[U-Boot-Users] [PATCH 21/30] cpu/m*: Remove obsolete references to CONFIG_COMMANDS
Signed-off-by: Jon Loeliger jdl@freescale.com --- cpu/mcf52x2/fec.c | 14 +++++++------- cpu/microblaze/cache.c | 2 +- cpu/microblaze/interrupts.c | 4 ++-- cpu/mips/au1x00_eth.c | 8 ++++---- cpu/mpc5xx/interrupts.c | 4 ++-- cpu/mpc5xx/traps.c | 16 ++++++++-------- cpu/mpc5xxx/cpu_init.c | 2 +- cpu/mpc5xxx/fec.c | 6 +++--- cpu/mpc5xxx/interrupts.c | 2 +- cpu/mpc5xxx/traps.c | 16 ++++++++-------- cpu/mpc8220/cpu_init.c | 2 +- cpu/mpc8220/fec.c | 6 +++--- cpu/mpc8220/traps.c | 16 ++++++++-------- cpu/mpc824x/traps.c | 4 ++-- cpu/mpc8260/bedbug_603e.c | 2 +- cpu/mpc8260/ether_fcc.c | 6 +++--- cpu/mpc8260/ether_scc.c | 2 +- cpu/mpc8260/interrupts.c | 4 ++-- cpu/mpc8260/kgdb.S | 2 +- cpu/mpc8260/traps.c | 16 ++++++++-------- cpu/mpc83xx/interrupts.c | 4 ++-- cpu/mpc83xx/traps.c | 14 +++++++------- cpu/mpc85xx/ether_fcc.c | 6 +++--- cpu/mpc85xx/interrupts.c | 4 ++-- cpu/mpc85xx/traps.c | 14 +++++++------- cpu/mpc8xx/bedbug_860.c | 2 +- cpu/mpc8xx/fec.c | 18 +++++++++--------- cpu/mpc8xx/kgdb.S | 2 +- cpu/mpc8xx/scc.c | 2 +- cpu/mpc8xx/serial.c | 2 +- cpu/mpc8xx/traps.c | 16 ++++++++-------- 31 files changed, 109 insertions(+), 109 deletions(-)
diff --git a/cpu/mcf52x2/fec.c b/cpu/mcf52x2/fec.c index 3627071..255b3d8 100644 --- a/cpu/mcf52x2/fec.c +++ b/cpu/mcf52x2/fec.c @@ -53,7 +53,7 @@ #undef ET_DEBUG #undef MII_DEBUG
-#if ((CONFIG_COMMANDS & CFG_CMD_NET) || defined(CONFIG_CMD_NET)) && defined(FEC_ENET) +#if defined(CONFIG_CMD_NET) && defined(FEC_ENET)
#ifdef CFG_DISCOVER_PHY #include <miiphy.h> @@ -363,7 +363,7 @@ void eth_halt (void) }
-#if defined(CFG_DISCOVER_PHY) || (CONFIG_COMMANDS & CFG_CMD_MII) || defined(CONFIG_CMD_MII) +#if defined(CFG_DISCOVER_PHY) || defined(CONFIG_CMD_MII)
static int phyaddr = -1; /* didn't find a PHY yet */ static uint phytype; @@ -419,7 +419,7 @@ static uint mii_send (uint mii_cmd) #endif return (mii_reply & 0xffff); /* data read from phy */ } -#endif /* CFG_DISCOVER_PHY || (CONFIG_COMMANDS & CFG_CMD_MII) */ +#endif
#if defined(CFG_DISCOVER_PHY) static void mii_discover_phy (void) @@ -485,7 +485,7 @@ static void mii_discover_phy (void) } #endif /* CFG_DISCOVER_PHY */
-#if ((CONFIG_COMMANDS & CFG_CMD_MII) || defined(CONFIG_CMD_MII)) && !defined(CONFIG_BITBANGMII) +#if defined(CONFIG_CMD_MII) && !defined(CONFIG_BITBANGMII)
static int mii_init_done = 0;
@@ -591,13 +591,13 @@ int mcf52x2_miiphy_write (char *devname, unsigned char addr,
return 0; } -#endif /* (CONFIG_COMMANDS & CFG_CMD_MII) && !defined(CONFIG_BITBANGMII) */ +#endif #endif /* CFG_CMD_NET, FEC_ENET */
int mcf52x2_miiphy_initialize(bd_t *bis) { -#if ((CONFIG_COMMANDS & CFG_CMD_NET) || defined(CONFIG_CMD_NET)) && defined(FEC_ENET) -#if ((CONFIG_COMMANDS & CFG_CMD_MII) || defined(CONFIG_CMD_MII)) && !defined(CONFIG_BITBANGMII) +#if defined(CONFIG_CMD_NET) && defined(FEC_ENET) +#if defined(CONFIG_CMD_MII) && !defined(CONFIG_BITBANGMII) miiphy_register("mcf52x2phy", mcf52x2_miiphy_read, mcf52x2_miiphy_write); #endif #endif diff --git a/cpu/microblaze/cache.c b/cpu/microblaze/cache.c index 2921551..6ce0b55 100644 --- a/cpu/microblaze/cache.c +++ b/cpu/microblaze/cache.c @@ -25,7 +25,7 @@ #include <common.h> #include <asm/asm.h>
-#if (CONFIG_COMMANDS & CFG_CMD_CACHE) || defined(CONFIG_CMD_CACHE) +#if defined(CONFIG_CMD_CACHE)
int dcache_status (void) { diff --git a/cpu/microblaze/interrupts.c b/cpu/microblaze/interrupts.c index b97465a..3f04b29 100644 --- a/cpu/microblaze/interrupts.c +++ b/cpu/microblaze/interrupts.c @@ -190,7 +190,7 @@ void interrupt_handler (void) } #endif
