[U-Boot] pull request for u-boot-tegra/master
Albert,
Please pull u-boot-tegra/master into arm master. Thanks!
The following changes since commit 6e7c76a15753f3a5e1b94df372392a08e4b11b02: Nobuhiro Iwamatsu (1): arm: ea20: Change macro from BOARD_LATE_INIT to CONFIG_BOARD_LATE_INIT
git://git.denx.de/u-boot-tegra master
Jimmy Zhang (3): tegra: Add EMC support for optimal memory timings tegra: Add PMU to manage power supplies tegra: Add EMC settings for Seaboard
Simon Glass (14): fdt: Add function to locate an array in the device tree fdt: Add function to return next compatible subnode Add abs() macro to return absolute value i2c: Add TPS6586X driver tegra: Move ap20.h header into arch location tegra: Add functions to access low-level Osc/PLL details tegra: Add tegra_get_chip_type() to detect SKU tegra: Add header file for APB_MISC register tegra: Set up PMU for Nvidia boards tegra: Set up warmboot code on Nvidia boards fdt: tegra: Add EMC node to device tree tegra: i2c: Add function to find DVC bus tegra: fdt: Add EMC data for Tegra2 Seaboard tegra: Enable LP0 on Seaboard
Wei Ni (1): tegra: Turn off power detect in board init
Yen Lin (5): Add AES crypto library tegra: Add crypto library for warmboot code tegra: Add flow, gp_padctl, fuse, sdram headers tegra: Add warmboot implementation tegra: Setup PMC scratch info from ap20 setup
arch/arm/cpu/armv7/tegra2/Makefile | 4 + arch/arm/cpu/armv7/tegra2/ap20.c | 44 ++- arch/arm/cpu/armv7/tegra2/board.c | 4 +- arch/arm/cpu/armv7/tegra2/clock.c | 32 + arch/arm/cpu/armv7/tegra2/crypto.c | 230 ++++++++ arch/arm/cpu/armv7/tegra2/crypto.h | 36 ++ arch/arm/cpu/armv7/tegra2/emc.c | 286 ++++++++++ arch/arm/cpu/armv7/tegra2/pmu.c | 70 +++ arch/arm/cpu/armv7/tegra2/warmboot.c | 382 +++++++++++++ arch/arm/cpu/armv7/tegra2/warmboot_avp.c | 250 ++++++++ arch/arm/cpu/armv7/tegra2/warmboot_avp.h | 81 +++ arch/arm/dts/tegra20.dtsi | 7 + .../tegra2 => include/asm/arch-tegra2}/ap20.h | 7 + arch/arm/include/asm/arch-tegra2/apb_misc.h | 36 ++ arch/arm/include/asm/arch-tegra2/clk_rst.h | 3 + arch/arm/include/asm/arch-tegra2/clock.h | 22 + arch/arm/include/asm/arch-tegra2/emc.h | 113 ++++ arch/arm/include/asm/arch-tegra2/flow.h | 36 ++ arch/arm/include/asm/arch-tegra2/fuse.h | 39 ++ arch/arm/include/asm/arch-tegra2/gp_padctrl.h | 73 +++ arch/arm/include/asm/arch-tegra2/pmu.h | 30 + arch/arm/include/asm/arch-tegra2/sdram_param.h | 148 +++++ arch/arm/include/asm/arch-tegra2/tegra2.h | 25 + arch/arm/include/asm/arch-tegra2/tegra_i2c.h | 7 + arch/arm/include/asm/arch-tegra2/warmboot.h | 150 +++++ board/nvidia/common/Makefile | 1 + board/nvidia/common/board.c | 41 ++- board/nvidia/common/emc.c | 53 ++ board/nvidia/common/emc.h | 29 + board/nvidia/dts/tegra2-seaboard.dts | 37 ++ drivers/i2c/tegra_i2c.c | 14 + drivers/power/Makefile | 1 + drivers/power/tps6586x.c | 280 +++++++++ include/aes.h | 70 +++ include/common.h | 13 + include/configs/seaboard.h | 8 + include/configs/tegra2-common.h | 17 + include/fdtdec.h | 38 ++ include/tps6586x.h | 68 +++ lib/Makefile | 1 + lib/aes.c | 598 ++++++++++++++++++++ lib/fdtdec.c | 28 + 42 files changed, 3408 insertions(+), 4 deletions(-) create mode 100644 arch/arm/cpu/armv7/tegra2/crypto.c create mode 100644 arch/arm/cpu/armv7/tegra2/crypto.h create mode 100644 arch/arm/cpu/armv7/tegra2/emc.c create mode 100644 arch/arm/cpu/armv7/tegra2/pmu.c create mode 100644 arch/arm/cpu/armv7/tegra2/warmboot.c create mode 100644 arch/arm/cpu/armv7/tegra2/warmboot_avp.c create mode 100644 arch/arm/cpu/armv7/tegra2/warmboot_avp.h rename arch/arm/{cpu/armv7/tegra2 => include/asm/arch-tegra2}/ap20.h (96%) create mode 100644 arch/arm/include/asm/arch-tegra2/apb_misc.h create mode 100644 arch/arm/include/asm/arch-tegra2/emc.h create mode 100644 arch/arm/include/asm/arch-tegra2/flow.h create mode 100644 arch/arm/include/asm/arch-tegra2/fuse.h create mode 100644 arch/arm/include/asm/arch-tegra2/gp_padctrl.h create mode 100644 arch/arm/include/asm/arch-tegra2/pmu.h create mode 100644 arch/arm/include/asm/arch-tegra2/sdram_param.h create mode 100644 arch/arm/include/asm/arch-tegra2/warmboot.h create mode 100644 board/nvidia/common/emc.c create mode 100644 board/nvidia/common/emc.h create mode 100644 drivers/power/tps6586x.c create mode 100644 include/aes.h create mode 100644 include/tps6586x.h create mode 100644 lib/aes.c
nvpublic
Tom Warren
