[U-Boot] [PATCH 1/2] OMAP: Remove omap1610inn-based boards
The CS_AUTOBOOT configurations have been broken for a long time. Kshitij Gupta is no longer at TI making these broken and orphaned boards, so remove.
Signed-off-by: Tom Rini trini@ti.com --- MAINTAINERS | 1 - board/ti/omap1610inn/Makefile | 45 --- board/ti/omap1610inn/config.mk | 26 -- board/ti/omap1610inn/flash.c | 495 ------------------------------ board/ti/omap1610inn/lowlevel_init.S | 452 --------------------------- board/ti/omap1610inn/omap1610innovator.c | 309 ------------------- boards.cfg | 8 - include/configs/omap1610h2.h | 197 ------------ include/configs/omap1610inn.h | 202 ------------ 9 files changed, 0 insertions(+), 1735 deletions(-) delete mode 100644 board/ti/omap1610inn/Makefile delete mode 100644 board/ti/omap1610inn/config.mk delete mode 100644 board/ti/omap1610inn/flash.c delete mode 100644 board/ti/omap1610inn/lowlevel_init.S delete mode 100644 board/ti/omap1610inn/omap1610innovator.c delete mode 100644 include/configs/omap1610h2.h delete mode 100644 include/configs/omap1610inn.h
diff --git a/MAINTAINERS b/MAINTAINERS index 46f63a0..72f8b64 100644 --- a/MAINTAINERS +++ b/MAINTAINERS @@ -672,7 +672,6 @@ Igor Grinberg grinberg@compulab.co.il Kshitij Gupta kshitij@ti.com
omap1510inn ARM925T - omap1610inn ARM926EJS
Stefan Herbrechtsmeier stefan@code.herbrechtsmeier.net
diff --git a/board/ti/omap1610inn/Makefile b/board/ti/omap1610inn/Makefile deleted file mode 100644 index 2b8641f..0000000 --- a/board/ti/omap1610inn/Makefile +++ /dev/null @@ -1,45 +0,0 @@ -# -# (C) Copyright 2000-2006 -# Wolfgang Denk, DENX Software Engineering, wd@denx.de. -# -# See file CREDITS for list of people who contributed to this -# project. -# -# This program is free software; you can redistribute it and/or -# modify it under the terms of the GNU General Public License as -# published by the Free Software Foundation; either version 2 of -# the License, or (at your option) any later version. -# -# This program is distributed in the hope that it will be useful, -# but WITHOUT ANY WARRANTY; without even the implied warranty of -# MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the -# GNU General Public License for more details. -# -# You should have received a copy of the GNU General Public License -# along with this program; if not, write to the Free Software -# Foundation, Inc., 59 Temple Place, Suite 330, Boston, -# MA 02111-1307 USA -# - -include $(TOPDIR)/config.mk - -LIB = $(obj)lib$(BOARD).o - -COBJS := omap1610innovator.o flash.o -SOBJS := lowlevel_init.o - -SRCS := $(SOBJS:.o=.S) $(COBJS:.o=.c) -OBJS := $(addprefix $(obj),$(COBJS)) -SOBJS := $(addprefix $(obj),$(SOBJS)) - -$(LIB): $(obj).depend $(OBJS) $(SOBJS) - $(call cmd_link_o_target, $(OBJS) $(SOBJS)) - -######################################################################### - -# defines $(obj).depend target -include $(SRCTREE)/rules.mk - -sinclude $(obj).depend - -######################################################################### diff --git a/board/ti/omap1610inn/config.mk b/board/ti/omap1610inn/config.mk deleted file mode 100644 index ee0aa0a..0000000 --- a/board/ti/omap1610inn/config.mk +++ /dev/null @@ -1,26 +0,0 @@ -# -# (C) Copyright 2002 -# Gary Jennejohn, DENX Software Engineering, garyj@denx.de -# David Mueller, ELSOFT AG, d.mueller@elsoft.ch -# -# (C) Copyright 2003 -# Texas Instruments, <www.ti.com> -# Kshitij Gupta Kshitij@ti.com -# -# TI Innovator board with OMAP1610 (ARM925EJS) cpu -# see http://www.ti.com/ for more information on Texas Instruments -# -# Innovator has 1 bank of 256 MB SDRAM -# Physical Address: -# 1000'0000 to 2000'0000 -# -# -# Linux-Kernel is expected to be at 1000'8000, entry 1000'8000 -# (mem base + reserved) -# -# we load ourself to 1108'0000 -# -# - - -CONFIG_SYS_TEXT_BASE = 0x11080000 diff --git a/board/ti/omap1610inn/flash.c b/board/ti/omap1610inn/flash.c deleted file mode 100644 index a99a91c..0000000 --- a/board/ti/omap1610inn/flash.c +++ /dev/null @@ -1,495 +0,0 @@ -/* - * (C) Copyright 2001 - * Kyle Harris, Nexus Technologies, Inc. kharris@nexus-tech.net - * - * (C) Copyright 2001-2004 - * Wolfgang Denk, DENX Software Engineering, wd@denx.de. - * - * (C) Copyright 2003 - * Texas Instruments, <www.ti.com> - * Kshitij Gupta Kshitij@ti.com - * - * See file CREDITS for list of people who contributed to this - * project. - * - * This program is free software; you can redistribute it and/or - * modify it under the terms of the GNU General Public License as - * published by the Free Software Foundation; either version 2 of - * the License, or (at your option) any later version. - * - * This program is distributed in the hope that it will be useful, - * but WITHOUT ANY WARRANTY; without even the implied warranty of - * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the - * GNU General Public License for more details. - * - * You should have received a copy of the GNU General Public License - * along with this program; if not, write to the Free Software - * Foundation, Inc., 59 Temple Place, Suite 330, Boston, - * MA 02111-1307 USA - */ - -#include <common.h> -#include <linux/byteorder/swab.h> - -#define PHYS_FLASH_SECT_SIZE 0x00020000 /* 256 KB sectors (x2) */ -flash_info_t flash_info[CONFIG_SYS_MAX_FLASH_BANKS]; /* info for FLASH chips */ - -/* Board support for 1 or 2 flash devices */ -#undef FLASH_PORT_WIDTH32 -#define FLASH_PORT_WIDTH16 - -#ifdef FLASH_PORT_WIDTH16 -#define FLASH_PORT_WIDTH ushort -#define FLASH_PORT_WIDTHV vu_short -#define SWAP(x) __swab16(x) -#else -#define FLASH_PORT_WIDTH ulong -#define FLASH_PORT_WIDTHV vu_long -#define SWAP(x) __swab32(x) -#endif - -#define FPW FLASH_PORT_WIDTH -#define FPWV FLASH_PORT_WIDTHV - -#define mb() __asm__ __volatile__ ("" : : : "memory") - - -/* Flash Organization Structure */ -typedef struct OrgDef { - unsigned int sector_number; - unsigned int sector_size; -} OrgDef; - - -/* Flash Organizations */ -OrgDef OrgIntel_28F256L18T[] = { - {4, 32 * 1024}, /* 4 * 32kBytes sectors */ - {255, 128 * 1024}, /* 255 * 128kBytes sectors */ -}; - - -/*----------------------------------------------------------------------- - * Functions - */ -unsigned long flash_init (void); -static ulong flash_get_size (FPW * addr, flash_info_t * info); -static int write_data (flash_info_t * info, ulong dest, FPW data); -static void flash_get_offsets (ulong base, flash_info_t * info); -void inline spin_wheel (void); -void flash_print_info (flash_info_t * info); -void flash_unprotect_sectors (FPWV * addr); -int flash_erase (flash_info_t * info, int s_first, int s_last); -int write_buff (flash_info_t * info, uchar * src, ulong addr, ulong cnt); -void flash_unlock(flash_info_t * info); - -/*----------------------------------------------------------------------- - */ - -unsigned long flash_init (void) -{ - int i; - ulong size = 0; - - for (i = 0; i < CONFIG_SYS_MAX_FLASH_BANKS; i++) { - switch (i) { - case 0: - flash_get_size ((FPW *) CONFIG_SYS_FLASH_BASE, &flash_info[i]); - flash_get_offsets (CONFIG_SYS_FLASH_BASE, &flash_info[i]); - /* to reset the lock bit */ - flash_unlock(&flash_info[i]); - break; - default: - panic ("configured too many flash banks!