-#if (CONFIG_COMMANDS & CFG_CMD_IRQ) || defined(CONFIG_CMD_IRQ) +#if defined(CONFIG_CMD_IRQ) #ifdef CFG_INTC_0 int do_irqinfo (cmd_tbl_t * cmdtp, int flag, int argc, char *argv[]) { @@ -217,4 +217,4 @@ int do_irqinfo (cmd_tbl_t * cmdtp, int flag, int argc, char *argv[]) puts ("Undefined interrupt controller\n"); } #endif -#endif /* CONFIG_COMMANDS & CFG_CMD_IRQ */ +#endif diff --git a/cpu/mips/au1x00_eth.c b/cpu/mips/au1x00_eth.c index de13b05..b69741a 100644 --- a/cpu/mips/au1x00_eth.c +++ b/cpu/mips/au1x00_eth.c @@ -63,7 +63,7 @@ #include <asm/io.h> #include <asm/au1x00.h>
-#if (CONFIG_COMMANDS & CFG_CMD_MII) || defined(CONFIG_CMD_MII) +#if defined(CONFIG_CMD_MII) #include <miiphy.h> #endif
@@ -241,7 +241,7 @@ int au1x00_enet_initialize(bd_t *bis){
eth_register(dev);
-#if (CONFIG_COMMANDS & CFG_CMD_MII) || defined(CONFIG_CMD_MII) +#if defined(CONFIG_CMD_MII) miiphy_register(dev->name, au1x00_miiphy_read, au1x00_miiphy_write); #endif @@ -249,7 +249,7 @@ int au1x00_enet_initialize(bd_t *bis){ return 1; }
-#if (CONFIG_COMMANDS & CFG_CMD_MII) || defined(CONFIG_CMD_MII) +#if defined(CONFIG_CMD_MII) int au1x00_miiphy_read(char *devname, unsigned char addr, unsigned char reg, unsigned short * value) { @@ -306,6 +306,6 @@ int au1x00_miiphy_write(char *devname, unsigned char addr, *mii_control_reg = mii_control; return 0; } -#endif /* CONFIG_COMMANDS & CFG_CMD_MII */ +#endif
#endif /* CONFIG_AU1X00 */ diff --git a/cpu/mpc5xx/interrupts.c b/cpu/mpc5xx/interrupts.c index 70803cf..a4f47c7 100644 --- a/cpu/mpc5xx/interrupts.c +++ b/cpu/mpc5xx/interrupts.c @@ -178,7 +178,7 @@ void timer_interrupt_cpu (struct pt_regs *regs) return; }
-#if (CONFIG_COMMANDS & CFG_CMD_IRQ) || defined(CONFIG_CMD_IRQ) +#if defined(CONFIG_CMD_IRQ) /******************************************************************************* * * irqinfo - print information about IRQs @@ -204,4 +204,4 @@ int do_irqinfo(cmd_tbl_t *cmdtp, int flag, int argc, char *argv[]) }
-#endif /* CONFIG_COMMANDS & CFG_CMD_IRQ */ +#endif diff --git a/cpu/mpc5xx/traps.c b/cpu/mpc5xx/traps.c index 26a253f..d22b89a 100644 --- a/cpu/mpc5xx/traps.c +++ b/cpu/mpc5xx/traps.c @@ -36,11 +36,11 @@ #include <command.h> #include <asm/processor.h>
-#if (CONFIG_COMMANDS & CFG_CMD_KGDB) || defined(CONFIG_CMD_KGDB) +#if defined(CONFIG_CMD_KGDB) int (*debugger_exception_handler)(struct pt_regs *) = 0; #endif
-#if (CONFIG_COMMANDS & CFG_CMD_BEDBUG) || defined(CONFIG_CMD_BEDBUG) +#if defined(CONFIG_CMD_BEDBUG) extern void do_bedbug_breakpoint(struct pt_regs *); #endif
@@ -131,7 +131,7 @@ void MachineCheckException(struct pt_regs *regs) return; }
-#if (CONFIG_COMMANDS & CFG_CMD_KGDB) || defined(CONFIG_CMD_KGDB) +#if defined(CONFIG_CMD_KGDB) if (debugger_exception_handler && (*debugger_exception_handler)(regs)) return; #endif @@ -165,7 +165,7 @@ void MachineCheckException(struct pt_regs *regs) */ void AlignmentException(struct pt_regs *regs) { -#if (CONFIG_COMMANDS & CFG_CMD_KGDB) || defined(CONFIG_CMD_KGDB) +#if defined(CONFIG_CMD_KGDB) if (debugger_exception_handler && (*debugger_exception_handler)(regs)) return; #endif @@ -179,7 +179,7 @@ void AlignmentException(struct pt_regs *regs) */ void ProgramCheckException(struct pt_regs *regs) { -#if (CONFIG_COMMANDS & CFG_CMD_KGDB) || defined(CONFIG_CMD_KGDB) +#if defined(CONFIG_CMD_KGDB) if (debugger_exception_handler && (*debugger_exception_handler)(regs)) return; #endif @@ -193,7 +193,7 @@ void ProgramCheckException(struct pt_regs *regs) */ void SoftEmuException(struct pt_regs *regs) { -#if (CONFIG_COMMANDS & CFG_CMD_KGDB) || defined(CONFIG_CMD_KGDB) +#if defined(CONFIG_CMD_KGDB) if (debugger_exception_handler && (*debugger_exception_handler)(regs)) return; #endif @@ -208,7 +208,7 @@ void SoftEmuException(struct pt_regs *regs) */ void UnknownException(struct pt_regs *regs) { -#if (CONFIG_COMMANDS & CFG_CMD_KGDB) || defined(CONFIG_CMD_KGDB) +#if defined(CONFIG_CMD_KGDB) if (debugger_exception_handler && (*debugger_exception_handler)(regs)) return; #endif @@ -224,7 +224,7 @@ void DebugException(struct pt_regs *regs) { printf("Debugger trap at @ %lx\n", regs->nip ); show_regs(regs); -#if (CONFIG_COMMANDS & CFG_CMD_BEDBUG) || defined(CONFIG_CMD_BEDBUG) +#if defined(CONFIG_CMD_BEDBUG) do_bedbug_breakpoint( regs ); #endif } diff --git a/cpu/mpc5xxx/cpu_init.c b/cpu/mpc5xxx/cpu_init.c index 7ec3594..bc6201e 100644 --- a/cpu/mpc5xxx/cpu_init.c +++ b/cpu/mpc5xxx/cpu_init.c @@ -198,7 +198,7 @@ int cpu_init_r (void) /* route critical ints to normal ints */ *(vu_long *)MPC5XXX_ICTL_EXT |= 0x00000001;
