Re: [PATCH] fs/squashfs: fix memory leak in sqfs_read()
Reviewed-by: João Marcos Costa jmcosta944@gmail.com
Em dom., 25 de out. de 2020 às 14:46, Barbaros Tokaoglu < btokaoglu@airspan.com> escreveu:
data_buffer should be freed on each iteration
Signed-off-by: Barbaros Tokaoglu btokaoglu@airspan.com
fs/squashfs/sqfs.c | 21 +++++++++++---------- 1 file changed, 11 insertions(+), 10 deletions(-)
diff --git a/fs/squashfs/sqfs.c b/fs/squashfs/sqfs.c index 15208b4..c7ddb0d 100644 --- a/fs/squashfs/sqfs.c +++ b/fs/squashfs/sqfs.c @@ -1355,7 +1355,8 @@ int sqfs_read(const char *filename, void *buf, loff_t offset, loff_t len,
- image with mksquashfs's -b <block_size> option.
*/ printf("Error: too many data blocks to be read.\n");
- goto free_buffer;
free(data_buffer);
goto free_datablk; }
data = data_buffer + table_offset;
@@ -1365,8 +1366,10 @@ int sqfs_read(const char *filename, void *buf, loff_t offset, loff_t len, dest_len = get_unaligned_le32(&sblk->block_size); ret = sqfs_decompress(&ctxt, datablock, &dest_len, data, table_size);
- if (ret)
- goto free_buffer;
if (ret) {
free(data_buffer);
goto free_datablk;
memcpy(buf + offset + *actread, datablock, dest_len); *actread += dest_len;
@@ -1376,6 +1379,8 @@ int sqfs_read(const char *filename, void *buf, loff_t offset, loff_t len, }
data_offset += table_size;
free(data_buffer); }
free(finfo.blk_sizes);
@@ -1385,7 +1390,7 @@ int sqfs_read(const char *filename, void *buf, loff_t offset, loff_t len, */ if (!finfo.frag) { ret = 0;
- goto free_buffer;
start = frag_entry.start / ctxt.cur_dev->blksz;
@@ -1397,7 +1402,7 @@ int sqfs_read(const char *filename, void *buf, loff_t offset, loff_t len,
if (!fragment) { ret = -ENOMEM;
- goto free_buffer;
ret = sqfs_disk_read(start, n_blks, fragment);
@@ -1439,12 +1444,8 @@ int sqfs_read(const char *filename, void *buf, loff_t offset, loff_t len,
free_fragment: free(fragment); -free_buffer:
- if (datablk_count)
- free(data_buffer);
free_datablk:
- free(datablock);
- free(datablock);
free_paths: free(file); free(dir); -- 2.7.4
*From:* Barbaros Tokaoglu *Sent:* Friday, October 23, 2020 4:26:02 PM *To:* u-boot@lists.denx.de *Cc:* Metin Kaya; jmcosta944@gmail.com *Subject:* [PATCH] fs/squashfs: fix memory leak in sqfs_read()
On each iteration data_buffer is malloc'ed but not freed which causes memory leak and malloc failure on next iterations with bigger files.
The patch is to fix this by freeing data_buffer on each iteration.
João Marcos Costa