\n"); - break; - } - size += flash_info[i].size; - } - - /* Protect monitor and environment sectors - */ - flash_protect (FLAG_PROTECT_SET, - CONFIG_SYS_FLASH_BASE, - CONFIG_SYS_FLASH_BASE + monitor_flash_len - 1, &flash_info[0]); - - flash_protect (FLAG_PROTECT_SET, - CONFIG_ENV_ADDR, - CONFIG_ENV_ADDR + CONFIG_ENV_SIZE - 1, &flash_info[0]); - - return size; -} - -/*----------------------------------------------------------------------- - */ -void flash_unlock(flash_info_t * info) -{ - int j; - for (j=2;j<CONFIG_SYS_MAX_FLASH_SECT;j++){ - FPWV *addr = (FPWV *) (info->start[j]); - flash_unprotect_sectors (addr); - *addr = (FPW) 0x00500050;/* clear status register */ - *addr = (FPW) 0x00FF00FF;/* resest to read mode */ - } -} - -/*----------------------------------------------------------------------- - */ -static void flash_get_offsets (ulong base, flash_info_t * info) -{ - int i; - - if (info->flash_id == FLASH_UNKNOWN) { - return; - } - - if ((info->flash_id & FLASH_VENDMASK) == FLASH_MAN_INTEL) { - for (i = 0; i < info->sector_count; i++) { - if (i > 255) { - info->start[i] = base + (i * 0x8000); - info->protect[i] = 0; - } else { - info->start[i] = base + - (i * PHYS_FLASH_SECT_SIZE); - info->protect[i] = 0; - } - } - } -} - -/*----------------------------------------------------------------------- - */ -void flash_print_info (flash_info_t * info) -{ - int i; - - if (info->flash_id == FLASH_UNKNOWN) { - printf ("missing or unknown FLASH type\n"); - return; - } - - switch (info->flash_id & FLASH_VENDMASK) { - case FLASH_MAN_INTEL: - printf ("INTEL "); - break; - default: - printf ("Unknown Vendor "); - break; - } - - switch (info->flash_id & FLASH_TYPEMASK) { - case FLASH_28F256L18T: - printf ("FLASH 28F256L18T\n"); - break; - default: - printf ("Unknown Chip Type\n"); - break; - } - - printf (" Size: %ld MB in %d Sectors\n", - info->size >> 20, info->sector_count); - - printf (" Sector Start Addresses:"); - for (i = 0; i < info->sector_count; ++i) { - if ((i % 5) == 0) - printf ("\n "); - printf (" %08lX%s", - info->start[i], info->protect[i] ? " (RO)" : " "); - } - printf ("\n"); - return; -} - -/* - * The following code cannot be run from FLASH! - */ -static ulong flash_get_size (FPW * addr, flash_info_t * info) -{ - volatile FPW value; - - /* Write auto select command: read Manufacturer ID */ - addr[0x5555] = (FPW) 0x00AA00AA; - addr[0x2AAA] = (FPW) 0x00550055; - addr[0x5555] = (FPW) 0x00900090; - - mb (); - value = addr[0]; - - switch (value) { - - case (FPW) INTEL_MANUFACT: - info->flash_id = FLASH_MAN_INTEL; - break; - - default: - info->flash_id = FLASH_UNKNOWN; - info->sector_count = 0; - info->size = 0; - addr[0] = (FPW) 0x00FF00FF; /* restore read mode */ - return (0); /* no or unknown flash */ - } - - mb (); - value = addr[1]; /* device ID */ - switch (value) { - - case (FPW) (INTEL_ID_28F256L18T): - info->flash_id += FLASH_28F256L18T; - info->sector_count = 259; - info->size = 0x02000000; - break; /* => 32 MB */ - - default: - info->flash_id = FLASH_UNKNOWN; - break; - } - - if (info->sector_count > CONFIG_SYS_MAX_FLASH_SECT) { - printf ("** ERROR: sector count %d > max (%d) **\n", - info->sector_count, CONFIG_SYS_MAX_FLASH_SECT); - info->sector_count = CONFIG_SYS_MAX_FLASH_SECT; - } - - addr[0] = (FPW) 0x00FF00FF; /* restore read mode */ - - return (info->size); -} - - -/* unprotects a sector for write and erase - * on some intel parts, this unprotects the entire chip, but it - * wont hurt to call this additional times per sector... - */ -void flash_unprotect_sectors (FPWV * addr) -{ -#define PD_FINTEL_WSMS_READY_MASK 0x0080 - - *addr = (FPW) 0x00500050; /* clear status register */ - - /* this sends the clear lock bit command */ - *addr = (FPW) 0x00600060; - *addr = (FPW) 0x00D000D0; -} - - -/*----------------------------------------------------------------------- - */ - -int flash_erase (flash_info_t * info, int s_first, int s_last) -{ - int flag, prot, sect; - ulong type, start; - int rcode = 0; - - if ((s_first < 0) || (s_first > s_last)) { - if (info->flash_id == FLASH_UNKNOWN) { - printf ("- missing\n"); - } else { - printf ("- no sectors to erase\n"); - } - return 1; - } - - type = (info->flash_id & FLASH_VENDMASK); - if ((type != FLASH_MAN_INTEL)) { - printf ("Can't erase unknown flash type %08lx - aborted\n", - info->flash_id); - return 1; - } - - prot = 0; - for (sect = s_first; sect <= s_last; ++sect) { - if (info->protect[sect]) { - prot++; - } - } - - if (prot) { - printf ("- Warning: %d protected sectors will not be erased!\n", - prot); - } else { - printf ("\n"); - } - - /* Disable interrupts which might cause a timeout here */ - flag = disable_interrupts (); - - /* Start erase on unprotected sectors */ - for (sect = s_first; sect <= s_last; sect++) { - if (info->protect[sect] == 0) { /* not protected */ - FPWV *addr = (FPWV *) (info->start[sect]); - FPW status; - - printf ("Erasing sector %2d ... ", sect); - - flash_unprotect_sectors (addr); - - /* arm simple, non interrupt dependent timer */ - start = get_timer(0); - - *addr = (FPW) 0x00500050;/* clear status register */ - *addr = (FPW) 0x00200020;/* erase setup */ - *addr = (FPW) 0x00D000D0;/* erase confirm */ - - while (((status = - *addr) & (FPW) 0x00800080) != - (FPW) 0x00800080) { - if (get_timer(start) > - CONFIG_SYS_FLASH_ERASE_TOUT) { - printf ("Timeout\n"); - /* suspend erase */ - *addr = (FPW) 0x00B000B0; - /* reset to read mode */ - *addr = (FPW) 0x00FF00FF; - rcode = 1; - break; - } - } - - /* clear status register cmd. */ - *addr = (FPW) 0x00500050; - *addr = (FPW) 0x00FF00FF;/* resest to read mode */ - printf (" done\n"); - } - } - if (flag) - enable_interrupts(); - - return