-#if ((CONFIG_COMMANDS & CFG_CMD_NET) || defined(CONFIG_CMD_NET)) && defined(CONFIG_MPC5xxx_FEC) +#if defined(CONFIG_CMD_NET) && defined(CONFIG_MPC5xxx_FEC) /* load FEC microcode */ loadtask(0, 2); #endif diff --git a/cpu/mpc5xxx/fec.c b/cpu/mpc5xxx/fec.c index 5f9d6ad..727f954 100644 --- a/cpu/mpc5xxx/fec.c +++ b/cpu/mpc5xxx/fec.c @@ -18,10 +18,10 @@ DECLARE_GLOBAL_DATA_PTR;
/* #define DEBUG 0x28 */
-#if ((CONFIG_COMMANDS & CFG_CMD_NET) || defined(CONFIG_CMD_NET)) && defined(CONFIG_NET_MULTI) && \ +#if defined(CONFIG_CMD_NET) && defined(CONFIG_NET_MULTI) && \ defined(CONFIG_MPC5xxx_FEC)
-#if !(defined(CONFIG_MII) || (CONFIG_COMMANDS & CFG_CMD_MII) || defined(CONFIG_CMD_MII)) +#if !(defined(CONFIG_MII) || defined(CONFIG_CMD_MII)) #error "CONFIG_MII has to be defined!" #endif
@@ -917,7 +917,7 @@ int mpc5xxx_fec_initialize(bd_t * bis) sprintf(dev->name, "FEC ETHERNET"); eth_register(dev);
-#if defined(CONFIG_MII) || (CONFIG_COMMANDS & CFG_CMD_MII) || defined(CONFIG_CMD_MII) +#if defined(CONFIG_MII) || defined(CONFIG_CMD_MII) miiphy_register (dev->name, fec5xxx_miiphy_read, fec5xxx_miiphy_write); #endif diff --git a/cpu/mpc5xxx/interrupts.c b/cpu/mpc5xxx/interrupts.c index 4b414ea..8816dd1 100644 --- a/cpu/mpc5xxx/interrupts.c +++ b/cpu/mpc5xxx/interrupts.c @@ -310,7 +310,7 @@ void irq_free_handler(int irq)
-#if (CONFIG_COMMANDS & CFG_CMD_IRQ) || defined(CONFIG_CMD_IRQ) +#if defined(CONFIG_CMD_IRQ) void do_irqinfo(cmd_tbl_t * cmdtp, bd_t * bd, int flag, int argc, char *argv[]) { int irq, re_enable; diff --git a/cpu/mpc5xxx/traps.c b/cpu/mpc5xxx/traps.c index 8810a76..daa1ec6 100644 --- a/cpu/mpc5xxx/traps.c +++ b/cpu/mpc5xxx/traps.c @@ -37,7 +37,7 @@ #include <command.h> #include <asm/processor.h>
@@ -123,7 +123,7 @@ MachineCheckException(struct pt_regs *regs) return; }
-#if (CONFIG_COMMANDS & CFG_CMD_KGDB) || defined(CONFIG_CMD_KGDB) +#if defined(CONFIG_CMD_KGDB) if (debugger_exception_handler && (*debugger_exception_handler)(regs)) return; #endif @@ -158,7 +158,7 @@ MachineCheckException(struct pt_regs *regs) void AlignmentException(struct pt_regs *regs) { -#if (CONFIG_COMMANDS & CFG_CMD_KGDB) || defined(CONFIG_CMD_KGDB) +#if defined(CONFIG_CMD_KGDB) if (debugger_exception_handler && (*debugger_exception_handler)(regs)) return; #endif @@ -170,7 +170,7 @@ AlignmentException(struct pt_regs *regs) void ProgramCheckException(struct pt_regs *regs) { -#if (CONFIG_COMMANDS & CFG_CMD_KGDB) || defined(CONFIG_CMD_KGDB) +#if defined(CONFIG_CMD_KGDB) if (debugger_exception_handler && (*debugger_exception_handler)(regs)) return; #endif @@ -182,7 +182,7 @@ ProgramCheckException(struct pt_regs *regs) void SoftEmuException(struct pt_regs *regs) { -#if (CONFIG_COMMANDS & CFG_CMD_KGDB) || defined(CONFIG_CMD_KGDB) +#if defined(CONFIG_CMD_KGDB) if (debugger_exception_handler && (*debugger_exception_handler)(regs)) return; #endif @@ -195,7 +195,7 @@ SoftEmuException(struct pt_regs *regs) void UnknownException(struct pt_regs *regs) { -#if (CONFIG_COMMANDS & CFG_CMD_KGDB) || defined(CONFIG_CMD_KGDB) +#if defined(CONFIG_CMD_KGDB) if (debugger_exception_handler && (*debugger_exception_handler)(regs)) return; #endif @@ -204,7 +204,7 @@ UnknownException(struct pt_regs *regs) _exception(0, regs); }
@@ -214,7 +214,7 @@ DebugException(struct pt_regs *regs)
