[PATCH 0/2] DSA switch fixes
This small patch set contains some bug fixes. The first is for the recently introduced ->port_probe() DSA switch method, and the second is for the recently introduced SJA1105 driver.
Vladimir Oltean (2): net: dsa: fix phydev->speed being uninitialized for the CPU port fixed PHY net: dsa: sja1105: fix device id detection
drivers/net/sja1105.c | 6 ------ net/dsa-uclass.c | 11 +++++++++++ 2 files changed, 11 insertions(+), 6 deletions(-)
If the DSA API is going to allow drivers to do things such as:
- phy_config in dsa_ops :: port_probe - phy_startup in dsa_ops :: port_enable
then it would actually be good if the ->port_probe() method would actually be called in all cases before the ->port_enable() is.
Currently this is true for user ports, but not true for the CPU port, because the CPU port does not have a udevice registered for it (this is all part of DSA's design). So the current issue is that after phy_startup has finished for the CPU port, its phydev->speed is an uninitialized value, because phy_config() was never called for the priv->cpu_port_fixed_phy, and it is precisely phy_config() who copies the speed into the phydev in the case of the fixed PHY driver.
So we need to simulate a probing event for the CPU port by manually calling the driver's ->port_probe() method for the CPU port.
Fixes: 8a2982574854 ("net: dsa: introduce a .port_probe() method in struct dsa_ops") Signed-off-by: Vladimir Oltean vladimir.oltean@nxp.com --- net/dsa-uclass.c | 11 +++++++++++ 1 file changed, 11 insertions(+)
diff --git a/net/dsa-uclass.c b/net/dsa-uclass.c index 606b1539a776..9ff55a02fb23 100644 --- a/net/dsa-uclass.c +++ b/net/dsa-uclass.c @@ -466,6 +466,8 @@ static int dsa_pre_probe(struct udevice *dev) { struct dsa_pdata *pdata = dev_get_uclass_plat(dev); struct dsa_priv *priv = dev_get_uclass_priv(dev); + struct dsa_ops *ops = dsa_get_ops(dev); + int err;
priv->num_ports = pdata->num_ports; priv->cpu_port = pdata->cpu_port; @@ -477,6 +479,15 @@ static int dsa_pre_probe(struct udevice *dev)
uclass_find_device_by_ofnode(UCLASS_ETH, pdata->master_node, &priv->master_dev); + + /* Simulate a probing event for the CPU port */ + if (ops->port_probe) { + err = ops->port_probe(dev, priv->cpu_port, + priv->cpu_port_fixed_phy); + if (err) + return err; + } + return 0; }
On Sun, Dec 5, 2021 at 1:01 AM Vladimir Oltean vladimir.oltean@nxp.com wrote:
int err; priv->num_ports = pdata->num_ports; priv->cpu_port = pdata->cpu_port;
if (err)
return err;
-- 2.25.1
Reviewed-by: Ramon Fried rfried.dev@gmail.com
if (err)
return err;
-- 2.25.1
Applied to u-boot-net/next, Thanks !
On Sat, Dec 4, 2021 at 3:01 PM Vladimir Oltean vladimir.oltean@nxp.com wrote:
if (err)
return err;
-- 2.25.1
Vladimir,
I came across this while looking for the best place to configure cpu port interface mode (ie rgmii id) for the mv88e61xx dsa driver I'm working on. Note that this patch causes port_probe to be called on the cpu port 'before' the master device has been probed. I'm not sure if this is intended or not?
In my case I was looking to configure the cpu port interface mode when the port was probed but I can't do that because it happens before the switch is probed because of some things that need to happen there. Best Regards,
Tim
Hi Tim,
On Fri, Mar 25, 2022 at 09:53:20AM -0700, Tim Harvey wrote:
Vladimir,
Tim
You're past the DM_MDIO probing issues now? Glad to hear that. Probing the DSA CPU port before the master wasn't necessarily the intention, but then again, I'm not sure that there's a strict ordering guarantee between the two that needs to be satisfied?
