[U-Boot] Pull request: u-boot-uniphier
Hi Tom,
Please pull some Panasonic SoC specific updates.
The following changes since commit 40ad4c4b1fea2497bc019ee82163b76d4b076730:
Kconfig: move EXPERT option under "General setup" menu (2015-01-07 14:48:47 -0500)
git://git.denx.de/u-boot-uniphier.git master
for you to fetch changes up to b4ad44baab713af371b1113dd63dd222ba73ba13:
ARM: UniPhier: add UART initialization routine for low-level debug (2015-01-08 23:01:56 +0900)
---------------------------------------------------------------- Masahiro Yamada (3): ARM: UniPhier: fix SRAM size on support card ARM: UniPhier: enable output of system bus ARM: UniPhier: add UART initialization routine for low-level debug
arch/arm/cpu/armv7/uniphier/lowlevel_init.S | 4 ++++ arch/arm/cpu/armv7/uniphier/ph1-ld4/Makefile | 1 + arch/arm/cpu/armv7/uniphier/ph1-ld4/lowlevel_debug.S | 29 +++++++++++++++++++++++++++++ arch/arm/cpu/armv7/uniphier/ph1-ld4/sbc_init.c | 7 +++++++ arch/arm/cpu/armv7/uniphier/ph1-pro4/Makefile | 1 + arch/arm/cpu/armv7/uniphier/ph1-pro4/lowlevel_debug.S | 39 +++++++++++++++++++++++++++++++++++++++ arch/arm/cpu/armv7/uniphier/ph1-sld8/Makefile | 1 + arch/arm/cpu/armv7/uniphier/ph1-sld8/lowlevel_debug.S | 29 +++++++++++++++++++++++++++++ arch/arm/cpu/armv7/uniphier/ph1-sld8/sbc_init.c | 7 +++++++ arch/arm/cpu/armv7/uniphier/support_card.c | 6 +++--- arch/arm/include/asm/arch-uniphier/debug-uart.S | 24 ++++++++++++++++++++++++ arch/arm/include/asm/arch-uniphier/sbc-regs.h | 1 + 12 files changed, 146 insertions(+), 3 deletions(-) create mode 100644 arch/arm/cpu/armv7/uniphier/ph1-ld4/lowlevel_debug.S create mode 100644 arch/arm/cpu/armv7/uniphier/ph1-pro4/lowlevel_debug.S create mode 100644 arch/arm/cpu/armv7/uniphier/ph1-sld8/lowlevel_debug.S create mode 100644 arch/arm/include/asm/arch-uniphier/debug-uart.S
On Thu, Jan 08, 2015 at 11:08:45PM +0900, Masahiro YAMADA wrote:
Hi Tom,
Masahiro YAMADA
