[U-Boot] [PATCH 1/1] net: phy/vitesse: Add support for VSC8514 phy module
This patch adds support for VSC8514 PHY module which can be found on Freescale's T1040RDB boards.
Signed-off-by: Arpit Goel B44344@freescale.com Signed-off-by: Bhupesh Sharma bhupesh.sharma@freescale.com --- drivers/net/phy/vitesse.c | 69 ++++++++++++++++++++++++++++++++++++++++++++++- 1 file changed, 68 insertions(+), 1 deletion(-)
diff --git a/drivers/net/phy/vitesse.c b/drivers/net/phy/vitesse.c index 5cf103e..c555979 100644 --- a/drivers/net/phy/vitesse.c +++ b/drivers/net/phy/vitesse.c @@ -49,6 +49,15 @@ #define MIIM_VSC8574_18G_QSGMII 0x80e0 #define MIIM_VSC8574_18G_CMDSTAT 0x8000
+/* Vitesse VSC8514 control register */ +#define MIIM_VSC8514_GENERAL18 0x12 +#define MIIM_VSC8514_GENERAL19 0x13 +#define MIIM_VSC8514_GENERAL23 0x17 + +/* Vitesse VSC8514 gerenal purpose register 18 */ +#define MIIM_VSC8514_18G_QSGMII 0x80e0 +#define MIIM_VSC8514_18G_CMDSTAT 0x8000 + /* CIS8201 */ static int vitesse_config(struct phy_device *phydev) { @@ -148,7 +157,7 @@ static int vsc8601_config(struct phy_device *phydev) static int vsc8574_config(struct phy_device *phydev) { u32 val; - /* configure regiser 19G for MAC */ + /* configure register 19G for MAC */ phy_write(phydev, MDIO_DEVAD_NONE, PHY_EXT_PAGE_ACCESS, PHY_EXT_PAGE_ACCESS_GENERAL);
@@ -188,6 +197,53 @@ static int vsc8574_config(struct phy_device *phydev) return 0; }
+static int vsc8514_config(struct phy_device *phydev) +{ + u32 val; + int timeout = 1000000; + + /* configure register to access 19G */ + phy_write(phydev, MDIO_DEVAD_NONE, PHY_EXT_PAGE_ACCESS, + PHY_EXT_PAGE_ACCESS_GENERAL); + + val = phy_read(phydev, MDIO_DEVAD_NONE, MIIM_VSC8514_GENERAL19); + if (phydev->interface == PHY_INTERFACE_MODE_QSGMII) { + /* set bit 15:14 to '01' for QSGMII mode */ + val = (val & 0x3fff) | (1 << 14); + phy_write(phydev, MDIO_DEVAD_NONE, + MIIM_VSC8514_GENERAL19, val); + /* Enable 4 ports MAC QSGMII */ + phy_write(phydev, MDIO_DEVAD_NONE, MIIM_VSC8514_GENERAL18, + MIIM_VSC8514_18G_QSGMII); + } else { + /*TODO Add SGMII functionality once spec sheet + * for VSC8514 defines complete functionality + */ + } + + val = phy_read(phydev, MDIO_DEVAD_NONE, MIIM_VSC8514_GENERAL18); + /* When bit 15 is cleared the command has completed */ + while ((val & MIIM_VSC8514_18G_CMDSTAT) && timeout--) + val = phy_read(phydev, MDIO_DEVAD_NONE, MIIM_VSC8514_GENERAL18); + + if (0 == timeout) { + printf("PHY 8514 config failed\n"); + return -1; + } + + phy_write(phydev, MDIO_DEVAD_NONE, PHY_EXT_PAGE_ACCESS, 0); + + /* configure register to access 23 */ + val = phy_read(phydev, MDIO_DEVAD_NONE, MIIM_VSC8514_GENERAL23); + /* set bits 10:8 to '000' */ + val = (val & 0xf8ff); + phy_write(phydev, MDIO_DEVAD_NONE, MIIM_VSC8514_GENERAL23, val); + + genphy_config_aneg(phydev); + + return 0; +} + static struct phy_driver VSC8211_driver = { .name = "Vitesse VSC8211", .uid = 0xfc4b0, @@ -238,6 +294,16 @@ static struct phy_driver VSC8574_driver = { .shutdown = &genphy_shutdown, };
+static struct phy_driver VSC8514_driver = { + .name = "Vitesse VSC8514", + .uid = 0x70570, + .mask = 0xffff0, + .features = PHY_GBIT_FEATURES, + .config = &vsc8514_config, + .startup = &vitesse_startup, + .shutdown = &genphy_shutdown, +}; + static struct phy_driver VSC8601_driver = { .name = "Vitesse VSC8601", .uid = 0x70420, @@ -298,6 +364,7 @@ int phy_vitesse_init(void) phy_register(&VSC8211_driver); phy_register(&VSC8221_driver); phy_register(&VSC8574_driver); + phy_register(&VSC8514_driver); phy_register(&VSC8662_driver); phy_register(&cis8201_driver); phy_register(&cis8204_driver);
Hi Joe, List
-----Original Message----- From: Sharma Bhupesh-B45370 Sent: Friday, August 23, 2013 8:18 PM To: u-boot@lists.denx.de; joe.hershberger@gmail.com Cc: Goel Arpit-B44344; Sharma Bhupesh-B45370 Subject: [PATCH 1/1] net: phy/vitesse: Add support for VSC8514 phy module
- /* configure register 19G for MAC */ phy_write(phydev, MDIO_DEVAD_NONE, PHY_EXT_PAGE_ACCESS, PHY_EXT_PAGE_ACCESS_GENERAL);
+static int vsc8514_config(struct phy_device *phydev) {
- u32 val;
- int timeout = 1000000;
- /* configure register to access 19G */
- phy_write(phydev, MDIO_DEVAD_NONE, PHY_EXT_PAGE_ACCESS,
- val = phy_read(phydev, MDIO_DEVAD_NONE, MIIM_VSC8514_GENERAL19);
- if (phydev->interface == PHY_INTERFACE_MODE_QSGMII) {
- } else {
- val = phy_read(phydev, MDIO_DEVAD_NONE, MIIM_VSC8514_GENERAL18);
- /* When bit 15 is cleared the command has completed */
- while ((val & MIIM_VSC8514_18G_CMDSTAT) && timeout--)
- if (0 == timeout) {
return -1;
- phy_write(phydev, MDIO_DEVAD_NONE, PHY_EXT_PAGE_ACCESS, 0);
- /* configure register to access 23 */
- val = phy_read(phydev, MDIO_DEVAD_NONE, MIIM_VSC8514_GENERAL23);
- /* set bits 10:8 to '000' */
- val = (val & 0xf8ff);
- phy_write(phydev, MDIO_DEVAD_NONE, MIIM_VSC8514_GENERAL23, val);
- genphy_config_aneg(phydev);
- .name = "Vitesse VSC8514",
- .uid = 0x70570,
- .mask = 0xffff0,
- .features = PHY_GBIT_FEATURES,
- .config = &vsc8514_config,
- .startup = &vitesse_startup,
- .shutdown = &genphy_shutdown,
- phy_register(&VSC8514_driver); phy_register(&VSC8662_driver); phy_register(&cis8201_driver); phy_register(&cis8204_driver);
-- 1.7.11.7
Any comments on this patch? Does it seem fine and can be taken up in Joe's 'net' repo?
Thanks, Bhupesh
Bhupesh Sharma
