Pull request: u-boot-sunxi/master for v2023.07
Hi Tom,
please pull the sunxi/master branch, containing the first part of the 2023.07 changes.
The biggest change is some refactoring of the H616 DRAM driver, which allows better fine-tuning for each board, and is the base for pending LPDDR3 and LPDDR4 support, needed by new boards. The sun8i-emac Ethernet driver sees some refactoring that enables it for the Allwinner D1 EMAC IP. The sunxi HDMI driver is now using more DT properties. Also the early SPL code now supports some odd H616 SoC variant.
There are some more patches pending, that require the final review touches and some testing, I will send a separate PR for them later.
The gitlab CI completed successfully, and I boot tested a few boards with different SoCs, via FEL and SD card, into Linux.
Thanks, Andre
=========================== The following changes since commit 9e804638bfe2693a908abf066ff66c251572afa7:
Merge tag 'for-v2023-07-rc1' of https://source.denx.de/u-boot/custodians/u-boot-i2c (2023-04-11 09:29:28 -0400)
https://source.denx.de/u-boot/custodians/u-boot-sunxi.git master
for you to fetch changes up to 5fc892e83f34a0b082ff46d3cc411d6813c1f726:
sunxi: A64: drop boot0 header reservation (2023-04-12 00:17:22 +0100)
---------------------------------------------------------------- Andre Przywara (3): sunxi: boot0.h: allow RVBAR MMIO address customisation sunxi: arm64: boot0.h: runtime check for RVBAR address sunxi: A64: drop boot0 header reservation
Jernej Skrabec (10): sunxi: Fix write to H616 DRAM CR register sunxi: cosmetic: Fix H616 DRAM driver code style sunxi: parameterize H616 DRAM ODT values sunxi: Convert H616 DRAM options to single setting sunxi: Always configure ODT on H616 DRAM sunxi: Make bit delay function in H616 DRAM code void sunxi: Parameterize bit delay code in H616 DRAM driver sunxi: Parameterize "unknown feature" in H616 DRAM driver sunxi: Parameterize some of H616 DDR3 timings sunxi: Add TPR2 parameter for H616 DRAM driver
Samuel Holland (8): video: sunxi: dw-hdmi: Use DM for clock gates and resets video: sunxi: dw-hdmi: Use DM for HVCC regulator net: sun8i-emac: Add a structure for variant data net: sun8i-emac: Add a flag for RMII support net: sun8i-emac: Add a flag for the internal PHY switch net: sun8i-emac: Use common syscon setup for R40 net: sun8i-emac: Remove the SoC variant ID ARM: dts: sun6i: mixtile-loftq: Add USB1 VBUS regulator
arch/arm/dts/sun6i-a31-mixtile-loftq.dts | 17 + arch/arm/include/asm/arch-sunxi/boot0.h | 21 +- arch/arm/include/asm/arch-sunxi/dram_sun50i_h616.h | 17 + arch/arm/mach-sunxi/Kconfig | 99 ++-- arch/arm/mach-sunxi/dram_sun50i_h616.c | 508 ++++++++++++++------- arch/arm/mach-sunxi/dram_timings/h616_ddr3_1333.c | 20 +- configs/a64-olinuxino-emmc_defconfig | 1 - configs/a64-olinuxino_defconfig | 1 - configs/amarula_a64_relic_defconfig | 1 - configs/bananapi_m64_defconfig | 1 - configs/nanopi_a64_defconfig | 1 - configs/oceanic_5205_5inmfd_defconfig | 1 - configs/orangepi_win_defconfig | 1 - configs/orangepi_zero2_defconfig | 8 +- configs/pine64_plus_defconfig | 1 - configs/sopine_baseboard_defconfig | 1 - configs/x96_mate_defconfig | 7 + drivers/net/sun8i_emac.c | 96 ++-- drivers/video/sunxi/sunxi_dw_hdmi.c | 36 +- 19 files changed, 564 insertions(+), 274 deletions(-)
On Thu, Apr 13, 2023 at 11:20:48AM +0100, Andre Przywara wrote:
Hi Tom,
Thanks, Andre
Andre Przywara
