[U-Boot] Problems with latest U-boot on Mini2440
Dear List,
I have been trying to get a working binary of latest U-boot from git repo (git://git.denx.de/u-boot.git) for my Mini2440 (Samsung S3C2440, ARM926T) for weeks, without any success.
I tried to use 3 different CodeBench toolchains and DENX ELDK for armv4t as well, but no joy so far. Compilation finishes successfully, but the resulting code does not print anything on the serial line. I have the original Supervivi in the NOR and updating the NAND bootloader from it in two different ways:
Tried to load the U-boot image to RAM and start it by jumping to the correct memory address, but I always get the followings on the serial console:
argument 0 = 0x00000000 argument 1 = 0x00000000 argument 2 = 0x00000000 argument 3 = 0x00000000 And nothing else.
If I try to download U-boot directly to the NAND and reset the board, nothing is displayed.
Both method works well with the image provided by the manufacturer's website, but I need to enable netconsole option on my board, which is not configured on their binary.
A fork is available which provides the source tree of their version (at git://repo.or.cz/u-boot-openmoko/mini2440.git), but it is version 1.3.2, and if I enable netconsole, it fails to compile. Without the netconsole settings this source compiles and runs fine on the board, which I believe confirms that my toolchain is fine.
I tried to disable optimization of the compiler (-O0) as suggested on U-boot FAQ, but also did not help with any of the compilers.
Do you have any experience with this board, or can you suggest me how to locate the issue? Unfortunately I don't have a JTAG debugger, which might make debugging a bit harder.
Thanks in advance for any help!
Best regards, Peter
On Thu, Jan 09, 2014 at 11:08 +0300, Peter Germer wrote:
Dear List,
First I thought "arm926" would translate into "armv5te", but then I learned that there is "arm920t" which is "armv4t" (was misled by former work on "arm926ejs").
So the armv4t toolchain appears to be the correct one for S3C2440.
According to `git log` and `git show b77026225a31` ("ARM : Add support for MINI2440 (s3c2440)." as of 2012-05-02) only boot from NOR is supported. Later commit 79a6fcf2573e (2013-06-15) fixed GPIO register access, and commit 2108f4c4a302 (2013-10-04) adjusted CONFIG_SYS_HZ.
Later I2C and USB got adjusted, but those changes should only have an affect after a banner was shown (that's an assumption of mine, I2C _may_ be involved in detecting the board before showing a banner). Correct clocks OTOH are a prerequisite for serial communication.
You may want to check those exact revisions identified above which changed "mini" related code, or their direct predecessors in case a change broke a feature for you. If one of those works for you, you may 'git bisect' from there, to help diagnose what needs to get improved or added to re-gain support for your board in mainline U-Boot.
And check the `git log` output for more keywords than I did, there may have been more commits of interest in the area of serial communication that I might have missed.
I understand that you want to keep the current bootloader in NOR, which means that lack of support to boot from NAND only leaves you with boot from RAM, which the software may not support either (it's not as trivial as it may sound, and requires explicit support). So when the software only supports booting from NOR, and you don't have the software in NOR, this may be a reason why it doesn't work for you.
In the absence of a JTAG _debugger_, can you somehow get a quick or cheap JTAG _programmer_? There are several of them which you can build yourself, or get for some EUR 50,- if you can live with USB attached tools (FTDI based). But keep away from the parport "wigglers", and pick a model that adjusts its pin levels to the target voltage. This way you can do more involved experiments, and still won't lose your currently working although limited status. For "stupid" JTAG adaptors, the difference between programming and debugging only lies in PC side software, and for "old" CPUs like ARM9 you may get debugging for free with OpenSource PC software. It's certainly worth looking into getting a JTAG adaptor ...
virtually yours Gerhard Sittig
Dear Gerhard,
2014/1/9 Gerhard Sittig gsi@denx.de
Thank you for the guidance to the exact revisions where "mini" related changes were committed. I tried all of them, but I could not run the binaries on my board. In `git show b77026225a31` it is mentioned, that the git I used successfully earlier [1] was merged to the mainline U-Boot, but this one did not work neither (from NAND or RAM). I tried all the revisions you mentioned, and the direct predecessors as well, and some other I found could be related to "mini', but so far no joy.
Correct. At least since I don't have a JTAG programmer I don't dare to swipe out the original 'supervivi' boot loader, as with it I can play with the NAND with no risk. In case the U-Boot I write to NOR would not work, I will brick my board till I can get a JTAG programmer. The version from [1] can be started both from RAM and from NAND without any hassle, but in the mainline log it is clearly mentioned that after integrating it supports only NOR. So far I could not find any other revision mentioning that booting from NAND or RAM was solved regarding the specific board.
I just saw that the board support was removed with the new RC released this week. So for me it seems the best idea would playing with the source tree available at [1], as it has more functions supported on my board. Anyway, thank you for your kind help!
Best regards, Peter
[1] git://repo.or.cz/u-boot-openmoko/mini2440.git
Gerhard Sittig
Peter Germer