What do you need exactly? We could probably always reverse the device_probe(master) call with the probing of the CPU port if the ordering turns out to be a real problem. I can regression-test the change on my boards, but I'd like to understand the need you have, maybe even document it so that future changes are aware of it.
On Fri, Mar 25, 2022 at 11:07 AM Vladimir Oltean vladimir.oltean@nxp.com wrote:
Hi Tim,
Vladimir,
Tim
Yes, I've got the mdio probing working now. The mv88e61xx driver supports several chips that have different register offsets that need to be known before indirect read/write and port read/write can be used. That detection happens early on so I have it in the dsa_probe. I would prefer to configure the cpu port interface mode (mac mode, link speed/duplex etc) once instead of doing it every time the cpu port gets enabled so I want to put that in the dsa_probe but at that time I don't have the phy_device to determine interface mode (I suppose I could get it from dt?). I noticed dsa_class calls ops->port_probe for the cpu port early so that seemed like a great place to do all that, but then I found my switch dsa_probe hadn't been called yet so I haven't identified the switch and set the register offsets yet.
I have worked around the fact that the port_probe is called for the cpu port before the switch is probed I just wasn't sure if something in this patch should be changed in case others fall into this trap in the future. dsa_port_probe probes the master before calling ops->port_probe with the comment 'We depend on the master device for proper operation' so I just figured the same should be done for the pre_probe.
I hope to send a series in the next few days but I do have a few items I still need to fix:
1. my board currently uses the mv88e61xx_hw_reset weak override to configure LEDs, GPIO's using direct register writes as I need one of the GPIO's to be configured as a 125MHz RGMII_RCLK and configure MAC interface mode(rgmii delays). I've moved the mac interface config into the driver based on the dt props (phy-mode and fixed-link subnode) but am still not sure how to go about dealing with the 'very custom' LED and GPIO config without the hassle of defining new dt bindings. I was hoping to use board_phy_config() but when that is called for the switch the phy_id is a generic PHY_FIXED_ID and when called for the ports the phydev->bus uses indirect register writes which can't be used to configure the gpios. 2. While my switch mdio bus is probing now as well as my fec_dm_mdio bus I'm not clear how to properly get the struct mii_dev * associated with the fec_dm_mdio from the dsa switch. Currently I'm using miiphy_get_dev_by_name("mdio") which is horrible. How do I get the mii_bus or even the udevice of an dm_mdio bus associated with a dm_eth device?
Best Regards,
Tim
Hi Tim,
Vladimir,
Tim
Sorry, that was quite a blunder, we should definitely ensure that U_BOOT_DRIVER :: probe gets called before dsa_ops :: port_probe. I've made a change moving the port_probe call for the CPU port to dsa_post_probe(), tested it in the sandbox, and it appears to work.
- my board currently uses the mv88e61xx_hw_reset weak override to
How are these configs handled in Linux?
- While my switch mdio bus is probing now as well as my fec_dm_mdio
Hmm, isn't the MDIO bus udevice the dev->parent of the switch? Assuming that the reason you need this is for MDIO input/output towards the switch. Although my suggestion would be to wrap this I/O behind dm_mdio_read(struct udevice *dev /* MDIO child device */) and dm_mdio_write(struct udevice *dev), rather than poking inside struct udevice from the mv88e61xx driver.
On Mon, Mar 28, 2022 at 2:26 AM Vladimir Oltean vladimir.oltean@nxp.com wrote:
Hi Tim,
Vladimir,
Tim
Ok, sounds good - did you submit this someplace? I haven't seen it.
Each of the 14 GPIO's for MV88E61xx can be configured as GPIO, PTP_TRIG (PTP output trigger), PTP_EVREQ (PTP event request input), PTP_EXTCLK (PTP ext clock input), SE_RCLK0 (SyncE RX clock 0 output), SE_RCLK1 (SyncE RX clock 1 output), or CLK125 (125 MHz clock output). Currently the only config handled in Linux is PTP_EVREQ for PTP support.
Each port has 2 LED's which can be configured for 16 different functions. The LED config is not handled at all the the Linux driver (PHY LED config is spotty in general).