rcode; -} - -/*----------------------------------------------------------------------- - * Copy memory to flash, returns: - * 0 - OK - * 1 - write timeout - * 2 - Flash not erased - * 4 - Flash not identified - */ - -int write_buff (flash_info_t * info, uchar * src, ulong addr, ulong cnt) -{ - ulong cp, wp; - FPW data; - int count, i, l, rc, port_width; - - if (info->flash_id == FLASH_UNKNOWN) { - return 4; - } -/* get lower word aligned address */ -#ifdef FLASH_PORT_WIDTH16 - wp = (addr & ~1); - port_width = 2; -#else - wp = (addr & ~3); - port_width = 4; -#endif - - /* - * handle unaligned start bytes - */ - if ((l = addr - wp) != 0) { - data = 0; - for (i = 0, cp = wp; i < l; ++i, ++cp) { - data = (data << 8) | (*(uchar *) cp); - } - for (; i < port_width && cnt > 0; ++i) { - data = (data << 8) | *src++; - --cnt; - ++cp; - } - for (; cnt == 0 && i < port_width; ++i, ++cp) { - data = (data << 8) | (*(uchar *) cp); - } - - if ((rc = write_data (info, wp, SWAP (data))) != 0) { - return (rc); - } - wp += port_width; - } - - /* - * handle word aligned part - */ - count = 0; - while (cnt >= port_width) { - data = 0; - for (i = 0; i < port_width; ++i) { - data = (data << 8) | *src++; - } - if ((rc = write_data (info, wp, SWAP (data))) != 0) { - return (rc); - } - wp += port_width; - cnt -= port_width; - if (count++ > 0x800) { - spin_wheel (); - count = 0; - } - } - - if (cnt == 0) { - return (0); - } - - /* - * handle unaligned tail bytes - */ - data = 0; - for (i = 0, cp = wp; i < port_width && cnt > 0; ++i, ++cp) { - data = (data << 8) | *src++; - --cnt; - } - for (; i < port_width; ++i, ++cp) { - data = (data << 8) | (*(uchar *) cp); - } - - return (write_data (info, wp, SWAP (data))); -} - -/*----------------------------------------------------------------------- - * Write a word or halfword to Flash, returns: - * 0 - OK - * 1 - write timeout - * 2 - Flash not erased - */ -static int write_data (flash_info_t * info, ulong dest, FPW data) -{ - FPWV *addr = (FPWV *) dest; - ulong status; - int flag, rc = 0; - ulong start; - - /* Check if Flash is (sufficiently) erased */ - if ((*addr & data) != data) { - printf("not erased at %08lx (%x)\n", (ulong) addr, *addr); - return 2; - } - /* Disable interrupts which might cause a timeout here */ - flag = disable_interrupts (); - *addr = (FPW) 0x00400040; /* write setup */ - *addr = data; - - /* arm simple, non interrupt dependent timer */ - start = get_timer(0); - - /* wait while polling the status register */ - while (((status = *addr) & (FPW) 0x00800080) != (FPW) 0x00800080) { - if (get_timer(start) > CONFIG_SYS_FLASH_WRITE_TOUT) { - rc = 1; - goto done; - } - } -done: - if (flag) - enable_interrupts(); - - *addr = (FPW) 0x00FF00FF; /* restore read mode */ - return rc; -} - -void inline spin_wheel (void) -{ - static int p = 0; - static char w[] = "\/-"; - - printf ("\010%c", w[p]); - (++p == 3) ? (p = 0) : 0; -} diff --git a/board/ti/omap1610inn/lowlevel_init.S b/board/ti/omap1610inn/lowlevel_init.S deleted file mode 100644 index b376ba5..0000000 --- a/board/ti/omap1610inn/lowlevel_init.S +++ /dev/null @@ -1,452 +0,0 @@ -/* - * Board specific setup info - * - * (C) Copyright 2003 - * Texas Instruments, <www.ti.com> - * Kshitij Gupta Kshitij@ti.com - * - * Modified for OMAP 1610 H2 board by Nishant Kamat, Jan 2004 - * - * See file CREDITS for list of people who contributed to this - * project. - * - * This program is free software; you can redistribute it and/or - * modify it under the terms of the GNU General Public License as - * published by the Free Software Foundation; either version 2 of - * the License, or (at your option) any later version. - * - * This program is distributed in the hope that it will be useful, - * but WITHOUT ANY WARRANTY; without even the implied warranty of - * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the - * GNU General Public License for more details. - * - * You should have received a copy of the GNU General Public License - * along with this program; if not, write to the Free Software - * Foundation, Inc., 59 Temple Place, Suite 330, Boston, - * MA 02111-1307 USA - */ - -#include <config.h> -#include <version.h> - -#if defined(CONFIG_OMAP1610) -#include <./configs/omap1510.h> -#endif - - -_TEXT_BASE: - .word CONFIG_SYS_TEXT_BASE /* sdram load addr from config.mk */ - -.globl lowlevel_init -lowlevel_init: - - - /*------------------------------------------------------* - *mask all IRQs by setting all bits in the INTMR default* - *------------------------------------------------------*/ - mov r1, #0xffffffff - ldr r0, =REG_IHL1_MIR - str r1, [r0] - ldr r0, =REG_IHL2_MIR - str r1, [r0] - - /*------------------------------------------------------* - * Set up ARM CLM registers (IDLECT1) * - *------------------------------------------------------*/ - ldr r0, REG_ARM_IDLECT1 - ldr r1, VAL_ARM_IDLECT1 - str r1, [r0] - - /*------------------------------------------------------* - * Set up ARM CLM registers (IDLECT2) * - *------------------------------------------------------*/ - ldr r0, REG_ARM_IDLECT2 - ldr r1, VAL_ARM_IDLECT2 - str r1, [r0] - - /*------------------------------------------------------* - * Set up ARM CLM registers (IDLECT3) * - *------------------------------------------------------*/ - ldr r0, REG_ARM_IDLECT3 - ldr r1, VAL_ARM_IDLECT3 - str r1, [r0] - -#ifdef CONFIG_CS_AUTOBOOT /* do the setup depending on boot mode */ - ldr r0, CONF_STATUS - ldr r1, [r0] - tst r1, #0x02 - beq disable_wd /* booting from RAM, skip setup */ -#endif - - mov r1, #0x01 /* PER_EN bit */ - ldr r0, REG_ARM_RSTCT2 - strh r1, [r0] /* CLKM; Peripheral reset. */ - - /* Set CLKM to Sync-Scalable */ - /* I supposedly need to enable the dsp clock before switching */ - mov r1, #0x0000 - ldr r0, REG_ARM_SYSST - strh r1, [r0] - mov r0, #0x400 -1: - subs r0, r0, #0x1 /* wait for any bubbles to finish */ - bne 1b - ldr r1, VAL_ARM_CKCTL - ldr r0, REG_ARM_CKCTL - strh r1, [r0] - - /* a few nops to let settle */ - nop - nop - nop - nop - nop - nop - nop - nop - nop - nop - - /* setup DPLL 1 */ - /* Ramp up the clock to 96Mhz */ - ldr r1, VAL_DPLL1_CTL - ldr r0, REG_DPLL1_CTL - strh r1, [r0] - ands r1, r1, #0x10 /* Check if PLL is enabled. */ - beq lock_end /* Do not look for lock if BYPASS selected */ -2: - ldrh r1, [r0] - ands r1, r1, #0x01 /* Check the LOCK bit.