[U-Boot] u-boot sandbox crash
Hello,
I think this segfault below is not wanted?
$ ./MAKEALL sandbox Configuring for sandbox board... text data bss dec hex filename 131497 6048 28488 166033 28891 ./u-boot
--------------------- SUMMARY ---------------------------- Boards compiled: 1 ---------------------------------------------------------- marex@mashiro:~/U-Boot/u-boot-marex$ ./u-boot
U-Boot 2011.12-00509-ge7dc4f9 (Mar 18 2012 - 03:10:34)
DRAM: 128 MiB Using default environment
In: serial Out: serial Err: serial
=>base Base Address: 0x00000000 =>md 0 00000000:Segmentation fault
Best regards, Marek Vasut
Dear Mike Frysinger,
I see.
this is because the change to make this work was reverted. i think ppc is broken, but haven't gone through the details to figure things out. -mike
Hrm ... I wish I'd be able to figure out how to run PPC/Taihu or PPC/Bamboo U- Boot in QEMU.
It's because sandbox has a 128MB memory region, which is just created using malloc(). We want address 0 to refer to the first byte of this region.
I did create a patch to fix this, which used the map_physmem() to get the address in the md command. However, ppc expects that the md command just blindly uses the address it is given (i.e. assume it is already a virtual address if the MMU is on, and a physical address if not). I suspect other archs would have the same requirement if they ever mapped virtual memory differently to physical memory.
I did post about it at the time. My proposed fix was to introduce the idea of mapping an 'apparent' address. This would be a 1-1 mapping for all architectures except sandbox, which would map it into its malloc'd memory.
It's a little unfortunate that sandbox has to be the only thing with a mapping, though. Partly that's why I haven't sent a patch. Taken to its logical conclusion then any memory access that the user requests would end up going through this veneer. But I don't have any better ideas yet.
If you're interested, the original patch was here:
http://patchwork.ozlabs.org/patch/121815/
-mike
Mike Frysinger
