells = <0>; + sound-name-prefix = "FRDDR_B"; + interrupts = <GIC_SPI 153 IRQ_TYPE_EDGE_RISING>; + clocks = <&clkc_audio AUD_CLKID_FRDDR_B>; + resets = <&arb AXG_ARB_FRDDR_B>; + status = "disabled"; + }; + + frddr_c: audio-controller@240 { + compatible = "amlogic,g12a-frddr", + "amlogic,axg-frddr"; + reg = <0x0 0x240 0x0 0x1c>; + #sound-dai-cells = <0>; + sound-name-prefix = "FRDDR_C"; + interrupts = <GIC_SPI 154 IRQ_TYPE_EDGE_RISING>; + clocks = <&clkc_audio AUD_CLKID_FRDDR_C>; + resets = <&arb AXG_ARB_FRDDR_C>; + status = "disabled"; + }; + + arb: reset-controller@280 { + status = "disabled"; + compatible = "amlogic,meson-axg-audio-arb"; + reg = <0x0 0x280 0x0 0x4>; + #reset-cells = <1>; + clocks = <&clkc_audio AUD_CLKID_DDR_ARB>; + }; + + tdmin_a: audio-controller@300 { + compatible = "amlogic,g12a-tdmin", + "amlogic,axg-tdmin"; + reg = <0x0 0x300 0x0 0x40>; + sound-name-prefix = "TDMIN_A"; + resets = <&clkc_audio AUD_RESET_TDMIN_A>; + clocks = <&clkc_audio AUD_CLKID_TDMIN_A>, + <&clkc_audio AUD_CLKID_TDMIN_A_SCLK>, + <&clkc_audio AUD_CLKID_TDMIN_A_SCLK_SEL>, + <&clkc_audio AUD_CLKID_TDMIN_A_LRCLK>, + <&clkc_audio AUD_CLKID_TDMIN_A_LRCLK>; + clock-names = "pclk", "sclk", "sclk_sel", + "lrclk", "lrclk_sel"; + status = "disabled"; + }; + + tdmin_b: audio-controller@340 { + compatible = "amlogic,g12a-tdmin", + "amlogic,axg-tdmin"; + reg = <0x0 0x340 0x0 0x40>; + sound-name-prefix = "TDMIN_B"; + resets = <&clkc_audio AUD_RESET_TDMIN_B>; + clocks = <&clkc_audio AUD_CLKID_TDMIN_B>, + <&clkc_audio AUD_CLKID_TDMIN_B_SCLK>, + <&clkc_audio AUD_CLKID_TDMIN_B_SCLK_SEL>, + <&clkc_audio AUD_CLKID_TDMIN_B_LRCLK>, + <&clkc_audio AUD_CLKID_TDMIN_B_LRCLK>; + clock-names = "pclk", "sclk", "sclk_sel", + "lrclk", "lrclk_sel"; + status = "disabled"; + }; + + tdmin_c: audio-controller@380 { + compatible = "amlogic,g12a-tdmin", + "amlogic,axg-tdmin"; + reg = <0x0 0x380 0x0 0x40>; + sound-name-prefix = "TDMIN_C"; + resets = <&clkc_audio AUD_RESET_TDMIN_C>; + clocks = <&clkc_audio AUD_CLKID_TDMIN_C>, + <&clkc_audio AUD_CLKID_TDMIN_C_SCLK>, + <&clkc_audio AUD_CLKID_TDMIN_C_SCLK_SEL>, + <&clkc_audio AUD_CLKID_TDMIN_C_LRCLK>, + <&clkc_audio AUD_CLKID_TDMIN_C_LRCLK>; + clock-names = "pclk", "sclk", "sclk_sel", + "lrclk", "lrclk_sel"; + status = "disabled"; + }; + + tdmin_lb: audio-controller@3c0 { + compatible = "amlogic,g12a-tdmin", + "amlogic,axg-tdmin"; + reg = <0x0 0x3c0 0x0 0x40>; + sound-name-prefix = "TDMIN_LB"; + resets = <&clkc_audio AUD_RESET_TDMIN_LB>; + clocks = <&clkc_audio AUD_CLKID_TDMIN_LB>, + <&clkc_audio AUD_CLKID_TDMIN_LB_SCLK>, + <&clkc_audio AUD_CLKID_TDMIN_LB_SCLK_SEL>, + <&clkc_audio AUD_CLKID_TDMIN_LB_LRCLK>, + <&clkc_audio AUD_CLKID_TDMIN_LB_LRCLK>; + clock-names = "pclk", "sclk", "sclk_sel", + "lrclk", "lrclk_sel"; + status = "disabled"; + }; + + spdifin: audio-controller@400 { + compatible = "amlogic,g12a-spdifin", + "amlogic,axg-spdifin"; + reg = <0x0 0x400 0x0 0x30>; + #sound-dai-cells = <0>; + sound-name-prefix = "SPDIFIN"; + interrupts = <GIC_SPI 151 IRQ_TYPE_EDGE_RISING>; + clocks = <&clkc_audio AUD_CLKID_SPDIFIN>, + <&clkc_audio AUD_CLKID_SPDIFIN_CLK>; + clock-names = "pclk", "refclk"; + status = "disabled"; + }; + + spdifout: audio-controller@480 { + compatible = "amlogic,g12a-spdifout", + "amlogic,axg-spdifout"; + reg = <0x0 0x480 0x0 0x50>; + #sound-dai-cells = <0>; + sound-name-prefix = "SPDIFOUT"; + clocks = <&clkc_audio AUD_CLKID_SPDIFOUT>, + <&clkc_audio AUD_CLKID_SPDIFOUT_CLK>; + clock-names = "pclk", "mclk"; + status = "disabled"; + }; + + tdmout_a: audio-controller@500 { + compatible = "amlogic,g12a-tdmout"; + reg = <0x0 0x500 0x0 0x40>; + sound-name-prefix = "TDMOUT_A"; + resets = <&clkc_audio AUD_RESET_TDMOUT_A>; + clocks = <&clkc_audio AUD_CLKID_TDMOUT_A>, + <&clkc_audio AUD_CLKID_TDMOUT_A_SCLK>, + <&clkc_audio AUD_CLKID_TDMOUT_A_SCLK_SEL>, + <&clkc_audio AUD_CLKID_TDMOUT_A_LRCLK>, + <&clkc_audio AUD_CLKID_TDMOUT_A_LRCLK>; + clock-names = "pclk", "sclk", "sclk_sel", + "lrclk", "lrclk_sel"; + status = "disabled"; + }; + + tdmout_b: audio-controller@540 { + compatible = "amlogic,g12a-tdmout"; + reg = <0x0 0x540 0x0 0x40>; + sound-name-prefix = "TDMOUT_B"; + resets = <&clkc_audio AUD_RESET_TDMOUT_B>; + clocks = <&clkc_audio AUD_CLKID_TDMOUT_B>, + <&clkc_audio AUD_CLKID_TDMOUT_B_SCLK>, + <&clkc_audio AUD_CLKID_TDMOUT_B_SCLK_SEL>, + <&clkc_audio AUD_CLKID_TDMOUT_B_LRCLK>, + <&clkc_audio AUD_CLKID_TDMOUT_B_LRCLK>; + clock-names = "pclk", "sclk", "sclk_sel", + "lrclk", "lrclk_sel"; + status = "disabled"; + }; + + tdmout_c: audio-controller@580 { + compatible = "amlogic,g12a-tdmout"; + reg = <0x0 0x580 0x0 0x40>; + sound-name-prefix = "TDMOUT_C"; + resets = <&clkc_audio AUD_RESET_TDMOUT_C>; + clocks = <&clkc_audio AUD_CLKID_TDMOUT_C>, + <&clkc_audio AUD_CLKID_TDMOUT_C_SCLK>, + <&clkc_audio AUD_CLKID_TDMOUT_C_SCLK_SEL>, + <&clkc_audio AUD_CLKID_TDMOUT_C_LRCLK>, + <&clkc_audio AUD_CLKID_TDMOUT_C_LRCLK>; + clock-names = "pclk", "sclk", "sclk_sel", + "lrclk", "lrclk_sel"; + status = "disabled"; + }; + + spdifout_b: audio-controller@680 { + compatible = "amlogic,g12a-spdifout", + "amlogic,axg-spdifout"; + reg = <0x0 0x680 0x0 0x50>; + #sound-dai-cells = <0>; + sound-name-prefix = "SPDIFOUT_B"; + clocks = <&clkc_audio AUD_CLKID_SPDIFOUT_B>, + <&clkc_audio AUD_CLKID_SPDIFOUT_B_CLK>; + clock-names = "pclk", "mclk"; + status = "disabled"; + }; + + tohdmitx: audio-controller@744 { + compatible = "amlogic,g12a-tohdmitx"; + reg = <0x0 0x744 0x0 0x4>; + #sound-dai-cells = <1>; + sound-name-prefix = "TOHDMITX"; + status = "disabled"; + }; + }; + + usb3_pcie_phy: phy@46000 { + compatible = "amlogic,g12a-usb3-pcie-phy"; + reg = <0x0 0x46000 0x0 0x2000>; + clocks = <&clkc CLKID_PCIE_PLL>; + clock-names = "ref_clk"; + resets = <&reset RESET_PCIE_PHY>; + reset-names = "phy"; + assigned-clocks = <&clkc CLKID_PCIE_PLL>; + assigned-clock-rates = <100000000>; + #phy-cells = <1>; + }; + + eth_phy: mdio-multiplexer@4c000 { + compatible = "amlogic,g12a-mdio-mux"; + reg = <0x0 0x4c000 0x0 0xa4>; + clocks = <&clkc CLKID_ETH_PHY>, + <&xtal>, + <&clkc CLKID_MPLL_50M>; + clock-names = "pclk", "clkin0", "clkin1"; + mdio-parent-bus = <&mdio0>; + #address-cells = <1>; + #size-cells = <0>; + + ext_mdio: mdio@0 { + reg = <0>; + #address-cells = <1>; + #size-cells = <0>; + }; + + int_mdio: mdio@1 { + reg = <1>; + #address-cells = <1>; + #size-cells = <0>; + + internal_ephy: ethernet_phy@8 { + compatible = "ethernet-phy-id0180.3301", + "ethernet-phy-ieee802.3-c22"; + interrupts = <GIC_SPI 9 IRQ_TYPE_LEVEL_HIGH>; + reg = <8>; + max-speed = <100>; + }; + }; + }; + }; + + aobus: bus@ff800000 { + compatible = "simple-bus"; + reg = <0x0 0xff800000 0x0 0x100000>; + #address-cells = <2>; + #size-cells = <2>; + ranges = <0x0 0x0 0x0 0xff800000 0x0 0x100000>; + + rti: sys-ctrl@0 { + compatible = "amlogic,meson-gx-ao-sysctrl", + "simple-mfd", "syscon"; + reg = <0x0 0x0 0x0 0x100>; + #address-cells = <2>; + #size-cells = <2>; + ranges = <0x0 0x0 0x0 0x0 0x0 0x100>; + + clkc_AO: clock-controller { + compatible = "amlogic,meson-g12a-aoclkc"; + #clock-cells = <1>; + #reset-cells = <1>; + clocks = <&xtal>, <&clkc CLKID_CLK81>; + clock-names = "xtal", "mpeg-clk"; + }; + + ao_pinctrl: pinctrl@14 { + compatible = "amlogic,meson-g12a-aobus-pinctrl"; + #address-cells = <2>; + #size-cells = <2>; + ranges; + + gpio_ao: bank@14 { + reg = <0x0 0x14 0x0 0x8>, + <0x0 0x1c 0x0 0x8>, + <0x0 0x24 0x0 0x14>; + reg-names = "mux", + "ds", + "gpio"; + gpio-controller; + #gpio-cells = <2>; + gpio-ranges = <&ao_pinctrl 0 0 15>; + }; + + i2c_ao_sck_pins: i2c_ao_sck_pins { + mux { + groups = "i2c_ao_sck"; + function = "i2c_ao"; + bias-disable; + drive-strength-microamp = <3000>; + }; + }; + + i2c_ao_sda_pins: i2c_ao_sda { + mux { + groups = "i2c_ao_sda"; + function = "i2c_ao"; + bias-disable; + drive-strength-microamp = <3000>; + }; + }; + + i2c_ao_sck_e_pins: i2c_ao_sck_e { + mux { + groups = "i2c_ao_sck_e"; + function = "i2c_ao"; + bias-disable; + drive-strength-microamp = <3000>; + }; + }; + + i2c_ao_sda_e_pins: i2c_ao_sda_e { + mux { + groups = "i2c_ao_sda_e"; + function = "i2c_ao"; + bias-disable; + drive-strength-microamp = <3000>; + }; + }; + + mclk0_ao_pins: mclk0-ao { + mux { + groups = "mclk0_ao"; + function = "mclk0_ao"; + bias-disable; + drive-strength-microamp = <3000>; + }; + }; + + tdm_ao_b_din0_pins: tdm-ao-b-din0 { + mux { + groups = "tdm_ao_b_din0"; + function = "tdm_ao_b"; + bias-disable; + }; + }; + + spdif_ao_out_pins: spdif-ao-out { + mux { + groups = "spdif_ao_out"; + function = "spdif_ao_out"; + drive-strength-microamp = <500>; + bias-disable; + }; + }; + + tdm_ao_b_din1_pins: tdm-ao-b-din1 { + mux { + groups = "tdm_ao_b_din1"; + function = "tdm_ao_b"; + bias-disable; + }; + }; + + tdm_ao_b_din2_pins: tdm-ao-b-din2 { + mux { + groups = "tdm_ao_b_din2"; + function = "tdm_ao_b"; + bias-disable; + }; + }; + + tdm_ao_b_dout0_pins: tdm-ao-b-dout0 { + mux { + groups = "tdm_ao_b_dout0"; + function = "tdm_ao_b"; + bias-disable; + drive-strength-microamp = <3000>; + }; + }; + + tdm_ao_b_dout1_pins: tdm-ao-b-dout1 { + mux { + groups = "tdm_ao_b_dout1"; + function = "tdm_ao_b"; + bias-disable; + drive-strength-microamp = <3000>; + }; + }; + + tdm_ao_b_dout2_pins: tdm-ao-b-dout2 { + mux { + groups = "tdm_ao_b_dout2"; + function = "tdm_ao_b"; + bias-disable; + drive-strength-microamp = <3000>; + }; + }; + + tdm_ao_b_fs_pins: tdm-ao-b-fs { + mux { + groups = "tdm_ao_b_fs"; + function = "tdm_ao_b"; + bias-disable; + drive-strength-microamp = <3000>; + }; + }; + + tdm_ao_b_sclk_pins: tdm-ao-b-sclk { + mux { + groups = "tdm_ao_b_sclk"; + function = "tdm_ao_b"; + bias-disable; + drive-strength-microamp = <3000>; + }; + }; + + tdm_ao_b_slv_fs_pins: tdm-ao-b-slv-fs { + mux { + groups = "tdm_ao_b_slv_fs"; + function = "tdm_ao_b"; + bias-disable; + }; + }; + + tdm_ao_b_slv_sclk_pins: tdm-ao-b-slv-sclk { + mux { + groups = "tdm_ao_b_slv_sclk"; + function = "tdm_ao_b"; + bias-disable; + }; + }; + + uart_ao_a_pins: uart-a-ao { + mux { + groups = "uart_ao_a_tx", + "uart_ao_a_rx"; + function = "uart_ao_a"; + bias-disable; + }; + }; + + uart_ao_a_cts_rts_pins: uart-ao-a-cts-rts { + mux { + groups = "uart_ao_a_cts", + "uart_ao_a_rts"; + function = "uart_ao_a"; + bias-disable; + }; + }; + + pwm_a_e_pins: pwm-a-e { + mux { + groups = "pwm_a_e"; + function = "pwm_a_e"; + bias-disable; + }; + }; + + pwm_ao_a_pins: pwm-ao-a { + mux { + groups = "pwm_ao_a"; + function = "pwm_ao_a"; + bias-disable; + }; + }; + + pwm_ao_b_pins: pwm-ao-b { + mux { + groups = "pwm_ao_b"; + function = "pwm_ao_b"; + bias-disable; + }; + }; + + pwm_ao_c_4_pins: pwm-ao-c-4 { + mux { + groups = "pwm_ao_c_4"; + function = "pwm_ao_c"; + bias-disable; + }; + }; + + pwm_ao_c_6_pins: pwm-ao-c-6 { + mux { + groups = "pwm_ao_c_6"; + function = "pwm_ao_c"; + bias-disable; + }; + }; + + pwm_ao_d_5_pins: pwm-ao-d-5 { + mux { + groups = "pwm_ao_d_5"; + function = "pwm_ao_d"; + bias-disable; + }; + }; + + pwm_ao_d_10_pins: pwm-ao-d-10 { + mux { + groups = "pwm_ao_d_10"; + function = "pwm_ao_d"; + bias-disable; + }; + }; + + pwm_ao_d_e_pins: pwm-ao-d-e { + mux { + groups = "pwm_ao_d_e"; + function = "pwm_ao_d"; + }; + }; + + remote_input_ao_pins: remote-input-ao { + mux { + groups = "remote_ao_input"; + function = "remote_ao_input"; + bias-disable; + }; + }; + }; + }; + + vrtc: rtc@0a8 { + compatible = "amlogic,meson-vrtc"; + reg = <0x0 0x000a8 0x0 0x4>; + }; + + cec_AO: cec@100 { + compatible = "amlogic,meson-gx-ao-cec"; + reg = <0x0 0x00100 0x0 0x14>; + interrupts = <GIC_SPI 199 IRQ_TYPE_EDGE_RISING>; + clocks = <&clkc_AO CLKID_AO_CEC>; + clock-names = "core"; + status = "disabled"; + }; + + sec_AO: ao-secure@140 { + compatible = "amlogic,meson-gx-ao-secure", "syscon"; + reg = <0x0 0x140 0x0 0x140>; + amlogic,has-chip-id; + }; + + cecb_AO: cec@280 { + compatible = "amlogic,meson-g12a-ao-cec"; + reg = <0x0 0x00280 0x0 0x1c>; + interrupts = <GIC_SPI 203 IRQ_TYPE_EDGE_RISING>; + clocks = <&clkc_AO CLKID_AO_CTS_OSCIN>; + clock-names = "oscin"; + status = "disabled"; + }; + + pwm_AO_cd: pwm@2000 { + compatible = "amlogic,meson-g12a-ao-pwm-cd"; + reg = <0x0 0x2000 0x0 0x20>; + #pwm-cells = <3>; + status = "disabled"; + }; + + uart_AO: serial@3000 { + compatible = "amlogic,meson-gx-uart", + "amlogic,meson-ao-uart"; + reg = <0x0 0x3000 0x0 0x18>; + interrupts = <GIC_SPI 193 