[U-Boot-Users] [PATCH] Make scripts and Makefiles POSIX compliant
The bash builtin versions of the "test" (resp. "[") command allow using "==" for string comparisons, but POSIX compatible implemen- tations (like /usr/bin/test) insist on using "=" only. On such systems you will see:
$ /usr/bin/test a == a && echo OK /usr/bin/test: ==: binary operator expected
This patch fixes Makefiles and scripts to use POSIX style.
Signed-off-by: Wolfgang Denk wd@denx.de --- This problem shows up on some [k]ubuntu systems. Thanks to Stefan Roese for reporting the issue.
Makefile | 6 +++--- board/integratorap/split_by_variant.sh | 4 ++-- board/integratorcp/split_by_variant.sh | 4 ++-- board/versatile/split_by_variant.sh | 2 +- 4 files changed, 8 insertions(+), 8 deletions(-)
diff --git a/Makefile b/Makefile index 34e9f9d..189e1de 100644 --- a/Makefile +++ b/Makefile @@ -1682,14 +1682,14 @@ TQM8265_AA_config: unconfig fi; \ echo "#define CONFIG_$${CFREQ}MHz" >>$(obj)include/config.h ; \ echo "... with $${CFREQ}MHz system clock" ; \ - if [ "$${CACHE}" == "yes" ] ; then \ + if [ "$${CACHE}" = "yes" ] ; then \ echo "#define CONFIG_L2_CACHE" >>$(obj)include/config.h ; \ echo "... with L2 Cache support" ; \ else \ echo "#undef CONFIG_L2_CACHE" >>$(obj)include/config.h ; \ echo "... without L2 Cache support" ; \ fi; \ - if [ "$${BMODE}" == "60x" ] ; then \ + if [ "$${BMODE}" = "60x" ] ; then \ echo "#define CONFIG_BUSMODE_60x" >>$(obj)include/config.h ; \ echo "... with 60x Bus Mode" ; \ else \ @@ -1803,7 +1803,7 @@ M54455EVB_i66_config : unconfig M54455EVB_i66_config) FLASH=INTEL; FREQ=66666666;; \ esac; \ >include/config.h ; \ - if [ "$${FLASH}" == "INTEL" ] ; then \ + if [ "$${FLASH}" = "INTEL" ] ; then \ echo "#undef CFG_ATMEL_BOOT" >> $(obj)include/config.h ; \ echo "TEXT_BASE = 0x00000000" > $(obj)board/freescale/m54455evb/config.tmp ; \ cp $(obj)board/freescale/m54455evb/u-boot.int $(obj)board/freescale/m54455evb/u-boot.lds ; \ diff --git a/board/integratorap/split_by_variant.sh b/board/integratorap/split_by_variant.sh index 53b0d1e..4b94d8f 100755 --- a/board/integratorap/split_by_variant.sh +++ b/board/integratorap/split_by_variant.sh @@ -14,7 +14,7 @@ echo " 1 /* Integrator/AP */" >> tmp.fil cpu="arm_intcm" variant="unknown core module"
-if [ "$1" == "" ] +if [ "$1" = "" ] then echo "$0:: No parameters - using arm_intcm" else @@ -84,7 +84,7 @@ else esac fi
-if [ "$cpu" == "arm_intcm" ] +if [ "$cpu" = "arm_intcm" ] then echo "/* Core module undefined/not ported */" >> tmp.fil echo "#define CONFIG_ARM_INTCM 1" >> tmp.fil diff --git a/board/integratorcp/split_by_variant.sh b/board/integratorcp/split_by_variant.sh index 37ae517..79a6a9d 100755 --- a/board/integratorcp/split_by_variant.sh +++ b/board/integratorcp/split_by_variant.sh @@ -12,7 +12,7 @@ echo " 1 /* Integrator/CP */" >> tmp.fil cpu="arm_intcm" variant="unknown core module"
-if [ "$1" == "" ] +if [ "$1" = "" ] then echo "$0:: No parameters - using arm_intcm" else @@ -79,7 +79,7 @@ else
fi
-if [ "$cpu" == "arm_intcm" ] +if [ "$cpu" = "arm_intcm" ] then echo "/* Core module undefined/not ported */" >> tmp.fil echo "#define CONFIG_ARM_INTCM 1" >> tmp.fil diff --git a/board/versatile/split_by_variant.sh b/board/versatile/split_by_variant.sh index 25461c2..ccded7e 100755 --- a/board/versatile/split_by_variant.sh +++ b/board/versatile/split_by_variant.sh @@ -8,7 +8,7 @@
mkdir -p ${obj}include variant=PB926EJ-S -if [ "$1" == "" ] +if [ "$1" = "" ] then echo "$0:: No parameters - using versatilepb_config" echo "#define CONFIG_ARCH_VERSATILE_PB" > ${obj}include/config.h
