[U-Boot] [PATCH v2] armv8: fsl-layerscape: Update qspi clk cfg
Update qspi clock configuration in TFABOOT in case of all boot sources except qspi boot source.
Signed-off-by: Pankit Garg pankit.garg@nxp.com --- Changes for v2: - change subject line of commit-id
arch/arm/cpu/armv8/fsl-layerscape/soc.c | 9 +++++++++ 1 file changed, 9 insertions(+)
diff --git a/arch/arm/cpu/armv8/fsl-layerscape/soc.c b/arch/arm/cpu/armv8/fsl-layerscape/soc.c index df3200e..aeaf7b8 100644 --- a/arch/arm/cpu/armv8/fsl-layerscape/soc.c +++ b/arch/arm/cpu/armv8/fsl-layerscape/soc.c @@ -609,6 +609,9 @@ void fsl_lsch2_early_init_f(void) struct ccsr_cci400 *cci = (struct ccsr_cci400 *)(CONFIG_SYS_IMMR + CONFIG_SYS_CCI400_OFFSET); struct ccsr_scfg *scfg = (struct ccsr_scfg *)CONFIG_SYS_FSL_SCFG_ADDR; +#ifdef CONFIG_TFABOOT + enum boot_src src; +#endif
#ifdef CONFIG_LAYERSCAPE_NS_ACCESS enable_layerscape_ns_access(); @@ -618,9 +621,15 @@ void fsl_lsch2_early_init_f(void) init_early_memctl_regs(); /* tighten IFC timing */ #endif
+#if defined(CONFIG_FSL_QSPI) && defined(CONFIG_TFABOOT) + src = get_boot_src(); + if (src != BOOT_SOURCE_QSPI_NOR) + out_be32(&scfg->qspi_cfg, SCFG_QSPI_CLKSEL); +#else #if defined(CONFIG_FSL_QSPI) && !defined(CONFIG_QSPI_BOOT) out_be32(&scfg->qspi_cfg, SCFG_QSPI_CLKSEL); #endif +#endif /* Make SEC reads and writes snoopable */ setbits_be32(&scfg->snpcnfgcr, SCFG_SNPCNFGCR_SECRDSNP | SCFG_SNPCNFGCR_SECWRSNP |
-----Original Message----- From: Pankit Garg Sent: Wednesday, May 29, 2019 5:43 PM To: u-boot@lists.denx.de Cc: Prabhakar Kushwaha prabhakar.kushwaha@nxp.com; Jagdish Gediya jagdish.gediya@nxp.com Subject: [PATCH v2] armv8: fsl-layerscape: Update qspi clk cfg
This patch has been applied to fsl-qoriq master, awaiting upstream.
--pk
Pankit Garg
Prabhakar Kushwaha
