[U-Boot] pull request for u-boot-tegra/master
Albert,
Please pull u-boot-tegra/master into arm master. Thanks!
The following changes since commit 4a3ea216414ad762b3718775a65437c13f0accbc:
ARM: highbank: setup env from boot source register (2012-03-28 23:34:27 +0200)
are available in the git repository at: git://git.denx.de/u-boot-tegra master
Simon Glass (32): fdt: Add fdtdec_find_aliases() to deal with alias nodes fdt: Add tests for fdtdec fdt: Tidy up a few fdtdec problems fdt: Add functions to access phandles, arrays and bools fdt: Add basic support for decoding GPIO definitions arm: fdt: Add skeleton device tree file from kernel tegra: fdt: Add Tegra2x device tree file from kernel tegra: fdt: Add device tree file for Tegra2 Seaboard from kernel fdt: Add staging area for device tree binding documentation fdt: Add tegra-usb bindings file from linux tegra: fdt: Add additional USB binding tegra: fdt: Add clock bindings tegra: fdt: Add clock bindings for Tegra2 Seaboard tegra: usb: fdt: Add additional device tree definitions for USB ports tegra: usb: fdt: Add USB definitions for Tegra2 Seaboard usb: Add support for txfifo threshold tegra: fdt: Add function to return peripheral/clock ID tegra: usb: Add support for Tegra USB peripheral fdt: Avoid early panic() when there is no FDT present arm: Check for valid FDT after console is up tegra: usb: Add USB support to nvidia boards tegra: usb: Add common USB defines for tegra2 boards tegra: usb: Enable USB on Seaboard tegra: fdt: Enable FDT support for Seaboard tegra: Rename NV_PA_PMC_BASE to TEGRA2_PMC_BASE fdt: Add function to allow aliases to refer to multiple nodes tegra: Enhance clock support to handle 16-bit clock divisors tegra: i2c: Initialise I2C on Nvidia boards tegra: i2c: Select number of controllers for Tegra2 boards tegra: i2c: Enable I2C on Seaboard tegra: i2c: Select I2C ordering for Seaboard tegra: fdt: i2c: Add extra I2C bindings for U-Boot
Tom Warren (2): arm: Tegra2: Fix ELDK42 gcc failure with inline asm stack pointer load tegra: fdt: Enable FDT support for Ventana
Yen Lin (1): tegra: i2c: Add I2C driver
README | 3 + arch/arm/cpu/armv7/tegra2/Makefile | 4 +- arch/arm/cpu/armv7/tegra2/ap20.c | 20 +- arch/arm/cpu/armv7/tegra2/board.c | 2 +- arch/arm/cpu/armv7/tegra2/clock.c | 121 ++++- arch/arm/cpu/armv7/tegra2/config.mk | 2 + arch/arm/cpu/armv7/tegra2/usb.c | 460 ++++++++++++++++ arch/arm/dts/skeleton.dtsi | 13 + arch/arm/dts/tegra20.dtsi | 196 +++++++ arch/arm/include/asm/arch-tegra2/clk_rst.h | 10 +- arch/arm/include/asm/arch-tegra2/clock.h | 13 + arch/arm/include/asm/arch-tegra2/tegra2.h | 6 +- arch/arm/include/asm/arch-tegra2/tegra_i2c.h | 157 ++++++ arch/arm/include/asm/arch-tegra2/usb.h | 252 +++++++++ arch/arm/lib/board.c | 8 + board/nvidia/common/board.c | 19 + board/nvidia/common/board.h | 6 + board/nvidia/dts/tegra2-seaboard.dts | 92 ++++ board/nvidia/seaboard/seaboard.c | 6 + doc/device-tree-bindings/README | 17 + .../clock/nvidia,tegra20-car.txt | 207 +++++++ doc/device-tree-bindings/i2c/tegra20-i2c.txt | 23 + doc/device-tree-bindings/usb/tegra-usb.txt | 25 + drivers/i2c/Makefile | 1 + drivers/i2c/tegra_i2c.c | 569 ++++++++++++++++++++ drivers/usb/host/Makefile | 1 + drivers/usb/host/ehci-hcd.c | 7 + drivers/usb/host/ehci-tegra.c | 62 +++ drivers/usb/host/ehci.h | 6 +- include/configs/seaboard.h | 20 + include/configs/tegra2-common.h | 13 + include/configs/ventana.h | 5 + include/fdtdec.h | 197 +++++++- lib/Makefile | 1 + lib/fdtdec.c | 323 +++++++++++- lib/fdtdec_test.c | 226 ++++++++ 36 files changed, 3038 insertions(+), 55 deletions(-) create mode 100644 arch/arm/cpu/armv7/tegra2/usb.c create mode 100644 arch/arm/dts/skeleton.dtsi create mode 100644 arch/arm/dts/tegra20.dtsi create mode 100644 arch/arm/include/asm/arch-tegra2/tegra_i2c.h create mode 100644 arch/arm/include/asm/arch-tegra2/usb.h create mode 100644 board/nvidia/dts/tegra2-seaboard.dts create mode 100644 doc/device-tree-bindings/README create mode 100644 doc/device-tree-bindings/clock/nvidia,tegra20-car.txt create mode 100644 doc/device-tree-bindings/i2c/tegra20-i2c.txt create mode 100644 doc/device-tree-bindings/usb/tegra-usb.txt create mode 100644 drivers/i2c/tegra_i2c.c create mode 100644 drivers/usb/host/ehci-tegra.c create mode 100644 lib/fdtdec_test.c
nvpublic
Hi Tom,
Le 28/03/2012 23:48, Tom Warren a écrit :
Albert,
Applied to u-boot-arm/master, thanks!
Amicalement,
Albert ARIBAUD
Tom Warren