I think it makes sense to handle this in board_config_phy() and I can do and avoid the issue of direct register access with something like:
int board_phy_config(struct phy_device *phydev) { unsigned short val;
/* Fixed PHY: for GW5904/GW5909 this is Marvell 88E6176 GbE Switch */ if (phydev->phy_id == 0xa5a55a5a && ((board_type == GW5904) || (board_type == GW5909))) { /* get the mdio parent bus so we have direct register access */ struct mii_dev *bus = miiphy_get_dev_by_name("mdio");
puts("MV88E61XX ");
/* GPIO[0] output CLK125 for RGMII_REFCLK: * GPIO[7:0] Direction register is 0x62 of Scratch registers: 1=input 0=output * GPIO[0] Pin Control register is 0x68 of Scratch registers: 7=CLK125 (Free running 125MHz clock output) * Scratch register access is at 0x1a of GLOBAL2 register (0x1c) */ bus->write(bus, 0x1c, 0, 0x1a, (1 << 15) | (0x62 << 8) | 0xfe); bus->write(bus, 0x1c, 0, 0x1a, (1 << 15) | (0x68 << 8) | 7);
/* Port 0-3 LED configuration: Table 80/82 * LED configuration: 7:4-green (8=Activity) 3:0 amber (8=Link) * LED Control is register 0x16 of port registers * port registers are at 0x10 + port */ bus->write(bus, 0x10, 0, 0x16, 0x8088); bus->write(bus, 0x11, 0, 0x16, 0x8088); bus->write(bus, 0x12, 0, 0x16, 0x8088); bus->write(bus, 0x13, 0, 0x16, 0x8088);
My dt is:
&fec { pinctrl-names = "default"; pinctrl-0 = <&pinctrl_enet>; phy-mode = "rgmii-id"; status = "okay";
fixed-link { speed = <1000>; full-duplex; };
mdio { #address-cells = <1>; #size-cells = <0>;
switch@0 { compatible = "marvell,mv88e6085"; reg = <0>;
mdios { #address-cells = <1>; #size-cells = <0>;
sw_phy0: ethernet-phy@0 { reg = <0x0>; };
sw_phy1: ethernet-phy@1 { reg = <0x1>; };
sw_phy2: ethernet-phy@2 { reg = <0x2>; };
sw_phy3: ethernet-phy@3 { reg = <0x3>; }; };
ports { #address-cells = <1>; #size-cells = <0>;
port@0 { reg = <0>; label = "lan4"; phy-mode = "internal"; phy-handle = <&sw_phy0>; };
port@1 { reg = <1>; label = "lan3"; phy-mode = "internal"; phy-handle = <&sw_phy1>; };
port@2 { reg = <2>; label = "lan2"; phy-mode = "internal"; phy-handle = <&sw_phy2>; };
port@3 { reg = <3>; label = "lan1"; phy-mode = "internal"; phy-handle = <&sw_phy3>; };
port@5 { reg = <5>; label = "cpu"; ethernet = <&fec>; phy-mode = "rgmii-id";
fixed-link { speed = <1000>; full-duplex; }; }; }; }; }; };
Assuming this looks correct to you the dm_fec_mdio UCLASS_MDIO gets bound to the 'mdio' node and its parent is the fec eth device. So in my switch probe the parent of the switch is the dm_fec_mdio device but I'm not clear how to get to that udevice's strict mii_dev*.
I'm not clear what you mean by the above?
My current pass at adding DSA support to the mv88e61xx driver is to change the struct phy_device *phydev argument to struct udevice *dev throughout (which actually isn't as messy as it seems) and I store the struct mii_dev* in the switch priv structure to be used by the low level functions needing mii.
Best Regards,
Tim
Hi Tim,
Vladimir,
Tim
No, I didn't submit it anywhere. My thinking is that since the existing DSA drivers aren't critically affected by the calling order, you could include a change along those lines in your work for Marvell switches.
