[U-Boot] [PATCH] zynqmp: Add generic target
I would like to create a generic U-Boot build that adapts itself completely based on the DT passed in. That way we can potentially support running random board configurations with a single U-Boot binary built as part of the distribution.
Currently a few things are still missing to make it a full reality. The most obvious one I think is the EEPROM location. This would need to also move into something described by DT.
Apart from that, we're almost there. This patch adds a defconfig that simply contains all drivers we could make use of. We can then enable individual boards along the way and slowly adapt everything to be fully DT described while we identify each missing bit.
Signed-off-by: Alexander Graf agraf@suse.de --- configs/xilinx_zynqmp_generic_defconfig | 97 +++++++++++++++++++++++++++++++++ include/configs/xilinx_zynqmp_generic.h | 23 ++++++++ 2 files changed, 120 insertions(+) create mode 100644 configs/xilinx_zynqmp_generic_defconfig create mode 100644 include/configs/xilinx_zynqmp_generic.h
diff --git a/configs/xilinx_zynqmp_generic_defconfig b/configs/xilinx_zynqmp_generic_defconfig new file mode 100644 index 0000000000..afbf6ad0af --- /dev/null +++ b/configs/xilinx_zynqmp_generic_defconfig @@ -0,0 +1,97 @@ +CONFIG_ARM=y +CONFIG_SYS_CONFIG_NAME="xilinx_zynqmp_generic" +CONFIG_ARCH_ZYNQMP=y +CONFIG_SYS_TEXT_BASE=0x8000000 +CONFIG_SYS_MALLOC_F_LEN=0x8000 +CONFIG_IDENT_STRING=" Xilinx ZynqMP based platform" +CONFIG_DEFAULT_DEVICE_TREE="zynqmp-mini-emmc" +CONFIG_ZYNQMP_USB=y +CONFIG_DEBUG_UART=y +CONFIG_AHCI=y +CONFIG_DISTRO_DEFAULTS=y +CONFIG_FIT=y +CONFIG_FIT_VERBOSE=y +CONFIG_SPL_LOAD_FIT=y +# CONFIG_DISPLAY_CPUINFO is not set +# CONFIG_DISPLAY_BOARDINFO is not set +CONFIG_BOARD_EARLY_INIT_R=y +CONFIG_SPL_OS_BOOT=y +CONFIG_SPL_RAM_SUPPORT=y +CONFIG_SPL_RAM_DEVICE=y +CONFIG_SPL_ATF=y +CONFIG_SYS_PROMPT="ZynqMP> " +CONFIG_FASTBOOT=y +CONFIG_FASTBOOT_FLASH=y +CONFIG_FASTBOOT_FLASH_MMC_DEV=0 +CONFIG_CMD_THOR_DOWNLOAD=y +CONFIG_CMD_MEMTEST=y +CONFIG_SYS_ALT_MEMTEST=y +CONFIG_CMD_CLK=y +CONFIG_CMD_DFU=y +# CONFIG_CMD_FLASH is not set +CONFIG_CMD_FPGA_LOADBP=y +CONFIG_CMD_FPGA_LOADP=y +CONFIG_CMD_GPIO=y +CONFIG_CMD_GPT=y +CONFIG_CMD_I2C=y +CONFIG_CMD_MMC=y +CONFIG_CMD_USB=y +CONFIG_CMD_TFTPPUT=y +CONFIG_CMD_TIME=y +CONFIG_CMD_TIMER=y +CONFIG_CMD_EXT4_WRITE=y +CONFIG_SPL_OF_CONTROL=y +CONFIG_OF_BOARD=y +CONFIG_ENV_IS_IN_FAT=y +CONFIG_NET_RANDOM_ETHADDR=y +CONFIG_SPL_DM=y +CONFIG_SPL_DM_SEQ_ALIAS=y +CONFIG_SCSI_AHCI=y +CONFIG_SATA_CEVA=y +CONFIG_CLK_ZYNQMP=y +CONFIG_DFU_RAM=y +CONFIG_FPGA_XILINX=y +CONFIG_FPGA_ZYNQMPPL=y +CONFIG_DM_GPIO=y +CONFIG_CMD_PCA953X=y +CONFIG_SYS_I2C_ZYNQ=y +CONFIG_ZYNQ_I2C0=y +CONFIG_ZYNQ_I2C1=y +CONFIG_MISC=y +CONFIG_DM_MMC=y +CONFIG_MMC_SDHCI=y +CONFIG_MMC_SDHCI_ZYNQ=y +CONFIG_SPI_FLASH=y +CONFIG_SPI_FLASH_BAR=y +CONFIG_SPI_FLASH_MACRONIX=y +CONFIG_SPI_FLASH_SPANSION=y +CONFIG_SPI_FLASH_STMICRO=y +CONFIG_SPI_FLASH_WINBOND=y +# CONFIG_SPI_FLASH_USE_4K_SECTORS is not set +CONFIG_PHY_MARVELL=y +CONFIG_PHY_NATSEMI=y +CONFIG_PHY_REALTEK=y +CONFIG_PHY_TI=y +CONFIG_PHY_VITESSE=y +CONFIG_PHY_FIXED=y +CONFIG_DM_ETH=y +CONFIG_PHY_GIGE=y +CONFIG_ZYNQ_GEM=y +CONFIG_SCSI=y +CONFIG_DM_SCSI=y +CONFIG_ZYNQ_SERIAL=y +CONFIG_USB=y +CONFIG_USB_XHCI_HCD=y +CONFIG_USB_XHCI_DWC3=y +CONFIG_USB_XHCI_ZYNQMP=y +CONFIG_USB_DWC3=y +CONFIG_USB_DWC3_GADGET=y +CONFIG_USB_ULPI_VIEWPORT=y +CONFIG_USB_ULPI=y +CONFIG_USB_STORAGE=y +CONFIG_USB_GADGET=y +CONFIG_USB_GADGET_MANUFACTURER="Xilinx" +CONFIG_USB_GADGET_VENDOR_NUM=0x03FD +CONFIG_USB_GADGET_PRODUCT_NUM=0x0300 +CONFIG_USB_FUNCTION_THOR=y +CONFIG_EFI_LOADER_BOUNCE_BUFFER=y diff --git a/include/configs/xilinx_zynqmp_generic.h b/include/configs/xilinx_zynqmp_generic.h new file mode 100644 index 0000000000..56bd5bd6f1 --- /dev/null +++ b/include/configs/xilinx_zynqmp_generic.h @@ -0,0 +1,23 @@ +/* + * Configuration for the Xilinx ZynqMP generic platform + * + * (C) Copyright 2018 Alexander Graf agraf@suse.de + * (C) Copyright 2015 Xilinx, Inc. + * Michal Simek michal.simek@xilinx.com + * + * SPDX-License-Identifier: GPL-2.0+ + */ + +#ifndef __CONFIG_ZYNQMP_GENERIC_H +#define __CONFIG_ZYNQMP_GENERIC_H + +/* All of these should be enumerated using DT instead ... */ + +#define CONFIG_ZYNQ_SDHCI0 +#define CONFIG_ZYNQ_SDHCI1 + +#define CONFIG_ZYNQMP_XHCI_LIST {ZYNQMP_USB0_XHCI_BASEADDR} + +#include <configs/xilinx_zynqmp.h> + +#endif /* __CONFIG_ZYNQMP_GENERIC_H */
Alexander Graf