IRQ_TYPE_EDGE_RISING>; + clocks = <&xtal>, <&clkc_AO CLKID_AO_UART>, <&xtal>; + clock-names = "xtal", "pclk", "baud"; + status = "disabled"; + }; + + uart_AO_B: serial@4000 { + compatible = "amlogic,meson-gx-uart", + "amlogic,meson-ao-uart"; + reg = <0x0 0x4000 0x0 0x18>; + interrupts = <GIC_SPI 197 IRQ_TYPE_EDGE_RISING>; + clocks = <&xtal>, <&clkc_AO CLKID_AO_UART2>, <&xtal>; + clock-names = "xtal", "pclk", "baud"; + status = "disabled"; + }; + + i2c_AO: i2c@5000 { + compatible = "amlogic,meson-axg-i2c"; + status = "disabled"; + reg = <0x0 0x05000 0x0 0x20>; + interrupts = <GIC_SPI 195 IRQ_TYPE_EDGE_RISING>; + #address-cells = <1>; + #size-cells = <0>; + clocks = <&clkc CLKID_I2C>; + }; + + pwm_AO_ab: pwm@7000 { + compatible = "amlogic,meson-g12a-ao-pwm-ab"; + reg = <0x0 0x7000 0x0 0x20>; + #pwm-cells = <3>; + status = "disabled"; + }; + + ir: ir@8000 { + compatible = "amlogic,meson-gxbb-ir"; + reg = <0x0 0x8000 0x0 0x20>; + interrupts = <GIC_SPI 196 IRQ_TYPE_EDGE_RISING>; + status = "disabled"; + }; + + saradc: adc@9000 { + compatible = "amlogic,meson-g12a-saradc", + "amlogic,meson-saradc"; + reg = <0x0 0x9000 0x0 0x48>; + #io-channel-cells = <1>; + interrupts = <GIC_SPI 200 IRQ_TYPE_EDGE_RISING>; + clocks = <&xtal>, + <&clkc_AO CLKID_AO_SAR_ADC>, + <&clkc_AO CLKID_AO_SAR_ADC_CLK>, + <&clkc_AO CLKID_AO_SAR_ADC_SEL>; + clock-names = "clkin", "core", "adc_clk", "adc_sel"; + status = "disabled"; + }; + }; + + vpu: vpu@ff900000 { + compatible = "amlogic,meson-g12a-vpu"; + reg = <0x0 0xff900000 0x0 0x100000>, + <0x0 0xff63c000 0x0 0x1000>; + reg-names = "vpu", "hhi"; + interrupts = <GIC_SPI 3 IRQ_TYPE_EDGE_RISING>; + #address-cells = <1>; + #size-cells = <0>; + amlogic,canvas = <&canvas>; + + /* CVBS VDAC output port */ + cvbs_vdac_port: port@0 { + reg = <0>; + }; + + /* HDMI-TX output port */ + hdmi_tx_port: port@1 { + reg = <1>; + + hdmi_tx_out: endpoint { + remote-endpoint = <&hdmi_tx_in>; + }; + }; + }; + + gic: interrupt-controller@ffc01000 { + compatible = "arm,gic-400"; + reg = <0x0 0xffc01000 0 0x1000>, + <0x0 0xffc02000 0 0x2000>, + <0x0 0xffc04000 0 0x2000>, + <0x0 0xffc06000 0 0x2000>; + interrupt-controller; + interrupts = <GIC_PPI 9 + (GIC_CPU_MASK_SIMPLE(8) | IRQ_TYPE_LEVEL_HIGH)>; + #interrupt-cells = <3>; + #address-cells = <0>; + }; + + cbus: bus@ffd00000 { + compatible = "simple-bus"; + reg = <0x0 0xffd00000 0x0 0x100000>; + #address-cells = <2>; + #size-cells = <2>; + ranges = <0x0 0x0 0x0 0xffd00000 0x0 0x100000>; + + reset: reset-controller@1004 { + compatible = "amlogic,meson-axg-reset"; + reg = <0x0 0x1004 0x0 0x9c>; + #reset-cells = <1>; + }; + + gpio_intc: interrupt-controller@f080 { + compatible = "amlogic,meson-g12a-gpio-intc", + "amlogic,meson-gpio-intc"; + reg = <0x0 0xf080 0x0 0x10>; + interrupt-controller; + #interrupt-cells = <2>; + amlogic,channel-interrupts = <64 65 66 67 68 69 70 71>; + }; + + pwm_ef: pwm@19000 { + compatible = "amlogic,meson-g12a-ee-pwm"; + reg = <0x0 0x19000 0x0 0x20>; + #pwm-cells = <3>; + status = "disabled"; + }; + + pwm_cd: pwm@1a000 { + compatible = "amlogic,meson-g12a-ee-pwm"; + reg = <0x0 0x1a000 0x0 0x20>; + #pwm-cells = <3>; + status = "disabled"; + }; + + pwm_ab: pwm@1b000 { + compatible = "amlogic,meson-g12a-ee-pwm"; + reg = <0x0 0x1b000 0x0 0x20>; + #pwm-cells = <3>; + status = "disabled"; + }; + + i2c3: i2c@1c000 { + compatible = "amlogic,meson-axg-i2c"; + status = "disabled"; + reg = <0x0 0x1c000 0x0 0x20>; + interrupts = <GIC_SPI 39 IRQ_TYPE_EDGE_RISING>; + #address-cells = <1>; + #size-cells = <0>; + clocks = <&clkc CLKID_I2C>; + }; + + i2c2: i2c@1d000 { + compatible = "amlogic,meson-axg-i2c"; + status = "disabled"; + reg = <0x0 0x1d000 0x0 0x20>; + interrupts = <GIC_SPI 215 IRQ_TYPE_EDGE_RISING>; + #address-cells = <1>; + #size-cells = <0>; + clocks = <&clkc CLKID_I2C>; + }; + + i2c1: i2c@1e000 { + compatible = "amlogic,meson-axg-i2c"; + status = "disabled"; + reg = <0x0 0x1e000 0x0 0x20>; + interrupts = <GIC_SPI 214 IRQ_TYPE_EDGE_RISING>; + #address-cells = <1>; + #size-cells = <0>; + clocks = <&clkc CLKID_I2C>; + }; + + i2c0: i2c@1f000 { + compatible = "amlogic,meson-axg-i2c"; + status = "disabled"; + reg = <0x0 0x1f000 0x0 0x20>; + interrupts = <GIC_SPI 21 IRQ_TYPE_EDGE_RISING>; + #address-cells = <1>; + #size-cells = <0>; + clocks = <&clkc CLKID_I2C>; + }; + + clk_msr: clock-measure@18000 { + compatible = "amlogic,meson-g12a-clk-measure"; + reg = <0x0 0x18000 0x0 0x10>; + }; + + uart_C: serial@22000 { + compatible = "amlogic,meson-gx-uart"; + reg = <0x0 0x22000 0x0 0x18>; + interrupts = <GIC_SPI 93 IRQ_TYPE_EDGE_RISING>; + clocks = <&xtal>, <&clkc CLKID_UART2>, <&xtal>; + clock-names = "xtal", "pclk", "baud"; + status = "disabled"; + }; + + uart_B: serial@23000 { + compatible = "amlogic,meson-gx-uart"; + reg = <0x0 0x23000 0x0 0x18>; + interrupts = <GIC_SPI 75 IRQ_TYPE_EDGE_RISING>; + clocks = <&xtal>, <&clkc CLKID_UART1>, <&xtal>; + clock-names = "xtal", "pclk", "baud"; + status = "disabled"; + }; + + uart_A: serial@24000 { + compatible = "amlogic,meson-gx-uart"; + reg = <0x0 0x24000 0x0 0x18>; + interrupts = <GIC_SPI 26 IRQ_TYPE_EDGE_RISING>; + clocks = <&xtal>, <&clkc CLKID_UART0>, <&xtal>; + clock-names = "xtal", "pclk", "baud"; + status = "disabled"; + }; + }; + + sd_emmc_a: sd@ffe03000 { + compatible = "amlogic,meson-axg-mmc"; + reg = <0x0 0xffe03000 0x0 0x800>; + interrupts = <GIC_SPI 189 IRQ_TYPE_EDGE_RISING>; + status = "disabled"; + clocks = <&clkc CLKID_SD_EMMC_A>, + <&clkc CLKID_SD_EMMC_A_CLK0>, + <&clkc CLKID_FCLK_DIV2>; + clock-names = "core", "clkin0", "clkin1"; + resets = <&reset RESET_SD_EMMC_A>; + }; + + sd_emmc_b: sd@ffe05000 { + compatible = "amlogic,meson-axg-mmc"; + reg = <0x0 0xffe05000 0x0 0x800>; + interrupts = <GIC_SPI 190 IRQ_TYPE_EDGE_RISING>; + status = "disabled"; + clocks = <&clkc CLKID_SD_EMMC_B>, + <&clkc CLKID_SD_EMMC_B_CLK0>, + <&clkc CLKID_FCLK_DIV2>; + clock-names = "core", "clkin0", "clkin1"; + resets = <&reset RESET_SD_EMMC_B>; + }; + + sd_emmc_c: mmc@ffe07000 { + compatible = "amlogic,meson-axg-mmc"; + reg = <0x0 0xffe07000 0x0 0x800>; + interrupts = <GIC_SPI 191 IRQ_TYPE_EDGE_RISING>; + status = "disabled"; + clocks = <&clkc CLKID_SD_EMMC_C>, + <&clkc CLKID_SD_EMMC_C_CLK0>, + <&clkc CLKID_FCLK_DIV2>; + clock-names = "core", "clkin0", "clkin1"; + resets = <&reset RESET_SD_EMMC_C>; + }; + + usb: usb@ffe09000 { + status = "disabled"; + compatible = "amlogic,meson-g12a-usb-ctrl"; + reg = <0x0 0xffe09000 0x0 0xa0>; + interrupts = <GIC_SPI 16 IRQ_TYPE_LEVEL_HIGH>; + #address-cells = <2>; + #size-cells = <2>; + ranges; + + clocks = <&clkc CLKID_USB>; + resets = <&reset RESET_USB>; + + dr_mode = "otg"; + + phys = <&usb2_phy0>, <&usb2_phy1>, + <&usb3_pcie_phy PHY_TYPE_USB3>; + phy-names = "usb2-phy0", "usb2-phy1", "usb3-phy0"; + + dwc2: usb@ff400000 { + compatible = "amlogic,meson-g12a-usb", "snps,dwc2"; + reg = <0x0 0xff400000 0x0 0x40000>; + interrupts = <GIC_SPI 31 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&clkc CLKID_USB1_DDR_BRIDGE>; + clock-names = "ddr"; + phys = <&usb2_phy1>; + phy-names = "usb2-phy"; + dr_mode = "peripheral"; + g-rx-fifo-size = <192>; + g-np-tx-fifo-size = <128>; + g-tx-fifo-size = <128 128 16 16 16>; + }; + + dwc3: usb@ff500000 { + compatible = "snps,dwc3"; + reg = <0x0 0xff500000 0x0 0x100000>; + interrupts = <GIC_SPI 30 IRQ_TYPE_LEVEL_HIGH>; + dr_mode = "host"; + snps,dis_u2_susphy_quirk; + snps,quirk-frame-length-adjustment; + }; + }; + + mali: gpu@ffe40000 { + compatible = "amlogic,meson-g12a-mali", "arm,mali-bifrost"; + reg = <0x0 0xffe40000 0x0 0x40000>; + interrupt-parent = <&gic>; + interrupts = <GIC_SPI 160 IRQ_TYPE_LEVEL_HIGH>, + <GIC_SPI 161 IRQ_TYPE_LEVEL_HIGH>, + <GIC_SPI 162 IRQ_TYPE_LEVEL_HIGH>; + interrupt-names = "gpu", "mmu", "job"; + clocks = <&clkc CLKID_MALI>; + resets = <&reset RESET_DVALIN_CAPB3>, <&reset RESET_DVALIN>; + + /* + * Mali clocking is provided by two identical clock paths + * MALI_0 and MALI_1 muxed to a single clock by a glitch + * free mux to safely change frequency while running. + */ + assigned-clocks = <&clkc CLKID_MALI_0_SEL>, + <&clkc CLKID_MALI_0>, + <&clkc CLKID_MALI>; /* Glitch free mux */ + assigned-clock-parents = <&clkc CLKID_FCLK_DIV2P5>, + <0>, /* Do Nothing */ + <&clkc CLKID_MALI_0>; + assigned-clock-rates = <0>, /* Do Nothing */ + <800000000>, + <0>; /* Do Nothing */ + }; + }; + + timer { + compatible = "arm,armv8-timer"; + interrupts = <GIC_PPI 13 + (GIC_CPU_MASK_RAW(0xff) | IRQ_TYPE_LEVEL_LOW)>, + <GIC_PPI 14 + (GIC_CPU_MASK_RAW(0xff) | IRQ_TYPE_LEVEL_LOW)>, + <GIC_PPI 11 + (GIC_CPU_MASK_RAW(0xff) | IRQ_TYPE_LEVEL_LOW)>, + <GIC_PPI 10 + (GIC_CPU_MASK_RAW(0xff) | IRQ_TYPE_LEVEL_LOW)>; + arm,no-tick-in-suspend; + }; + + xtal: xtal-clk { + compatible = "fixed-clock"; + clock-frequency = <24000000>; + clock-output-names = "xtal"; + #clock-cells = <0>; + }; + +}; diff --git a/arch/arm/dts/meson-g12b-a311d-khadas-vim3.dts b/arch/arm/dts/meson-g12b-a311d-khadas-vim3.dts new file mode 100644 index 0000000000..73128ed243 --- /dev/null +++ b/arch/arm/dts/meson-g12b-a311d-khadas-vim3.dts @@ -0,0 +1,15 @@ +// SPDX-License-Identifier: (GPL-2.0+ OR MIT) +/* + * Copyright (c) 2019 BayLibre, SAS + * Author: Neil Armstrong narmstrong@baylibre.com + * Copyright (c) 2019 Christian Hewitt christianshewitt@gmail.com + */ + +/dts-v1/; + +#include "meson-g12b-a311d.dtsi" +#include "meson-g12b-khadas-vim3.dtsi" + +/ { + compatible = "khadas,vim3", "amlogic,a311d", "amlogic,g12b"; +}; diff --git a/arch/arm/dts/meson-g12b-a311d.dtsi b/arch/arm/dts/meson-g12b-a311d.dtsi new file mode 100644 index 0000000000..d61f43052a --- /dev/null +++ b/arch/arm/dts/meson-g12b-a311d.dtsi @@ -0,0 +1,149 @@ +// SPDX-License-Identifier: (GPL-2.0+ OR MIT) +/* + * Copyright (c) 2019 BayLibre, SAS + * Author: Neil Armstrong narmstrong@baylibre.com + */ + +#include "meson-g12b.dtsi" + +/ { + cpu_opp_table_0: opp-table-0 { + compatible = "operating-points-v2"; + opp-shared; + + opp-100000000 { + opp-hz = /bits/ 64 <100000000>; + opp-microvolt = <731000>; + }; + + opp-250000000 { + opp-hz = /bits/ 64 <250000000>; + opp-microvolt = <731000>; + }; + + opp-500000000 { + opp-hz = /bits/ 64 <500000000>; + opp-microvolt = <731000>; + }; + + opp-667000000 { + opp-hz = /bits/ 64 <667000000>; + opp-microvolt = <731000>; + }; + + opp-1000000000 { + opp-hz = /bits/ 64 <1000000000>; + opp-microvolt = <761000>; + }; + + opp-1200000000 { + opp-hz = /bits/ 64 <1200000000>; + opp-microvolt = <781000>; + }; + + opp-1398000000 { + opp-hz = /bits/ 64 <1398000000>; + opp-microvolt = <811000>; + }; + + opp-1512000000 { + opp-hz = /bits/ 64 <1512000000>; + opp-microvolt = <861000>; + }; + + opp-1608000000 { + opp-hz = /bits/ 64 <1608000000>; + opp-microvolt = <901000>; + }; + + opp-1704000000 { + opp-hz = /bits/ 64 <1704000000>; + opp-microvolt = <951000>; + }; + + opp-1800000000 { + opp-hz = /bits/ 64 <1800000000>; + opp-microvolt = <1001000>; + }; + }; + + cpub_opp_table_1: opp-table-1 { + compatible = "operating-points-v2"; + opp-shared; + + opp-100000000 { + opp-hz = /bits/ 64 <100000000>; + opp-microvolt = <731000>; + }; + + opp-250000000 { + opp-hz = /bits/ 64 <250000000>; + opp-microvolt = <731000>; + }; + + opp-500000000 { + opp-hz = /bits/ 64 <500000000>; + opp-microvolt = <731000>; + }; + + opp-667000000 { + opp-hz = /bits/ 64 <667000000>; + opp-microvolt = <731000>; + }; + + opp-1000000000 { + opp-hz = /bits/ 64 <1000000000>; + opp-microvolt = <731000>; + }; + + opp-1200000000 { + opp-hz = /bits/ 64 <1200000000>; + opp-microvolt = <751000>; + }; + + opp-1398000000 { + opp-hz = /bits/ 64 <1398000000>; + opp-microvolt = <771000>; + }; + + opp-1512000000 { + opp-hz = /bits/ 64 <1512000000>; + opp-microvolt = <771000>; + }; + + opp-1608000000 { + opp-hz = /bits/ 64 <1608000000>; + opp-microvolt = <781000>; + }; + + opp-1704000000 { + opp-hz = /bits/ 64 <1704000000>; + opp-microvolt = <791000>; + }; + + opp-1800000000 { + opp-hz = /bits/ 64 <1800000000>; + opp-microvolt = <831000>; + }; + + opp-1908000000 { + opp-hz = /bits/ 64 <1908000000>; + opp-microvolt = <861000>; + }; + + opp-2016000000 { + opp-hz = /bits/ 64 <2016000000>; + opp-microvolt = <911000>; + }; + + opp-2108000000 { + opp-hz = /bits/ 64 <2108000000>; + opp-microvolt = <951000>; + }; + + opp-2208000000 { + opp-hz = /bits/ 64 <2208000000>; + opp-microvolt = <1011000>; + }; + }; +}; diff --git a/arch/arm/dts/meson-g12b-khadas-vim3.dtsi b/arch/arm/dts/meson-g12b-khadas-vim3.dtsi new file mode 100644 index 0000000000..9c3ca2edc7 --- /dev/null +++ b/arch/arm/dts/meson-g12b-khadas-vim3.dtsi @@ -0,0 +1,544 @@ +// SPDX-License-Identifier: (GPL-2.0+ OR MIT) +/* + * Copyright (c) 2019 BayLibre, SAS + * Author: Neil Armstrong narmstrong@baylibre.com + * Copyright (c) 2019 Christian Hewitt christianshewitt@gmail.com + */ + +#include <dt-bindings/input/input.h> +#include <dt-bindings/gpio/meson-g12a-gpio.h> +#include <dt-bindings/sound/meson-g12a-tohdmitx.h> + +/ { + model = "Khadas VIM3"; + + aliases { + serial0 = &uart_AO; + ethernet0 = ðmac; + }; + + chosen { + stdout-path = "serial0:115200n8"; + }; + + memory@0 { + device_type = "memory"; + reg = <0x0 0x0 0x0 0x80000000>; + }; + + adc-keys { + compatible = "adc-keys"; + io-channels = <&saradc 2>; + io-channel-names = "buttons"; + keyup-threshold-microvolt = <1710000>; + + button-function { + label = "Function"; + linux,code = <KEY_FN>; + press-threshold-microvolt = <10000>; + }; + }; + + leds { + compatible = "gpio-leds"; + + white { + label = "vim3:white:sys"; + gpios = <&gpio_ao GPIOAO_4 GPIO_ACTIVE_LOW>; + linux,default-trigger = "heartbeat"; + }; + + red { + label = "vim3:red"; + gpios = <&gpio_expander 5 GPIO_ACTIVE_LOW>; + }; + }; + + emmc_pwrseq: emmc-pwrseq { + compatible = "mmc-pwrseq-emmc"; + reset-gpios = <&gpio BOOT_12 GPIO_ACTIVE_LOW>; + }; + + gpio-keys-polled { + compatible = "gpio-keys-polled"; + poll-interval = <100>; + + power-button { + label = "power"; + linux,code = <KEY_POWER>; + gpios = <&gpio_ao GPIOAO_7 GPIO_ACTIVE_LOW>; + }; + }; + + sdio_pwrseq: sdio-pwrseq { + compatible = "mmc-pwrseq-simple"; + reset-gpios = <&gpio GPIOX_6 GPIO_ACTIVE_LOW>; + clocks = <&wifi32k>; + clock-names = "ext_clock"; + }; + + dc_in: regulator-dc_in { + compatible = "regulator-fixed"; + regulator-name = "DC_IN"; + regulator-min-microvolt = <5000000>; + regulator-max-microvolt = <5000000>; + regulator-always-on; + }; + + vcc_5v: regulator-vcc_5v { + compatible = "regulator-fixed"; + regulator-name = "VCC_5V"; + regulator-min-microvolt = <5000000>; + regulator-max-microvolt = <5000000>; + vin-supply = <&dc_in>; + + gpio = <&gpio GPIOH_8 GPIO_OPEN_DRAIN>; + enable-active-high; + }; + + vcc_1v8: regulator-vcc_1v8 { + compatible = "regulator-fixed"; + regulator-name = "VCC_1V8"; + regulator-min-microvolt = <1800000>; + regulator-max-microvolt = <1800000>; + vin-supply = <&vcc_3v3>; + regulator-always-on; + }; + + vcc_3v3: regulator-vcc_3v3 { + compatible = "regulator-fixed"; + regulator-name = "VCC_3V3"; + regulator-min-microvolt = <3300000>; + regulator-max-microvolt = <3300000>; + vin-supply = <&vsys_3v3>; + regulator-always-on; + /* FIXME: actually controlled by VDDCPU_B_EN */ + }; + + vddcpu_a: regulator-vddcpu-a { + /* + * MP8756GD Regulator. + */ + compatible = "pwm-regulator"; + + regulator-name = "VDDCPU_A"; + regulator-min-microvolt = <690000>; + regulator-max-microvolt = <1050000>; + + vin-supply = <&dc_in>; + + pwms = <&pwm_ab 0 1250 0>; + pwm-dutycycle-range = <100 0>; + + regulator-boot-on; + regulator-always-on; + }; + + vddcpu_b: regulator-vddcpu-b { + /* + * Silergy SY8030DEC Regulator. + */ + compatible = "pwm-regulator"; + + regulator-name = "VDDCPU_B"; + regulator-min-microvolt = <690000>; + regulator-max-microvolt = <1050000>; + + vin-supply = <&vsys_3v3>; + + pwms = <&pwm_AO_cd 1 1250 0>; + pwm-dutycycle-range = <100 0>; + + regulator-boot-on; + regulator-always-on; + }; + + vddao_1v8: regulator-vddao_1v8 { + compatible = "regulator-fixed"; + regulator-name = "VDDIO_AO1V8"; + regulator-min-microvolt = <1800000>; + regulator-max-microvolt = <1800000>; + vin-supply = <&vsys_3v3>; + regulator-always-on; + }; + + emmc_1v8: regulator-emmc_1v8 { + compatible = "regulator-fixed"; + regulator-name = "EMMC_AO1V8"; + regulator-min-microvolt = <1800000>; + regulator-max-microvolt = <1800000>; + vin-supply = <&vcc_3v3>; + regulator-always-on; + }; + + vsys_3v3: regulator-vsys_3v3 { + compatible = "regulator-fixed"; + regulator-name = "VSYS_3V3"; + regulator-min-microvolt = <3300000>; + regulator-max-microvolt = <3300000>; + vin-supply = <&dc_in>; + regulator-always-on; + }; + + usb_pwr: regulator-usb_pwr { + compatible = "regulator-fixed"; + regulator-name = "USB_PWR"; + regulator-min-microvolt = <5000000>; + regulator-max-microvolt = <5000000>; + vin-supply = <&vcc_5v>; + + gpio = <&gpio GPIOA_6 GPIO_ACTIVE_HIGH>; + enable-active-high; + }; + + hdmi-connector { + compatible = "hdmi-connector"; + type = "a"; + + port { + hdmi_connector_in: endpoint { + remote-endpoint = <&hdmi_tx_tmds_out>; + }; + }; + }; + + wifi32k: wifi32k { + compatible = "pwm-clock"; + #clock-cells = <0>; + clock-frequency = <32768>; + pwms = <&pwm_ef 0 30518 0>; /* PWM_E at 32.768KHz */ + }; + + sound { + compatible = "amlogic,axg-sound-card"; + model = "G12A-KHADAS-VIM3"; + audio-aux-devs = <&tdmout_b>; + audio-routing = "TDMOUT_B IN 0", "FRDDR_A OUT 1", + "TDMOUT_B IN 1", "FRDDR_B OUT 1", + "TDMOUT_B IN 2", "FRDDR_C OUT 1", + "TDM_B Playback", "TDMOUT_B OUT"; + + assigned-clocks = <&clkc CLKID_MPLL2>, + <&clkc CLKID_MPLL0>, + <&clkc CLKID_MPLL1>; + assigned-clock-parents = <0>, <0>, <0>; + assigned-clock-rates = <294912000>, + <270950400>, + <393216000>; + status = "okay"; + + dai-link-0 { + sound-dai = <&frddr_a>; + }; + + dai-link-1 { + sound-dai = <&frddr_b>; + }; + + dai-link-2 { + sound-dai = <&frddr_c>; + }; + + /* 8ch hdmi interface */ + dai-link-3 { + sound-dai = <&tdmif_b>; + dai-format = "i2s"; + dai-tdm-slot-tx-mask-0 = <1 1>; + dai-tdm-slot-tx-mask-1 = <1 1>; + dai-tdm-slot-tx-mask-2 = <1 1>; + dai-tdm-slot-tx-mask-3 = <1 1>; + mclk-fs = <256>; + + codec { + sound-dai = <&tohdmitx TOHDMITX_I2S_IN_B>; + }; + }; + + /* hdmi glue */ + dai-link-4 { + sound-dai = <&tohdmitx TOHDMITX_I2S_OUT>; + + codec { + sound-dai = <&hdmi_tx>; + }; + }; + }; +}; + +&arb { + status = "okay"; +}; + +&cec_AO { + pinctrl-0 = <&cec_ao_a_h_pins>; + pinctrl-names = "default"; + status = "disabled"; + hdmi-phandle = <&hdmi_tx>; +}; + +&cecb_AO { + pinctrl-0 = <&cec_ao_b_h_pins>; + pinctrl-names = "default"; + status = "okay"; + hdmi-phandle = <&hdmi_tx>; +}; + +&clkc_audio { + status = "okay"; +}; + +&cpu0 { + cpu-supply = <&vddcpu_b>; + operating-points-v2 = <&cpu_opp_table_0>; + clocks = <&clkc CLKID_CPU_CLK>; + clock-latency = <50000>; +}; + +&cpu1 { + cpu-supply = <&vddcpu_b>; + operating-points-v2 = <&cpu_opp_table_0>; + clocks = <&clkc CLKID_CPU_CLK>; + clock-latency = <50000>; +}; + +&cpu100 { + cpu-supply = <&vddcpu_a>; + operating-points-v2 = <&cpub_opp_table_1>; + clocks = <&clkc CLKID_CPUB_CLK>; + clock-latency = <50000>; +}; + +&cpu101 { + cpu-supply = <&vddcpu_a>; + operating-points-v2 = <&cpub_opp_table_1>; + clocks = <&clkc CLKID_CPUB_CLK>; + clock-latency = <50000>; +}; + +&cpu102 { + cpu-supply = <&vddcpu_a>; + operating-points-v2 = <&cpub_opp_table_1>; + clocks = <&clkc CLKID_CPUB_CLK>; + clock-latency = <50000>; +}; + +&cpu103 { + cpu-supply = <&vddcpu_a>; + operating-points-v2 = <&cpub_opp_table_1>; + clocks = <&clkc CLKID_CPUB_CLK>; + clock-latency = <50000>; +}; + +&ext_mdio { + external_phy: ethernet-phy@0 { + /* Realtek RTL8211F (0x001cc916) */ + reg = <0>; + max-speed = <1000>; + + interrupt-parent = <&gpio_intc>; + /* MAC_INTR on GPIOZ_14 */ + interrupts = <26 IRQ_TYPE_LEVEL_LOW>; + }; +}; + +ðmac { + pinctrl-0 = <ð_pins>, <ð_rgmii_pins>; + pinctrl-names = "default"; + status = "okay"; + phy-mode = "rgmii"; + phy-handle = <&external_phy>; + amlogic,tx-delay-ns = <2>; +}; + +&frddr_a { + status = "okay"; +}; + +&frddr_b { + status = "okay"; +}; + +&frddr_c { + status = "okay"; +}; + +&hdmi_tx { + status = "okay"; + pinctrl-0 = <&hdmitx_hpd_pins>, <&hdmitx_ddc_pins>; + pinctrl-names = "default"; + hdmi-supply = <&vcc_5v>; +}; + +&hdmi_tx_tmds_port { + hdmi_tx_tmds_out: endpoint { + remote-endpoint = <&hdmi_connector_in>; + }; +}; + +&i2c_AO { + status = "okay"; + pinctrl-0 = <&i2c_ao_sck_pins>, <&i2c_ao_sda_pins>; + pinctrl-names = "default"; + + gpio_expander: gpio-controller@20 { + compatible = "ti,tca6408"; + reg = <0x20>; + vcc-supply = <&vcc_3v3>; + gpio-controller; + #gpio-cells = <2>; + }; + + rtc@51 { + compatible = "haoyu,hym8563"; + reg = <0x51>; + #clock-cells = <0>; + }; +}; + +&ir { + status = "okay"; + pinctrl-0 = <&remote_input_ao_pins>; + pinctrl-names = "default"; + linux,rc-map-name = "rc-khadas"; +}; + +&pwm_ab { + pinctrl-0 = <&pwm_a_e_pins>; + pinctrl-names = "default"; + clocks = <&xtal>; + clock-names = "clkin0"; + status = "okay"; +}; + +&pwm_AO_cd { + pinctrl-0 = <&pwm_ao_d_e_pins>; + pinctrl-names = "default"; + clocks = <&xtal>; + clock-names = "clkin1"; + status = "okay"; +}; + +&pwm_ef { + status = "okay"; + pinctrl-0 = <&pwm_e_pins>; + pinctrl-names = "default"; +}; + +&saradc { + status = "okay"; + vref-supply = <&vddao_1v8>; +}; + +/* SDIO */ +&sd_emmc_a { + status = "okay"; + pinctrl-0 = <&sdio_pins>; + pinctrl-1 = <&sdio_clk_gate_pins>; + pinctrl-names = "default", "clk-gate"; + #address-cells = <1>; + #size-cells = <0>; + + bus-width = <4>; + cap-sd-highspeed; + sd-uhs-sdr50; + max-frequency = <100000000>; + + non-removable; + disable-wp; + + mmc-pwrseq = <&sdio_pwrseq>; + + vmmc-supply = <&vsys_3v3>; + vqmmc-supply = <&vddao_1v8>; + + brcmf: wifi@1 { + reg = <1>; + compatible = "brcm,bcm4329-fmac"; + }; +}; + +/* SD card */ +&sd_emmc_b { + status = "okay"; + pinctrl-0 = <&sdcard_c_pins>; + pinctrl-1 = <&sdcard_clk_gate_c_pins>; + pinctrl-names = "default", "clk-gate"; + + bus-width = <4>; + cap-sd-highspeed; + max-frequency = <50000000>; + disable-wp; + + cd-gpios = <&gpio GPIOC_6 GPIO_ACTIVE_LOW>; + vmmc-supply = <&vsys_3v3>; + vqmmc-supply = <&vsys_3v3>; +}; + +/* eMMC */ +&sd_emmc_c { + status = "okay"; + pinctrl-0 = <&emmc_pins>, <&emmc_ds_pins>; + pinctrl-1 = <&emmc_clk_gate_pins>; + pinctrl-names = "default", "clk-gate"; + + bus-width = <8>; + cap-mmc-highspeed; + mmc-ddr-1_8v; + mmc-hs200-1_8v; + max-frequency = <200000000>; + disable-wp; + + mmc-pwrseq = <&emmc_pwrseq>; + vmmc-supply = <&vcc_3v3>; + vqmmc-supply = <&emmc_1v8>; +}; + +&tdmif_b { + status = "okay"; +}; + +&tdmout_b { + status = "okay"; +}; + +&tohdmitx { + status = "okay"; +}; + +&uart_A { + status = "okay"; + pinctrl-0 = <&uart_a_pins>, <&uart_a_cts_rts_pins>; + pinctrl-names = "default"; + uart-has-rtscts; + + bluetooth { + compatible = "brcm,bcm43438-bt"; + shutdown-gpios = <&gpio GPIOX_17 GPIO_ACTIVE_HIGH>; + max-speed = <2000000>; + clocks = <&wifi32k>; + clock-names = "lpo"; + }; +}; + +&uart_AO { + status = "okay"; + pinctrl-0 = <&uart_ao_a_pins>; + pinctrl-names = "default"; +}; + +&usb2_phy0 { + phy-supply = <&dc_in>; +}; + +&usb2_phy1 { + phy-supply = <&usb_pwr>; +}; + +&usb3_pcie_phy { + phy-supply = <&usb_pwr>; +}; + +&usb { + status = "okay"; + dr_mode = "peripheral"; +}; diff --git a/arch/arm/dts/meson-g12b.dtsi b/arch/arm/dts/meson-g12b.dtsi index 9e88e513b2..5628ccd545 100644 --- a/arch/arm/dts/meson-g12b.dtsi +++ b/arch/arm/dts/meson-g12b.dtsi @@ -4,12 +4,16 @@ * Author: Neil Armstrong narmstrong@baylibre.com */
-#include "meson-g12a.dtsi" +#include "meson-g12-common.dtsi" +#include <dt-bindings/power/meson-g12a-power.h>
/ { compatible = "amlogic,g12b";
cpus { + #address-cells = <0x2>; + #size-cells = <0x0>; + cpu-map { cluster0 { core0 { @@ -40,8 +44,21 @@ }; };
- /delete-node/ cpu@2; - /delete-node/ cpu@3; + cpu0: cpu@0 { + device_type = "cpu"; + compatible = "arm,cortex-a53"; + reg = <0x0 0x0>; + enable-method = "psci"; + next-level-cache = <&l2>; + }; + + cpu1: cpu@1 { + device_type = "cpu"; + compatible = "arm,cortex-a53"; + reg = <0x0 0x1>; + enable-method = "psci"; + next-level-cache = <&l2>; + };
cpu100: cpu@100 { device_type = "cpu"; @@ -74,9 +91,25 @@ enable-method = "psci"; next-level-cache = <&l2>; }; + + l2: l2-cache0 { + compatible = "cache"; + }; }; };
&clkc { compatible = "amlogic,g12b-clkc"; }; + +ðmac { + power-domains = <&pwrc PWRC_G12A_ETH_ID>; +}; + +&vpu { + power-domains = <&pwrc PWRC_G12A_VPU_ID>; +}; + +&sd_emmc_a { + amlogic,dram-access-quirk; +}; diff --git a/include/dt-bindings/clock/g12a-clkc.h b/include/dt-bindings/clock/g12a-clkc.h index b6b127e456..0837c1a7ae 100644 --- a/include/dt-bindings/clock/g12a-clkc.h +++ b/include/dt-bindings/clock/g12a-clkc.h @@ -137,5 +137,11 @@ #define CLKID_VDEC_HEVC 207 #define CLKID_VDEC_HEVCF 210 #define CLKID_TS 212 +#define CLKID_CPUB_CLK 224 +#define CLKID_GP1_PLL 243 +#define CLKID_DSU_CLK 252 +#define CLKID_CPU1_CLK 253 +#define CLKID_CPU2_CLK 254 +#define CLKID_CPU3_CLK 255
