[U-Boot] [PATCH] p5040ds: changed liodn offsets
Offsets were overlaping, causing pamu access violations in hypervised scenarios.
Signed-off-by: Cristian Sovaiala cristian.sovaiala@freescale.com Signed-off-by: Laurentiu Tudor Laurentiu.Tudor@freescale.com Reviewed-by: Fleming Andrew-AFLEMING AFLEMING@freescale.com Reviewed-by: Sun Yusong-R58495 yorksun@freescale.com --- arch/powerpc/cpu/mpc85xx/p5040_ids.c | 24 ++++++++++++------------ 1 file changed, 12 insertions(+), 12 deletions(-)
diff --git a/arch/powerpc/cpu/mpc85xx/p5040_ids.c b/arch/powerpc/cpu/mpc85xx/p5040_ids.c index d4343ef..98a568f 100644 --- a/arch/powerpc/cpu/mpc85xx/p5040_ids.c +++ b/arch/powerpc/cpu/mpc85xx/p5040_ids.c @@ -49,23 +49,23 @@ int liodn_tbl_sz = ARRAY_SIZE(liodn_tbl);
#ifdef CONFIG_SYS_DPAA_FMAN struct liodn_id_table fman1_liodn_tbl[] = { - SET_FMAN_RX_1G_LIODN(1, 0, 6), - SET_FMAN_RX_1G_LIODN(1, 1, 7), - SET_FMAN_RX_1G_LIODN(1, 2, 8), - SET_FMAN_RX_1G_LIODN(1, 3, 9), - SET_FMAN_RX_1G_LIODN(1, 4, 10), - SET_FMAN_RX_10G_LIODN(1, 0, 11), + SET_FMAN_RX_1G_LIODN(1, 0, 11), + SET_FMAN_RX_1G_LIODN(1, 1, 12), + SET_FMAN_RX_1G_LIODN(1, 2, 13), + SET_FMAN_RX_1G_LIODN(1, 3, 14), + SET_FMAN_RX_1G_LIODN(1, 4, 15), + SET_FMAN_RX_10G_LIODN(1, 0, 16), }; int fman1_liodn_tbl_sz = ARRAY_SIZE(fman1_liodn_tbl);
#if (CONFIG_SYS_NUM_FMAN == 2) struct liodn_id_table fman2_liodn_tbl[] = { - SET_FMAN_RX_1G_LIODN(2, 0, 12), - SET_FMAN_RX_1G_LIODN(2, 1, 13), - SET_FMAN_RX_1G_LIODN(2, 2, 14), - SET_FMAN_RX_1G_LIODN(2, 3, 15), - SET_FMAN_RX_1G_LIODN(2, 4, 16), - SET_FMAN_RX_10G_LIODN(2, 0, 17), + SET_FMAN_RX_1G_LIODN(2, 0, 17), + SET_FMAN_RX_1G_LIODN(2, 1, 18), + SET_FMAN_RX_1G_LIODN(2, 2, 19), + SET_FMAN_RX_1G_LIODN(2, 3, 20), + SET_FMAN_RX_1G_LIODN(2, 4, 21), + SET_FMAN_RX_10G_LIODN(2, 0, 22), }; int fman2_liodn_tbl_sz = ARRAY_SIZE(fman2_liodn_tbl); #endif
Applied to u-boot-mpc85xx master, awaiting upstream.
York
Laurentiu Tudor
York Sun
