[U-Boot-Users] [PATCH: cmdcfg: 09/19] rtc/: Augment CONFIG_COMMANDS tests with defined(CONFIG_CMD_*).
This is a compatibility step that allows both the older form and the new form to co-exist for a while until the older can be removed entirely.
All transformations are of the form: Before: #if (CONFIG_COMMANDS & CFG_CMD_AUTOSCRIPT) After: #if (CONFIG_COMMANDS & CFG_CMD_AUTOSCRIPT) || defined(CONFIG_CMD_AUTOSCRIPT)
Signed-off-by: Jon Loeliger jdl@freescale.com --- rtc/bf5xx_rtc.c | 2 +- rtc/date.c | 2 +- rtc/ds12887.c | 2 +- rtc/ds1302.c | 2 +- rtc/ds1306.c | 2 +- rtc/ds1307.c | 2 +- rtc/ds1337.c | 2 +- rtc/ds1374.c | 2 +- rtc/ds1556.c | 2 +- rtc/ds164x.c | 2 +- rtc/ds174x.c | 2 +- rtc/ds3231.c | 2 +- rtc/m41t11.c | 2 +- rtc/m48t35ax.c | 2 +- rtc/max6900.c | 2 +- rtc/mc146818.c | 2 +- rtc/mk48t59.c | 2 +- rtc/mpc5xxx.c | 2 +- rtc/mpc8xx.c | 2 +- rtc/pcf8563.c | 2 +- rtc/rs5c372.c | 2 +- rtc/s3c24x0_rtc.c | 2 +- 22 files changed, 22 insertions(+), 22 deletions(-)
diff --git a/rtc/bf5xx_rtc.c b/rtc/bf5xx_rtc.c index 85bbb56..b10be81 100644 --- a/rtc/bf5xx_rtc.c +++ b/rtc/bf5xx_rtc.c @@ -49,7 +49,7 @@ #include <command.h> #include <rtc.h>
-#if defined(CONFIG_RTC_BFIN) && (CONFIG_COMMANDS & CFG_CMD_DATE) +#if defined(CONFIG_RTC_BFIN) && ((CONFIG_COMMANDS & CFG_CMD_DATE) || defined(CONFIG_CMD_DATE))
#include <asm/blackfin.h> #include <asm/arch/bf5xx_rtc.h> diff --git a/rtc/date.c b/rtc/date.c index b5f8c48..17d870f 100644 --- a/rtc/date.c +++ b/rtc/date.c @@ -29,7 +29,7 @@ #include <command.h> #include <rtc.h>
-#if (CONFIG_COMMANDS & CFG_CMD_DATE) || defined(CONFIG_TIMESTAMP) +#if (CONFIG_COMMANDS & CFG_CMD_DATE) || defined(CONFIG_CMD_DATE) || defined(CONFIG_TIMESTAMP)
#define FEBRUARY 2 #define STARTOFTIME 1970 diff --git a/rtc/ds12887.c b/rtc/ds12887.c index 8b12893..60382a1 100644 --- a/rtc/ds12887.c +++ b/rtc/ds12887.c @@ -28,7 +28,7 @@ #include <config.h> #include <rtc.h>
-#if defined(CONFIG_RTC_DS12887) && (CONFIG_COMMANDS & CFG_CMD_DATE) +#if defined(CONFIG_RTC_DS12887) && ((CONFIG_COMMANDS & CFG_CMD_DATE) || defined(CONFIG_CMD_DATE))
#define RTC_SECONDS 0x00 #define RTC_SECONDS_ALARM 0x01 diff --git a/rtc/ds1302.c b/rtc/ds1302.c index 98dce89..908cc7c 100644 --- a/rtc/ds1302.c +++ b/rtc/ds1302.c @@ -9,7 +9,7 @@ #include <command.h> #include <rtc.h>
-#if defined(CONFIG_RTC_DS1302) && (CONFIG_COMMANDS & CFG_CMD_DATE) +#if defined(CONFIG_RTC_DS1302) && ((CONFIG_COMMANDS & CFG_CMD_DATE) || defined(CONFIG_CMD_DATE))
