[U-Boot] [PATCH v3 1/2] i2c: mvtwsi: disable i2c slave on Armada 38x
Equivalent code that disables the hidden i2c0 slave already exists in the Turris Omnia platform specific code. But this hidden i2c0 slave that interferes the i2c bus is not board specific. Armada 38x SoCs and at least some Kirkwood variants are affected as well. Add code to disable this slave to the i2c bus driver to make it work on all affected hardware.
Use the bind callback because we want this to always run at boot, regardless of whether U-Boot uses the i2c bus.
Cc: Rabeeh Khoury rabeeh@solid-run.com Cc: Chris Packham judge.packham@gmail.com Reviewed-by: Stefan Roese sr@denx.de Reviewed-by: Heiko Schocher hs@denx.de Signed-off-by: Baruch Siach baruch@tkos.co.il --- v3: * Fix build for SUNXI (Heiko Schocher)
v2: * Use clrbits_le32 (Stefan Roese)
* Apply to Kirkwood (Chris Packham)
* Add review tags from Stefan and Heiko --- drivers/i2c/mvtwsi.c | 25 ++++++++++++++++++++++++- 1 file changed, 24 insertions(+), 1 deletion(-)
diff --git a/drivers/i2c/mvtwsi.c b/drivers/i2c/mvtwsi.c index f9822e56b894..c4f387992b5d 100644 --- a/drivers/i2c/mvtwsi.c +++ b/drivers/i2c/mvtwsi.c @@ -11,6 +11,7 @@ #include <i2c.h> #include <linux/errno.h> #include <asm/io.h> +#include <linux/bitops.h> #include <linux/compat.h> #ifdef CONFIG_DM_I2C #include <dm.h> @@ -70,8 +71,10 @@ struct mvtwsi_registers { u32 baudrate; /* When writing */ }; u32 xtnd_slave_addr; - u32 reserved[2]; + u32 reserved0[2]; u32 soft_reset; + u32 reserved1[27]; + u32 debug; };
#endif @@ -795,6 +798,25 @@ static int mvtwsi_i2c_ofdata_to_platdata(struct udevice *bus) return 0; }
+static void twsi_disable_i2c_slave(struct mvtwsi_registers *twsi) +{ +#if (defined(CONFIG_ARMADA_38X) || defined(CONFIG_KIRKWOOD)) + clrbits_le32(&twsi->debug, BIT(18)); +#endif +} + +static int mvtwsi_i2c_bind(struct udevice *bus) +{ + struct mvtwsi_registers *twsi = devfdt_get_addr_ptr(bus); + + /* Disable the hidden slave in i2c0 of these platforms */ + if ((IS_ENABLED(CONFIG_ARMADA_38X) || IS_ENABLED(CONFIG_KIRKWOOD)) + && bus->req_seq == 0) + twsi_disable_i2c_slave(twsi); + + return 0; +} + static int mvtwsi_i2c_probe(struct udevice *bus) { struct mvtwsi_i2c_dev *dev = dev_get_priv(bus); @@ -850,6 +872,7 @@ U_BOOT_DRIVER(i2c_mvtwsi) = { .name = "i2c_mvtwsi", .id = UCLASS_I2C, .of_match = mvtwsi_i2c_ids, + .bind = mvtwsi_i2c_bind, .probe = mvtwsi_i2c_probe, .ofdata_to_platdata = mvtwsi_i2c_ofdata_to_platdata, .priv_auto_alloc_size = sizeof(struct mvtwsi_i2c_dev),
Code that disables the i2c slave is now in the mvtwsi i2c driver. Platform must enable DM_I2C to use that code. Add a comment in the code as a reminder for the planned DM_I2C migration of Turris Omnia.
Reviewed-by: Heiko Schocher hs@denx.de Signed-off-by: Baruch Siach baruch@tkos.co.il --- v2: Add Reviewed-by from Heiko --- board/CZ.NIC/turris_omnia/turris_omnia.c | 6 +++++- 1 file changed, 5 insertions(+), 1 deletion(-)
diff --git a/board/CZ.NIC/turris_omnia/turris_omnia.c b/board/CZ.NIC/turris_omnia/turris_omnia.c index da663cf1bb0c..160d30cd795a 100644 --- a/board/CZ.NIC/turris_omnia/turris_omnia.c +++ b/board/CZ.NIC/turris_omnia/turris_omnia.c @@ -321,7 +321,11 @@ int board_early_init_f(void) writel(OMNIA_GPP_OUT_ENA_LOW, MVEBU_GPIO0_BASE + 0x04); writel(OMNIA_GPP_OUT_ENA_MID, MVEBU_GPIO1_BASE + 0x04);
- /* Disable I2C debug mode blocking 0x64 I2C address */ + /* + * Disable I2C debug mode blocking 0x64 I2C address. + * Note: that would be redundant once Turris Omnia migrates to DM_I2C, + * because the mvtwsi driver includes equivalent code. + */ i2c_debug_reg = readl(MVEBU_TWSI_BASE + MVTWSI_ARMADA_DEBUG_REG); i2c_debug_reg &= ~(1<<18); writel(i2c_debug_reg, MVEBU_TWSI_BASE + MVTWSI_ARMADA_DEBUG_REG);
v3:
- Fix build for SUNXI (Heiko Schocher)
v2:
- u32 reserved[2];
u32 reserved1[27];
u32 debug; };
#endif
- clrbits_le32(&twsi->debug, BIT(18));
+#endif +}
I would prefer this version:
#if (defined(CONFIG_ARMADA_38X) || defined(CONFIG_KIRKWOOD)) static void twsi_disable_i2c_slave(struct mvtwsi_registers *twsi) { clrbits_le32(&twsi->debug, BIT(18)); } #else static inline void twsi_disable_i2c_slave(struct mvtwsi_registers *twsi) { } #endif
Thanks, Stefan
Hi Stefan,
v3:
v2:
- u32 reserved[2];
- u32 reserved0[2]; u32 soft_reset;
- u32 reserved1[27];
- u32 debug; }; #endif
@@ -795,6 +798,25 @@ static int mvtwsi_i2c_ofdata_to_platdata(struct udevice *bus) return 0; } +static void twsi_disable_i2c_slave(struct mvtwsi_registers *twsi) +{ +#if (defined(CONFIG_ARMADA_38X) || defined(CONFIG_KIRKWOOD))
+#endif +}
Should I drop the IS_ENABLED condition from the bind routine, then?
baruch
Hi Baruch,
On 07.06.2018 08:59, Baruch Siach wrote:
Hi Stefan,
* Apply to Kirkwood (Chris Packham) * Add review tags from Stefan and Heiko
- u32 reserved[2];
+#endif +}
Thinking a bit more about this, perhaps its better to also add this debug register to the SUNXI register struct (with a comment, that its not used - only to enable compilation without errors) and drop the #ifdef completely.
Thanks, Stefan
Hi Stefan,
- u32 reserved[2];
+#endif +}
I don't like this idea. It creates a non-existing register definition, and makes the code harder to comprehend.
baruch
Hello Baruch,
Am 07.06.2018 um 09:18 schrieb Baruch Siach:
Hi Stefan,
- u32 reserved[2];
+#endif +}
I like Stefans idea ... we would prevent the "#if defined..." mess.
bye, Heiko
Baruch Siach
Heiko Schocher
Stefan Roese