printf("Debugger trap at @ %lx\n", regs->nip ); show_regs(regs); -#if (CONFIG_COMMANDS & CFG_CMD_BEDBUG) || defined(CONFIG_CMD_BEDBUG) +#if defined(CONFIG_CMD_BEDBUG) do_bedbug_breakpoint( regs ); #endif } diff --git a/cpu/mpc8220/cpu_init.c b/cpu/mpc8220/cpu_init.c index db47a4b..0daac5b 100644 --- a/cpu/mpc8220/cpu_init.c +++ b/cpu/mpc8220/cpu_init.c @@ -128,7 +128,7 @@ int cpu_init_r (void) /* route critical ints to normal ints */ *(vu_long *) 0xf0000710 |= 0x00000001;
-#if ((CONFIG_COMMANDS & CFG_CMD_NET) || defined(CONFIG_CMD_NET)) && defined(CONFIG_MPC8220_FEC) +#if defined(CONFIG_CMD_NET) && defined(CONFIG_MPC8220_FEC) /* load FEC microcode */ loadtask (0, 2); #endif diff --git a/cpu/mpc8220/fec.c b/cpu/mpc8220/fec.c index 144d623..992e0ff 100644 --- a/cpu/mpc8220/fec.c +++ b/cpu/mpc8220/fec.c @@ -15,10 +15,10 @@ #include "fec.h"
#undef DEBUG -#if ((CONFIG_COMMANDS & CFG_CMD_NET) || defined(CONFIG_CMD_NET)) && defined(CONFIG_NET_MULTI) && \ +#if defined(CONFIG_CMD_NET) && defined(CONFIG_NET_MULTI) && \ defined(CONFIG_MPC8220_FEC)
@@ -847,7 +847,7 @@ int mpc8220_fec_initialize (bd_t * bis) sprintf (dev->name, "FEC ETHERNET"); eth_register (dev);
-#if defined(CONFIG_MII) || (CONFIG_COMMANDS & CFG_CMD_MII) || defined(CONFIG_CMD_MII) +#if defined(CONFIG_MII) || defined(CONFIG_CMD_MII) miiphy_register (dev->name, fec8220_miiphy_read, fec8220_miiphy_write); #endif diff --git a/cpu/mpc8220/traps.c b/cpu/mpc8220/traps.c index e921cdd..89cca1d 100644 --- a/cpu/mpc8220/traps.c +++ b/cpu/mpc8220/traps.c @@ -37,7 +37,7 @@ #include <command.h> #include <asm/processor.h>
-#if (CONFIG_COMMANDS & CFG_CMD_KGDB) || defined(CONFIG_CMD_KGDB) +#if defined(CONFIG_CMD_KGDB) int (*debugger_exception_handler) (struct pt_regs *) = 0; #endif
@@ -118,7 +118,7 @@ void MachineCheckException (struct pt_regs *regs) regs->nip = fixup; return; } -#if (CONFIG_COMMANDS & CFG_CMD_KGDB) || defined(CONFIG_CMD_KGDB) +#if defined(CONFIG_CMD_KGDB) if (debugger_exception_handler && (*debugger_exception_handler) (regs)) return; @@ -152,7 +152,7 @@ void MachineCheckException (struct pt_regs *regs)
void AlignmentException (struct pt_regs *regs) { -#if (CONFIG_COMMANDS & CFG_CMD_KGDB) || defined(CONFIG_CMD_KGDB) +#if defined(CONFIG_CMD_KGDB) if (debugger_exception_handler && (*debugger_exception_handler) (regs)) return; @@ -164,7 +164,7 @@ void AlignmentException (struct pt_regs *regs)
void ProgramCheckException (struct pt_regs *regs) { -#if (CONFIG_COMMANDS & CFG_CMD_KGDB) || defined(CONFIG_CMD_KGDB) +#if defined(CONFIG_CMD_KGDB) if (debugger_exception_handler && (*debugger_exception_handler) (regs)) return; @@ -176,7 +176,7 @@ void ProgramCheckException (struct pt_regs *regs)
void SoftEmuException (struct pt_regs *regs) { -#if (CONFIG_COMMANDS & CFG_CMD_KGDB) || defined(CONFIG_CMD_KGDB) +#if defined(CONFIG_CMD_KGDB) if (debugger_exception_handler && (*debugger_exception_handler) (regs)) return; @@ -189,7 +189,7 @@ void SoftEmuException (struct pt_regs *regs)
void UnknownException (struct pt_regs *regs) { -#if (CONFIG_COMMANDS & CFG_CMD_KGDB) || defined(CONFIG_CMD_KGDB) +#if defined(CONFIG_CMD_KGDB) if (debugger_exception_handler && (*debugger_exception_handler) (regs)) return; @@ -199,7 +199,7 @@ void UnknownException (struct pt_regs *regs) _exception (0, regs); }
-#if (CONFIG_COMMANDS & CFG_CMD_BEDBUG) || defined(CONFIG_CMD_BEDBUG) +#if defined(CONFIG_CMD_BEDBUG) extern void do_bedbug_breakpoint (struct pt_regs *); #endif
@@ -208,7 +208,7 @@ void DebugException (struct pt_regs *regs)
printf ("Debugger trap at @ %lx\n", regs->nip); show_regs (regs); -#if (CONFIG_COMMANDS & CFG_CMD_BEDBUG) || defined(CONFIG_CMD_BEDBUG) +#if defined(CONFIG_CMD_BEDBUG) do_bedbug_breakpoint (regs); #endif } diff --git a/cpu/mpc824x/traps.c b/cpu/mpc824x/traps.c index e93cffb..0a72430 100644 --- a/cpu/mpc824x/traps.c +++ b/cpu/mpc824x/traps.c @@ -175,7 +175,7 @@ UnknownException(struct pt_regs *regs) _exception(0, regs); }