/* GPP Pins */ #define DATA 0x200 diff --git a/rtc/ds1306.c b/rtc/ds1306.c index e01e1ce..08622fb 100644 --- a/rtc/ds1306.c +++ b/rtc/ds1306.c @@ -36,7 +36,7 @@ #include <rtc.h> #include <spi.h>
-#if defined(CONFIG_RTC_DS1306) && (CONFIG_COMMANDS & CFG_CMD_DATE) +#if defined(CONFIG_RTC_DS1306) && ((CONFIG_COMMANDS & CFG_CMD_DATE) || defined(CONFIG_CMD_DATE))
#define RTC_SECONDS 0x00 #define RTC_MINUTES 0x01 diff --git a/rtc/ds1307.c b/rtc/ds1307.c index 3b26a0a..79201a1 100644 --- a/rtc/ds1307.c +++ b/rtc/ds1307.c @@ -36,7 +36,7 @@ #include <i2c.h>
#if (defined(CONFIG_RTC_DS1307) || defined(CONFIG_RTC_DS1338) ) && \ - (CONFIG_COMMANDS & CFG_CMD_DATE) + ((CONFIG_COMMANDS & CFG_CMD_DATE) || defined(CONFIG_CMD_DATE))
/*---------------------------------------------------------------------*/ #undef DEBUG_RTC diff --git a/rtc/ds1337.c b/rtc/ds1337.c index 9f0c8c0..4de4fa3 100644 --- a/rtc/ds1337.c +++ b/rtc/ds1337.c @@ -32,7 +32,7 @@ #include <rtc.h> #include <i2c.h>
-#if defined(CONFIG_RTC_DS1337) && (CONFIG_COMMANDS & CFG_CMD_DATE) +#if defined(CONFIG_RTC_DS1337) && ((CONFIG_COMMANDS & CFG_CMD_DATE) || defined(CONFIG_CMD_DATE))
/*---------------------------------------------------------------------*/ #undef DEBUG_RTC diff --git a/rtc/ds1374.c b/rtc/ds1374.c index 50a996c..b0dd9dc 100644 --- a/rtc/ds1374.c +++ b/rtc/ds1374.c @@ -35,7 +35,7 @@ #include <rtc.h> #include <i2c.h>
-#if (defined(CONFIG_RTC_DS1374)) && (CONFIG_COMMANDS & CFG_CMD_DATE) +#if (defined(CONFIG_RTC_DS1374)) && ((CONFIG_COMMANDS & CFG_CMD_DATE) || defined(CONFIG_CMD_DATE))
/*---------------------------------------------------------------------*/ #undef DEBUG_RTC diff --git a/rtc/ds1556.c b/rtc/ds1556.c index dd9ea5e..8d4602a 100644 --- a/rtc/ds1556.c +++ b/rtc/ds1556.c @@ -37,7 +37,7 @@ #include <rtc.h>
-#if defined(CONFIG_RTC_DS1556) && (CONFIG_COMMANDS & CFG_CMD_DATE) +#if defined(CONFIG_RTC_DS1556) && ((CONFIG_COMMANDS & CFG_CMD_DATE) || defined(CONFIG_CMD_DATE))
static uchar rtc_read( unsigned int addr ); static void rtc_write( unsigned int addr, uchar val); diff --git a/rtc/ds164x.c b/rtc/ds164x.c index 3cc76ab..36a0fb4 100644 --- a/rtc/ds164x.c +++ b/rtc/ds164x.c @@ -37,7 +37,7 @@ #include <rtc.h>
-#if defined(CONFIG_RTC_DS164x) && (CONFIG_COMMANDS & CFG_CMD_DATE) +#if defined(CONFIG_RTC_DS164x) && ((CONFIG_COMMANDS & CFG_CMD_DATE) || defined(CONFIG_CMD_DATE))