/* Fixed PHY: for GW5904/GW5909 this is Marvell 88E6176 GbE Switch */ if (phydev->phy_id == 0xa5a55a5a && ((board_type == GW5904) || (board_type == GW5909))) { /* get the mdio parent bus so we have direct register access */ struct mii_dev *bus = miiphy_get_dev_by_name("mdio"); puts("MV88E61XX "); /* GPIO[0] output CLK125 for RGMII_REFCLK: * GPIO[7:0] Direction register is 0x62 of Scratch registers: 1=input 0=output * GPIO[0] Pin Control register is 0x68 of Scratch registers: 7=CLK125 (Free running 125MHz clock output) * Scratch register access is at 0x1a of GLOBAL2 register (0x1c) */ bus->write(bus, 0x1c, 0, 0x1a, (1 << 15) | (0x62 << 8) | 0xfe); bus->write(bus, 0x1c, 0, 0x1a, (1 << 15) | (0x68 << 8) | 7); /* Port 0-3 LED configuration: Table 80/82 * LED configuration: 7:4-green (8=Activity) 3:0 amber (8=Link) * LED Control is register 0x16 of port registers * port registers are at 0x10 + port */ bus->write(bus, 0x10, 0, 0x16, 0x8088); bus->write(bus, 0x11, 0, 0x16, 0x8088); bus->write(bus, 0x12, 0, 0x16, 0x8088); bus->write(bus, 0x13, 0, 0x16, 0x8088); }
My dt is:
fixed-link { speed = <1000>; full-duplex; }; mdio { #address-cells = <1>; #size-cells = <0>; switch@0 { compatible = "marvell,mv88e6085"; reg = <0>; mdios { #address-cells = <1>; #size-cells = <0>; sw_phy0: ethernet-phy@0 { reg = <0x0>; }; sw_phy1: ethernet-phy@1 { reg = <0x1>; }; sw_phy2: ethernet-phy@2 { reg = <0x2>; }; sw_phy3: ethernet-phy@3 { reg = <0x3>; }; }; ports { #address-cells = <1>; #size-cells = <0>; port@0 { reg = <0>; label = "lan4"; phy-mode = "internal"; phy-handle = <&sw_phy0>; }; port@1 { reg = <1>; label = "lan3"; phy-mode = "internal"; phy-handle = <&sw_phy1>; }; port@2 { reg = <2>; label = "lan2"; phy-mode = "internal"; phy-handle = <&sw_phy2>; }; port@3 { reg = <3>; label = "lan1"; phy-mode = "internal"; phy-handle = <&sw_phy3>; }; port@5 { reg = <5>; label = "cpu"; ethernet = <&fec>; phy-mode = "rgmii-id"; fixed-link { speed = <1000>; full-duplex; }; }; }; }; };
My confusion comes from the fact that I don't really understand why you want to get to the struct mii_dev. In DM world, that structure would be at dev_get_uclass_priv(dev->parent)->mii_bus from the perspective of the DM_DSA driver, but see below.
What I meant by the above was that I was assuming you wouldn't attempt to configure the switch in any way outside of its DM_DSA driver, that is kind of the point of the device model. Which is also the point of me pointing out that the MDIO bus udevice is the dev->parent of the DM_DSA udevice, with no implications whatsoever to what you should do to access the switch "cleaner" from board/ files.
I know of no clean way to mix DM code with board code, maybe others reading this could chime in.
For LED control, perhaps you could come up with some "one size fits all" configuration which is done from the DM_DSA driver rather than the board files. Although you're probably doing this in the first place so that you don't have to do it in Linux, case in which...
Generally the stance in the ARM DT world has been that Linux takes care of initializing the hardware up to the state it needs, assuming a blank slate, and the bootloader minimally initializes the peripherals it needs for a successful boot process.
For the 125 MHz clock, "qca,clk-out-frequency" from drivers/net/phy/atheros.c seems to me like a close enough precedent that's supported in U-Boot as well. I would propose some DT bindings and certainly make sure to run them by the Linux community first, even as an RFC, then do the same here once there is basic agreement.