@@ -185,7 +185,7 @@ DebugException(struct pt_regs *regs)
printf("Debugger trap at @ %lx\n", regs->nip ); show_regs(regs); -#if (CONFIG_COMMANDS & CFG_CMD_BEDBUG) || defined(CONFIG_CMD_BEDBUG) +#if defined(CONFIG_CMD_BEDBUG) do_bedbug_breakpoint( regs ); #endif } diff --git a/cpu/mpc8260/bedbug_603e.c b/cpu/mpc8260/bedbug_603e.c index 7ca193d..f1be485 100644 --- a/cpu/mpc8260/bedbug_603e.c +++ b/cpu/mpc8260/bedbug_603e.c @@ -10,7 +10,7 @@ #include <bedbug/regs.h> #include <bedbug/ppc.h>
-#if ((CONFIG_COMMANDS & CFG_CMD_BEDBUG) || defined(CONFIG_CMD_BEDBUG)) \ +#if defined(CONFIG_CMD_BEDBUG) \ && (defined(CONFIG_MPC824X) || defined(CONFIG_MPC8260))
#define MAX_BREAK_POINTS 1 diff --git a/cpu/mpc8260/ether_fcc.c b/cpu/mpc8260/ether_fcc.c index 51d0de2..08d2847 100644 --- a/cpu/mpc8260/ether_fcc.c +++ b/cpu/mpc8260/ether_fcc.c @@ -47,13 +47,13 @@ #include <config.h> #include <net.h>
-#if defined(CONFIG_MII) || (CONFIG_COMMANDS & CFG_CMD_MII) || defined(CONFIG_CMD_MII) +#if defined(CONFIG_MII) || defined(CONFIG_CMD_MII) #include <miiphy.h> #endif
-#if defined(CONFIG_ETHER_ON_FCC) && ((CONFIG_COMMANDS & CFG_CMD_NET) || defined(CONFIG_CMD_NET)) && \ +#if defined(CONFIG_ETHER_ON_FCC) && defined(CONFIG_CMD_NET) && \ defined(CONFIG_NET_MULTI)
static struct ether_fcc_info_s @@ -393,7 +393,7 @@ int fec_initialize(bd_t *bis)
eth_register(dev);
-#if (defined(CONFIG_MII) || (CONFIG_COMMANDS & CFG_CMD_MII) || defined(CONFIG_CMD_MII)) \ +#if (defined(CONFIG_MII) || defined(CONFIG_CMD_MII)) \ && defined(CONFIG_BITBANGMII) miiphy_register(dev->name, bb_miiphy_read, bb_miiphy_write); diff --git a/cpu/mpc8260/ether_scc.c b/cpu/mpc8260/ether_scc.c index ec682ec..b9ae082 100644 --- a/cpu/mpc8260/ether_scc.c +++ b/cpu/mpc8260/ether_scc.c @@ -36,7 +36,7 @@ #include <command.h> #include <config.h>
-#if defined(CONFIG_ETHER_ON_SCC) && ((CONFIG_COMMANDS & CFG_CMD_NET) || defined(CONFIG_CMD_NET)) +#if defined(CONFIG_ETHER_ON_SCC) && defined(CONFIG_CMD_NET)
#if (CONFIG_ETHER_INDEX == 1) # define PROFF_ENET PROFF_SCC1 diff --git a/cpu/mpc8260/interrupts.c b/cpu/mpc8260/interrupts.c index 6e5ab4c..bf0d4d0 100644 --- a/cpu/mpc8260/interrupts.c +++ b/cpu/mpc8260/interrupts.c @@ -246,7 +246,7 @@ void timer_interrupt_cpu (struct pt_regs *regs)
/* ripped this out of ppc4xx/interrupts.c */
@@ -276,4 +276,4 @@ do_irqinfo (cmd_tbl_t * cmdtp, bd_t * bd, int flag, int argc, char *argv[]) enable_interrupts (); }
-#endif /* CONFIG_COMMANDS & CFG_CMD_IRQ */ +#endif diff --git a/cpu/mpc8260/kgdb.S b/cpu/mpc8260/kgdb.S index fc1ebe2..5a7d0b7 100644 --- a/cpu/mpc8260/kgdb.S +++ b/cpu/mpc8260/kgdb.S @@ -34,7 +34,7 @@ #include <asm/cache.h> #include <asm/mmu.h>
/* * cache flushing routines for kgdb diff --git a/cpu/mpc8260/traps.c b/cpu/mpc8260/traps.c index 07be0fa..b5d416c 100644 --- a/cpu/mpc8260/traps.c +++ b/cpu/mpc8260/traps.c @@ -37,7 +37,7 @@ #include <asm/processor.h> #include <asm/m8260_pci.h>
@@ -150,7 +150,7 @@ MachineCheckException(struct pt_regs *regs) return; }
-#if (CONFIG_COMMANDS & CFG_CMD_KGDB) || defined(CONFIG_CMD_KGDB) +#if defined(CONFIG_CMD_KGDB) if (debugger_exception_handler && (*debugger_exception_handler)(regs)) return; #endif @@ -186,7 +186,7 @@ MachineCheckException(struct pt_regs *regs) void AlignmentException(struct pt_regs *regs) { -#if (CONFIG_COMMANDS & CFG_CMD_KGDB) || defined(CONFIG_CMD_KGDB) +#if defined(CONFIG_CMD_KGDB) if (debugger_exception_handler && (*debugger_exception_handler)(regs)) return; #endif @@ -198,7 +198,7 @@ AlignmentException(struct pt_regs *regs) void ProgramCheckException(struct pt_regs *regs) { -#if (CONFIG_COMMANDS & CFG_CMD_KGDB) || defined(CONFIG_CMD_KGDB) +#if defined(CONFIG_CMD_KGDB) if (debugger_exception_handler && (*debugger_exception_handler)(regs)) return; #endif @@ -210,7 +210,7 @@ ProgramCheckException(struct pt_regs *regs) void SoftEmuException(struct pt_regs *regs) { -#if (CONFIG_COMMANDS & CFG_CMD_KGDB) || defined(CONFIG_CMD_KGDB) +#if defined(CONFIG_CMD_KGDB) if (debugger_exception_handler && (*debugger_exception_handler)(regs)) return; #endif @@ -223,7 +223,7 @@ SoftEmuException(struct pt_regs *regs) void UnknownException(struct pt_regs *regs) { -#if (CONFIG_COMMANDS & CFG_CMD_KGDB) || defined(CONFIG_CMD_KGDB) +#if defined(CONFIG_CMD_KGDB) if (debugger_exception_handler && (*debugger_exception_handler)(regs)) return; #endif @@ -232,7 +232,7 @@ UnknownException(struct pt_regs *regs) _exception(0, regs); }
