[PATCH] efi_loader: file: set a backend block device for file operations
In the current implementation, set_blk_dev() is called in opening a file, but not in opening a directory. This will cause failures at succeeding directory operations as the "current" block device remains nullified. Adding set_blk_dev() fixes this issue.
Signed-off-by: AKASHI Takahiro takahiro.akashi@linaro.org --- lib/efi_loader/efi_file.c | 3 +++ 1 file changed, 3 insertions(+)
diff --git a/lib/efi_loader/efi_file.c b/lib/efi_loader/efi_file.c index 140116ddc4ac..ba55b2829e03 100644 --- a/lib/efi_loader/efi_file.c +++ b/lib/efi_loader/efi_file.c @@ -235,6 +235,9 @@ static struct efi_file_handle *file_open(struct file_system *fs, } else { fh->isdir = 1; strcpy(fh->path, ""); + + if (set_blk_dev(fh)) + goto error; }
return &fh->base;
goto error;
In the 'true' path of the if statement is_dir() results in fs_type = FS_TYPE_ANY. It would be inconsistent to call set_blk_dev() here.
Which "succeeding directory operation" does not call set_blk_dev(fh)?
Where did you observe an error?
Best regards
Heinrich
return &fh->base;
goto error;
Ah, it would be better to fix my code as I had a mixed use of efi interface, open_volume(), and U-Boot interfaces, like fs_opendir()/ readdir().
Thanks, -Takahiro Akashi
Best regards
Heinrich
return &fh->base;
AKASHI Takahiro
