[PATCH] tools: open FIT image for reading as O_RDONLY instead of O_RDWR
The only usage of the fd is for the single read() below; this prevented mkimage -f auto -A arm64 \ -T kernel -C lz4 -d Image-6.6.15.lz4 \ -b mt8173-elm-hana-6.6.15.dtb outf when the inputs were unwriteable.
Link: https://bugs.debian.org/1063097 Signed-off-by: Ahelenia Ziemiańska nabijaczleweli@nabijaczleweli.xyz --- tools/fit_image.c | 2 +- 1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/tools/fit_image.c b/tools/fit_image.c index beef1fa8..0fccfbb4 100644 --- a/tools/fit_image.c +++ b/tools/fit_image.c @@ -137,7 +137,7 @@ static int fdt_property_file(struct image_tool_params *params, int ret; int fd;
- fd = open(fname, O_RDWR | O_BINARY); + fd = open(fname, O_RDONLY | O_BINARY); if (fd < 0) { fprintf(stderr, "%s: Can't open %s: %s\n", params->cmdname, fname, strerror(errno));
Hello Ahelenia,
Please see my comments below.
s/unwriteable/unwritable/
Also, the patch subject could be moved to the patch description, and the following could be used instead, as the subject:
tools: open FIT image read-only
Looking good to me. Opening the file read-only is also good from the standpoint of using least privilege to perform the required operation.
With the small nitpicks above,
Reviewed-by: Dragan Simic dsimic@manjaro.org
- fd = open(fname, O_RDONLY | O_BINARY); if (fd < 0) { fprintf(stderr, "%s: Can't open %s: %s\n", params->cmdname, fname, strerror(errno));
Open for reading as O_RDONLY instead of O_RDWR: the only usage of the fd is for the single read() below; this prevented mkimage -f auto -A arm64 \ -T kernel -C lz4 -d Image-6.6.15.lz4 \ -b mt8173-elm-hana-6.6.15.dtb outf when the inputs were unwritable.
Link: https://bugs.debian.org/1063097 Signed-off-by: Ahelenia Ziemiańska nabijaczleweli@nabijaczleweli.xyz Reviewed-by: Dragan Simic dsimic@manjaro.org --- tools/fit_image.c | 2 +- 1 file changed, 1 insertion(+), 1 deletion(-)
Hello all,
Just a brief reminder about merging this patch. It looks fine to me.
Ahelenia Ziemiańska
Dragan Simic