That is quite interesting, I would have expected quite the contrary. Since DSA uses the device model, and your switch is the first driver to probe on an MDIO bus (=> which also uses the device model, otherwise it wouldn't probe), the expectation would be to not make use of struct mii_dev, but rather go through the struct mdio_ops :: read and write methods of the DM_MDIO udevice (for which I see no existing wrapper functions, hence the prior reference to dm_mdio_read and dm_mdio_write as naming suggestions for these wrapper functions). The lack of these wrappers is probably explained due to the traditional lack of DM devices sitting on MDIO buses. This is probably why the code conversion doesn't seem messy to you.
On Mon, Mar 28, 2022 at 5:03 PM Vladimir Oltean vladimir.oltean@nxp.com wrote:
Hi Tim,
Vladimir,
Tim
Ok, I'll add this to my series
My dt is:
ok, I finally understand what you mean. I was confused when you mentioned dm_mdio_read/dm_mdio_write as those don't exist until I finally noticed Marek's patch to add them: https://patchwork.ozlabs.org/project/uboot/patch/20220318145035.10148-5-kabe...
Now that I understand and agree that dropping the notion of struct mii_dev is the way to go.
I'm not interested in solving the one size fits all PHY LED configuration (or GPIO as clock output for that matter). There are people working on something like that and I'll wait and see where that goes.
For now I'll just use board_phy_config which is working fine.
You may be right that it's cleaner with a completely new driver. I switched back to that and during review its easy to side-by-side diff my dsa driver with the old one to see the differences as I've kept the structure the same.
I thought I was done with the DM_MDIO conversion for fex_mxc but after some additional testing I see that I can't convert it to use MDIO_UCLASS for all suers. There are several boards using fec_mxc with DM_MDIO defined that don't have a proper dt to support it (either missing the mdio subnode so nothing to bind to, or missing the phy-mode/phy-handle/fixed-phy nodes so dm_eth_phy_connect would fail. So I need to make sure fec_mxc binds a DM_MDIO bus and 'attempts' dm_eth_phy_connect and uses the existing non DM_MDIO as a fallback if it fails. There are only a couple of eth drivers in U-Boot currently using UCLASS_MDIO and none of them do this but I think it's likely because they are all drivers for newere boards with proper dts?
At any rate... getting close now.
Best Regards,
Tim
The sja1105_check_device_id() function contains logic to work without changing the device tree on reworked boards, one of which I have (the NXP LS1021A-TSN normally has a SJA1105T, but I have a version with a resoldered SJA1105Q which is pin compatible). This logic is taken from the Linux driver.
However this logic gets shortcircuited in U-Boot by an earlier check for the exact device ID specified in the device tree. So the reworked board does not probe the SJA1105Q switch. Remove this duplicated logic and let the automatic device ID detection do its job.
Fixes: f24b666b2204 ("net: dsa: add driver for NXP SJA1105 L2 switch") Signed-off-by: Vladimir Oltean vladimir.oltean@nxp.com --- drivers/net/sja1105.c | 6 ------ 1 file changed, 6 deletions(-)
diff --git a/drivers/net/sja1105.c b/drivers/net/sja1105.c index 17bab33eddb7..4ca8709e347c 100644 --- a/drivers/net/sja1105.c +++ b/drivers/net/sja1105.c @@ -3276,12 +3276,6 @@ static int sja1105_check_device_id(struct sja1105_private *priv) sja1105_packing(packed_buf, &device_id, 31, 0, SJA1105_SIZE_DEVICE_ID, UNPACK);
- if (device_id != priv->info->device_id) { - printf("Expected device ID 0x%llx but read 0x%llx\n", - priv->info->device_id, device_id); - return -ENODEV; - } - rc = sja1105_xfer_buf(priv, SPI_READ, regs->prod_id, packed_buf, SJA1105_SIZE_DEVICE_ID); if (rc < 0)
return -ENODEV;
-- 2.25.1
return -ENODEV;
-- 2.25.1
Applied to u-boot-net/next Thanks !
Ramon Fried
Tim Harvey
Vladimir Oltean