*/ - beq 2b /* loop until bit goes hi. */ -lock_end: - - - /*------------------------------------------------------* - * Turn off the watchdog during init... * - *------------------------------------------------------*/ -disable_wd: - ldr r0, REG_WATCHDOG - ldr r1, WATCHDOG_VAL1 - str r1, [r0] - ldr r1, WATCHDOG_VAL2 - str r1, [r0] - ldr r0, REG_WSPRDOG - ldr r1, WSPRDOG_VAL1 - str r1, [r0] - ldr r0, REG_WWPSDOG - -watch1Wait: - ldr r1, [r0] - tst r1, #0x10 - bne watch1Wait - - ldr r0, REG_WSPRDOG - ldr r1, WSPRDOG_VAL2 - str r1, [r0] - ldr r0, REG_WWPSDOG -watch2Wait: - ldr r1, [r0] - tst r1, #0x10 - bne watch2Wait - - - /* Set memory timings corresponding to the new clock speed */ - - /* Check execution location to determine current execution location - * and branch to appropriate initialization code. - */ - /* Load physical SDRAM base. */ - mov r0, #0x10000000 - /* Get current execution location. */ - mov r1, pc - /* Compare. */ - cmp r1, r0 - /* Skip over EMIF-fast initialization if running from SDRAM. */ - bge skip_sdram - - /* - * Delay for SDRAM initialization. - */ - mov r3, #0x1800 /* value should be checked */ -3: - subs r3, r3, #0x1 /* Decrement count */ - bne 3b - - - /* - * Set SDRAM control values. Disable refresh before MRS command. - */ - - /* mobile ddr operation */ - ldr r0, REG_SDRAM_OPERATION - mov r2, #07 - str r2, [r0] - - /* config register */ - ldr r0, REG_SDRAM_CONFIG - ldr r1, SDRAM_CONFIG_VAL - str r1, [r0] - - /* manual command register */ - ldr r0, REG_SDRAM_MANUAL_CMD - /* issue set cke high */ - mov r1, #CMD_SDRAM_CKE_SET_HIGH - str r1, [r0] - /* issue nop */ - mov r1, #CMD_SDRAM_NOP - str r1, [r0] - - mov r2, #0x0100 -waitMDDR1: - subs r2, r2, #1 - bne waitMDDR1 /* delay loop */ - - /* issue precharge */ - mov r1, #CMD_SDRAM_PRECHARGE - str r1, [r0] - - /* issue autorefresh x 2 */ - mov r1, #CMD_SDRAM_AUTOREFRESH - str r1, [r0] - str r1, [r0] - - /* mrs register ddr mobile */ - ldr r0, REG_SDRAM_MRS - mov r1, #0x33 - str r1, [r0] - - /* emrs1 low-power register */ - ldr r0, REG_SDRAM_EMRS1 - /* self refresh on all banks */ - mov r1, #0 - str r1, [r0] - - ldr r0, REG_DLL_URD_CONTROL - ldr r1, DLL_URD_CONTROL_VAL - str r1, [r0] - - ldr r0, REG_DLL_LRD_CONTROL - ldr r1, DLL_LRD_CONTROL_VAL - str r1, [r0] - - ldr r0, REG_DLL_WRT_CONTROL - ldr r1, DLL_WRT_CONTROL_VAL - str r1, [r0] - - /* delay loop */ - mov r2, #0x0100 -waitMDDR2: - subs r2, r2, #1 - bne waitMDDR2 - - /* - * Delay for SDRAM initialization. - */ - mov r3, #0x1800 -4: - subs r3, r3, #1 /* Decrement count. */ - bne 4b - b common_tc - -skip_sdram: - - ldr r0, REG_SDRAM_CONFIG - ldr r1, SDRAM_CONFIG_VAL - str r1, [r0] - -common_tc: - /* slow interface */ - ldr r1, VAL_TC_EMIFS_CS0_CONFIG - ldr r0, REG_TC_EMIFS_CS0_CONFIG - str r1, [r0] /* Chip Select 0 */ - - ldr r1, VAL_TC_EMIFS_CS1_CONFIG - ldr r0, REG_TC_EMIFS_CS1_CONFIG - str r1, [r0] /* Chip Select 1 */ - ldr r1, VAL_TC_EMIFS_CS3_CONFIG - ldr r0, REG_TC_EMIFS_CS3_CONFIG - str r1, [r0] /* Chip Select 3 */ - -#ifdef CONFIG_H2_OMAP1610 - /* inserting additional 2 clock cycle hold time for LAN */ - ldr r0, REG_TC_EMIFS_CS1_ADVANCED - ldr r1, VAL_TC_EMIFS_CS1_ADVANCED - str r1, [r0] -#endif - /* Start MPU Timer 1 */ - ldr r0, REG_MPU_LOAD_TIMER - ldr r1, VAL_MPU_LOAD_TIMER - str r1, [r0] - - ldr r0, REG_MPU_CNTL_TIMER - ldr r1, VAL_MPU_CNTL_TIMER - str r1, [r0] - - /* back to arch calling code */ - mov pc, lr - - /* the literal pools origin */ - .ltorg - -#ifdef CONFIG_CS_AUTOBOOT -CONF_STATUS: - .word 0xfffe1130 /* 32 bits */ -#endif - -REG_TC_EMIFS_CONFIG: /* 32 bits */ - .word 0xfffecc0c -REG_TC_EMIFS_CS0_CONFIG: /* 32 bits */ - .word 0xfffecc10 -REG_TC_EMIFS_CS1_CONFIG: /* 32 bits */ - .word 0xfffecc14 -REG_TC_EMIFS_CS2_CONFIG: /* 32 bits */ - .word 0xfffecc18 -REG_TC_EMIFS_CS3_CONFIG: /* 32 bits */ - .word 0xfffecc1c - -#ifdef CONFIG_H2_OMAP1610 -REG_TC_EMIFS_CS1_ADVANCED: /* 32 bits */ - .word 0xfffecc54 -#endif - -/* MPU clock/reset/power mode control registers */ -REG_ARM_CKCTL: /* 16 bits */ - .word 0xfffece00 - -REG_ARM_IDLECT3: /* 16 bits */ - .word 0xfffece24 -REG_ARM_IDLECT2: /* 16 bits */ - .word 0xfffece08 -REG_ARM_IDLECT1: /* 16 bits */ - .word 0xfffece04 - -REG_ARM_RSTCT2: /* 16 bits */ - .word 0xfffece14 -REG_ARM_SYSST: /* 16 bits */ - .word 0xfffece18 -/* DPLL control registers */ -REG_DPLL1_CTL: /* 16 bits */ - .word 0xfffecf00 - -/* Watch Dog register */ -/* secure watchdog stop */ -REG_WSPRDOG: - .word 0xfffeb048 -/* watchdog write pending */ -REG_WWPSDOG: - .word 0xfffeb034 - -WSPRDOG_VAL1: - .word 0x0000aaaa -WSPRDOG_VAL2: - .word 0x00005555 - -/* SDRAM config is: auto refresh enabled, 16 bit 4 bank, - counter @8192 rows, 10 ns, 8 burst */ -REG_SDRAM_CONFIG: - .word 0xfffecc20 - -/* Operation register */ -REG_SDRAM_OPERATION: - .word 0xfffecc80 - -/* Manual command register */ -REG_SDRAM_MANUAL_CMD: - .word 0xfffecc84 - -/* SDRAM MRS (New) config is: CAS latency is 2, burst length 8 */ -REG_SDRAM_MRS: - .word 0xfffecc70 - -/* SDRAM MRS (New) config is: CAS latency is 2, burst length 8 */ -REG_SDRAM_EMRS1: - .word 0xfffecc78 - -/* WRT DLL register */ -REG_DLL_WRT_CONTROL: - .word 0xfffecc68 -DLL_WRT_CONTROL_VAL: - .word 0x03f00002 - -/* URD DLL register */ -REG_DLL_URD_CONTROL: - .word 0xfffeccc0 -DLL_URD_CONTROL_VAL: - .word 0x00800002 - -/* LRD DLL register */ -REG_DLL_LRD_CONTROL: - .word 0xfffecccc - -REG_WATCHDOG: - .word 0xfffec808 - -REG_MPU_LOAD_TIMER: - .word 0xfffec504 -REG_MPU_CNTL_TIMER: - .word 0xfffec500 - -/* 96 MHz Samsung Mobile DDR */ -SDRAM_CONFIG_VAL: - .word 0x001200f4 - -DLL_LRD_CONTROL_VAL: - .word 0x00800002 - -VAL_ARM_CKCTL: - .word 0x3000 -VAL_DPLL1_CTL: - .word 0x2830 - -#ifdef CONFIG_INNOVATOROMAP1610 -VAL_TC_EMIFS_CS0_CONFIG: - .word 0x002130b0 -VAL_TC_EMIFS_CS1_CONFIG: - .word 0x00001131 -VAL_TC_EMIFS_CS2_CONFIG: - .word 0x000055f0 -VAL_TC_EMIFS_CS3_CONFIG: - .word 0x88011131 -#endif - -#ifdef CONFIG_H2_OMAP1610 -VAL_TC_EMIFS_CS0_CONFIG: - .word 0x00203331 -VAL_TC_EMIFS_CS1_CONFIG: - .word 0x8180fff3 -VAL_TC_EMIFS_CS2_CONFIG: - .word 0xf800f22a -VAL_TC_EMIFS_CS3_CONFIG: - .word 0x88011131 -VAL_TC_EMIFS_CS1_ADVANCED: - .word 0x00000022 -#endif - -VAL_TC_EMIFF_SDRAM_CONFIG: - .word 0x010290fc -VAL_TC_EMIFF_MRS: - .word 0x00000027 - -VAL_ARM_IDLECT1: - .word 0x00000400 - -VAL_ARM_IDLECT2: - .word 0x00000886 -VAL_ARM_IDLECT3: - .word 0x00000015 - -WATCHDOG_VAL1: - .word 0x000000f5 -WATCHDOG_VAL2: - .word 0x000000a0 - -VAL_MPU_LOAD_TIMER: - .word 0xffffffff -VAL_MPU_CNTL_TIMER: - .word 0xffffffa1 - -/* command values */ -.equ CMD_SDRAM_NOP, 