@@ -242,7 +242,7 @@ DebugException(struct pt_regs *regs)
printf("Debugger trap at @ %lx\n", regs->nip ); show_regs(regs); -#if (CONFIG_COMMANDS & CFG_CMD_BEDBUG) || defined(CONFIG_CMD_BEDBUG) +#if defined(CONFIG_CMD_BEDBUG) do_bedbug_breakpoint( regs ); #endif } diff --git a/cpu/mpc83xx/interrupts.c b/cpu/mpc83xx/interrupts.c index 2604066..98ed21c 100644 --- a/cpu/mpc83xx/interrupts.c +++ b/cpu/mpc83xx/interrupts.c @@ -81,7 +81,7 @@ void timer_interrupt_cpu (struct pt_regs *regs) }
@@ -94,4 +94,4 @@ do_irqinfo(cmd_tbl_t *cmdtp, bd_t *bd, int flag, int argc, char *argv[]) { }
-#endif /* CONFIG_COMMANDS & CFG_CMD_IRQ */ +#endif diff --git a/cpu/mpc83xx/traps.c b/cpu/mpc83xx/traps.c index 83dcec3..dfd6c03 100644 --- a/cpu/mpc83xx/traps.c +++ b/cpu/mpc83xx/traps.c @@ -140,7 +140,7 @@ MachineCheckException(struct pt_regs *regs) return; }
-#if (CONFIG_COMMANDS & CFG_CMD_KGDB) || defined(CONFIG_CMD_KGDB) +#if defined(CONFIG_CMD_KGDB) if (debugger_exception_handler && (*debugger_exception_handler)(regs)) return; #endif @@ -176,7 +176,7 @@ MachineCheckException(struct pt_regs *regs) void AlignmentException(struct pt_regs *regs) { -#if (CONFIG_COMMANDS & CFG_CMD_KGDB) || defined(CONFIG_CMD_KGDB) +#if defined(CONFIG_CMD_KGDB) if (debugger_exception_handler && (*debugger_exception_handler)(regs)) return; #endif @@ -188,7 +188,7 @@ AlignmentException(struct pt_regs *regs) void ProgramCheckException(struct pt_regs *regs) { -#if (CONFIG_COMMANDS & CFG_CMD_KGDB) || defined(CONFIG_CMD_KGDB) +#if defined(CONFIG_CMD_KGDB) if (debugger_exception_handler && (*debugger_exception_handler)(regs)) return; #endif @@ -200,7 +200,7 @@ ProgramCheckException(struct pt_regs *regs) void SoftEmuException(struct pt_regs *regs) { -#if (CONFIG_COMMANDS & CFG_CMD_KGDB) || defined(CONFIG_CMD_KGDB) +#if defined(CONFIG_CMD_KGDB) if (debugger_exception_handler && (*debugger_exception_handler)(regs)) return; #endif @@ -213,7 +213,7 @@ SoftEmuException(struct pt_regs *regs) void UnknownException(struct pt_regs *regs) { -#if (CONFIG_COMMANDS & CFG_CMD_KGDB) || defined(CONFIG_CMD_KGDB) +#if defined(CONFIG_CMD_KGDB) if (debugger_exception_handler && (*debugger_exception_handler)(regs)) return; #endif @@ -222,7 +222,7 @@ UnknownException(struct pt_regs *regs) _exception(0, regs); }
@@ -231,7 +231,7 @@ DebugException(struct pt_regs *regs) { printf("Debugger trap at @ %lx\n", regs->nip ); show_regs(regs); -#if (CONFIG_COMMANDS & CFG_CMD_BEDBUG) || defined(CONFIG_CMD_BEDBUG) +#if defined(CONFIG_CMD_BEDBUG) do_bedbug_breakpoint( regs ); #endif } diff --git a/cpu/mpc85xx/ether_fcc.c b/cpu/mpc85xx/ether_fcc.c index ec3990c..4448cc3 100644 --- a/cpu/mpc85xx/ether_fcc.c +++ b/cpu/mpc85xx/ether_fcc.c @@ -48,13 +48,13 @@ #include <config.h> #include <net.h>
#if defined(CONFIG_CPM2)
static struct ether_fcc_info_s @@ -458,7 +458,7 @@ int fec_initialize(bd_t *bis)
eth_register(dev);
-#if (defined(CONFIG_MII) || (CONFIG_COMMANDS & CFG_CMD_MII) || defined(CONFIG_CMD_MII)) \ +#if (defined(CONFIG_MII) || defined(CONFIG_CMD_MII)) \ && defined(CONFIG_BITBANGMII) miiphy_register(dev->name, bb_miiphy_read, bb_miiphy_write); diff --git a/cpu/mpc85xx/interrupts.c b/cpu/mpc85xx/interrupts.c index ed15c46..dc246dc 100644 --- a/cpu/mpc85xx/interrupts.c +++ b/cpu/mpc85xx/interrupts.c @@ -144,7 +144,7 @@ void set_timer (ulong t) timestamp = t; }