static uchar rtc_read(unsigned int addr ); static void rtc_write(unsigned int addr, uchar val); diff --git a/rtc/ds174x.c b/rtc/ds174x.c index 58b13e9..5261e54 100644 --- a/rtc/ds174x.c +++ b/rtc/ds174x.c @@ -33,7 +33,7 @@ #include <command.h> #include <rtc.h>
-#if defined(CONFIG_RTC_DS174x) && (CONFIG_COMMANDS & CFG_CMD_DATE) +#if defined(CONFIG_RTC_DS174x) && ((CONFIG_COMMANDS & CFG_CMD_DATE) || defined(CONFIG_CMD_DATE))
static uchar rtc_read( unsigned int addr ); static void rtc_write( unsigned int addr, uchar val); diff --git a/rtc/ds3231.c b/rtc/ds3231.c index 50aeeb5..208f152 100644 --- a/rtc/ds3231.c +++ b/rtc/ds3231.c @@ -33,7 +33,7 @@ #include <rtc.h> #include <i2c.h>
-#if defined(CONFIG_RTC_DS3231) && (CONFIG_COMMANDS & CFG_CMD_DATE) +#if defined(CONFIG_RTC_DS3231) && ((CONFIG_COMMANDS & CFG_CMD_DATE) || defined(CONFIG_CMD_DATE))
/*---------------------------------------------------------------------*/ #undef DEBUG_RTC diff --git a/rtc/m41t11.c b/rtc/m41t11.c index c725cc9..1f87aef 100644 --- a/rtc/m41t11.c +++ b/rtc/m41t11.c @@ -43,7 +43,7 @@ #endif */
-#if defined(CONFIG_RTC_M41T11) && defined(CFG_I2C_RTC_ADDR) && (CONFIG_COMMANDS & CFG_CMD_DATE) +#if defined(CONFIG_RTC_M41T11) && defined(CFG_I2C_RTC_ADDR) && ((CONFIG_COMMANDS & CFG_CMD_DATE) || defined(CONFIG_CMD_DATE))
static unsigned bcd2bin (uchar n) { diff --git a/rtc/m48t35ax.c b/rtc/m48t35ax.c index 6c38a53..f22405b 100644 --- a/rtc/m48t35ax.c +++ b/rtc/m48t35ax.c @@ -33,7 +33,7 @@ #include <rtc.h> #include <config.h>
-#if defined(CONFIG_RTC_M48T35A) && (CONFIG_COMMANDS & CFG_CMD_DATE) +#if defined(CONFIG_RTC_M48T35A) && ((CONFIG_COMMANDS & CFG_CMD_DATE) || defined(CONFIG_CMD_DATE))
static uchar rtc_read (uchar reg); static void rtc_write (uchar reg, uchar val); diff --git a/rtc/max6900.c b/rtc/max6900.c index 73919cd..8bf23d5 100644 --- a/rtc/max6900.c +++ b/rtc/max6900.c @@ -32,7 +32,7 @@ #include <rtc.h> #include <i2c.h>
-#if defined(CONFIG_RTC_MAX6900) && (CONFIG_COMMANDS & CFG_CMD_DATE) +#if defined(CONFIG_RTC_MAX6900) && ((CONFIG_COMMANDS & CFG_CMD_DATE) || defined(CONFIG_CMD_DATE))
#ifndef CFG_I2C_RTC_ADDR #define CFG_I2C_RTC_ADDR 0x50 diff --git a/rtc/mc146818.c b/rtc/mc146818.c index 20b1b3e..3a29d06 100644 --- a/rtc/mc146818.c +++ b/rtc/mc146818.c @@ -31,7 +31,7 @@ #include <command.h> #include <rtc.h>
-#if defined(CONFIG_RTC_MC146818) && (CONFIG_COMMANDS & CFG_CMD_DATE) +#if defined(CONFIG_RTC_MC146818) && ((CONFIG_COMMANDS & CFG_CMD_DATE) || defined(CONFIG_CMD_DATE))