#endif /* __G12A_CLKC_H */ diff --git a/include/dt-bindings/power/meson-g12a-power.h b/include/dt-bindings/power/meson-g12a-power.h new file mode 100644 index 0000000000..bb5e67a842 --- /dev/null +++ b/include/dt-bindings/power/meson-g12a-power.h @@ -0,0 +1,13 @@ +/* SPDX-License-Identifier: (GPL-2.0+ or MIT) */ +/* + * Copyright (c) 2019 BayLibre, SAS + * Author: Neil Armstrong narmstrong@baylibre.com + */ + +#ifndef _DT_BINDINGS_MESON_G12A_POWER_H +#define _DT_BINDINGS_MESON_G12A_POWER_H + +#define PWRC_G12A_VPU_ID 0 +#define PWRC_G12A_ETH_ID 1 + +#endif diff --git a/include/dt-bindings/reset/amlogic,meson-g12a-audio-reset.h b/include/dt-bindings/reset/amlogic,meson-g12a-audio-reset.h new file mode 100644 index 0000000000..14b78dabed --- /dev/null +++ b/include/dt-bindings/reset/amlogic,meson-g12a-audio-reset.h @@ -0,0 +1,38 @@ +/* SPDX-License-Identifier: GPL-2.0 */ +/* + * Copyright (c) 2019 BayLibre, SAS. + * Author: Jerome Brunet jbrunet@baylibre.com + * + */ + +#ifndef _DT_BINDINGS_AMLOGIC_MESON_G12A_AUDIO_RESET_H +#define _DT_BINDINGS_AMLOGIC_MESON_G12A_AUDIO_RESET_H + +#define AUD_RESET_PDM 0 +#define AUD_RESET_TDMIN_A 1 +#define AUD_RESET_TDMIN_B 2 +#define AUD_RESET_TDMIN_C 3 +#define AUD_RESET_TDMIN_LB 4 +#define AUD_RESET_LOOPBACK 5 +#define AUD_RESET_TODDR_A 6 +#define AUD_RESET_TODDR_B 7 +#define AUD_RESET_TODDR_C 8 +#define AUD_RESET_FRDDR_A 9 +#define AUD_RESET_FRDDR_B 10 +#define AUD_RESET_FRDDR_C 11 +#define AUD_RESET_TDMOUT_A 12 +#define AUD_RESET_TDMOUT_B 13 +#define AUD_RESET_TDMOUT_C 14 +#define AUD_RESET_SPDIFOUT 15 +#define AUD_RESET_SPDIFOUT_B 16 +#define AUD_RESET_SPDIFIN 17 +#define AUD_RESET_EQDRC 18 +#define AUD_RESET_RESAMPLE 19 +#define AUD_RESET_DDRARB 20 +#define AUD_RESET_POWDET 21 +#define AUD_RESET_TORAM 22 +#define AUD_RESET_TOACODEC 23 +#define AUD_RESET_TOHDMITX 24 +#define AUD_RESET_CLKTREE 25 + +#endif
Derived from odroid-n2_defconfig and README.odroid-n2.
Reviewed-by: Neil Armstrong narmstrong@baylibre.com Signed-off-by: Andreas Färber afaerber@suse.de --- v1 -> v2: * Fixed branch name in README
board/amlogic/w400/MAINTAINERS | 1 + board/amlogic/w400/README.khadas-vim3 | 132 ++++++++++++++++++++++++++++++++++ configs/khadas-vim3_defconfig | 54 ++++++++++++++ 3 files changed, 187 insertions(+) create mode 100644 board/amlogic/w400/README.khadas-vim3 create mode 100644 configs/khadas-vim3_defconfig
diff --git a/board/amlogic/w400/MAINTAINERS b/board/amlogic/w400/MAINTAINERS index 6e68fa73f7..3b21f50367 100644 --- a/board/amlogic/w400/MAINTAINERS +++ b/board/amlogic/w400/MAINTAINERS @@ -3,4 +3,5 @@ M: Neil Armstrong narmstrong@baylibre.com S: Maintained L: u-boot-amlogic@groups.io F: board/amlogic/w400/ +F: configs/khadas-vim3_defconfig F: configs/odroid-n2_defconfig diff --git a/board/amlogic/w400/README.khadas-vim3 b/board/amlogic/w400/README.khadas-vim3 new file mode 100644 index 0000000000..45ef90c1b0 --- /dev/null +++ b/board/amlogic/w400/README.khadas-vim3 @@ -0,0 +1,132 @@ +U-Boot for Khadas VIM3 +====================== + +Khadas VIM3 is a single board computer manufactured by Shenzhen Wesion +Technology Co., Ltd. with the following specifications: + + - Amlogic A311D Arm Cortex-A53 dual-core + Cortex-A73 quad-core SoC + - 4GB LPDDR4 SDRAM + - Gigabit Ethernet + - HDMI 2.1 display + - 40-pin GPIO header + - 1 x USB 3.0 Host, 1 x USB 2.0 Host + - eMMC, microSD + - M.2 + - Infrared receiver + +Schematics are available on the manufacturer website. + +Currently the U-Boot port supports the following devices: + - serial + - eMMC, microSD + - Ethernet + - I2C + - Regulators + - Reset controller + - Clock controller + - ADC + +u-boot compilation +================== + + > export ARCH=arm + > export CROSS_COMPILE=aarch64-none-elf- + > make khadas-vim3_defconfig + > make + +Image creation +============== + +Amlogic doesn't provide sources for the firmware and for tools needed +to create the bootloader image, so it is necessary to obtain them from +the git tree published by the board vendor: + + > wget https://releases.linaro.org/archive/13.11/components/toolchain/binaries/gcc-... + > wget https://releases.linaro.org/archive/13.11/components/toolchain/binaries/gcc-... + > tar xvfJ gcc-linaro-aarch64-none-elf-4.8-2013.11_linux.tar.xz + > tar xvfJ gcc-linaro-arm-none-eabi-4.8-2013.11_linux.tar.xz + > export PATH=$PWD/gcc-linaro-aarch64-none-elf-4.8-2013.11_linux/bin:$PWD/gcc-linaro-arm-none-eabi-4.8-2013.11_linux/bin:$PATH + + > DIR=vim3-u-boot + > git clone --depth 1 \ + https://github.com/khadas/u-boot.git -b khadas-vims-v2015.01 \ + $DIR + + > cd vim3-u-boot + > make kvim3_defconfig + > make + > export UBOOTDIR=$PWD + + Go back to mainline U-Boot source tree then : + > mkdir fip + + > cp $UBOOTDIR/build/scp_task/bl301.bin fip/ + > cp $UBOOTDIR/build/board/khadas/kvim3/firmware/acs.bin fip/ + > cp $UBOOTDIR/fip/g12b/bl2.bin fip/ + > cp $UBOOTDIR/fip/g12b/bl30.bin fip/ + > cp $UBOOTDIR/fip/g12b/bl31.img fip/ + > cp $UBOOTDIR/fip/g12b/ddr3_1d.fw fip/ + > cp $UBOOTDIR/fip/g12b/ddr4_1d.fw fip/ + > cp $UBOOTDIR/fip/g12b/ddr4_2d.fw fip/ + > cp $UBOOTDIR/fip/g12b/diag_lpddr4.fw fip/ + > cp $UBOOTDIR/fip/g12b/lpddr3_1d.fw fip/ + > cp $UBOOTDIR/fip/g12b/lpddr4_1d.fw fip/ + > cp $UBOOTDIR/fip/g12b/lpddr4_2d.fw fip/ + > cp $UBOOTDIR/fip/g12b/piei.fw fip/ + > cp $UBOOTDIR/fip/g12b/aml_ddr.fw fip/ + > cp u-boot.bin fip/bl33.bin + + > sh fip/blx_fix.sh \ + fip/bl30.bin \ + fip/zero_tmp \ + fip/bl30_zero.bin \ + fip/bl301.bin \ + fip/bl301_zero.bin \ + fip/bl30_new.bin \ + bl30 + + > sh fip/blx_fix.sh \ + fip/bl2.bin \ + fip/zero_tmp \ + fip/bl2_zero.bin \ + fip/acs.bin \ + fip/bl21_zero.bin \ + fip/bl2_new.bin \ + bl2 + + > $UBOOTDIR/fip/g12b/aml_encrypt_g12b --bl30sig --input fip/bl30_new.bin \ + --output fip/bl30_new.bin.g12a.enc \ + --level v3 + > $UBOOTDIR/fip/g12b/aml_encrypt_g12b --bl3sig --input fip/bl30_new.bin.g12a.enc \ + --output fip/bl30_new.bin.enc \ + --level v3 --type bl30 + > $UBOOTDIR/fip/g12b/aml_encrypt_g12b --bl3sig --input fip/bl31.img \ + --output fip/bl31.img.enc \ + --level v3 --type bl31 + > $UBOOTDIR/fip/g12b/aml_encrypt_g12b --bl3sig --input fip/bl33.bin --compress lz4 \ + --output fip/bl33.bin.enc \ + --level v3 --type bl33 --compress lz4 + > $UBOOTDIR/fip/g12b/aml_encrypt_g12b --bl2sig --input fip/bl2_new.bin \ + --output fip/bl2.n.bin.sig + > $UBOOTDIR/fip/g12b/aml_encrypt_g12b --bootmk \ + --output fip/u-boot.bin \ + --bl2 fip/bl2.n.bin.sig \ + --bl30 fip/bl30_new.bin.enc \ + --bl31 fip/bl31.img.enc \ + --bl33 fip/bl33.bin.enc \ + --ddrfw1 fip/ddr4_1d.fw \ + --ddrfw2 fip/ddr4_2d.fw \ + --ddrfw3 fip/ddr3_1d.fw \ + --ddrfw4 fip/piei.fw \ + --ddrfw5 fip/lpddr4_1d.fw \ + --ddrfw6 fip/lpddr4_2d.fw \ + --ddrfw7 fip/diag_lpddr4.fw \ + --ddrfw8 fip/aml_ddr.fw \ + --ddrfw9 fip/lpddr3_1d.fw \ + --level v3 + +and then write the image to SD with: + + > DEV=/dev/your_sd_device + > dd if=fip/u-boot.bin.sd.bin of=$DEV conv=fsync,notrunc bs=512 skip=1 seek=1 + > dd if=fip/u-boot.bin.sd.bin of=$DEV conv=fsync,notrunc bs=1 count=444 diff --git a/configs/khadas-vim3_defconfig b/configs/khadas-vim3_defconfig new file mode 100644 index 0000000000..cd37f7840e --- /dev/null +++ b/configs/khadas-vim3_defconfig @@ -0,0 +1,54 @@ +CONFIG_ARM=y +CONFIG_SYS_BOARD="w400" +CONFIG_ARCH_MESON=y +CONFIG_SYS_TEXT_BASE=0x01000000 +CONFIG_MESON_G12A=y +CONFIG_NR_DRAM_BANKS=1 +CONFIG_DEBUG_UART_BASE=0xff803000 +CONFIG_DEBUG_UART_CLOCK=24000000 +CONFIG_IDENT_STRING=" khadas-vim3" +CONFIG_DEBUG_UART=y +CONFIG_OF_BOARD_SETUP=y +CONFIG_MISC_INIT_R=y +# CONFIG_DISPLAY_CPUINFO is not set +# CONFIG_CMD_BDI is not set +# CONFIG_CMD_IMI is not set +CONFIG_CMD_GPIO=y +# CONFIG_CMD_LOADS is not set +CONFIG_CMD_MMC=y +CONFIG_CMD_USB=y +CONFIG_CMD_USB_MASS_STORAGE=y +# CONFIG_CMD_SETEXPR is not set +CONFIG_CMD_REGULATOR=y +CONFIG_OF_CONTROL=y +CONFIG_DEFAULT_DEVICE_TREE="meson-g12b-a311d-khadas-vim3" +CONFIG_NET_RANDOM_ETHADDR=y +CONFIG_DM_GPIO=y +CONFIG_DM_MMC=y +CONFIG_MMC_MESON_GX=y +CONFIG_PHY_REALTEK=y +CONFIG_DM_ETH=y +CONFIG_ETH_DESIGNWARE=y +CONFIG_MESON_G12A_USB_PHY=y +CONFIG_PINCTRL=y +CONFIG_PINCTRL_MESON_G12A=y +CONFIG_DM_REGULATOR=y +CONFIG_DM_REGULATOR_FIXED=y +CONFIG_DM_RESET=y +CONFIG_DEBUG_UART_MESON=y +CONFIG_DEBUG_UART_ANNOUNCE=y +CONFIG_DEBUG_UART_SKIP_INIT=y +CONFIG_MESON_SERIAL=y +CONFIG_USB=y +CONFIG_DM_USB=y +CONFIG_USB_XHCI_HCD=y +CONFIG_USB_XHCI_DWC3=y +CONFIG_USB_DWC3=y +CONFIG_USB_DWC3_MESON_G12A=y +CONFIG_USB_GADGET=y +CONFIG_USB_GADGET_VENDOR_NUM=0x1b8e +CONFIG_USB_GADGET_PRODUCT_NUM=0xfada +CONFIG_USB_GADGET_DWC2_OTG=y +CONFIG_USB_GADGET_DWC2_OTG_PHY_BUS_WIDTH_8=y +CONFIG_USB_GADGET_DOWNLOAD=y +CONFIG_OF_LIBFDT_OVERLAY=y
Write SoC instead of Soc. The Linux driver is not affected.
Fixes: f41d723b9f ("ARM: meson: display Amlogic SoC Information") Signed-off-by: Julien Masson jmasson@baylibre.com Signed-off-by: Andreas Färber afaerber@suse.de --- v2: New
arch/arm/mach-meson/board-info.c | 2 +- 1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/arch/arm/mach-meson/board-info.c b/arch/arm/mach-meson/board-info.c index ba248e8ff6..ea32c01d11 100644 --- a/arch/arm/mach-meson/board-info.c +++ b/arch/arm/mach-meson/board-info.c @@ -154,7 +154,7 @@ int show_board_info(void)
/* print board information */ print_board_model(); - printf("Soc: Amlogic Meson %s (%s) Revision %x:%x (%x:%x)\n", + printf("SoC: Amlogic Meson %s (%s) Revision %x:%x (%x:%x)\n", socinfo_to_soc_id(socinfo), socinfo_to_package_id(socinfo), socinfo_to_major(socinfo),
Values imported from Linux driver, but in correct numeric order.
Khadas VIM3 prints: Amlogic Meson G12B (A311D) Revision 29:b (10:2)
Cc: Christian Hewitt christianshewitt@gmail.com Signed-off-by: Andreas Färber afaerber@suse.de --- v2: New
arch/arm/mach-meson/board-info.c | 1 + 1 file changed, 1 insertion(+)
diff --git a/arch/arm/mach-meson/board-info.c b/arch/arm/mach-meson/board-info.c index ea32c01d11..9571b5a189 100644 --- a/arch/arm/mach-meson/board-info.c +++ b/arch/arm/mach-meson/board-info.c @@ -59,6 +59,7 @@ static const struct meson_gx_package_id { { "A113D", 0x25, 0x22, 0xff }, { "S905D2", 0x28, 0x10, 0xf0 }, { "S905X2", 0x28, 0x40, 0xf0 }, + { "A311D", 0x29, 0x10, 0xf0 }, { "S922X", 0x29, 0x40, 0xf0 }, };
Hi Andreas,
On 02/09/2019 14:19, Andreas Färber wrote:
Hi Neil,
This mini-series adds initial support for Amlogic A311D based Khadas VIM3.
v2 fixes an oversight and adds some cleanups.
Regards, Andreas
v1 -> v2:
- Fixed branch name in README
- Mention linux-next tag for DT/header import (Neil)
- Avoid "Unknown" SoC output for A311D, fixing a typo while at it
Do you have time to rebase patch 1 on Linux v5.3-rc1 ? Or do you allow me to rebase it myself ?
Neil
Cc: Neil Armstrong narmstrong@baylibre.com
Andreas Färber (4): arm: dts: Import and update DT for Khadas VIM3 configs: Add Khadas VIM3 defconfig arm: meson: Tidy SoC information output arm: meson: Recognize A311D SoC
arch/arm/dts/Makefile | 3 +- arch/arm/dts/meson-g12-common.dtsi | 2435 ++++++++++++++++++++ arch/arm/dts/meson-g12b-a311d-khadas-vim3.dts | 15 + arch/arm/dts/meson-g12b-a311d.dtsi | 149 ++ arch/arm/dts/meson-g12b-khadas-vim3.dtsi | 544 +++++ arch/arm/dts/meson-g12b.dtsi | 39 +- arch/arm/mach-meson/board-info.c | 3 +- board/amlogic/w400/MAINTAINERS | 1 + board/amlogic/w400/README.khadas-vim3 | 132 ++ configs/khadas-vim3_defconfig | 54 + include/dt-bindings/clock/g12a-clkc.h | 6 + include/dt-bindings/power/meson-g12a-power.h | 13 + .../reset/amlogic,meson-g12a-audio-reset.h | 38 + 13 files changed, 3427 insertions(+), 5 deletions(-) create mode 100644 arch/arm/dts/meson-g12-common.dtsi create mode 100644 arch/arm/dts/meson-g12b-a311d-khadas-vim3.dts create mode 100644 arch/arm/dts/meson-g12b-a311d.dtsi create mode 100644 arch/arm/dts/meson-g12b-khadas-vim3.dtsi create mode 100644 board/amlogic/w400/README.khadas-vim3 create mode 100644 configs/khadas-vim3_defconfig create mode 100644 include/dt-bindings/power/meson-g12a-power.h create mode 100644 include/dt-bindings/reset/amlogic,meson-g12a-audio-reset.h
Andreas Färber
Neil Armstrong