/******************************************************************************* * @@ -159,4 +159,4 @@ do_irqinfo(cmd_tbl_t *cmdtp, int flag, int argc, char *argv[]) return 0; }
-#endif /* CONFIG_COMMANDS & CFG_CMD_IRQ */ +#endif diff --git a/cpu/mpc85xx/traps.c b/cpu/mpc85xx/traps.c index fc0c0aa..9cd621c 100644 --- a/cpu/mpc85xx/traps.c +++ b/cpu/mpc85xx/traps.c @@ -41,7 +41,7 @@
@@ -74,7 +74,7 @@ static __inline__ unsigned long get_esr(void) #define ESR_DIZ 0x00400000 #define ESR_U0F 0x00008000
@@ -159,7 +159,7 @@ MachineCheckException(struct pt_regs *regs) return; }
-#if (CONFIG_COMMANDS & CFG_CMD_KGDB) || defined(CONFIG_CMD_KGDB) +#if defined(CONFIG_CMD_KGDB) if (debugger_exception_handler && (*debugger_exception_handler)(regs)) return; #endif @@ -192,7 +192,7 @@ MachineCheckException(struct pt_regs *regs) void AlignmentException(struct pt_regs *regs) { -#if (CONFIG_COMMANDS & CFG_CMD_KGDB) || defined(CONFIG_CMD_KGDB) +#if defined(CONFIG_CMD_KGDB) if (debugger_exception_handler && (*debugger_exception_handler)(regs)) return; #endif @@ -207,7 +207,7 @@ ProgramCheckException(struct pt_regs *regs) { long esr_val;
-#if (CONFIG_COMMANDS & CFG_CMD_KGDB) || defined(CONFIG_CMD_KGDB) +#if defined(CONFIG_CMD_KGDB) if (debugger_exception_handler && (*debugger_exception_handler)(regs)) return; #endif @@ -244,7 +244,7 @@ PITException(struct pt_regs *regs) void UnknownException(struct pt_regs *regs) { -#if (CONFIG_COMMANDS & CFG_CMD_KGDB) || defined(CONFIG_CMD_KGDB) +#if defined(CONFIG_CMD_KGDB) if (debugger_exception_handler && (*debugger_exception_handler)(regs)) return; #endif @@ -259,7 +259,7 @@ DebugException(struct pt_regs *regs) { printf("Debugger trap at @ %lx\n", regs->nip ); show_regs(regs); -#if (CONFIG_COMMANDS & CFG_CMD_BEDBUG) || defined(CONFIG_CMD_BEDBUG) +#if defined(CONFIG_CMD_BEDBUG) do_bedbug_breakpoint( regs ); #endif } diff --git a/cpu/mpc8xx/bedbug_860.c b/cpu/mpc8xx/bedbug_860.c index 4516f2f..5d52366 100644 --- a/cpu/mpc8xx/bedbug_860.c +++ b/cpu/mpc8xx/bedbug_860.c @@ -10,7 +10,7 @@ #include <bedbug/ppc.h> #include <bedbug/type.h>
-#if ((CONFIG_COMMANDS & CFG_CMD_BEDBUG) || defined(CONFIG_CMD_BEDBUG)) && defined(CONFIG_8xx) +#if defined(CONFIG_CMD_BEDBUG) && defined(CONFIG_8xx)
#define MAX_BREAK_POINTS 2
diff --git a/cpu/mpc8xx/fec.c b/cpu/mpc8xx/fec.c index 520953c..10d825f 100644 --- a/cpu/mpc8xx/fec.c +++ b/cpu/mpc8xx/fec.c @@ -31,7 +31,7 @@ DECLARE_GLOBAL_DATA_PTR;
#undef ET_DEBUG
-#if ((CONFIG_COMMANDS & CFG_CMD_NET) || defined(CONFIG_CMD_NET)) && \ +#if defined(CONFIG_CMD_NET) && \ (defined(FEC_ENET) || defined(CONFIG_ETHER_ON_FEC1) || defined(CONFIG_ETHER_ON_FEC2))
/* compatibility test, if only FEC_ENET defined assume ETHER on FEC1 */ @@ -49,7 +49,7 @@ DECLARE_GLOBAL_DATA_PTR; #if defined(WANT_MII) #include <miiphy.h>
@@ -182,7 +182,7 @@ int fec_initialize(bd_t *bis)
eth_register(dev);
-#if defined(CONFIG_MII) || (CONFIG_COMMANDS & CFG_CMD_MII) || defined(CONFIG_CMD_MII) +#if defined(CONFIG_MII) || defined(CONFIG_CMD_MII) miiphy_register(dev->name, fec8xx_miiphy_read, fec8xx_miiphy_write); #endif @@ -268,7 +268,7 @@ static int fec_recv (struct eth_device *dev)
length -= 4;
-#if (CONFIG_COMMANDS & CFG_CMD_CDP) || defined(CONFIG_CMD_CDP) +#if defined(CONFIG_CMD_CDP) if ((rx[0] & 1) != 0 && memcmp ((uchar *) rx, NetBcastAddr, 6) != 0 && memcmp ((uchar *) rx, NetCDPAddr, 6) != 0) @@ -608,7 +608,7 @@ static int fec_init (struct eth_device *dev, bd_t * bd) fecp->fec_addr_high = (ea[4] << 8) | (ea[5]); #undef ea
-#if (CONFIG_COMMANDS & CFG_CMD_CDP) || defined(CONFIG_CMD_CDP) +#if defined(CONFIG_CMD_CDP) /* * Turn on multicast address hash table */ @@ -787,7 +787,7 @@ static void fec_halt(struct eth_device* dev) efis->initialized = 0; }