static uchar rtc_read (uchar reg); static void rtc_write (uchar reg, uchar val); diff --git a/rtc/mk48t59.c b/rtc/mk48t59.c index 64f751f..3987e27 100644 --- a/rtc/mk48t59.c +++ b/rtc/mk48t59.c @@ -131,7 +131,7 @@ void nvram_write(short dest, const void *src, size_t count) rtc_write(d++, *s++); }
-#if (CONFIG_COMMANDS & CFG_CMD_DATE) +#if (CONFIG_COMMANDS & CFG_CMD_DATE) || defined(CONFIG_CMD_DATE)
diff --git a/rtc/mpc5xxx.c b/rtc/mpc5xxx.c index 2053df1..7195af0 100644 --- a/rtc/mpc5xxx.c +++ b/rtc/mpc5xxx.c @@ -32,7 +32,7 @@ #include <command.h> #include <rtc.h>
-#if defined(CONFIG_RTC_MPC5200) && (CONFIG_COMMANDS & CFG_CMD_DATE) +#if defined(CONFIG_RTC_MPC5200) && ((CONFIG_COMMANDS & CFG_CMD_DATE) || defined(CONFIG_CMD_DATE))
/***************************************************************************** * this structure should be defined in mpc5200.h ... diff --git a/rtc/mpc8xx.c b/rtc/mpc8xx.c index 830e56e..33f867a 100644 --- a/rtc/mpc8xx.c +++ b/rtc/mpc8xx.c @@ -31,7 +31,7 @@ #include <command.h> #include <rtc.h>
-#if defined(CONFIG_RTC_MPC8xx) && (CONFIG_COMMANDS & CFG_CMD_DATE) +#if defined(CONFIG_RTC_MPC8xx) && ((CONFIG_COMMANDS & CFG_CMD_DATE) || defined(CONFIG_CMD_DATE))
diff --git a/rtc/pcf8563.c b/rtc/pcf8563.c index 05ae97e..1dacaa3 100644 --- a/rtc/pcf8563.c +++ b/rtc/pcf8563.c @@ -32,7 +32,7 @@ #include <rtc.h> #include <i2c.h>
-#if defined(CONFIG_RTC_PCF8563) && (CONFIG_COMMANDS & CFG_CMD_DATE) +#if defined(CONFIG_RTC_PCF8563) && ((CONFIG_COMMANDS & CFG_CMD_DATE) || defined(CONFIG_CMD_DATE))
static uchar rtc_read (uchar reg); static void rtc_write (uchar reg, uchar val); diff --git a/rtc/rs5c372.c b/rtc/rs5c372.c index b56808b..6e11710 100644 --- a/rtc/rs5c372.c +++ b/rtc/rs5c372.c @@ -34,7 +34,7 @@ #include <rtc.h> #include <i2c.h>
-#if defined(CONFIG_RTC_RS5C372A) && (CONFIG_COMMANDS & CFG_CMD_DATE) +#if defined(CONFIG_RTC_RS5C372A) && ((CONFIG_COMMANDS & CFG_CMD_DATE) || defined(CONFIG_CMD_DATE)) /* * Reads are always done starting with register 15, which requires some * jumping-through-hoops to access the data correctly. diff --git a/rtc/s3c24x0_rtc.c b/rtc/s3c24x0_rtc.c index 9e2191e..0b0b160 100644 --- a/rtc/s3c24x0_rtc.c +++ b/rtc/s3c24x0_rtc.c @@ -28,7 +28,7 @@ #include <common.h> #include <command.h>
-#if defined(CONFIG_RTC_S3C24X0) && (CONFIG_COMMANDS & CFG_CMD_DATE) +#if defined(CONFIG_RTC_S3C24X0) && ((CONFIG_COMMANDS & CFG_CMD_DATE) || defined(CONFIG_CMD_DATE))
#if defined(CONFIG_S3C2400) #include <s3c2400.h>
Jon Loeliger