0x00000000 -.equ CMD_SDRAM_PRECHARGE, 0x00000001 -.equ CMD_SDRAM_AUTOREFRESH, 0x00000002 -.equ CMD_SDRAM_CKE_SET_HIGH, 0x00000007 diff --git a/board/ti/omap1610inn/omap1610innovator.c b/board/ti/omap1610inn/omap1610innovator.c deleted file mode 100644 index 16e8237..0000000 --- a/board/ti/omap1610inn/omap1610innovator.c +++ /dev/null @@ -1,309 +0,0 @@ -/* - * (C) Copyright 2002 - * Sysgo Real-Time Solutions, GmbH <www.elinos.com> - * Marius Groeger mgroeger@sysgo.de - * - * (C) Copyright 2002 - * David Mueller, ELSOFT AG, d.mueller@elsoft.ch - * - * (C) Copyright 2003 - * Texas Instruments, <www.ti.com> - * Kshitij Gupta Kshitij@ti.com - * - * Modified for OMAP 1610 H2 board by Nishant Kamat, Jan 2004 - * - * See file CREDITS for list of people who contributed to this - * project. - * - * This program is free software; you can redistribute it and/or - * modify it under the terms of the GNU General Public License as - * published by the Free Software Foundation; either version 2 of - * the License, or (at your option) any later version. - * - * This program is distributed in the hope that it will be useful, - * but WITHOUT ANY WARRANTY; without even the implied warranty of - * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the - * GNU General Public License for more details. - * - * You should have received a copy of the GNU General Public License - * along with this program; if not, write to the Free Software - * Foundation, Inc., 59 Temple Place, Suite 330, Boston, - * MA 02111-1307 USA - */ - -#include <common.h> -#include <netdev.h> -#if defined(CONFIG_OMAP1610) -#include <./configs/omap1510.h> -#endif - -DECLARE_GLOBAL_DATA_PTR; - -#ifdef CONFIG_CS_AUTOBOOT -unsigned long omap_flash_base; -#endif - -void flash__init (void); -void ether__init (void); -void set_muxconf_regs (void); -void peripheral_power_enable (void); - -#define COMP_MODE_ENABLE ((unsigned int)0x0000EAEF) - -static inline void delay (unsigned long loops) -{ - __asm__ volatile ("1:\n" - "subs %0, %1, #1\n" - "bne 1b":"=r" (loops):"0" (loops)); -} - -/* - * Miscellaneous platform dependent initialisations - */ - -int board_init (void) -{ - /* adress of boot parameters */ - gd->bd->bi_boot_params = 0x10000100; - - /* Configure MUX settings */ - set_muxconf_regs (); - peripheral_power_enable (); - -/* this speeds up your boot a quite a bit. However to make it - * work, you need make sure your kernel startup flush bug is fixed. - * ... rkw ... - */ - icache_enable (); - - flash__init (); - ether__init (); - return 0; -} - - -int misc_init_r (void) -{ - /* currently empty */ - return (0); -} - -/****************************** - Routine: - Description: -******************************/ -void flash__init (void) -{ -#define EMIFS_GlB_Config_REG 0xfffecc0c - unsigned int regval; - -#ifdef CONFIG_CS_AUTOBOOT - /* Check swapping of CS0 and CS3, set flash base accordingly */ - omap_flash_base = ((*((u32 *)OMAP_EMIFS_CONFIG_REG) & 0x02) == 0) ? - PHYS_FLASH_1_BM0 : PHYS_FLASH_1_BM1; -#endif - regval = *((volatile unsigned int *) EMIFS_GlB_Config_REG); - /* Turn off write protection for flash devices. */ - regval = regval | 0x0001; - *((volatile unsigned int *) EMIFS_GlB_Config_REG) = regval; -} -/************************************************************* - Routine:ether__init - Description: take the Ethernet controller out of reset and wait - for the EEPROM load to complete. -*************************************************************/ -void ether__init (void) -{ -#define ETH_CONTROL_REG 0x0400030b - -#ifdef CONFIG_H2_OMAP1610 - #define LAN_RESET_REGISTER 0x0400001c - - /* The debug board on which the lan chip resides may not be powered - * ON at the same time as the OMAP chip. So wait in a loop until the - * lan reset register (on the debug board) is available (powered on) - * and reset the lan chip. - */ - - *((volatile unsigned short *) LAN_RESET_REGISTER) = 0x0000; - do { - *((volatile unsigned short *) LAN_RESET_REGISTER) = 0x0001; - udelay (3); - } while (*((volatile unsigned short *) LAN_RESET_REGISTER) != 0x0001); - - do { - *((volatile unsigned short *) LAN_RESET_REGISTER) = 0x0000; - udelay (3); - } while (*((volatile unsigned short *) LAN_RESET_REGISTER) != 0x0000); -#endif - - *((volatile unsigned char *) ETH_CONTROL_REG) &= ~0x01; - udelay (3); -} - -/****************************** - Routine: - Description: -******************************/ -int dram_init (void) -{ - gd->bd->bi_dram[0].start = PHYS_SDRAM_1; - gd->bd->bi_dram[0].size = PHYS_SDRAM_1_SIZE; - - return 0; -} - -/****************************************************** - Routine: set_muxconf_regs - Description: Setting up the configuration Mux registers - specific to the hardware -*******************************************************/ -void set_muxconf_regs (void) -{ - volatile unsigned int *MuxConfReg; - /* set each registers to its reset value; */ - MuxConfReg = - (volatile unsigned int *) ((unsigned int) FUNC_MUX_CTRL_0); - /* setup for UART1 */ - *MuxConfReg &= ~(0x02000000); /* bit 25 */ - /* setup for UART2 */ - *MuxConfReg &= ~(0x01000000); /* bit 24 */ - /* Disable Uwire CS Hi-Z */ - *MuxConfReg |= 0x08000000; - MuxConfReg = - (volatile unsigned int *) ((unsigned int) FUNC_MUX_CTRL_3); - *MuxConfReg = 0x00000000; - MuxConfReg = - (volatile unsigned int *) ((unsigned int) FUNC_MUX_CTRL_4); - *MuxConfReg = 0x00000000; - MuxConfReg = - (volatile unsigned int *) ((unsigned int) FUNC_MUX_CTRL_5); - *MuxConfReg = 0x00000000; - MuxConfReg = - (volatile unsigned int *) ((unsigned int) FUNC_MUX_CTRL_6); - /*setup mux for UART3 */ - *MuxConfReg |= 0x00000001; /* bit3, 1, 0 (mux0 5,5,26) */ - *MuxConfReg &= ~0x0000003e; - MuxConfReg = - (volatile unsigned int *) ((unsigned int) FUNC_MUX_CTRL_7); - *MuxConfReg = 0x00000000; - MuxConfReg = - (volatile unsigned int *) ((unsigned int) FUNC_MUX_CTRL_8); - /* Disable Uwire CS Hi-Z */ - *MuxConfReg |= 0x00001200; /*bit 9 for CS0 12 for CS3 */ - MuxConfReg = - (volatile unsigned int *) ((unsigned int) FUNC_MUX_CTRL_9); - /* Need to turn on bits 21 and 12 in FUNC_MUX_CTRL_9 so the */ - /* hardware will actually use TX and RTS based on bit 25 in */ - /* FUNC_MUX_CTRL_0. I told you this thing was screwy! */ - *MuxConfReg |= 0x00201000; - MuxConfReg = - (volatile unsigned int *) ((unsigned int) FUNC_MUX_CTRL_A); - *MuxConfReg = 0x00000000; - MuxConfReg = - (volatile unsigned int *) ((unsigned int) FUNC_MUX_CTRL_B); - *MuxConfReg = 0x00000000; - MuxConfReg = - (volatile unsigned int *) ((unsigned int) FUNC_MUX_CTRL_C); - /* setup for UART2 */ - /* Need to turn on bits 27 and 24 in FUNC_MUX_CTRL_C so the */ - /* hardware will actually use TX and RTS based on bit 24 in */ - /* FUNC_MUX_CTRL_0. */ - *MuxConfReg |= 0x09000000; - MuxConfReg = - (volatile unsigned int *) ((unsigned int) PULL_DWN_CTRL_0); - *MuxConfReg = 0x00000000; - MuxConfReg = - (volatile unsigned int *) ((unsigned int) PULL_DWN_CTRL_1); - *MuxConfReg = 0x00000000; - /* mux setup for SD/MMC driver */ - MuxConfReg = - (volatile unsigned int *) ((unsigned int) PULL_DWN_CTRL_2); - *MuxConfReg &= 0xFFFE0FFF; - MuxConfReg = - (volatile unsigned int *) ((unsigned int) PULL_DWN_CTRL_3); - *MuxConfReg = 0x00000000; - MuxConfReg = - (volatile unsigned int *) ((unsigned int) MOD_CONF_CTRL_0); - /* bit 13 for MMC2 XOR_CLK */ - *MuxConfReg &= ~(0x00002000); - /* bit 29 for UART 1 */ - *MuxConfReg &= ~(0x00002000); - MuxConfReg = - (volatile unsigned int *) ((unsigned int) FUNC_MUX_CTRL_0); - /* Configure for USB. Turn on VBUS_CTRL and VBUS_MODE. */ - *MuxConfReg |= 0x000C0000; - MuxConfReg = - (volatile unsigned int *) ((unsigned int)USB_TRANSCEIVER_CTRL); - *MuxConfReg &= ~(0x00000070); - *MuxConfReg &= ~(0x00000008); - *MuxConfReg |= 0x00000003; - *MuxConfReg |= 0x00000180; - MuxConfReg = - (volatile unsigned int *) ((unsigned int) MOD_CONF_CTRL_0); - /* bit 17, software controls VBUS */ - *MuxConfReg &= ~(0x00020000); - /* Enable USB 48 and 12M clocks */ - *MuxConfReg |= 0x00000200; - *MuxConfReg &= ~(0x00000180); - /*2.75V for MMCSDIO1 */ - MuxConfReg = - (volatile unsigned int *) ((unsigned int) VOLTAGE_CTRL_0); - *MuxConfReg = 0x00001FE7; - MuxConfReg = - (volatile unsigned int *) ((unsigned int) PU_PD_SEL_0); - *MuxConfReg = 0x00000000; - MuxConfReg = - (volatile unsigned int *) ((unsigned int) PU_PD_SEL_1); - *MuxConfReg = 0x00000000; - MuxConfReg = - (volatile unsigned int *) ((unsigned int) PU_PD_SEL_2); - *MuxConfReg = 0x00000000; - MuxConfReg = - (volatile unsigned int *) ((unsigned int) PU_PD_SEL_3); - *MuxConfReg = 0x00000000; - MuxConfReg = - (volatile unsigned int *) ((unsigned int) PU_PD_SEL_4); - *MuxConfReg = 0x00000000; - MuxConfReg = - (volatile unsigned int *) ((unsigned int) PULL_DWN_CTRL_4); - *MuxConfReg = 0x00000000; - /* Turn on UART2 48 MHZ clock */ - MuxConfReg = - (volatile unsigned int *) ((unsigned int) MOD_CONF_CTRL_0); - *MuxConfReg |= 0x40000000; - MuxConfReg = - (volatile unsigned int *) ((unsigned int) USB_OTG_CTRL); - /* setup for USB VBus detection OMAP161x */ - *MuxConfReg |= 0x00040000; /* bit 18 */ - MuxConfReg = - (volatile unsigned int *) ((unsigned int) PU_PD_SEL_2); - /* PullUps for SD/MMC driver */ - *MuxConfReg |= ~(0xFFFE0FFF); - MuxConfReg = - (volatile unsigned int *) ((unsigned int)COMP_MODE_CTRL_0); - *MuxConfReg = COMP_MODE_ENABLE; -} - -/****************************************************** - Routine: peripheral_power_enable - Description: Enable the power for UART1 -*******************************************************/ -void peripheral_power_enable (void) -{ -#define UART1_48MHZ_ENABLE ((unsigned short)0x0200) -#define SW_CLOCK_REQUEST ((volatile unsigned short *)0xFFFE0834) - - *SW_CLOCK_REQUEST |= UART1_48MHZ_ENABLE; -} - -#ifdef CONFIG_CMD_NET -int board_eth_init(bd_t *bis) -{ - int rc = 0; -#ifdef CONFIG_LAN91C96 - rc = lan91c96_initialize(0, CONFIG_LAN91C96_BASE); -#endif - return rc; -} -#endif diff --git a/boards.cfg b/boards.cfg index 28cc345..1ea0c9b 100644 --- a/boards.cfg +++ b/boards.cfg @@ -164,14 +164,6 @@ m28evk arm arm926ejs - denx mx28evk arm arm926ejs - freescale mx28 nhk8815 arm arm926ejs nhk8815 st nomadik nhk8815_onenand arm arm926ejs nhk8815 st nomadik nhk8815:BOOT_ONENAND -omap1610h2 arm arm926ejs omap1610inn ti omap omap1610inn:CS3_BOOT -omap1610h2_cs0boot arm arm926ejs omap1610inn ti omap omap1610inn:CS0_BOOT -omap1610h2_cs3boot arm arm926ejs omap1610inn ti omap omap1610inn:CS3_BOOT -omap1610h2_cs_autoboot arm arm926ejs omap1610inn ti omap omap1610inn:CS_AUTOBOOT -omap1610inn arm arm926ejs omap1610inn ti omap omap1610inn:CS3_BOOT -omap1610inn_cs0boot arm arm926ejs omap1610inn ti omap omap1610inn:CS0_BOOT -omap1610inn_cs3boot arm arm926ejs omap1610inn ti omap omap1610inn:CS3_BOOT -omap1610inn_cs_autoboot arm arm926ejs omap1610inn ti omap omap1610inn:CS_AUTOBOOT omap5912osk arm arm926ejs - ti omap omap730p2 arm arm926ejs omap730p2 ti omap omap730p2:CS3_BOOT omap730p2_cs0boot arm arm926ejs omap730p2 ti omap omap730p2:CS0_BOOT diff --git a/include/configs/omap1610h2.h b/include/configs/omap1610h2.h deleted file mode 100644 index d57e1a7..0000000 --- a/include/configs/omap1610h2.h +++ /dev/null @@ -1,197 +0,0 @@ -/* - * (C) Copyright 2004 - * Texas Instruments. - * Kshitij Gupta kshitij@ti.com - * Configuration settings for the TI OMAP 1610 H2 board. - * - * See file CREDITS for list of people who contributed to this - * project. - * - * This program is free software; you can redistribute it and/or - * modify it under the terms of the GNU General Public License as - * published by the Free Software Foundation; either version 2 of - * the License, or (at your option) any later version. - * - * This program is distributed in the hope that it will be useful, - * but WITHOUT ANY WARRANTY; without even the implied warranty of - * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the - * GNU General Public License for more details. - * - * You should have received a copy of the GNU General Public License - * along with this program; if not, write to the Free Software - * Foundation, Inc., 59 Temple Place, Suite 330, Boston, - * MA 02111-1307 USA - */ - -#ifndef __CONFIG_H -#define __CONFIG_H - -/* - * High Level Configuration Options - * (easy to change) - */ -#define CONFIG_ARM926EJS 1 /* This is an arm926ejs CPU core */ -#define CONFIG_OMAP 1 /* in a TI OMAP core */ -#define CONFIG_OMAP1610 1 /* which is in a 1610 */ -#define CONFIG_H2_OMAP1610 1 /* on an H2 Board */ - -#define CONFIG_MACH_TYPE MACH_TYPE_OMAP_H2 - -/* input clock of PLL */ -/* the OMAP1610 H2 has 12MHz input clock */ -#define CONFIG_SYS_CLK_FREQ 12000000 - -#undef CONFIG_USE_IRQ /* we don't need IRQ/FIQ stuff */ - -#define CONFIG_MISC_INIT_R - -#define CONFIG_CMDLINE_TAG 1 /* enable passing of ATAGs */ -#define CONFIG_SETUP_MEMORY_TAGS 1 -#define CONFIG_INITRD_TAG 1 - -/* - * Size of malloc() pool - */ -#define CONFIG_SYS_MALLOC_LEN (CONFIG_ENV_SIZE + 