-#if defined(CFG_DISCOVER_PHY) || defined(CONFIG_MII) || (CONFIG_COMMANDS & CFG_CMD_MII) || defined(CONFIG_CMD_MII) +#if defined(CFG_DISCOVER_PHY) || defined(CONFIG_MII) || defined(CONFIG_CMD_MII)
/* Make MII read/write commands for the FEC. */ @@ -852,7 +852,7 @@ mii_send(uint mii_cmd) #endif return (mii_reply & 0xffff); /* data read from phy */ } -#endif /* CFG_DISCOVER_PHY || (CONFIG_COMMANDS & CFG_CMD_MII) */ +#endif
#if defined(CFG_DISCOVER_PHY) static int mii_discover_phy(struct eth_device *dev) @@ -926,7 +926,7 @@ static int mii_discover_phy(struct eth_device *dev) } #endif /* CFG_DISCOVER_PHY */
-#if (defined(CONFIG_MII) || (CONFIG_COMMANDS & CFG_CMD_MII) || defined(CONFIG_CMD_MII)) && !defined(CONFIG_BITBANGMII) +#if (defined(CONFIG_MII) || defined(CONFIG_CMD_MII)) && !defined(CONFIG_BITBANGMII)
/**************************************************************************** * mii_init -- Initialize the MII for MII command without ethernet @@ -1020,6 +1020,6 @@ int fec8xx_miiphy_write(char *devname, unsigned char addr, #endif return 0; } -#endif /* (CONFIG_COMMANDS & CFG_CMD_MII) && !defined(CONFIG_BITBANGMII)*/ +#endif
#endif /* CFG_CMD_NET, FEC_ENET */ diff --git a/cpu/mpc8xx/kgdb.S b/cpu/mpc8xx/kgdb.S index c120744..d4c77e7 100644 --- a/cpu/mpc8xx/kgdb.S +++ b/cpu/mpc8xx/kgdb.S @@ -34,7 +34,7 @@ #include <asm/cache.h> #include <asm/mmu.h>
/* * cache flushing routines for kgdb diff --git a/cpu/mpc8xx/scc.c b/cpu/mpc8xx/scc.c index 0aa5976..a0ec5d7 100644 --- a/cpu/mpc8xx/scc.c +++ b/cpu/mpc8xx/scc.c @@ -38,7 +38,7 @@ #include <net.h> #include <command.h>
-#if ((CONFIG_COMMANDS & CFG_CMD_NET) || defined(CONFIG_CMD_NET)) && defined(SCC_ENET) +#if defined(CONFIG_CMD_NET) && defined(SCC_ENET)
/* Ethernet Transmit and Receive Buffers */ #define DBUF_LENGTH 1520 diff --git a/cpu/mpc8xx/serial.c b/cpu/mpc8xx/serial.c index 62af129..6e08b53 100644 --- a/cpu/mpc8xx/serial.c +++ b/cpu/mpc8xx/serial.c @@ -666,7 +666,7 @@ void enable_putc(void) } #endif
void kgdb_serial_init(void) diff --git a/cpu/mpc8xx/traps.c b/cpu/mpc8xx/traps.c index ce955d7..e1ec889 100644 --- a/cpu/mpc8xx/traps.c +++ b/cpu/mpc8xx/traps.c @@ -36,11 +36,11 @@ #include <command.h> #include <asm/processor.h>
@@ -126,7 +126,7 @@ MachineCheckException(struct pt_regs *regs) return; }
-#if (CONFIG_COMMANDS & CFG_CMD_KGDB) || defined(CONFIG_CMD_KGDB) +#if defined(CONFIG_CMD_KGDB) if (debugger_exception_handler && (*debugger_exception_handler)(regs)) return; #endif @@ -159,7 +159,7 @@ MachineCheckException(struct pt_regs *regs) void AlignmentException(struct pt_regs *regs) { -#if (CONFIG_COMMANDS & CFG_CMD_KGDB) || defined(CONFIG_CMD_KGDB) +#if defined(CONFIG_CMD_KGDB) if (debugger_exception_handler && (*debugger_exception_handler)(regs)) return; #endif @@ -171,7 +171,7 @@ AlignmentException(struct pt_regs *regs) void ProgramCheckException(struct pt_regs *regs) { -#if (CONFIG_COMMANDS & CFG_CMD_KGDB) || defined(CONFIG_CMD_KGDB) +#if defined(CONFIG_CMD_KGDB) if (debugger_exception_handler && (*debugger_exception_handler)(regs)) return; #endif @@ -183,7 +183,7 @@ ProgramCheckException(struct pt_regs *regs) void SoftEmuException(struct pt_regs *regs) { -#if (CONFIG_COMMANDS & CFG_CMD_KGDB) || defined(CONFIG_CMD_KGDB) +#if defined(CONFIG_CMD_KGDB) if (debugger_exception_handler && (*debugger_exception_handler)(regs)) return; #endif @@ -196,7 +196,7 @@ SoftEmuException(struct pt_regs *regs) void UnknownException(struct pt_regs *regs) { -#if (CONFIG_COMMANDS & CFG_CMD_KGDB) || defined(CONFIG_CMD_KGDB) +#if defined(CONFIG_CMD_KGDB) if (debugger_exception_handler && (*debugger_exception_handler)(regs)) return; #endif @@ -210,7 +210,7 @@ DebugException(struct pt_regs *regs) { printf("Debugger trap at @ %lx\n", regs->nip ); show_regs(regs); -#if (CONFIG_COMMANDS & CFG_CMD_BEDBUG) || defined(CONFIG_CMD_BEDBUG) +#if defined(CONFIG_CMD_BEDBUG) do_bedbug_breakpoint( regs ); #endif }
Jon Loeliger
