[PATCH] env: do not fail on non-existing env.in file
If include/generated/env.in does not exist, which is a typical case for clean build, quiet_cmd_gen_envp command tries to delete this file unconditionally.
This produces following warning during the build: ENVP include/generated/env.in rm: cannot remove 'include/generated/env.in': No such file or directory
Add '-f' option to the `rm` command to not complain if file does not exist.
Fixes: f432eb6d8a9d ("env: Avoid using a leftover text-environment file") Signed-off-by: Andrey Zhizhikin andrey.zhizhikin@leica-geosystems.com --- Makefile | 2 +- 1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/Makefile b/Makefile index 4672147318..868445bf33 100644 --- a/Makefile +++ b/Makefile @@ -1846,7 +1846,7 @@ quiet_cmd_gen_envp = ENVP $@ -I$(srctree)/arch/$(ARCH)/include \ $< -o $@; \ else \ - rm $@; \ + rm -f $@; \ touch $@ ; \ fi include/generated/env.in: include/generated/env.txt FORCE
Fixes: f432eb6d8a9d ("env: Avoid using a leftover text-environment file") Signed-off-by: Andrey Zhizhikin andrey.zhizhikin@leica-geosystems.com Reviewed-by: Sean Anderson seanga2@gmail.com
Andrey Zhizhikin