128*1024) - -/* - * Hardware drivers - */ -#define CONFIG_LAN91C96 -#define CONFIG_LAN91C96_BASE 0x04000300 -#define CONFIG_LAN91C96_EXT_PHY - -/* - * NS16550 Configuration - */ -#define CONFIG_SYS_NS16550 -#define CONFIG_SYS_NS16550_SERIAL -#define CONFIG_SYS_NS16550_REG_SIZE (-4) -#define CONFIG_SYS_NS16550_CLK (48000000) /* can be 12M/32Khz or 48Mhz */ -#define CONFIG_SYS_NS16550_COM1 0xfffb0000 /* uart1, bluetooth uart */ - -/* - * select serial console configuration - */ -#define CONFIG_SERIAL1 1 /* we use SERIAL 1 on OMAP1610 H2 */ - -/* allow to overwrite serial and ethaddr */ -#define CONFIG_ENV_OVERWRITE -#define CONFIG_CONS_INDEX 1 -#define CONFIG_BAUDRATE 115200 -#define CONFIG_SYS_BAUDRATE_TABLE { 9600, 19200, 38400, 57600, 115200 } - - -/* - * Command line configuration. - */ -#include <config_cmd_default.h> - -#define CONFIG_CMD_DHCP - - -/* - * BOOTP options - */ -#define CONFIG_BOOTP_SUBNETMASK -#define CONFIG_BOOTP_GATEWAY -#define CONFIG_BOOTP_HOSTNAME -#define CONFIG_BOOTP_BOOTPATH - - -#include <configs/omap1510.h> - -#define CONFIG_BOOTDELAY 3 -#define CONFIG_BOOTARGS "console=ttyS0,115200n8 noinitrd root=/dev/nfs ip=dhcp" -#define CONFIG_BOOTCOMMAND "bootp;tftp;bootm" -#define CONFIG_SYS_AUTOLOAD "n" /* No autoload */ - -#if defined(CONFIG_CMD_KGDB) -#define CONFIG_KGDB_BAUDRATE 115200 /* speed to run kgdb serial port */ -#define CONFIG_KGDB_SER_INDEX 1 /* which serial port to use */ -#endif - -/* - * Miscellaneous configurable options - */ -#define CONFIG_SYS_LONGHELP /* undef to save memory */ -#define CONFIG_SYS_PROMPT "OMAP1610 H2 # " /* Monitor Command Prompt */ -#define CONFIG_SYS_CBSIZE 256 /* Console I/O Buffer Size */ -/* Print Buffer Size */ -#define CONFIG_SYS_PBSIZE (CONFIG_SYS_CBSIZE+sizeof(CONFIG_SYS_PROMPT)+16) -#define CONFIG_SYS_MAXARGS 16 /* max number of command args */ -#define CONFIG_SYS_BARGSIZE CONFIG_SYS_CBSIZE /* Boot Argument Buffer Size */ - -#define CONFIG_SYS_MEMTEST_START 0x10000000 /* memtest works on */ -#define CONFIG_SYS_MEMTEST_END 0x12000000 /* 32 MB in DRAM */ - -#define CONFIG_SYS_LOAD_ADDR 0x10000000 /* default load address */ - -/* The 1610 has 6 timers, they can be driven by the RefClk (12Mhz) or by - * DPLL1. This time is further subdivided by a local divisor. - */ -#define CONFIG_SYS_TIMERBASE 0xFFFEC500 /* use timer 1 */ -#define CONFIG_SYS_PTV 7 /* 2^(PTV+1), divide by 256 */ -#define CONFIG_SYS_HZ ((CONFIG_SYS_CLK_FREQ)/(2 << CONFIG_SYS_PTV)) - -/*----------------------------------------------------------------------- - * Stack sizes - * - * The stack sizes are set up in start.S using the settings below - */ -#define CONFIG_STACKSIZE (128*1024) /* regular stack */ -#ifdef CONFIG_USE_IRQ -#define CONFIG_STACKSIZE_IRQ (4*1024) /* IRQ stack */ -#define CONFIG_STACKSIZE_FIQ (4*1024) /* FIQ stack */ -#endif - -/*----------------------------------------------------------------------- - * Physical Memory Map - */ -#define CONFIG_NR_DRAM_BANKS 1 /* we have 1 bank of DRAM */ -#define PHYS_SDRAM_1 0x10000000 /* SDRAM Bank #1 */ -#define PHYS_SDRAM_1_SIZE 0x02000000 /* 32 MB */ - -#define PHYS_FLASH_1_BM1 0x00000000 /* Flash Bank #1 if booting from flash */ -#define PHYS_FLASH_1_BM0 0x0C000000 /* Flash Bank #1 if booting from RAM */ - -#ifdef CONFIG_CS_AUTOBOOT /* Determine CS assignment in runtime */ - -#ifndef __ASSEMBLY__ -extern unsigned long omap_flash_base; /* set in flash__init */ -#endif -#define CONFIG_SYS_FLASH_BASE omap_flash_base - -#elif defined(CONFIG_CS0_BOOT) - -#define CONFIG_SYS_FLASH_BASE PHYS_FLASH_1_BM0 - -#else - -#define CONFIG_SYS_FLASH_BASE PHYS_FLASH_1_BM1 - -#endif - -#define PHYS_SRAM 0x20000000 - -/*----------------------------------------------------------------------- - * FLASH and environment organization - */ -#define CONFIG_SYS_MAX_FLASH_BANKS 1 /* max number of memory banks */ -#define PHYS_FLASH_SIZE 0x02000000 /* 32MB */ -#define CONFIG_SYS_MAX_FLASH_SECT (259) /* max number of sectors on one chip */ -/* addr of environment */ -#define CONFIG_ENV_ADDR (CONFIG_SYS_FLASH_BASE + 0x020000) - -/* timeout values are in ticks */ -#define CONFIG_SYS_FLASH_ERASE_TOUT (20*CONFIG_SYS_HZ) /* Timeout for Flash Erase */ -#define CONFIG_SYS_FLASH_WRITE_TOUT (20*CONFIG_SYS_HZ) /* Timeout for Flash Write */ - -#define CONFIG_ENV_IS_IN_FLASH 1 -#define CONFIG_ENV_SIZE 0x20000 /* Total Size of Environment Sector */ -#define CONFIG_ENV_OFFSET 0x20000 /* environment starts here */ - -#define CONFIG_SYS_SDRAM_BASE PHYS_SDRAM_1 -#define CONFIG_SYS_INIT_SP_ADDR PHYS_SRAM - -#endif /* __CONFIG_H */ diff --git a/include/configs/omap1610inn.h b/include/configs/omap1610inn.h deleted file mode 100644 index 7901b6c..0000000 --- a/include/configs/omap1610inn.h +++ /dev/null @@ -1,202 +0,0 @@ -/* - * (C) Copyright 2003 - * Texas Instruments. - * Kshitij Gupta kshitij@ti.com - * Configuation settings for the TI OMAP Innovator board. - * - * See file CREDITS for list of people who contributed to this - * project. - * - * This program is free software; you can redistribute it and/or - * modify it under the terms of the GNU General Public License as - * published by the Free Software Foundation; either version 2 of - * the License, or (at your option) any later version. - * - * This program is distributed in the hope that it will be useful, - * but WITHOUT ANY WARRANTY; without even the implied warranty of - * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the - * GNU General Public License for more details. - * - * You should have received a copy of the GNU General Public License - * along with this program; if not, write to the Free Software - * Foundation, Inc., 59 Temple Place, Suite 330, Boston, - * MA 02111-1307 USA - */ - -#ifndef __CONFIG_H -#define __CONFIG_H - -/* - * High Level Configuration Options - * (easy to change) - */ -#define CONFIG_ARM926EJS 1 /* This is an arm926ejs CPU core */ -#define CONFIG_OMAP 1 /* in a TI OMAP core */ -#define CONFIG_OMAP1610 1 /* which is in a 1610 */ -#define CONFIG_INNOVATOROMAP1610 1 /* a Innovator Board */ - -#define CONFIG_MACH_TYPE MACH_TYPE_OMAP_INNOVATOR - -/* input clock of PLL */ -/* the OMAP1610 Innovator has 12MHz input clock */ -#define CONFIG_SYS_CLK_FREQ 12000000 - -#undef CONFIG_USE_IRQ /* we don't need IRQ/FIQ stuff */ - -#define CONFIG_MISC_INIT_R - -#define CONFIG_CMDLINE_TAG 1 /* enable passing of ATAGs */ -#define CONFIG_SETUP_MEMORY_TAGS 1 - -/* - * Size of malloc() pool - */ -#define CONFIG_SYS_MALLOC_LEN (CONFIG_ENV_SIZE + 128*1024) - -/* - * Hardware drivers - */ -/* -*/ -#define CONFIG_LAN91C96 -#define CONFIG_LAN91C96_BASE 0x04000300 -#define CONFIG_LAN91C96_EXT_PHY - -/* - * NS16550 Configuration - */ -#define CONFIG_SYS_NS16550 -#define CONFIG_SYS_NS16550_SERIAL -#define CONFIG_SYS_NS16550_REG_SIZE (-4) -#define CONFIG_SYS_NS16550_CLK (48000000) /* can be 12M/32Khz or 48Mhz */ -#define CONFIG_SYS_NS16550_COM1 0xfffb0000 /* uart1, bluetooth uart on helen */ - -/* - * select serial console configuration - */ -#define CONFIG_SERIAL1 1 /* we use SERIAL 1 on OMAP1610 Innovator */ - -/* allow to overwrite serial and ethaddr */ -#define CONFIG_ENV_OVERWRITE -#define CONFIG_CONS_INDEX 1 -#define CONFIG_BAUDRATE 115200 -#define CONFIG_SYS_BAUDRATE_TABLE { 9600, 19200, 38400, 57600, 115200 } - - -/* - * Command line configuration. - */ -#include <config_cmd_default.h> - -#define CONFIG_CMD_DHCP - - -/* - * BOOTP options - */ -#define CONFIG_BOOTP_SUBNETMASK -#define CONFIG_BOOTP_GATEWAY -#define CONFIG_BOOTP_HOSTNAME -#define CONFIG_BOOTP_BOOTPATH - - -#include <configs/omap1510.h> - -#define CONFIG_BOOTDELAY 3 -#define CONFIG_BOOTARGS "mem=32M console=ttyS0,115200n8 noinitrd \ - root=/dev/nfs rw nfsroot=157.87.82.48:\ - /home/a0875451/mwd/myfs/target ip=dhcp" -#define CONFIG_NETMASK 255.255.254.0 /* talk on MY local net */ -#define CONFIG_IPADDR 156.117.97.156 /* static IP I currently own */ -#define CONFIG_SERVERIP 156.117.97.139 /* current IP of my dev pc */ -#define CONFIG_BOOTFILE "uImage" /* file to load */ - -#if defined(CONFIG_CMD_KGDB) -#define CONFIG_KGDB_BAUDRATE 115200 /* speed to run kgdb serial port */ -#define CONFIG_KGDB_SER_INDEX 1 /* which serial port to use */ -#endif - -/* - * Miscellaneous configurable options - */ -#define CONFIG_SYS_LONGHELP /* undef to save memory */ -#define CONFIG_SYS_PROMPT "OMAP1610 Innovator # " /* Monitor Command Prompt */ -#define CONFIG_SYS_CBSIZE 256 /* Console I/O Buffer Size */ -/* Print Buffer Size */ -#define CONFIG_SYS_PBSIZE (CONFIG_SYS_CBSIZE+sizeof(CONFIG_SYS_PROMPT)+16) -#define CONFIG_SYS_MAXARGS 16 /* max number of command args */ -#define CONFIG_SYS_BARGSIZE CONFIG_SYS_CBSIZE /* Boot Argument Buffer Size */ - -#define CONFIG_SYS_MEMTEST_START 0x10000000 /* memtest works on */ -#define CONFIG_SYS_MEMTEST_END 0x12000000 /* 32 MB in DRAM */ - -#define CONFIG_SYS_LOAD_ADDR 0x10000000 /* default load address */ - -/* The 1610 has 6 timers, they can be driven by the RefClk (12Mhz) or by - * DPLL1. This time is further subdivided by a local divisor. - */ -#define CONFIG_SYS_TIMERBASE 0xFFFEC500 /* use timer 1 */ -#define CONFIG_SYS_PTV 7 /* 2^(PTV+1), divide by 256 */ -#define CONFIG_SYS_HZ ((CONFIG_SYS_CLK_FREQ)/(2 << CONFIG_SYS_PTV)) - -/*----------------------------------------------------------------------- - * Stack sizes - * - * The stack sizes are set up in start.S using the settings below - */ -#define CONFIG_STACKSIZE (128*1024) /* regular stack */ -#ifdef CONFIG_USE_IRQ -#define CONFIG_STACKSIZE_IRQ (4*1024) /* IRQ stack */ -#define CONFIG_STACKSIZE_FIQ (4*1024) /* FIQ stack */ -#endif - -/*----------------------------------------------------------------------- - * Physical Memory Map - */ -#define CONFIG_NR_DRAM_BANKS 1 /* we have 1 bank of DRAM */ -#define PHYS_SDRAM_1 0x10000000 /* SDRAM Bank #1 */ -#define PHYS_SDRAM_1_SIZE 0x02000000 /* 32 MB */ - -#define PHYS_FLASH_1_BM1 0x00000000 /* Flash Bank #1 if booting from flash */ -#define PHYS_FLASH_1_BM0 0x0C000000 /* Flash Bank #1 if booting from RAM */ - -#ifdef CONFIG_CS_AUTOBOOT /* Determine CS assignment in runtime */ - -#ifndef __ASSEMBLY__ -extern unsigned long omap_flash_base; /* set in flash__init */ -#endif -#define CONFIG_SYS_FLASH_BASE omap_flash_base - -#elif defined(CONFIG_CS0_BOOT) - -#define CONFIG_SYS_FLASH_BASE PHYS_FLASH_1_BM0 - -#else - -#define CONFIG_SYS_FLASH_BASE PHYS_FLASH_1_BM1 - -#endif - -#define PHYS_SRAM 0x20000000 - -/*----------------------------------------------------------------------- - * FLASH and environment organization - */ -#define CONFIG_SYS_MAX_FLASH_BANKS 1 /* max number of memory banks */ -#define PHYS_FLASH_SIZE 0x02000000 /* 32MB */ -#define CONFIG_SYS_MAX_FLASH_SECT (259) /* max number of sectors on one chip */ -/* addr of environment */ -#define CONFIG_ENV_ADDR (CONFIG_SYS_FLASH_BASE + 0x020000) - -/* timeout values are in ticks */ -#define CONFIG_SYS_FLASH_ERASE_TOUT (20*CONFIG_SYS_HZ) /* Timeout for Flash Erase */ -#define CONFIG_SYS_FLASH_WRITE_TOUT (20*CONFIG_SYS_HZ) /* Timeout for Flash Write */ - -#define CONFIG_ENV_IS_IN_FLASH 1 -#define CONFIG_ENV_SIZE 0x20000 /* Total Size of Environment Sector */ -#define CONFIG_ENV_OFFSET 0x20000 /* environment starts here */ - -#define CONFIG_SYS_SDRAM_BASE PHYS_SDRAM_1 -#define CONFIG_SYS_INIT_SP_ADDR PHYS_SRAM - -#endif /* __CONFIG_H */
After removing omap1610inn for not building, move omap1510inn to orphaned. Also update boards.cfg to note it's part of the 'omap' SoC to make sure the board is built more often and future breakage noticed quicker.
Signed-off-by: Tom Rini trini@ti.com --- MAINTAINERS | 7 +++---- boards.cfg | 2 +- 2 files changed, 4 insertions(+), 5 deletions(-)
diff --git a/MAINTAINERS b/MAINTAINERS index 72f8b64..708ded7 100644 --- a/MAINTAINERS +++ b/MAINTAINERS @@ -669,10 +669,6 @@ Igor Grinberg grinberg@compulab.co.il
cm-t35 ARM ARMV7 (OMAP3xx Soc)
-Kshitij Gupta kshitij@ti.com - - omap1510inn ARM925T - Stefan Herbrechtsmeier stefan@code.herbrechtsmeier.net
dns325 ARM926EJS (Kirkwood SoC) @@ -941,6 +937,9 @@ Sughosh Ganu urwithsughosh@gmail.com Unknown / orphaned boards: Board CPU Last known maintainer / Comment ......................................................................... + + omap1510inn ARM925T Kshitij Gupta kshitij@ti.com + lubbock xscale/pxa Kyle Harris kharris@nexus-tech.net / dead address
imx31_phycore_eet i.MX31 Guennadi Liakhovetski g.liakhovetski@gmx.de / resigned diff --git a/boards.cfg b/boards.cfg index 1ea0c9b..3bcaeda 100644 --- a/boards.cfg +++ b/boards.cfg @@ -63,7 +63,7 @@ cm4008 arm arm920t - - cm41xx arm arm920t - - ks8695 VCMA9 arm arm920t vcma9 mpl s3c24x0 smdk2410 arm arm920t - samsung s3c24x0 -omap1510inn arm arm925t - ti +omap1510inn arm arm925t - ti omap integratorap_cm926ejs arm arm926ejs integrator armltd - integratorap:CM926EJ_S integratorcp_cm926ejs arm arm926ejs integrator armltd - integratorcp:CM924EJ_S aspenite arm arm926ejs - Marvell armada100
